[Stable-Staging Update] 2020-03-27 - Kernels, UKUI, AMDVLK, Browsers, Haskell, Python
Hello community,
here is another Stable-Staging Update for you:
Some feature-updates:
  • Some of our Kernels got updated
  • Another update for Palemoon and Firefox-Dev
  • AMDVLK driver is now at 2020.Q1.4
  • More package updates for ukui
  • Haskell and Python updates/cleanups
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages. Also check out our current 19.0.2 ISOs and give us the needed feedback. You might also want to give our latest spin with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Setup instructions
  • first update your stable branch to get the latest pacman-mirrors package
  • issue: sudo pacman-mirrors -a -B stable-staging
  • issue: sudo pacman -Syyu or pamac upgrade --force-refresh
Upstream notice
Arch updated their default compression to zstd. We adopted to the same standard. More and more packages will have the zst extension from now on. If you get for what ever reason an error with ZSTD not supported as archive format you can do this:
sudo pacman -Syy
sudo pacman -S pacman-static
sudo pacman-static -Syyu
Our current supported kernels
  • linux316 3.16.82
  • linux44 4.4.217
  • linux49 4.9.217
  • linux414 4.14.174
  • linux419 4.19.113
  • linux54 5.4.28
  • linux55 5.5.13
  • linux56 5.6-rc7
  • linux419-rt 4.19.106_rt45
  • linux54-rt 5.4.26_rt17
Package Changes (Fri Mar 27 12:15:59 CET 2020)
  • stable-staging community x86_64: 467 new and 458 removed package(s)
  • stable-staging core x86_64: 13 new and 13 removed package(s)
  • stable-staging extra x86_64: 102 new and 101 removed package(s)
  • stable-staging multilib x86_64: 8 new and 8 removed package(s)
Cleanups
  • stable-staging core x86_64: 4 new and 4 removed package(s)
  • stable-staging multilib x86_64: 7 new and 7 removed package(s)
  • stable-staging extra x86_64: 7 new and 7 removed package(s)
:: Different overlay package(s) in repository community x86_64
                             PACKAGE               stable       stable-staging
                               cpu-x3.2.4.r193.g73fe01e-33.2.4.r193.g73fe01e-5
                              etcher             1.5.79-1             1.5.80-1
                kdeplasma-addons-git5.18.80.r8314.g8d5e1a0b5-15.18.80.r8320.g7eaad09e1-1
                             kio-git5.69.0.r3840.g86832ca0-15.69.0.r3841.g50bc53ff-1
                     kitemmodels-git5.69.0.r419.gecdf87f-15.69.0.r420.g3775404-1
                      knetattach-git5.18.80.r7502.gfff5c0487-15.18.80.r7503.g38a874ab8-1
                       ksysguard-git5.18.80.r3236.g404ea7e9-15.18.80.r3237.g00f522a7-1
                    libksysguard-git5.18.80.r1777.g599270f-15.18.80.r1778.g7a13a67-1
          manjaro-pacbang-wallpapers                0.2-2                0.3-1
                        palemoon-bin             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-ar             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-bg             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-cs             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-da             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-de             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-el             28.8.4-1           28.9.0.2-1
                 palemoon-i18n-en-gb             28.8.4-1           28.9.0.2-1
                 palemoon-i18n-es-ar             28.8.4-1           28.9.0.2-1
                 palemoon-i18n-es-es             28.8.4-1           28.9.0.2-1
                 palemoon-i18n-es-mx             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-fi             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-fr             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-gl             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-hr             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-hu             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-id             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-is             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-it             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-ja             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-kn             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-ko             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-nl             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-pl             28.8.4-1           28.9.0.2-1
                 palemoon-i18n-pt-br             28.8.4-1           28.9.0.2-1
                 palemoon-i18n-pt-pt             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-ro             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-ru             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-sk             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-sl             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-sr             28.8.4-1           28.9.0.2-1
                 palemoon-i18n-sv-se             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-tl             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-tr             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-uk             28.8.4-1           28.9.0.2-1
                    palemoon-i18n-vi             28.8.4-1           28.9.0.2-1
                 palemoon-i18n-zh-cn             28.8.4-1           28.9.0.2-1
                 palemoon-i18n-zh-tw             28.8.4-1           28.9.0.2-1
                  plasma-desktop-git5.18.80.r7502.gfff5c0487-15.18.80.r7503.g38a874ab8-1
                plasma-framework-git5.69.0.r15389.g049978008-15.69.0.r15390.gf363a06ae-1
          plasma-wayland-session-git5.18.80.r8824.g86fd0f2f7-15.18.80.r8834.gdceb791c0-1
                plasma-workspace-git5.18.80.r8824.g86fd0f2f7-15.18.80.r8834.gdceb791c0-1
                          sonnet-git5.69.0.r522.g81fd758-15.69.0.r523.g12d1e20-1
                          st-manjaro1:0.8.2.r12.gf1546cf-21:0.8.2.r31.g51e19ea-1
                     diffuse-manjaro                    -              0.4.8-1
                              muffin                    -            4.4.3-0.1
:: Different sync package(s) in repository community x86_64
               aarch64-linux-gnu-gcc              9.2.0-1              9.3.0-1
                              aeolus              0.9.7-3              0.9.8-1
                                agda              2.6.1-8             2.6.1-10
                arm-none-eabi-newlib              3.1.0-2              3.3.0-1
                                asar              3.0.1-1              3.0.2-1
                        aws-c-common             0.4.22-2             0.4.34-1
                         aws-sdk-cpp            1.7.284-1            1.7.301-1
                               beets              1.4.9-2              1.4.9-3
                               bochs              2.6.9-3             2.6.11-1
                              bsdiff                4.3-9               4.3-10
                       cabal-install           3.0.0.0-62           3.0.0.0-65
                      cargo-outdated              0.9.7-1              0.9.8-1
                               cgrep            6.6.32-11            6.6.32-12
                            clipmenu              5.6.0-2              6.0.1-1
                                code             1.43.1-1             1.43.2-1
                           create_ap              0.4.6-2              0.4.6-3
                             cryptol             2.8.0-88             2.8.0-89
                              cython            0.29.15-1            0.29.16-1
                             cython2            0.29.15-1            0.29.16-1
                               darcs           2.14.2-198           2.14.2-200
                               dhall            1.30.0-22            1.30.0-25
                          dhall-bash            1.0.28-24            1.0.28-27
                          dhall-json             1.6.2-23             1.6.2-26
                                 din             44.0.2-1                 45-1
                         dns-lexicon             3.3.18-1             3.3.19-1
                      dnscrypt-proxy             2.0.40-2             2.0.42-1
                             drumkv1             0.9.12-1             0.9.13-1
                              drupal              8.8.3-1              8.8.4-1
                            ejabberd              20.02-1              20.03-1
                            electron              8.1.1-1              8.2.0-2
                              fcitx5     0.0.0.20200323-1     0.0.0.20200326-1
                        fcitx5-anthy     0.0.0.20200312-1     0.0.0.20200325-1
                      fcitx5-chewing     0.0.0.20200213-1     0.0.0.20200325-1
               fcitx5-chinese-addons     0.0.0.20200323-1     0.0.0.20200325-1
                       fcitx5-hangul     0.0.0.20200213-1     0.0.0.20200325-1
                           fcitx5-qt     0.0.0.20200321-1     0.0.0.20200325-1
                       fcitx5-unikey     0.0.0.20200308-1     0.0.0.20200325-1
           firefox-developer-edition             75.0b7-1             75.0b9-1
  firefox-developer-edition-i18n-ach             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-af             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-an             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-ar             75.0b7-1             75.0b9-1
  firefox-developer-edition-i18n-ast             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-az             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-be             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-bg             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-bn             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-br             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-bs             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-ca             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-ca-valencia             75.0b7-1             75.0b9-1
  firefox-developer-edition-i18n-cak             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-cs             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-cy             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-da             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-de             75.0b7-1             75.0b9-1
  firefox-developer-edition-i18n-dsb             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-el             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-en-ca             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-en-gb             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-en-us             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-eo             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-es-ar             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-es-cl             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-es-es             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-es-mx             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-et             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-eu             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-fa             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-ff             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-fi             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-fr             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-fy-nl             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-ga-ie             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-gd             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-gl             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-gn             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-gu-in             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-he             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-hi-in             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-hr             75.0b7-1             75.0b9-1
  firefox-developer-edition-i18n-hsb             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-hu             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-hy-am             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-ia             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-id             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-is             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-it             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-ja             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-ka             75.0b7-1             75.0b9-1
  firefox-developer-edition-i18n-kab             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-kk             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-km             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-kn             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-ko             75.0b7-1             75.0b9-1
  firefox-developer-edition-i18n-lij             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-lt             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-lv             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-mk             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-mr             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-ms             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-my             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-nb-no             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-ne-np             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-nl             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-nn-no             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-oc             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-pa-in             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-pl             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-pt-br             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-pt-pt             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-rm             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-ro             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-ru             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-si             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-sk             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-sl             75.0b7-1             75.0b9-1
  firefox-developer-edition-i18n-son             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-sq             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-sr             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-sv-se             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-ta             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-te             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-th             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-tl             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-tr             75.0b7-1             75.0b9-1
  firefox-developer-edition-i18n-trs             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-uk             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-ur             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-uz             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-vi             75.0b7-1             75.0b9-1
   firefox-developer-edition-i18n-xh             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-zh-cn             75.0b7-1             75.0b9-1
firefox-developer-edition-i18n-zh-tw             75.0b7-1             75.0b9-1
                          freeradius             3.0.20-4             3.0.21-1
                       frogatto-data              1.3.1-3              1.3.1-4
                             fscrypt              0.2.6-3              0.2.7-1
                    gimp-plugin-gmic              2.8.4-1              2.8.4-2
                           git-annex        8.20200309-30        8.20200309-33
                          git-repair        1.20200102-54        1.20200102-56
                              gitlab             12.8.7-1             12.9.0-1
                       gitlab-gitaly             12.8.5-1             12.9.0-1
                    gitlab-workhorse             8.24.0-1             8.27.0-1
                                 gox              1.0.1-2              1.0.1-3
                              gradle              6.2.2-1                6.3-1
                          gradle-doc              6.2.2-1                6.3-1
                          gradle-src              6.2.2-1                6.3-1
                      grafana-zabbix             3.10.5-1             3.11.0-1
        greenbone-security-assistant              8.0.1-1              9.0.0-1
                                  gx             0.14.1-4                    -
                               gx-go              1.9.0-2                    -
                       haskell-aeson            1.4.7.0-1            1.4.7.1-1
         haskell-aeson-better-errors          0.9.1.0-164          0.9.1.0-165
                haskell-aeson-compat             0.3.9-82             0.3.9-83
                  haskell-aeson-diff           1.1.0.8-79           1.1.0.8-80
                haskell-aeson-pretty             0.8.8-28             0.8.8-29
                    haskell-aeson-qq             0.8.3-38             0.8.3-39
                  haskell-aeson-yaml           1.0.6.0-12           1.0.6.0-13
               haskell-asn1-encoding             0.9.6-21             0.9.6-22
                  haskell-asn1-parse             0.9.5-21             0.9.5-22
                  haskell-asn1-types             0.3.3-31              0.3.4-1
                haskell-authenticate             1.3.5-84             1.3.5-86
          haskell-authenticate-oauth           1.6.0.1-64           1.6.0.1-66
                         haskell-aws              0.22-16              0.22-18
            haskell-binary-instances                 1-10            1.0.0.1-2
               haskell-binary-tagged               0.2-47               0.2-48
                  haskell-bower-json          1.0.0.1-162          1.0.0.1-163
                 haskell-casa-client              0.0.1-5              0.0.1-7
                  haskell-casa-types              0.0.1-6              0.0.1-7
                       haskell-cborg            0.2.2.1-6            0.2.2.1-7
                  haskell-cborg-json            0.2.2.0-6            0.2.2.0-7
                  haskell-cheapskate           0.1.1.2-53           0.1.1.2-55
                  haskell-connection             0.3.1-26             0.3.1-27
                   haskell-criterion           1.5.6.2-17           1.5.6.2-19
       haskell-criterion-measurement           0.1.2.0-32           0.1.2.0-33
               haskell-crypto-pubkey            0.2.8-142            0.2.8-143
         haskell-crypto-pubkey-types            0.4.3-127            0.4.3-128
                         haskell-dav             1.3.4-65             1.3.4-67
                        haskell-dbus             1.2.10-1             1.2.11-1
               haskell-dbus-hslogger           0.1.0.1-15           0.1.0.1-16
                 haskell-descriptive             0.9.5-94             0.9.5-95
                haskell-doctemplates             0.8.1-11             0.8.1-12
                   haskell-esqueleto              3.3.2-1              3.3.2-2
                  haskell-fdo-notify            0.3.1-268            0.3.1-269
              haskell-generic-random            1.3.0.0-2            1.3.0.1-1
                     haskell-githash           0.1.3.3-80           0.1.3.3-82
            haskell-hackage-security           0.6.0.0-52           0.6.0.0-55
             haskell-haddock-library             1.8.0-40             1.8.0-41
                      haskell-hakyll          4.13.2.0-29          4.13.2.0-31
                       haskell-hasql              1.4.2-1              1.4.2-2
                  haskell-hasql-pool             0.5.1-75             0.5.1-76
           haskell-hasql-transaction            1.0.0.1-5            1.0.0.1-6
                haskell-hjsonpointer             1.5.0-78             1.5.0-79
                 haskell-hledger-lib             1.17.1-1             1.17.1-2
                    haskell-hopenpgp             2.9.4-44             2.9.4-46
                       haskell-hpack            0.33.0-93            0.33.0-95
                   haskell-hspec-wai             0.10.1-9            0.10.1-10
              haskell-hspec-wai-json             0.10.1-9            0.10.1-10
                haskell-hsyaml-aeson           0.2.0.0-24           0.2.0.0-25
                        haskell-http        4000.3.14-151        4000.3.14-153
                 haskell-http-client           0.6.4.1-20           0.6.4.1-22
             haskell-http-client-tls          0.3.5.3-205          0.3.5.3-207
                haskell-http-conduit           2.3.7.3-97           2.3.7.3-99
               haskell-http-download           0.2.0.0-20           0.2.0.0-22
                haskell-http-streams           0.8.7.1-63           0.8.7.1-66
                       haskell-http2             2.0.3-63             2.0.3-64
                  haskell-httpd-shed           0.4.1.1-80           0.4.1.1-82
                         haskell-hxt          9.3.1.18-47          9.3.1.18-49
   haskell-insert-ordered-containers             0.2.3-18             0.2.3-19
                       haskell-ipynb              0.1-161              0.1-162
                        haskell-jose           0.8.2.0-66           0.8.2.0-68
                   haskell-js-jquery            3.3.1-390            3.3.1-392
                  haskell-lens-aeson               1.1-18               1.1-19
                       haskell-lukko           0.1.1.1-12            0.1.1.2-1
             haskell-microlens-aeson           2.3.0.4-44           2.3.0.4-45
                 haskell-microstache          1.0.1.1-139          1.0.1.1-140
                    haskell-mustache             2.3.1-68             2.3.1-70
                 haskell-network-uri           2.6.3.0-47           2.6.3.0-49
             haskell-optparse-simple          0.1.1.2-157          0.1.1.2-159
                haskell-pandoc-types              1.20-25              1.20-26
                      haskell-pantry            0.4.0.1-8           0.4.0.1-11
                        haskell-path              0.7.0-3              0.7.0-4
                     haskell-path-io             1.6.0-11             1.6.0-12
                  haskell-persistent          2.10.5.2-10          2.10.5.2-11
               haskell-persistent-qq           2.9.1.1-57           2.9.1.1-58
           haskell-persistent-sqlite          2.10.6.2-34          2.10.6.2-35
         haskell-persistent-template           2.8.2.3-12           2.8.2.3-13
             haskell-persistent-test            2.0.3.1-6            2.0.3.1-7
                  haskell-pipes-http            1.0.6-117            1.0.6-119
           haskell-postgresql-binary            0.12.2-31            0.12.2-32
             haskell-rio-prettyprint           0.1.0.0-44           0.1.0.0-45
                         haskell-rsa             2.4.1-14             2.4.1-15
                         haskell-sbv               8.6-50               8.6-51
                   haskell-serialise            0.2.2.0-6            0.2.2.0-7
                     haskell-servant              0.17-12              0.17-14
              haskell-servant-server              0.17-12              0.17-14
             haskell-servant-swagger             1.1.8-13             1.1.8-15
                       haskell-shake            0.18.5-57            0.18.5-59
                 haskell-shakespeare            2.0.24-16            2.0.24-17
                 haskell-skylighting           0.8.3.2-45           0.8.3.2-47
            haskell-skylighting-core           0.8.3.2-45           0.8.3.2-47
                   haskell-snap-core           1.0.4.1-58           1.0.4.1-60
                 haskell-snap-server          1.1.1.1-170          1.1.1.1-173
                   haskell-sourcemap            0.1.6-170            0.1.6-171
                  haskell-statistics           0.15.2.0-9          0.15.2.0-10
                    haskell-swagger2                2.5-1                2.5-2
       haskell-tamarin-prover-theory             1.4.1-72             1.4.1-73
                     haskell-texmath          0.12.0.1-38          0.12.0.1-40
                         haskell-tls              1.5.4-6              1.5.4-7
         haskell-tls-session-manager             0.0.4-30             0.0.4-31
                   haskell-tree-diff               0.1-72               0.1-73
                  haskell-uri-encode           1.5.0.5-58           1.5.0.5-60
              haskell-wai-app-static           3.1.7.1-59           3.1.7.1-61
                   haskell-wai-extra          3.0.29.1-28          3.0.29.1-29
          haskell-wai-handler-launch           3.0.3.1-28           3.0.3.1-30
                  haskell-wai-logger             2.3.6-57             2.3.6-58
                        haskell-warp             3.3.9-10             3.3.9-12
                    haskell-warp-tls            3.2.11-47            3.2.11-49
                        haskell-wreq          0.5.3.2-168          0.5.3.2-170
                        haskell-x509             1.7.5-53             1.7.5-54
                  haskell-x509-store             1.6.7-52             1.6.7-53
                 haskell-x509-system            1.6.6-120            1.6.6-121
             haskell-x509-validation            1.6.11-52            1.6.11-53
                  haskell-xml-hamlet           0.5.0.1-66           0.5.0.1-67
                haskell-xss-sanitize             0.3.6-95             0.3.6-97
                        haskell-yaml           0.11.3.0-7           0.11.3.0-8
                       haskell-yesod           1.6.0.1-63           1.6.0.1-65
                  haskell-yesod-auth             1.6.9-57             1.6.10-3
                  haskell-yesod-core          1.6.17.3-21          1.6.17.3-23
               haskell-yesod-default            1.2.0-704            1.2.0-706
                  haskell-yesod-form            1.6.7-142            1.6.7-144
            haskell-yesod-persistent           1.6.0.4-87           1.6.0.4-89
                haskell-yesod-static          1.6.0.1-344          1.6.0.1-346
                  haskell-yesod-test            1.6.9-103            1.6.9-105
                             hledger           1.17.1.1-2           1.17.1.1-3
                          hledger-ui           1.17.1.1-3           1.17.1.1-4
                         hledger-web             1.17.1-6             1.17.1-8
                               hlint            2.2.11-31            2.2.11-32
                      home-assistant            0.107.5-1            0.107.7-1
                              hoogle         5.0.17.15-18         5.0.17.15-20
                      hopenpgp-tools             0.23.1-4             0.23.1-6
                                hugo             0.68.1-1             0.68.3-1
                              hwinfo              21.68-2              21.69-1
                           hypercorn              0.9.1-1              0.9.3-1
                               idris            1.3.2-105            1.3.2-107
                                 iwd                1.5-1                1.6-1
                             jenkins              2.226-1              2.228-1
                               jruby           9.2.10.0-1           9.2.11.1-1
                                 k9s             0.17.7-1             0.18.1-1
                          kcm-fcitx5     0.0.0.20200322-1     0.0.0.20200325-1
                               kitty             0.17.0-1             0.17.1-1
                      kitty-terminfo             0.17.0-1             0.17.1-1
                   krita-plugin-gmic              2.8.4-1              2.8.4-2
                          latte-dock              0.9.9-1             0.9.10-1
                              libldm              0.2.4-3  0.2.4.r20.a856552-1
                            libmupdf             1.16.1-2             1.16.1-3
                                 lxc            1:3.2.1-2            1:4.0.0-1
                               lxcfs              4.0.0-1              4.0.1-1
                            metacity             3.36.0-1             3.36.1-1
                            mupdf-gl             1.16.1-2             1.16.1-3
                         mupdf-tools             1.16.1-2             1.16.1-3
                           nextcloud             18.0.2-1             18.0.3-1
                              nodejs            13.11.0-1            13.12.0-1
                              notion           20190501-1            1:4.0.0-1
                                 npm             6.14.3-1             6.14.4-1
                   npm-check-updates              4.0.5-1              4.1.0-1
                          obs-studio             25.0.1-1             25.0.3-1
                    otf-font-awesome             5.12.1-1             5.13.0-1
                             padthv1             0.9.12-1             0.9.13-1
                              pandoc             2.9.2-72             2.9.2-74
                     pandoc-citeproc              0.17-53              0.17-55
                     pandoc-crossref           0.3.6.2-50           0.3.6.2-52
                  perl-list-allutils               0.15-2               0.16-1
                       phpvirtualbox              5.2_1-1              5.2_1-2
                            plantuml           1.2020.2-1           1.2020.5-1
                           postgrest            6.0.2-107            6.0.2-109
                              ppsspp              1.9.4-1              1.9.4-2
                            prettier              2.0.1-1              2.0.2-1
                             prosody           1:0.11.4-1           1:0.11.5-1
                       python-bleach              3.1.1-1              3.1.3-1
                      python-blessed             1.17.3-1             1.17.4-1
                     python-cfn-lint             0.29.0-2             0.29.2-1
                         python-cmd2             0.10.1-1              1.0.1-1
                    python-fonttools              4.5.0-1              4.6.0-1
                       python-gitlab             1.14.0-1              2.1.2-1
                   python-hypothesis              5.7.1-1              5.8.0-1
                     python-identify             1.4.12-1             1.4.13-1
                        python-json5              0.9.3-1              0.9.4-1
                       python-minidb              2.0.2-4              2.0.3-1
              python-openstackclient              5.0.0-1              5.2.0-1
                 python-openstacksdk             0.43.0-1             0.44.0-1
                   python-persistent              4.6.3-1              4.6.4-1
                       python-pg8000             1.14.0-1             1.14.1-1
                     python-pwntools              4.0.1-2              4.0.1-3
                        python-pyaml            19.12.0-1             20.3.1-1
                     python-pyroute2             0.5.10-1             0.5.11-1
                   python-pyrsistent             0.15.7-2             0.16.0-1
                      python-pytorch              1.4.0-7              1.4.1-1
                 python-pytorch-cuda              1.4.0-7              1.4.1-1
                  python-pytorch-opt              1.4.0-7              1.4.1-1
             python-pytorch-opt-cuda              1.4.0-7              1.4.1-1
                    python-softlayer              5.8.5-1              5.8.6-1
                       python-stestr              2.6.0-2              3.0.0-1
                      python-tempora              2.1.1-1              3.0.0-1
                          python-tox             3.14.5-1             3.14.6-1
                  python-transaction              2.4.0-3              3.0.0-1
                       python2-pyaml            19.12.0-1             20.3.1-1
                         python2-tox             3.14.5-1             3.14.6-1
                               qconf                2.4-2                2.5-1
                            qjackctl              0.6.1-1              0.6.2-1
                            qmidictl              0.6.1-1              0.6.2-1
                            qmidinet              0.6.1-1              0.6.2-1
                            qsampler              0.6.1-1              0.6.2-1
                              qsynth              0.6.1-1              0.6.2-1
              qt5-ukui-platformtheme              0.9.0-1              1.0.0-1
                             qxgedit              0.6.1-1              0.6.2-1
                             redmine              4.0.5-2              4.1.0-1
                      rime-cantonese     0.0.0.20200319-1     0.0.0.20200325-1
                       ruby-net-ping              2.0.6-3              2.0.7-1
                            sagemath               9.0-11               9.0-12
                    sagemath-jupyter               9.0-11               9.0-12
                             samplv1             0.9.12-1             0.9.13-1
                          shellcheck            0.7.0-199            0.7.0-201
                           shorewall            5.2.3.7-1              5.2.4-1
                      shorewall-core            5.2.3.7-1              5.2.4-1
                          shorewall6            5.2.3.7-1              5.2.4-1
                      signal-desktop             1.32.1-1             1.32.3-1
                               stack    2.1.3.20200310-28    2.1.3.20200310-31
                     stylish-haskell          0.11.0.0-11          0.11.0.0-12
                            supertux              0.6.1-2              0.6.1-3
                             synthv1             0.9.12-1             0.9.13-1
                      tamarin-prover            1.4.1-307            1.4.1-310
                                tang                  7-4                  7-6
                             taskell           1.9.2.0-61           1.9.2.0-63
                           terraform            0.12.21-1            0.12.24-1
                            texworks              0.6.4-1              0.6.5-1
                            three.js               r114-1               r115-1
                              trojan             1.14.1-2             1.15.1-1
                    ttf-font-awesome             5.12.1-1             5.13.0-1
                           ukui-menu              2.0.2-2              2.0.3-1
                    ukui-screensaver             2.0.10-2              2.1.0-1
                ukui-session-manager              2.0.0-2              2.0.1-1
                ukui-settings-daemon              1.2.0-1              1.2.1-1
                             unbound             1.10.0-1             1.10.0-2
                                 upx               3.96-1               3.96-2
                                 urh              2.8.4-1              2.8.5-1
                      usb_modeswitch              2.6.0-1              2.6.0-2
                               v2ray             4.23.0-1             4.23.1-1
         v2ray-domain-list-community       202003221514-1       202003261452-1
                         v2ray-geoip       202003180002-1       202003250001-1
                              vegeta             12.8.1-1             12.8.2-1
                        vim-nerdtree              6.3.0-1              6.4.1-1
                                  wt              4.2.2-1              4.3.0-1
                              xmobar              0.33-17              0.33-20
                            yamllint             1.20.0-1             1.21.0-1
                          youtube-dl         2020.03.08-1         2020.03.24-1
                                zart              2.8.4-1              2.8.4-2
                      alicloud-vault                    -              1.2.0-1
                      ansible-bender                    -              0.8.1-2
                                pocl                    -                1.4-3
                   python-astunparse                    -              1.6.2-2
                      python-cytoolz                    -             0.10.1-2
                        python-migen                    -              0.9.2-1
                       python-nmigen                    -                0.2-1
                   python-pytest-tap                    -                3.1-1
                        python-pyvcd                    -              0.1.7-1
                        python-toolz                    -             0.10.0-2
:: Different overlay package(s) in repository core x86_64
                            linux419           4.19.112-1           4.19.113-1
                    linux419-headers           4.19.112-1           4.19.113-1
                             linux54             5.4.27-1             5.4.28-1
                     linux54-headers             5.4.27-1             5.4.28-1
                             linux55             5.5.11-1             5.5.13-1
                     linux55-headers             5.5.11-1             5.5.13-1
                             mhwd-db              0.6.4-9             0.6.4-10
:: Different sync package(s) in repository core x86_64
                                nano                4.8-1                4.9-1
:: Different overlay package(s) in repository extra x86_64
                       calamares-git3.2.21.r7402.252802870-13.2.21.r7473.b88e5589e-1
                  linux419-acpi_call            1.1.0-102            1.1.0-103
                   linux419-bbswitch              0.8-102              0.8-103
                linux419-broadcom-wl     6.30.223.271-101     6.30.223.271-102
                linux419-ndiswrapper              1.62-51              1.62-52
               linux419-nvidia-340xx           340.108-22           340.108-23
               linux419-nvidia-390xx           390.132-31           390.132-32
               linux419-nvidia-418xx           418.113-30           418.113-31
               linux419-nvidia-430xx            430.64-30            430.64-31
               linux419-nvidia-435xx            435.21-41            435.21-42
               linux419-nvidia-440xx             440.64-6             440.64-7
                   linux419-nvidiabl             0.88-101             0.88-102
                      linux419-r8168          8.048.00-16          8.048.00-17
                  linux419-rtl8723bu          20200126-13          20200126-14
                   linux419-tp_smapi              0.43-51              0.43-52
                linux419-vhba-module          20200106-16          20200106-17
   linux419-virtualbox-guest-modules              6.1.4-8              6.1.4-9
    linux419-virtualbox-host-modules              6.1.4-8              6.1.4-9
                        linux419-zfs             0.8.3-15             0.8.3-16
                   linux54-acpi_call             1.1.0-32             1.1.0-33
                    linux54-bbswitch               0.8-32               0.8-33
                 linux54-broadcom-wl      6.30.223.271-32      6.30.223.271-33
                 linux54-ndiswrapper              1.62-32              1.62-33
                linux54-nvidia-340xx           340.108-24           340.108-25
                linux54-nvidia-390xx           390.132-32           390.132-33
                linux54-nvidia-418xx           418.113-32           418.113-33
                linux54-nvidia-430xx            430.64-32            430.64-33
                linux54-nvidia-435xx            435.21-32            435.21-33
                linux54-nvidia-440xx             440.64-6             440.64-7
                    linux54-nvidiabl              0.88-32              0.88-33
                       linux54-r8168          8.048.00-17          8.048.00-18
                   linux54-rtl8723bu          20200126-14          20200126-15
                    linux54-tp_smapi              0.43-32              0.43-33
                 linux54-vhba-module          20200106-17          20200106-18
    linux54-virtualbox-guest-modules              6.1.4-8              6.1.4-9
     linux54-virtualbox-host-modules              6.1.4-8              6.1.4-9
                         linux54-zfs             0.8.3-16             0.8.3-17
                   linux55-acpi_call             1.1.0-14             1.1.0-16
                    linux55-bbswitch               0.8-14               0.8-16
                 linux55-broadcom-wl      6.30.223.271-14      6.30.223.271-16
                 linux55-ndiswrapper              1.62-14              1.62-16
                linux55-nvidia-340xx            340.108-8           340.108-10
                linux55-nvidia-390xx           390.132-14           390.132-16
                linux55-nvidia-418xx           418.113-14           418.113-17
                linux55-nvidia-430xx            430.64-14            430.64-17
                linux55-nvidia-435xx            435.21-14            435.21-17
                linux55-nvidia-440xx             440.64-6             440.64-9
                    linux55-nvidiabl              0.88-14              0.88-17
                       linux55-r8168          8.048.00-14          8.048.00-17
                   linux55-rtl8723bu          20200126-14          20200126-17
                    linux55-tp_smapi              0.43-14              0.43-17
                 linux55-vhba-module          20200106-14          20200106-17
    linux55-virtualbox-guest-modules              6.1.4-8             6.1.4-11
     linux55-virtualbox-host-modules              6.1.4-8             6.1.4-11
                         linux55-zfs             0.8.3-11             0.8.3-14
              manjaro-tools-base-git      r2885.1dcb41d-1      r2887.dee5a38-1
               manjaro-tools-iso-git      r2885.1dcb41d-1      r2887.dee5a38-1
               manjaro-tools-pkg-git      r2885.1dcb41d-1      r2887.dee5a38-1
              manjaro-tools-yaml-git      r2885.1dcb41d-1      r2887.dee5a38-1
                               snapd               2.44-1             2.44.1-1
:: Different sync package(s) in repository extra x86_64
                         389-ds-base            1.4.3.4-1            1.4.3.4-2
                              amdvlk          2020.Q1.3-1          2020.Q1.4-1
                               dav1d              0.5.2-1              0.6.0-1
                              ffmpeg            1:4.2.2-3            1:4.2.2-4
                gnome-remote-desktop              0.1.7-2              0.1.8-1
                              gpaste             3.36.0-1             3.36.2-1
                           kirigami2             5.68.0-1             5.68.0-2
                           libsigc++             2.10.2-1             2.10.3-1
                      libsigc++-docs             2.10.2-1             2.10.3-1
                            libwnck3             3.32.0-3             3.36.0-1
                           memcached             1.5.20-1             1.5.21-1
                               ndctl                 67-1                 68-1
                              netpbm           10.73.30-1           10.73.31-1
                    noto-fonts-emoji           20191016-4           20191016-6
              perl-ipc-system-simple               1.28-1               1.30-1
                          prometheus             2.16.0-2             2.17.1-1
                   python-setuptools           1:46.1.1-1           1:46.1.3-1
                              thunar             1.8.13-1             1.8.14-1
                                vala             0.48.1-1             0.48.2-1
                                 vlc             3.0.8-10             3.0.8-11
                   xfce4-screensaver              0.1.9-1              0.1.9-2
                            xine-lib             1.2.10-1             1.2.10-2
:: Different sync package(s) in repository multilib x86_64
                        lib32-amdvlk          2020.Q1.3-1          2020.Q1.4-1
0 voters
No hiccups on Openbox, and Pamac work alright even image loading animation is fixed :slight_smile: Still, it's a bit to big but all in all, cool. Thank you :heart:
Hm after upgrade packages what’s to downgrade to previous versions
After downgrade won’t upgrade pamac-mirrors —fasttrack 5 && pacman-Syyu
Upgrade but shows this
Your mirror is out of date. Seems you changed them. German mirrors normally sync more often.
pamac -Scc resolved it
I met problem similar to @pheiduck on stable-staging .
About a week ago (in time of solving hplip problem by manjaro-system package hacking) I noticed "package flapping"
  • if I get German one (with newer package) I got 20200324-4 package
  • if I got Czech (older) mirror I got 20200324-3 package
Maybe is something wrong with pacman-mirrors - don't identify out-dated mirrors on staging-stable branch correctly.
Of course problem disappeared if all mirrors are up to date.
cc @fhdk
