Alright, fixed it!
I followed this https://wiki.archlinux.org/index.php/Network_configuration/Wireless#Respecting_the_regulatory_domain
I set my device to "world regulatory domain", iw reg set 00
and queried with iw list | grep -A 15 Frequencies:
resulting:
Frequencies:
* 2412 MHz [1] (20.0 dBm)
* 2417 MHz [2] (20.0 dBm)
* 2422 MHz [3] (20.0 dBm)
* 2427 MHz [4] (20.0 dBm)
* 2432 MHz [5] (20.0 dBm)
* 2437 MHz [6] (20.0 dBm)
* 2442 MHz [7] (20.0 dBm)
* 2447 MHz [8] (20.0 dBm)
* 2452 MHz [9] (20.0 dBm)
* 2457 MHz [10] (20.0 dBm)
* 2462 MHz [11] (20.0 dBm)
* 2467 MHz [12] (disabled)
* 2472 MHz [13] (disabled)
* 2484 MHz [14] (disabled)
Band 2:
Frequencies:
* 5180 MHz [36] (30.0 dBm) (no IR)
* 5200 MHz [40] (30.0 dBm) (no IR)
* 5220 MHz [44] (30.0 dBm)
* 5240 MHz [48] (30.0 dBm) (no IR)
* 5260 MHz [52] (30.0 dBm) (no IR, radar detection)
* 5280 MHz [56] (30.0 dBm) (no IR, radar detection)
* 5300 MHz [60] (30.0 dBm) (no IR, radar detection)
* 5320 MHz [64] (30.0 dBm) (no IR, radar detection)
* 5500 MHz [100] (30.0 dBm) (no IR, radar detection)
* 5520 MHz [104] (30.0 dBm) (no IR, radar detection)
* 5540 MHz [108] (30.0 dBm) (no IR, radar detection)
* 5560 MHz [112] (30.0 dBm) (no IR, radar detection)
* 5580 MHz [116] (30.0 dBm) (no IR, radar detection)
* 5600 MHz [120] (30.0 dBm) (no IR, radar detection)
* 5620 MHz [124] (30.0 dBm) (no IR, radar detection)
As the router is using 2.4GHz I noticed that 12-14 channels are disabled and went to the router settings just to find that it was using channel 13
Changing to channel 10 (least noice) on router settings made wifi appear on the Network Manager list. Arch wiki is pretty amazing.
