Spotify on ARM64
Disclaimer: I'm not affiliated with either Spotify nor the makers of Ncspot. I just want to help folks out :wink:
Getting spotify to work on my raspberry pi has been bit of a pain. There isn't an arm x64 compiled version available for as far as I know, nor does the browser version work for me.
I'm not posting here to ask questions though (I'm all ears if you have working versions of the real apps though) as I have actually gotten a really neat spotify-client working! I wanted to use this forum post to help you get started to (if you are running Manjaro on an ARM64 system).
The player that I found works really well is "Ncspot"... It is however limited to premium spotify accounts only (since spotify blocks api access to their audio for non-premium members).
(screenshot taken on my Raspberry Pi4 running Manjaro with KDE)
Installation seems to be super simple (all in the terminal/konsole though):
  • Install the snap package manager using sudo pacman -S snapd
  • reboot your pi/computer or log out and in (snapd pacakges are added to your path on system login)
  • execute sudo snap install ncspot
  • start ncspot by typing ncspot in your console. upon opening the first time, you'll be prompted to log in through either Facebook or your Spotify account
  • press "?" with the terminal-based app open to reveal instructions, "backspace" to go back and "q" to quit.
links to things mentioned:
Edit:
It seems that ncspot is also available in the Arch Community repositories (aka AUR). As my manjaro OS runs on an arm64 raspberry pi I was hesitant to open my distro up to the scary wide world that AUR brings when you toggle it on (the ncspot snap package was just a tad cleaner because it would install one package in a folder that i could easily install if i choose to get rid of snap later). But if you want to install ncspot using pacman follow the following steps:
  • Open up your manjaro build-in app-store GUI ("install or remove software")
  • Go to the application's settings
  • Go to the AUR tab and toggle it on
  • Open an terminal and execute pacman -Syy to update your local list of available software
  • Execute pacman -S ncspot
Alternatively (and this is how I actually installed ncspot initially), you can build ncspot yourself by following the instructions on https://github.com/hrkfdn/ncspot
spotify-tui apparently works as well if you compile it with rust yourself, since they don't provide an ARM package.
ncspot and ncspot-git are also available in the AUR if you're not a snaps person.
I tried it just now. Looks really neat!
The only problem is that spotify-tui looks like a remote-control. The app itself doesn't play music, but controls other devices with the official spotify app open.
From the looks of their page however it seems that spotify-tui is compatible with spotifyd https://github.com/Rigellute/spotify-tui#using-with-spotifyd. I'll mess with that a bit :wink:
Thanks for the share!
Just remember to use build spotifyd with the pulseaudio plugin, since Manjaro uses pulseaudio. By default it only builds with Alsa. spotifyd-full in AUR compiles with pulseaudio support. Unfortunately, the spotifyd-bin-full one doesn't, per the comments at least.
Edit: Also, one of the ways spotifyd authenticates your account is unfortunately via plain text in the config file. But you only need to let it authenticate once, and spotify will send a token to spotifyd. You can remove your username and password from the config file after this.
Or you can use the other password options.
Thanks for posting this. I just got this running on my pinebook in which I was desperately missing spotify.
This is an important topic given the lack of an official client for arm64 and I noticed Spotifyd was added to the repo in the latest testing update for Manjaro ARM which will make things easier. Thanks to those responsible!
Another alternative to ncspot and spotify-tui is spotify-qt. This is only in AUR for x64 devices but I followed the instructions on the github page and it built without any issues on my Pinebook Pro.
It has a nice clean interface and there's no need to remember keyboard shortcuts, it is based on spotify--tui so can be used to play locally or via a spotify connect device on your network.
Can also be used with chromium dockers package.
This topic was automatically closed after 90 days. New replies are no longer allowed.
