[SOLVED] System Update???
I have an issue where the system says "x updates available" but when running "sudo pacman -Syu" it wll say the following "Starting full system upgrade...
there is nothing to do"
I have tried to clear the cache and build cache but to no avail
What updates does Pamac say you have?
(that's the software saying "x updates available)"
Sorry for that Strit. For some reason it was glitched and when I rebooted, it fixed itself. 🤦 "Did you try turning it off and back on?"
This topic was automatically closed 89 days after the last reply. New replies are no longer allowed.
