[Solved] Unable to open Settings/Display applet
After some mishaps with XFCE files , almost everything works ok except accessin the Settings Display part.
I am in a simple laptop without Nvidia nor ATI graphics.
Recently I have connected an external monitor via HDMI with higher resolution and only noticed have enabled the "mirror" screen option ...
But now, without access to the Settings Display widget , how can I turn it off ?
or put it in Extend mode ?
Although In the XFCE Panel widget I have tested and selected most of the available options with no sucess whatsoever.
How can I recover that Settings / Display widget ?
thanks in advance
Try re-installing xfce4-settings:
sudo pacman -Syu xfce4-settings
Perhaps this will restore everything as it shoul be.
Try Alt +F2 and run xfce4-display-settings
solved by re-installing xfce4-display-settings ...
Although it did run correctly , any option change did not have any effect...
nonetheless installed the AUR mons script and got it solved...
thanks for the fast answer ...
