I have two terminals installed on my Manjaro. One is the default terminal & the other "Terminator".
All was well till yesterday, but now I have run into this strange problem of terminal window crashing on launch. Due to this, I'm handicapped for most of my daily tasks.
Kindly help me with this. Thanks.
What DE and what terminal program? What did you do yesterday?
Error messages from journalctl and dmesg also.
history
can be helpful if you dont quite remember
I don't have a terminal to open now.
So, I'm wondering how I can check journalctl & dmesg or history messages.
Kindly guide me considering that I'm a noob.
ctrl+alt+f2
to get to tty
(F1 will get you back to desktop)
@cscs - I'm entering my username & password, but it says "Login incorrect". But if I give the same username & password to the GUI login manager, it works.
I tried to search in google to find out what's the reason for "Login incorrect", but I didn't understand the answers available. How to I tackle this?
PS: I'm using XFCE.
Installed "Terminal Emulator" which was available by default & additionally I installed "Terminator".
Important update:
Now I remember that I changed the shell to git-shell while doing something. How do I change it back to bash?
I also see some hint similar to that in /etc/passwd file. Please check line 32 below.
root:x:0:0:root:/root:/bin/bash
bin:x:1:1:bin:/bin:/usr/bin/nologin
daemon:x:2:2:daemon:/:/usr/bin/nologin
mail:x:8:12:mail:/var/spool/mail:/usr/bin/nologin
ftp:x:14:11:ftp:/srv/ftp:/usr/bin/nologin
http:x:33:33:http:/srv/http:/usr/bin/nologin
uuidd:x:68:68:uuidd:/:/usr/bin/nologin
dbus:x:81:81:dbus:/:/usr/bin/nologin
nobody:x:99:99:nobody:/:/usr/bin/nologin
systemd-journal-gateway:x:191:191:systemd-journal-gateway:/:/usr/bin/nologin
systemd-timesync:x:192:192:systemd-timesync:/:/usr/bin/nologin
systemd-network:x:193:193:systemd-network:/:/usr/bin/nologin
systemd-bus-proxy:x:194:194:systemd-bus-proxy:/:/usr/bin/nologin
systemd-resolve:x:195:195:systemd-resolve:/:/usr/bin/nologin
systemd-journal-upload:x:999:999:systemd Journal Upload:/:/sbin/nologin
systemd-journal-remote:x:997:997:systemd Journal Remote:/:/sbin/nologin
systemd-coredump:x:998:998:systemd Core Dumper:/:/sbin/nologin
rpc:x:32:32:Rpcbind Daemon:/dev/null:/bin/false
dnsmasq:x:996:996:dnsmasq daemon:/:/sbin/nologin
nbd:x:44:44:Network Block Device:/var/empty:/sbin/nologin
avahi:x:84:84:avahi:/:/bin/nologin
ntp:x:87:87:Network Time Protocol:/var/lib/ntp:/bin/false
polkitd:x:102:102:Policy Kit Daemon:/:/usr/bin/nologin
git:x:995:995:git daemon user:/:/bin/bash
usbmux:x:140:140:usbmux user:/:/sbin/nologin
lightdm:x:620:620:Light Display Manager:/var/lib/lightdm:/usr/bin/nologin
colord:x:124:124::/var/lib/colord:/bin/false
rtkit:x:133:133:RealtimeKit:/proc:/bin/false
nm-openconnect:x:619:619:NetworkManager OpenConnect:/:/usr/bin/nologin
nm-openvpn:x:618:618:NetworkManager OpenVPN:/:/usr/bin/nologin
rahul:x:1000:1001:Rahul:/home/rahul:/usr/bin/git-shell
mysql:x:89:89:MariaDB:/var/lib/mysql:/sbin/nologin
tor:x:43:43::/var/lib/tor:/bin/false
Any help please?
- I'm unable to login to tty using my username & password that I provide through GUI login.
- Thinking that I changed the shell options to git-shell, how do I change it back to bash?
chsh -s /usr/bin/bash $(whoami)
This kind of thing usually happens if your console keyboard is set to a wrong language. I think it defaults to us keymap?
You need to somehow access command line. Do you have pamac or octopi installed? You could install another terminal.
Also, in many terminals you can edit their settings to start another shell instead of your login shell.
Boot into live environment, chroot into your installed system, from command prompt install xterm.
sudo pacman -S xterm
Reboot and see if xterm crashes also.
If not then use xterm to get error messages launching your chosen terminal program from command line.
If crashes then boot back into live, chroot into installed system again, and try to gather journalctl error messages from there.
If you chroot, remember to also set the correct shell with
chsh -s /usr/bin/bash rahul
I did login using Manjaro Live USB.
Followed the steps in this link - https://archived.forum.manjaro.org/t/how-to-save-your-manjaro-installation-when-it-breaks/
Now chsh -s /usr/bin/bash/ rahul gives the following output.
[manjaro /]# chsh -s /usr/bin/bash rahul
Changing shell for rahul.
chsh: Warning: "/usr/bin/bash" is not listed in /etc/shells.
chsh: Shell not changed.
[manjaro Desktop]# dmesg
[ 0.000000] microcode: microcode updated early to revision 0xba, date = 2017-04-09
[ 0.000000] Linux version 4.9.58-1-MANJARO (builduser@manjaro) (gcc version 7.2.0 (GCC) ) #1 SMP PREEMPT Sat Oct 21 16:41:16 UTC 2017
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 misobasedir=manjaro misolabel=MJRO1706 quiet systemd.show_status=1
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ 0.000000] x86/fpu: Using 'eager' FPU context switches.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009e7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000640c1fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000640c2000-0x00000000640c2fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000640c3000-0x00000000640ecfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000640ed000-0x000000007a38efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007a38f000-0x000000007ad7efff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007ad7f000-0x000000007af7efff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007af7f000-0x000000007affefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000007afff000-0x000000007affffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007b000000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000fe7fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feb00000-0x00000000feb03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffa00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000027effffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: HP HP Notebook/81EC, BIOS F.18 09/26/2016
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x27f000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask 7C00000000 write-back
[ 0.000000] 1 base 007B000000 mask 7FFF000000 uncachable
[ 0.000000] 2 base 007C000000 mask 7FFC000000 uncachable
[ 0.000000] 3 base 0080000000 mask 7F80000000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] e820: update [mem 0x7b000000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0x7b000 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000fe1b0-0x000fe1bf] mapped at [ffff8800000fe1b0]
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] Base memory trampoline at [ffff880000098000] 98000 size 24576
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] BRK [0x01d59000, 0x01d59fff] PGTABLE
[ 0.000000] BRK [0x01d5a000, 0x01d5afff] PGTABLE
[ 0.000000] BRK [0x01d5b000, 0x01d5bfff] PGTABLE
[ 0.000000] BRK [0x01d5c000, 0x01d5cfff] PGTABLE
[ 0.000000] BRK [0x01d5d000, 0x01d5dfff] PGTABLE
[ 0.000000] BRK [0x01d5e000, 0x01d5efff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x33241000-0x35917fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000FE020 000024 (v02 HPQOEM)
[ 0.000000] ACPI: XSDT 0x000000007AFB9188 0000F4 (v01 HPQOEM SLIC-MPC 00000000 HP 01000013)
[ 0.000000] ACPI: FACP 0x000000007AFE4000 0000F4 (v05 HPQOEM SLIC-MPC 00000000 HP 00040000)
[ 0.000000] ACPI: DSDT 0x000000007AFBF000 020091 (v02 HPQOEM SLIC-MPC 00000000 ACPI 00040000)
[ 0.000000] ACPI: FACS 0x000000007AF7B000 000040
[ 0.000000] ACPI: UEFI 0x000000007AFFD000 000236 (v01 HPQOEM INSYDE 00000001 HP 00040000)
[ 0.000000] ACPI: UEFI 0x000000007AFFC000 000042 (v01 HPQOEM INSYDE 00000002 HP 00040000)
[ 0.000000] ACPI: SSDT 0x000000007AFF5000 006794 (v01 HPQOEM INSYDE 00001000 ACPI 00040000)
[ 0.000000] ACPI: SSDT 0x000000007AFEE000 0054B4 (v02 HPQOEM INSYDE 00003000 ACPI 00040000)
[ 0.000000] ACPI: SSDT 0x000000007AFEB000 002A34 (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ 0.000000] ACPI: DBGP 0x000000007AFEA000 000034 (v01 HPQOEM SLIC-MPC 00000001 HP 00040000)
[ 0.000000] ACPI: DBG2 0x000000007AFE9000 000054 (v00 HPQOEM INSYDE 00000000 HP 00040000)
[ 0.000000] ACPI: ASF! 0x000000007AFE8000 0000A5 (v32 HPQOEM INSYDE 00000001 HP 00040000)
[ 0.000000] ACPI: ASPT 0x000000007AFE7000 000034 (v07 HPQOEM INSYDE 00000001 HP 00040000)
[ 0.000000] ACPI: BOOT 0x000000007AFE6000 000028 (v01 HPQOEM INSYDE 00000001 HP 00040000)
[ 0.000000] ACPI: DBGP 0x000000007AFE5000 000034 (v01 HPQOEM SLIC-MPC 00000001 HP 00040000)
[ 0.000000] ACPI: HPET 0x000000007AFE3000 000038 (v01 HPQOEM INSYDE 00000001 HP 00040000)
[ 0.000000] ACPI: LPIT 0x000000007AFE2000 000094 (v01 HPQOEM INSYDE 00000000 HP 00040000)
[ 0.000000] ACPI: APIC 0x000000007AFE1000 0000BC (v03 HPQOEM SLIC-MPC 00000001 HP 00040000)
[ 0.000000] ACPI: MCFG 0x000000007AFE0000 00003C (v01 HPQOEM INSYDE 00000001 HP 00040000)
[ 0.000000] ACPI: SSDT 0x000000007AFBE000 0002D4 (v01 HPQOEM INSYDE 00000000 ACPI 00040000)
[ 0.000000] ACPI: SSDT 0x000000007AFBD000 000EA7 (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ 0.000000] ACPI: SSDT 0x000000007AFBC000 00019A (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ 0.000000] ACPI: SSDT 0x000000007AFBB000 0009FD (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ 0.000000] ACPI: SSDT 0x000000007AFBA000 000B49 (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ 0.000000] ACPI: SSDT 0x000000007AFB8000 00014A (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ 0.000000] ACPI: SSDT 0x000000007AFB7000 000E73 (v02 HPQOEM INSYDE 00003000 ACPI 00040000)
[ 0.000000] ACPI: SSDT 0x000000007AFB5000 001A69 (v01 HPQOEM INSYDE 00001000 ACPI 00040000)
[ 0.000000] ACPI: DMAR 0x000000007AFB4000 0000A8 (v01 HPQOEM INSYDE 00000001 HP 00040000)
[ 0.000000] ACPI: FPDT 0x000000007AFB3000 000044 (v01 HPQOEM SLIC-MPC 00000002 HP 00040000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000027effffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x27eff9000-0x27effdfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000027effffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000640c1fff]
[ 0.000000] node 0: [mem 0x00000000640ed000-0x000000007a38efff]
[ 0.000000] node 0: [mem 0x000000007afff000-0x000000007affffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000027effffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000027effffff]
[ 0.000000] On node 0 totalpages: 2069250
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3997 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 7758 pages used for memmap
[ 0.000000] DMA32 zone: 496485 pages, LIFO batch:31
[ 0.000000] Normal zone: 24512 pages used for memmap
[ 0.000000] Normal zone: 1568768 pages, LIFO batch:31
[ 0.000000] Reserving Intel graphics memory at 0x000000007c000000-0x000000007fffffff
[ 0.000000] ACPI: PM-Timer IO Port: 0x1808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x640c2000-0x640c2fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x640c3000-0x640ecfff]
[ 0.000000] PM: Registered nosave memory: [mem 0x7a38f000-0x7ad7efff]
[ 0.000000] PM: Registered nosave memory: [mem 0x7ad7f000-0x7af7efff]
[ 0.000000] PM: Registered nosave memory: [mem 0x7af7f000-0x7affefff]
[ 0.000000] PM: Registered nosave memory: [mem 0x7b000000-0x7fffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x80000000-0xdfffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xf0000000-0xfcffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfd000000-0xfe7fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfe800000-0xfeafffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfeb00000-0xfeb03fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfeb04000-0xfebfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed01000-0xfed0ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xff9fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xffa00000-0xffffffff]
[ 0.000000] e820: [mem 0x80000000-0xdfffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.000000] setup_percpu: NR_CPUS:128 nr_cpumask_bits:128 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] percpu: Embedded 35 pages/cpu @ffff88027ec00000 s103640 r8192 d31528 u524288
[ 0.000000] pcpu-alloc: s103640 r8192 d31528 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 2036895
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 misobasedir=manjaro misolabel=MJRO1706 quiet systemd.show_status=1
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 8025776K/8277000K available (6283K kernel code, 1079K rwdata, 1968K rodata, 1280K init, 1032K bss, 251224K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=128 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:8448 nr_irqs:1024 16
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Detected 2400.000 MHz processor
[ 0.000030] Calibrating delay loop (skipped), value calculated using timer frequency.. 4801.00 BogoMIPS (lpj=8000000)
[ 0.000033] pid_max: default: 32768 minimum: 301
[ 0.000042] ACPI: Core revision 20160831
[ 0.037264] ACPI: 12 ACPI AML tables successfully acquired and loaded
[ 0.037290] Security Framework initialized
[ 0.037290] Yama: becoming mindful.
[ 0.037678] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.039165] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.039822] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.039830] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.040121] CPU: Physical Processor ID: 0
[ 0.040122] CPU: Processor Core ID: 0
[ 0.040126] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.040126] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.040131] mce: CPU supports 8 MCE banks
[ 0.040139] CPU0: Thermal monitoring enabled (TM1)
[ 0.040155] process: using mwait in idle threads
[ 0.040157] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.040158] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.040495] Freeing SMP alternatives memory: 24K
[ 0.047512] ftrace: allocating 24878 entries in 98 pages
[ 0.058265] smpboot: Max logical packages: 2
[ 0.058272] DMAR: Host address width 39
[ 0.058273] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.058277] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 7e3ff0505e
[ 0.058278] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.058282] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.058282] DMAR: RMRR base: 0x0000007acaa000 end: 0x0000007acc9fff
[ 0.058283] DMAR: RMRR base: 0x0000007b800000 end: 0x0000007fffffff
[ 0.058285] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.058285] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.058286] DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
[ 0.058287] DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
[ 0.059699] DMAR-IR: Enabled IRQ remapping in xapic mode
[ 0.059699] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.063816] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.096828] TSC deadline timer enabled
[ 0.096832] smpboot: CPU0: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz (family: 0x6, model: 0x4e, stepping: 0x3)
[ 0.096836] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.096867] ... version: 4
[ 0.096867] ... bit width: 48
[ 0.096868] ... generic registers: 4
[ 0.096869] ... value mask: 0000ffffffffffff
[ 0.096869] ... max period: 00007fffffffffff
[ 0.096870] ... fixed-purpose events: 3
[ 0.096870] ... event mask: 000000070000000f
[ 0.130349] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.163710] x86: Booting SMP configuration:
[ 0.163711] .... node #0, CPUs: #1 #2 #3
[ 0.469288] x86: Booted up 1 node, 4 CPUs
[ 0.469290] smpboot: Total of 4 processors activated (19211.47 BogoMIPS)
[ 0.473168] devtmpfs: initialized
[ 0.473223] x86/mm: Memory block size: 128MB
[ 0.476468] PM: Registering ACPI NVS region [mem 0x640c2000-0x640c2fff] (4096 bytes)
[ 0.476469] PM: Registering ACPI NVS region [mem 0x7ad7f000-0x7af7efff] (2097152 bytes)
[ 0.476540] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.476547] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.476585] pinctrl core: initialized pinctrl subsystem
[ 0.476694] RTC time: 5:04:53, date: 12/26/17
[ 0.476772] NET: Registered protocol family 16
[ 0.492968] cpuidle: using governor ladder
[ 0.509665] cpuidle: using governor menu
[ 0.509708] Simple Boot Flag at 0x44 set to 0x1
[ 0.509723] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.509724] ACPI: bus type PCI registered
[ 0.509725] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.509783] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.509785] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.509788] pmd_set_huge: Cannot satisfy [mem 0xe0000000-0xe0200000] with a huge-page mapping due to MTRR override.
[ 0.510033] PCI: Using configuration type 1 for base access
[ 0.523109] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[ 0.523110] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.523283] ACPI: Added _OSI(Module Device)
[ 0.523284] ACPI: Added _OSI(Processor Device)
[ 0.523285] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.523285] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.524635] ACPI: Executed 18 blocks of module-level executable AML code
[ 0.531779] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.538613] ACPI: Dynamic OEM Table Load:
[ 0.538657] ACPI: SSDT 0xFFFF880274E7C800 00061E (v02 PmRef Cpu0Ist 00003000 INTL 20120913)
[ 0.538882] ACPI: \_PR_.CPU0: _OSC native thermal LVT Acked
[ 0.540267] ACPI: Dynamic OEM Table Load:
[ 0.540275] ACPI: SSDT 0xFFFF880274922000 00037F (v02 PmRef Cpu0Cst 00003001 INTL 20120913)
[ 0.540976] ACPI: Dynamic OEM Table Load:
[ 0.540984] ACPI: SSDT 0xFFFF880274E7D800 0005AA (v02 PmRef ApIst 00003000 INTL 20120913)
[ 0.541472] ACPI: Dynamic OEM Table Load:
[ 0.541479] ACPI: SSDT 0xFFFF880274971600 000119 (v02 PmRef ApCst 00003000 INTL 20120913)
[ 0.543440] ACPI : EC: EC started
[ 0.543440] ACPI : EC: interrupt blocked
[ 0.543829] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
[ 0.543831] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x50, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.543832] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
[ 0.543832] ACPI: Interpreter enabled
[ 0.543882] ACPI: (supports S0 S3 S4 S5)
[ 0.543883] ACPI: Using IOAPIC for interrupt routing
[ 0.543920] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.565046] ACPI: Power Resource [PC05] (on)
[ 0.576832] ACPI: Power Resource [FN00] (off)
[ 0.576919] ACPI: Power Resource [FN01] (off)
[ 0.577002] ACPI: Power Resource [FN02] (off)
[ 0.577083] ACPI: Power Resource [FN03] (off)
[ 0.577166] ACPI: Power Resource [FN04] (off)
[ 0.578370] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.578376] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.578407] acpi PNP0A08:00: _OSC failed (AE_ERROR); disabling ASPM
[ 0.580290] PCI host bridge to bus 0000:00
[ 0.580292] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.580293] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.580294] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.580296] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.580296] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[ 0.580298] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.580305] pci 0000:00:00.0: [8086:1904] type 00 class 0x060000
[ 0.581245] pci 0000:00:02.0: [8086:1916] type 00 class 0x030000
[ 0.581254] pci 0000:00:02.0: reg 0x10: [mem 0xb0000000-0xb0ffffff 64bit]
[ 0.581260] pci 0000:00:02.0: reg 0x18: [mem 0xa0000000-0xafffffff 64bit pref]
[ 0.581264] pci 0000:00:02.0: reg 0x20: [io 0x6000-0x603f]
[ 0.582011] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[ 0.582022] pci 0000:00:04.0: reg 0x10: [mem 0xb1420000-0xb1427fff 64bit]
[ 0.582837] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
[ 0.582855] pci 0000:00:14.0: reg 0x10: [mem 0xb1400000-0xb140ffff 64bit]
[ 0.582926] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.583656] pci 0000:00:14.0: System wakeup disabled by ACPI
[ 0.583694] pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000
[ 0.583713] pci 0000:00:14.2: reg 0x10: [mem 0xb1432000-0xb1432fff 64bit]
[ 0.584494] pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000
[ 0.584515] pci 0000:00:16.0: reg 0x10: [mem 0xb1433000-0xb1433fff 64bit]
[ 0.584590] pci 0000:00:16.0: PME# supported from D3hot
[ 0.585345] pci 0000:00:17.0: [8086:9d03] type 00 class 0x010601
[ 0.585360] pci 0000:00:17.0: reg 0x10: [mem 0xb1430000-0xb1431fff]
[ 0.585368] pci 0000:00:17.0: reg 0x14: [mem 0xb1436000-0xb14360ff]
[ 0.585375] pci 0000:00:17.0: reg 0x18: [io 0x6080-0x6087]
[ 0.585382] pci 0000:00:17.0: reg 0x1c: [io 0x6088-0x608b]
[ 0.585390] pci 0000:00:17.0: reg 0x20: [io 0x6060-0x607f]
[ 0.585398] pci 0000:00:17.0: reg 0x24: [mem 0xb1434000-0xb14347ff]
[ 0.585443] pci 0000:00:17.0: PME# supported from D3hot
[ 0.586192] pci 0000:00:1c.0: [8086:9d10] type 01 class 0x060400
[ 0.586258] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.587004] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.587048] pci 0000:00:1c.4: [8086:9d14] type 01 class 0x060400
[ 0.587114] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.587827] pci 0000:00:1c.4: System wakeup disabled by ACPI
[ 0.587863] pci 0000:00:1c.5: [8086:9d15] type 01 class 0x060400
[ 0.587930] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.588658] pci 0000:00:1c.5: System wakeup disabled by ACPI
[ 0.588704] pci 0000:00:1f.0: [8086:9d48] type 00 class 0x060100
[ 0.589539] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
[ 0.589551] pci 0000:00:1f.2: reg 0x10: [mem 0xb142c000-0xb142ffff]
[ 0.590346] pci 0000:00:1f.3: [8086:9d70] type 00 class 0x040300
[ 0.590370] pci 0000:00:1f.3: reg 0x10: [mem 0xb1428000-0xb142bfff 64bit]
[ 0.590405] pci 0000:00:1f.3: reg 0x20: [mem 0xb1410000-0xb141ffff 64bit]
[ 0.590457] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.591221] pci 0000:00:1f.3: System wakeup disabled by ACPI
[ 0.591262] pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500
[ 0.591308] pci 0000:00:1f.4: reg 0x10: [mem 0xb1435000-0xb14350ff 64bit]
[ 0.591377] pci 0000:00:1f.4: reg 0x20: [io 0x6040-0x605f]
[ 0.592236] pci 0000:01:00.0: [1002:6660] type 00 class 0x038000
[ 0.592251] pci 0000:01:00.0: reg 0x10: [mem 0x90000000-0x9fffffff 64bit pref]
[ 0.592261] pci 0000:01:00.0: reg 0x18: [mem 0xb1300000-0xb133ffff 64bit]
[ 0.592267] pci 0000:01:00.0: reg 0x20: [io 0x5000-0x50ff]
[ 0.592279] pci 0000:01:00.0: reg 0x30: [mem 0xfffe0000-0xffffffff pref]
[ 0.592336] pci 0000:01:00.0: supports D1 D2
[ 0.592337] pci 0000:01:00.0: PME# supported from D1 D2 D3hot
[ 0.592374] pci 0000:01:00.0: System wakeup disabled by ACPI
[ 0.603094] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.603096] pci 0000:00:1c.0: bridge window [io 0x5000-0x5fff]
[ 0.603099] pci 0000:00:1c.0: bridge window [mem 0xb1300000-0xb13fffff]
[ 0.603103] pci 0000:00:1c.0: bridge window [mem 0x90000000-0x9fffffff 64bit pref]
[ 0.603182] pci 0000:02:00.0: [10ec:8136] type 00 class 0x020000
[ 0.603210] pci 0000:02:00.0: reg 0x10: [io 0x4000-0x40ff]
[ 0.603242] pci 0000:02:00.0: reg 0x18: [mem 0xb1200000-0xb1200fff 64bit]
[ 0.603264] pci 0000:02:00.0: reg 0x20: [mem 0xb1000000-0xb1003fff 64bit pref]
[ 0.603369] pci 0000:02:00.0: supports D1 D2
[ 0.603370] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.603488] pci 0000:02:00.0: System wakeup disabled by ACPI
[ 0.613116] pci 0000:00:1c.4: PCI bridge to [bus 02]
[ 0.613119] pci 0000:00:1c.4: bridge window [io 0x4000-0x4fff]
[ 0.613121] pci 0000:00:1c.4: bridge window [mem 0xb1200000-0xb12fffff]
[ 0.613126] pci 0000:00:1c.4: bridge window [mem 0xb1000000-0xb10fffff 64bit pref]
[ 0.613189] pci 0000:03:00.0: [10ec:b723] type 00 class 0x028000
[ 0.613211] pci 0000:03:00.0: reg 0x10: [io 0x3000-0x30ff]
[ 0.613242] pci 0000:03:00.0: reg 0x18: [mem 0xb1100000-0xb1103fff 64bit]
[ 0.613361] pci 0000:03:00.0: supports D1 D2
[ 0.613362] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.613454] pci 0000:03:00.0: System wakeup disabled by ACPI
[ 0.623128] pci 0000:00:1c.5: PCI bridge to [bus 03]
[ 0.623131] pci 0000:00:1c.5: bridge window [io 0x3000-0x3fff]
[ 0.623134] pci 0000:00:1c.5: bridge window [mem 0xb1100000-0xb11fffff]
[ 0.630564] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.630612] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.630658] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.630703] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.630748] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.630792] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.630836] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.630880] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.631323] ACPI: Enabled 5 GPEs in block 00 to 7F
[ 0.631374] ACPI Warning: GPE type mismatch (level/edge) (20160831/evxface-826)
[ 0.631376] ACPI : EC: interrupt unblocked
[ 0.631390] ACPI : EC: event unblocked
[ 0.631401] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x50, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.631403] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
[ 0.631540] vgaarb: setting as boot device: PCI:0000:00:02.0
[ 0.631542] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.631544] vgaarb: loaded
[ 0.631545] vgaarb: bridge control possible 0000:00:02.0
[ 0.631616] PCI: Using ACPI for IRQ routing
[ 0.659627] PCI: pci_cache_line_size set to 64 bytes
[ 0.659687] e820: reserve RAM buffer [mem 0x0009e800-0x0009ffff]
[ 0.659688] e820: reserve RAM buffer [mem 0x640c2000-0x67ffffff]
[ 0.659689] e820: reserve RAM buffer [mem 0x7a38f000-0x7bffffff]
[ 0.659690] e820: reserve RAM buffer [mem 0x7b000000-0x7bffffff]
[ 0.659690] e820: reserve RAM buffer [mem 0x27f000000-0x27fffffff]
[ 0.659771] NetLabel: Initializing
[ 0.659772] NetLabel: domain hash size = 128
[ 0.659772] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.659784] NetLabel: unlabeled traffic allowed by default
[ 0.659889] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.659893] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.661933] clocksource: Switched to clocksource hpet
[ 0.667241] VFS: Disk quotas dquot_6.6.0
[ 0.667257] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.667318] pnp: PnP ACPI init
[ 0.667476] system 00:00: [mem 0xfd000000-0xfdabffff] has been reserved
[ 0.667478] system 00:00: [mem 0xfdad0000-0xfdadffff] has been reserved
[ 0.667479] system 00:00: [mem 0xfdb00000-0xfdffffff] has been reserved
[ 0.667480] system 00:00: [mem 0xfe000000-0xfe01ffff] has been reserved
[ 0.667481] system 00:00: [mem 0xfe036000-0xfe03bfff] has been reserved
[ 0.667483] system 00:00: [mem 0xfe03d000-0xfe3fffff] has been reserved
[ 0.667484] system 00:00: [mem 0xfe410000-0xfe7fffff] has been reserved
[ 0.667486] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.667794] system 00:01: [io 0x2000-0x20fe] has been reserved
[ 0.667796] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.667934] system 00:02: [io 0x0680-0x069f] has been reserved
[ 0.667935] system 00:02: [io 0xffff] has been reserved
[ 0.667936] system 00:02: [io 0xffff] has been reserved
[ 0.667938] system 00:02: [io 0xffff] has been reserved
[ 0.667939] system 00:02: [io 0x1800-0x18fe] has been reserved
[ 0.667940] system 00:02: [io 0x164e-0x164f] has been reserved
[ 0.667941] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.668038] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.668074] system 00:04: [io 0x1854-0x1857] has been reserved
[ 0.668075] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.668098] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.668132] pnp 00:06: Plug and Play ACPI device, IDs SYN3221 PNP0f03 (active)
[ 0.673155] system 00:07: [mem 0xfdaf0000-0xfdafffff] has been reserved
[ 0.673156] system 00:07: [mem 0xfdae0000-0xfdaeffff] has been reserved
[ 0.673158] system 00:07: [mem 0xfdac0000-0xfdacffff] has been reserved
[ 0.673159] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.673652] system 00:08: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.673653] system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.673654] system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.673655] system 00:08: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.673656] system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.673658] system 00:08: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.673659] system 00:08: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ 0.673660] system 00:08: [mem 0xff000000-0xffffffff] could not be reserved
[ 0.673661] system 00:08: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.673662] system 00:08: [mem 0x80000000-0x8001ffff] has been reserved
[ 0.673664] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.674117] pnp: PnP ACPI: found 9 devices
[ 0.681153] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.681157] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfffe0000-0xffffffff pref]: no compatible bridge window
[ 0.681180] pci 0000:01:00.0: BAR 6: assigned [mem 0xb1340000-0xb135ffff pref]
[ 0.681182] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.681184] pci 0000:00:1c.0: bridge window [io 0x5000-0x5fff]
[ 0.681188] pci 0000:00:1c.0: bridge window [mem 0xb1300000-0xb13fffff]
[ 0.681190] pci 0000:00:1c.0: bridge window [mem 0x90000000-0x9fffffff 64bit pref]
[ 0.681195] pci 0000:00:1c.4: PCI bridge to [bus 02]
[ 0.681196] pci 0000:00:1c.4: bridge window [io 0x4000-0x4fff]
[ 0.681200] pci 0000:00:1c.4: bridge window [mem 0xb1200000-0xb12fffff]
[ 0.681202] pci 0000:00:1c.4: bridge window [mem 0xb1000000-0xb10fffff 64bit pref]
[ 0.681206] pci 0000:00:1c.5: PCI bridge to [bus 03]
[ 0.681208] pci 0000:00:1c.5: bridge window [io 0x3000-0x3fff]
[ 0.681211] pci 0000:00:1c.5: bridge window [mem 0xb1100000-0xb11fffff]
[ 0.681218] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.681219] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.681220] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.681221] pci_bus 0000:00: resource 7 [mem 0x80000000-0xdfffffff window]
[ 0.681222] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
[ 0.681223] pci_bus 0000:01: resource 0 [io 0x5000-0x5fff]
[ 0.681224] pci_bus 0000:01: resource 1 [mem 0xb1300000-0xb13fffff]
[ 0.681225] pci_bus 0000:01: resource 2 [mem 0x90000000-0x9fffffff 64bit pref]
[ 0.681226] pci_bus 0000:02: resource 0 [io 0x4000-0x4fff]
[ 0.681227] pci_bus 0000:02: resource 1 [mem 0xb1200000-0xb12fffff]
[ 0.681228] pci_bus 0000:02: resource 2 [mem 0xb1000000-0xb10fffff 64bit pref]
[ 0.681229] pci_bus 0000:03: resource 0 [io 0x3000-0x3fff]
[ 0.681230] pci_bus 0000:03: resource 1 [mem 0xb1100000-0xb11fffff]
[ 0.681366] NET: Registered protocol family 2
[ 0.681503] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.681609] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.681777] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.681796] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.681821] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.681868] NET: Registered protocol family 1
[ 0.681878] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.683347] PCI: CLS 64 bytes, default 64
[ 0.683386] Unpacking initramfs...
[ 5.055205] Freeing initrd memory: 39772K
[ 5.055234] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 5.055237] software IO TLB [mem 0x7638f000-0x7a38f000] (64MB) mapped at [ffff88007638f000-ffff88007a38efff]
[ 5.055508] Scanning for low memory corruption every 60 seconds
[ 5.056078] Initialise system trusted keyrings
[ 5.056203] workingset: timestamp_bits=40 max_order=21 bucket_order=0
[ 5.057542] zbud: loaded
[ 5.058337] Key type asymmetric registered
[ 5.058380] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 5.058431] io scheduler noop registered
[ 5.058432] io scheduler deadline registered
[ 5.058438] io scheduler cfq registered
[ 5.058465] io scheduler bfq registered (default)
[ 5.058466] BFQ I/O-scheduler: v8r12 (with cgroups support)
[ 5.058996] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 5.059000] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 5.059009] vesafb: mode is 1280x1024x32, linelength=5120, pages=0
[ 5.059010] vesafb: scrolling: redraw
[ 5.059011] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 5.059023] vesafb: framebuffer at 0xa0000000, mapped to 0xffffc90002000000, using 5120k, total 5120k
[ 5.179632] Console: switching to colour frame buffer device 160x64
[ 5.300190] fb0: VESA VGA frame buffer device
[ 5.300201] intel_idle: MWAIT substates: 0x11142120
[ 5.300202] intel_idle: v0.4.1 model 0x4E
[ 5.300394] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 5.300600] GHES: HEST is not enabled!
[ 5.300672] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 5.301147] Linux agpgart interface v0.103
[ 5.301458] rtc_cmos 00:03: RTC can wake from S4
[ 5.301842] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 5.301925] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 5.301951] intel_pstate: Intel P-state driver initializing
[ 5.302165] intel_pstate: HWP enabled
[ 5.302291] ledtrig-cpu: registered to indicate activity on CPUs
[ 5.302534] NET: Registered protocol family 10
[ 5.302757] NET: Registered protocol family 17
[ 5.302995] microcode: sig=0x406e3, pf=0x80, revision=0xba
[ 5.303182] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 5.303513] registered taskstats version 1
[ 5.303519] Loading compiled-in X.509 certificates
[ 5.303528] zswap: loaded using pool lzo/zbud
[ 5.304308] Magic number: 13:33:63
[ 5.304474] rtc_cmos 00:03: setting system clock to 2017-12-26 05:04:58 UTC (1514264698)
[ 5.304520] PM: Hibernation image not present or could not be loaded.
[ 5.305310] Freeing unused kernel memory: 1280K
[ 5.305311] Write protecting the kernel read-only data: 10240k
[ 5.305685] Freeing unused kernel memory: 1892K
[ 5.305820] Freeing unused kernel memory: 80K
[ 5.323096] loop: module loaded
[ 5.324055] device-mapper: uevent: version 1.0.3
[ 5.324119] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 5.355443] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/PNP0C0D:00/input/input0
[ 5.355473] ACPI: Lid Switch [LID0]
[ 5.355562] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 5.355564] ACPI: Power Button [PWRF]
[ 5.356151] FUJITSU Extended Socket Network Device Driver - version 1.1 - Copyright (c) 2015 FUJITSU LIMITED
[ 5.362467] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 5.374337] wmi: Mapper loaded
[ 5.389402] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 5.389455] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 5.390690] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 5.390696] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 5.391368] SCSI subsystem initialized
[ 5.391381] r8169 0000:02:00.0 eth0: RTL8106e at 0xffffc90000cc5000, c8:d3:ff:91:58:89, XID 04900000 IRQ 122
[ 5.391602] [drm] Initialized
[ 5.392983] libata version 3.00 loaded.
[ 5.394222] ahci 0000:00:17.0: version 3.0
[ 5.394623] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 5.394626] ahci 0000:00:17.0: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
[ 5.396503] scsi host0: ahci
[ 5.396797] scsi host1: ahci
[ 5.396855] ata1: SATA max UDMA/133 abar m2048@0xb1434000 port 0xb1434100 irq 123
[ 5.396857] ata2: SATA max UDMA/133 abar m2048@0xb1434000 port 0xb1434180 irq 123
[ 5.397439] ACPI: bus type USB registered
[ 5.397462] usbcore: registered new interface driver usbfs
[ 5.397473] usbcore: registered new interface driver hub
[ 5.397494] usbcore: registered new device driver usb
[ 5.402100] [drm] Memory usable by graphics device = 4096M
[ 5.402103] checking generic (a0000000 500000) vs hw (a0000000 10000000)
[ 5.402104] fb: switching to inteldrmfb from VESA VGA
[ 5.402142] Console: switching to colour dummy device 80x25
[ 5.402217] [drm] Replacing VGA console driver
[ 5.404855] [drm] radeon kernel modesetting enabled.
[ 5.404868] vga_switcheroo: detected switching method \_SB_.PCI0.GFX0.ATPX handle
[ 5.404963] ATPX version 1, functions 0x00000033
[ 5.405027] ATPX Hybrid Graphics
[ 5.406105] radeon 0000:01:00.0: enabling device (0000 -> 0003)
[ 5.406333] [drm] initializing kernel modesetting (HAINAN 0x1002:0x6660 0x103C:0x81EC 0x83).
[ 5.406343] [drm] register mmio base: 0xB1300000
[ 5.406343] [drm] register mmio size: 262144
[ 5.407376] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.407377] [drm] Driver supports precise vblank timestamp query.
[ 5.410048] vga_switcheroo: enabled
[ 5.414013] ATOM BIOS: HP
[ 5.414067] radeon 0000:01:00.0: VRAM: 2048M 0x0000000000000000 - 0x000000007FFFFFFF (2048M used)
[ 5.414069] radeon 0000:01:00.0: GTT: 2048M 0x0000000080000000 - 0x00000000FFFFFFFF
[ 5.414072] [drm] Detected VRAM RAM=2048M, BAR=256M
[ 5.414073] [drm] RAM width 64bits DDR
[ 5.414123] [TTM] Zone kernel: Available graphics memory: 4034412 kiB
[ 5.414123] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 5.414124] [TTM] Initializing pool allocator
[ 5.414127] [TTM] Initializing DMA pool allocator
[ 5.414153] [drm] radeon: 2048M of VRAM memory ready
[ 5.414153] [drm] radeon: 2048M of GTT memory ready.
[ 5.414162] [drm] Loading hainan Microcode
[ 5.414239] [drm] Internal thermal controller without fan control
[ 5.414287] [drm] probing gen 2 caps for device 8086:9d10 = 1724843/e
[ 5.415754] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 5.417332] [drm] Finished loading i915/skl_dmc_ver1_26.bin (v1.26)
[ 5.419956] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 5.422251] [drm] radeon: dpm initialized
[ 5.422266] [drm] GART: num cpu pages 524288, num gpu pages 524288
[ 5.423597] [drm] probing gen 2 caps for device 8086:9d10 = 1724843/e
[ 5.423600] [drm] PCIE gen 3 link speeds already enabled
[ 5.425103] [drm] GuC firmware load skipped
[ 5.426695] [drm] PCIE GART of 2048M enabled (table at 0x0000000000040000).
[ 5.426799] radeon 0000:01:00.0: WB enabled
[ 5.426801] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00 and cpu addr 0xffff880268ea9c00
[ 5.426802] radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04 and cpu addr 0xffff880268ea9c04
[ 5.426803] radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08 and cpu addr 0xffff880268ea9c08
[ 5.426804] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c and cpu addr 0xffff880268ea9c0c
[ 5.426805] radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10 and cpu addr 0xffff880268ea9c10
[ 5.426806] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.426806] [drm] Driver supports precise vblank timestamp query.
[ 5.426807] radeon 0000:01:00.0: radeon: MSI limited to 32-bit
[ 5.426842] radeon 0000:01:00.0: radeon: using MSI.
[ 5.426857] [drm] radeon: irq initialized.
[ 5.621558] [drm] ring test on 0 succeeded in 1 usecs
[ 5.621562] [drm] ring test on 1 succeeded in 1 usecs
[ 5.621566] [drm] ring test on 2 succeeded in 1 usecs
[ 5.621574] [drm] ring test on 3 succeeded in 4 usecs
[ 5.621580] [drm] ring test on 4 succeeded in 3 usecs
[ 5.621744] [drm] ib test on ring 0 succeeded in 0 usecs
[ 5.621770] [drm] ib test on ring 1 succeeded in 0 usecs
[ 5.621794] [drm] ib test on ring 2 succeeded in 0 usecs
[ 5.621819] [drm] ib test on ring 3 succeeded in 0 usecs
[ 5.621844] [drm] ib test on ring 4 succeeded in 0 usecs
[ 5.622074] [drm] Radeon Display Connectors
[ 5.623444] [drm] Initialized radeon 2.49.0 20080528 for 0000:01:00.0 on minor 1
[ 5.627778] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 5.628674] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4
[ 5.628740] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[ 5.628921] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 5.628930] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 5.630134] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00109810
[ 5.630141] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 5.630560] hub 1-0:1.0: USB hub found
[ 5.630578] hub 1-0:1.0: 12 ports detected
[ 5.630886] fbcon: inteldrmfb (fb0) is primary device
[ 5.631582] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 5.631584] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 5.631736] hub 2-0:1.0: USB hub found
[ 5.631748] hub 2-0:1.0: 6 ports detected
[ 5.631992] usb: port power management may be unreliable
[ 5.706124] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 5.709446] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 5.709839] ata1.00: ATA-8: TOSHIBA MQ01ABD100, AX1R4C, max UDMA/100
[ 5.709842] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 5.715236] ata1.00: configured for UDMA/100
[ 5.715849] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MQ01ABD1 4C PQ: 0 ANSI: 5
[ 5.715868] ata2.00: ATAPI: hp DVDRW DU8AESH, 6H61, max UDMA/133
[ 5.716939] ata2.00: configured for UDMA/133
[ 5.756596] scsi 1:0:0:0: CD-ROM hp DVDRW DU8AESH 6H61 PQ: 0 ANSI: 5
[ 6.005516] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[ 6.058851] tsc: Refined TSC clocksource calibration: 2399.999 MHz
[ 6.058865] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2298364cab5, max_idle_ns: 440795214892 ns
[ 6.199686] hidraw: raw HID events driver (C) Jiri Kosina
[ 6.206785] usbcore: registered new interface driver usbhid
[ 6.206786] usbhid: USB HID core driver
[ 6.208397] input: Lenovo Lenovo 500 Wireless HID as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:17EF:6071.0001/input/input5
[ 6.262480] hid-generic 0003:17EF:6071.0001: input,hidraw0: USB HID v1.11 Keyboard [Lenovo Lenovo 500 Wireless HID] on usb-0000:00:14.0-1/input0
[ 6.264073] input: Lenovo Lenovo 500 Wireless HID as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:17EF:6071.0002/input/input6
[ 6.319134] hid-generic 0003:17EF:6071.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Lenovo Lenovo 500 Wireless HID] on usb-0000:00:14.0-1/input1
[ 6.319559] input: Lenovo Lenovo 500 Wireless HID as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/0003:17EF:6071.0003/input/input7
[ 6.319773] hid-generic 0003:17EF:6071.0003: input,hiddev0,hidraw2: USB HID v1.11 Mouse [Lenovo Lenovo 500 Wireless HID] on usb-0000:00:14.0-1/input2
[ 6.365516] usb 1-2: new high-speed USB device number 3 using xhci_hcd
[ 6.556505] usb-storage 1-2:1.0: USB Mass Storage device detected
[ 6.556804] scsi host2: usb-storage 1-2:1.0
[ 6.556974] usbcore: registered new interface driver usb-storage
[ 6.557801] usbcore: registered new interface driver uas
[ 6.722040] usb 1-4: new full-speed USB device number 4 using xhci_hcd
[ 6.768479] Console: switching to colour frame buffer device 240x67
[ 6.792484] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 6.811419] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 6.811423] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 6.811456] sd 0:0:0:0: [sda] Write Protect is off
[ 6.811460] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 6.811474] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 6.830649] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 6.830653] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 6.831098] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 7.072172] clocksource: Switched to clocksource tsc
[ 7.082046] usb 1-5: new high-speed USB device number 5 using xhci_hcd
[ 7.217676] sda: sda1 sda2 sda3
[ 7.219144] sd 0:0:0:0: [sda] Attached SCSI disk
[ 7.351267] random: fast init done
[ 7.525688] [drm] RC6 on
[ 7.579570] scsi 2:0:0:0: Direct-Access SanDisk Cruzer Micro 8.01 PQ: 0 ANSI: 0 CCS
[ 7.580868] sd 2:0:0:0: [sdb] 3940479 512-byte logical blocks: (2.02 GB/1.88 GiB)
[ 7.581010] sd 2:0:0:0: [sdb] Write Protect is off
[ 7.581016] sd 2:0:0:0: [sdb] Mode Sense: 45 00 00 08
[ 7.581139] sd 2:0:0:0: [sdb] No Caching mode page found
[ 7.581208] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 7.585022] sdb: sdb1
[ 7.586101] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 7.940302] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 8.389181] random: crng init done
[ 9.222724] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 9.228577] cgroup: cgroup2: unknown option "nsdelegate"
[ 9.272072] systemd[1]: systemd 235 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN default-hierarchy=hybrid)
[ 9.272198] systemd[1]: Detected architecture x86-64.
[ 9.285105] systemd[1]: Set hostname to <manjaro>.
[ 9.481094] systemd[1]: File /usr/lib/systemd/system/systemd-journald.service:33 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 9.481097] systemd[1]: Proceeding WITHOUT firewalling in effect!
[ 9.482465] systemd[1]: File /usr/lib/systemd/system/systemd-udevd.service:32 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 9.482466] systemd[1]: Proceeding WITHOUT firewalling in effect!
[ 9.520486] systemd[1]: File /usr/lib/systemd/system/systemd-logind.service:34 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 9.520488] systemd[1]: Proceeding WITHOUT firewalling in effect!
[ 9.527757] systemd[1]: Unnecessary job for /dev/loop2 was removed.
[ 9.689298] systemd-journald[224]: Received request to flush runtime journal from PID 1
[ 10.117383] Initializing HPQ6001 module
[ 10.117494] input: HP Wireless hotkeys as /devices/virtual/input/input8
[ 10.248742] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 10.249313] ACPI: AC Adapter [ACAD] (on-line)
[ 10.263319] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 10.347560] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 10.347596] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 10.383916] r8169 0000:02:00.0 enp2s0: renamed from eth0
[ 10.398714] ACPI: Battery Slot [BAT1] (battery present)
[ 10.505422] thermal LNXTHERM:00: registered as thermal_zone3
[ 10.505423] ACPI: Thermal Zone [TZ00] (28 C)
[ 10.505564] thermal LNXTHERM:01: registered as thermal_zone4
[ 10.505565] ACPI: Thermal Zone [TZ01] (30 C)
[ 10.505651] thermal LNXTHERM:02: registered as thermal_zone5
[ 10.505652] ACPI: Thermal Zone [TZ02] (10 C)
[ 10.627534] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 10.627541] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 10.627542] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 10.627542] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 10.627543] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 10.627544] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 10.751607] [drm] amdgpu kernel modesetting enabled.
[ 10.751628] vga_switcheroo: detected switching method \_SB_.PCI0.GFX0.ATPX handle
[ 10.751787] ATPX version 1, functions 0x00000033
[ 10.752080] ATPX Hybrid Graphics
[ 10.771895] input: PC Speaker as /devices/platform/pcspkr/input/input10
[ 10.843788] Bluetooth: Core ver 2.22
[ 10.843803] NET: Registered protocol family 31
[ 10.843804] Bluetooth: HCI device and connection manager initialized
[ 10.843807] Bluetooth: HCI socket layer initialized
[ 10.843809] Bluetooth: L2CAP socket layer initialized
[ 10.843813] Bluetooth: SCO socket layer initialized
[ 11.202572] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops vgt_balloon_space [i915])
[ 11.340773] AVX2 version of gcm_enc/dec engaged.
[ 11.340774] AES CTR mode by8 optimization enabled
[ 11.455640] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3227: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 11.455642] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 11.455643] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 11.455644] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 11.455645] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 11.455646] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ 11.455647] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 11.508749] psmouse serio1: synaptics: queried max coordinates: x [..5652], y [..4846]
[ 11.538300] psmouse serio1: synaptics: queried min coordinates: x [1330..], y [1094..]
[ 11.596271] psmouse serio1: synaptics: Touchpad model: 1, fw: 8.1, id: 0x1e2b1, caps: 0xf00123/0x840300/0x2e800/0x0, board id: 3127, fw id: 8526786
[ 11.633148] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input9
[ 11.655657] iTCO_vendor_support: vendor-support=0
[ 11.668556] Bluetooth: HCI UART driver ver 2.3
[ 11.668557] Bluetooth: HCI UART protocol H4 registered
[ 11.668558] Bluetooth: HCI UART protocol BCSP registered
[ 11.668558] Bluetooth: HCI UART protocol LL registered
[ 11.668559] Bluetooth: HCI UART protocol ATH3K registered
[ 11.668559] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 11.668584] Bluetooth: HCI UART protocol Intel registered
[ 11.668603] Bluetooth: HCI UART protocol Broadcom registered
[ 11.668604] Bluetooth: HCI UART protocol QCA registered
[ 11.668604] Bluetooth: HCI UART protocol AG6XX registered
[ 11.668605] Bluetooth: HCI UART protocol Marvell registered
[ 11.716552] mousedev: PS/2 mouse device common for all mice
[ 11.720116] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[ 11.720470] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[ 11.720530] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[ 11.720588] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[ 11.720644] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[ 11.720706] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 11.953334] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 11.953466] iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[ 11.958016] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 12.107165] input: HP WMI hotkeys as /devices/virtual/input/input11
[ 12.237344] rtl8723be: Using firmware rtlwifi/rtl8723befw.bin
[ 12.275511] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 12.275724] rtlwifi: rtlwifi: wireless switch is on
[ 12.282169] rtl8723be 0000:03:00.0 wlo1: renamed from wlan0
[ 12.506225] Adding 9227464k swap on /dev/sda3. Priority:-1 extents:1 across:9227464k FS
[ 12.524958] kvm: disabled by bios
[ 12.552713] kvm: disabled by bios
[ 12.705903] intel_rapl: Found RAPL domain package
[ 12.705906] intel_rapl: Found RAPL domain core
[ 12.705907] intel_rapl: Found RAPL domain uncore
[ 12.705909] intel_rapl: Found RAPL domain dram
[ 12.765507] usbcore: registered new interface driver btusb
[ 12.853606] media: Linux media interface: v0.10
[ 12.947907] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.947910] Bluetooth: BNEP filters: protocol multicast
[ 12.947916] Bluetooth: BNEP socket layer initialized
[ 12.959935] Linux video capture interface: v2.00
[ 12.998021] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 12.998023] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_config.bin
[ 12.999512] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 12.999514] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin
[ 13.000342] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
[ 13.063060] Bluetooth: hci0: rom_version status=0 version=1
[ 13.063065] Bluetooth: cfg_sz 0, total size 22496
[ 13.162092] uvcvideo: Found UVC 1.00 device HP TrueVision HD (04f2:b56c)
[ 13.163676] uvcvideo 1-5:1.0: Entity type for entity Extension 4 was not initialized!
[ 13.163681] uvcvideo 1-5:1.0: Entity type for entity Processing 2 was not initialized!
[ 13.163682] uvcvideo 1-5:1.0: Entity type for entity Camera 1 was not initialized!
[ 13.163774] input: HP TrueVision HD as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input18
[ 13.163828] usbcore: registered new interface driver uvcvideo
[ 13.163829] USB Video Class driver (1.1.1)
[ 13.227706] [drm] probing gen 2 caps for device 8086:9d10 = 1724843/e
[ 13.227709] [drm] PCIE gen 3 link speeds already enabled
[ 13.233610] [drm] PCIE GART of 2048M enabled (table at 0x0000000000040000).
[ 13.233721] radeon 0000:01:00.0: WB enabled
[ 13.233724] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00 and cpu addr 0xffff880268ea9c00
[ 13.233726] radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04 and cpu addr 0xffff880268ea9c04
[ 13.233727] radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08 and cpu addr 0xffff880268ea9c08
[ 13.233729] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c and cpu addr 0xffff880268ea9c0c
[ 13.233730] radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10 and cpu addr 0xffff880268ea9c10
[ 13.433825] [drm] ring test on 0 succeeded in 1 usecs
[ 13.433831] [drm] ring test on 1 succeeded in 1 usecs
[ 13.433836] [drm] ring test on 2 succeeded in 1 usecs
[ 13.433844] [drm] ring test on 3 succeeded in 4 usecs
[ 13.433850] [drm] ring test on 4 succeeded in 3 usecs
[ 13.433884] [drm] ib test on ring 0 succeeded in 0 usecs
[ 13.433908] [drm] ib test on ring 1 succeeded in 0 usecs
[ 13.433931] [drm] ib test on ring 2 succeeded in 0 usecs
[ 13.433944] [drm] ib test on ring 3 succeeded in 0 usecs
[ 13.433956] [drm] ib test on ring 4 succeeded in 0 usecs
[ 13.487920] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 13.676388] r8169 0000:02:00.0 enp2s0: link down
[ 13.676483] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 13.679785] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 14.132986] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[ 14.252683] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 14.307971] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 14.308015] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 14.308048] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 14.699838] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 15.072083] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 25.973260] [drm] probing gen 2 caps for device 8086:9d10 = 1724843/e
[ 25.973264] [drm] PCIE gen 3 link speeds already enabled
[ 25.979037] [drm] PCIE GART of 2048M enabled (table at 0x0000000000040000).
[ 25.979160] radeon 0000:01:00.0: WB enabled
[ 25.979166] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00 and cpu addr 0xffff880268ea9c00
[ 25.979168] radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04 and cpu addr 0xffff880268ea9c04
[ 25.979170] radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08 and cpu addr 0xffff880268ea9c08
[ 25.979172] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c and cpu addr 0xffff880268ea9c0c
[ 25.979173] radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10 and cpu addr 0xffff880268ea9c10
[ 26.551612] [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x850C)=0xCAFEDEAD)
[ 26.552349] [drm:si_resume [radeon]] *ERROR* si startup failed on resume
[ 30.212225] fuse init (API version 7.26)
[ 31.137947] Bluetooth: RFCOMM TTY layer initialized
[ 31.137952] Bluetooth: RFCOMM socket layer initialized
[ 31.137956] Bluetooth: RFCOMM ver 1.11
[ 37.002680] usb 1-4: reset full-speed USB device number 4 using xhci_hcd
[ 39.558968] Bluetooth: hci0 urb ffff880273f18180 failed to resubmit (113)
[ 358.908891] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 674.908345] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 990.908302] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 1193.100811] EXT4-fs (sda2): recovery complete
[ 1193.100824] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 1306.967962] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 1622.965113] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 1880.465759] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 1880.476545] JFS: nTxBlock = 8192, nTxLock = 65536
[ 1880.551444] ntfs: driver 2.1.32 [Flags: R/W MODULE].
[ 1880.634049] raid6: sse2x1 gen() 10001 MB/s
[ 1880.690664] raid6: sse2x1 xor() 7390 MB/s
[ 1880.747330] raid6: sse2x2 gen() 12543 MB/s
[ 1880.803998] raid6: sse2x2 xor() 8559 MB/s
[ 1880.860665] raid6: sse2x4 gen() 14583 MB/s
[ 1880.917329] raid6: sse2x4 xor() 9107 MB/s
[ 1880.973997] raid6: avx2x1 gen() 20250 MB/s
[ 1881.030661] raid6: avx2x2 gen() 25132 MB/s
[ 1881.087331] raid6: avx2x4 gen() 28059 MB/s
[ 1881.087331] raid6: using algorithm avx2x4 gen() 28059 MB/s
[ 1881.087332] raid6: using avx2x2 recovery algorithm
[ 1881.098217] xor: automatically using best checksumming function avx
[ 1881.134331] Btrfs loaded, crc32c=crc32c-intel
[ 1938.956909] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 2219.559364] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 2229.002198] wlo1: authenticate with 6c:72:20:a2:87:88
[ 2229.023678] wlo1: send auth to 6c:72:20:a2:87:88 (try 1/3)
[ 2229.029030] wlo1: authenticated
[ 2229.030551] wlo1: associate with 6c:72:20:a2:87:88 (try 1/3)
[ 2229.035636] wlo1: RX AssocResp from 6c:72:20:a2:87:88 (capab=0x431 status=0 aid=1)
[ 2229.037967] wlo1: associated
[ 2229.037992] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
I tried to paste/link journalctl log too. But it's too huge for even 10 day period.
Kindly help me resolve this. Thanks.
Guys,
Finally I found how to change my shell and I'm able to get my shell back.
I used the following command & it worked. Thanks for all your patience & support.
usermod -s /bin/bash <username>
