Hey guys!
Ive been an Arch user for a long time, but I decided to give Manjaro a go on my new build, and so far I really like it. I've managed to get my setup exactly as I want it, with one niggling problem.
I'm running xfce with a dual monitor setup. I've disabled lighDM so I can boot to command line, and I've installed xfce4-screensaver so I can lock my screen. I've set the screen saver to activate after 55 mins, and (in the power manager) DPMS sleep to occur after 60 mins. The screen saver activates as expected, but it's 50/50 as to whether it then sets the monitors to standby 5 mins later.
If I force standby with the command
xset dpms force standby
I see the same issue! sometimes it goes into standby, sometimes it goes into the screen saver.
This is weird......any ideas!
here are my display options:
Keyboard Control:
auto repeat: on key click percent: 0 LED mask: 00000000
XKB indicators:
00: Caps Lock: off 01: Num Lock: off 02: Scroll Lock: off
03: Compose: off 04: Kana: off 05: Sleep: off
06: Suspend: off 07: Mute: off 08: Misc: off
09: Mail: off 10: Charging: off 11: Shift Lock: off
12: Group 2: off 13: Mouse Keys: off
auto repeat delay: 500 repeat rate: 20
auto repeating keys: 00ffffffdffffbbf
fadfffefffedffff
9fffffffffffffff
fff7ffffffffffff
bell percent: 50 bell pitch: 400 bell duration: 100
Pointer Control:
acceleration: 2/1 threshold: 4
Screen Saver:
prefer blanking: no allow exposures: no
timeout: 3300 cycle: 3300
Colors:
default colormap: 0x20 BlackPixel: 0x0 WhitePixel: 0xffffff
Font Path:
/usr/share/fonts/misc,/usr/share/fonts/TTF,built-ins
DPMS (Energy Star):
Standby: 3600 Suspend: 0 Off: 0
DPMS is Enabled
Monitor is On
edit:
browsing the forums, I've just seen this Steam screws up suspend
possibly related....manually suspend does seem to be working now I've shutdown the steam client
