[Stable Update] 2020-05-03 - Kernels, LXQt 0.15, Vulkan, VLC 3.0.10, Mesa 20.0.6, AMDVLK 20.Q2.2
Attention:
Wer Chrome unter Linux, macOS oder Windows nutzt,
sollte die aktuelle Version 81.0.4044.138 installieren. Darin haben die Entwickler drei Schwachstellen aus der Welt geschafft.
Wie aus einer Warnmeldung von Google hervorgeht:
(https://chromereleases.googleblog.com/2020/05/stable-channel-update-for-desktop.html),
ist der Bedrohungsgrad als " hoch " eingestuft. Wie gewohnt hält Google sich mit Details zu den Lücken zurück, damit Angreifer so wenig Ansatzpunkte wie möglich haben.
................................... in gebräuchlicherer Sprache: ............................................................................
If you use Chrome under Linux, macOS or Windows, you should install the current version
81.0.4044.138 . In it, the developers have eliminated three vulnerabilities.
[As shown by a warning message from Google]
(https://chromereleases.googleblog.com/2020/05/stable-channel-update-for-desktop.html), the level of threat is classified as "** high **". As usual, Google retains details about the gaps so that attackers have as few starting points as possible.
THIS AFFECTS CHROMIUM TOO
I stumbled accross a strange bug, that has been introduced after this (or the last stable) update: "Desktop effects have been suspended by another application"
I seem not to be the only one with this problem: Manjaro KDE Desktop effect suspended after login
I just can't point my finger on what causes this problem.
I recently got this issue every time I enable my second screen, it's been a few updates back, it is the Nvidia drivers. Didn't try to troubleshoot more, I just enable the desktop effects back.
My AMD-machine is stuck on boot after update. KDE.
IMG_20200507_171828
IMG_20200507_171810
:flushed:
Edit: Reboots again after several tries. Selfhealing Manjaro.
The original anydesk-bin got updated yesterday and now works again.
Please check your hard disk health. I've been here. Your hard disk is about to crash in few weeks.
Or simply a bad cable/connection, may check that as well. For health stat, check it with SMART tools like GsmartControl or similar tool able to read the S.M.A.R.T.
This was fixed, hopefully it gets backported https://gitlab.freedesktop.org/mesa/mesa/-/issues/2877
If it doesn't maybe @philm can patch it in mesa
Removing openjpeg would also remove another AUR package that depends on openjpeg - would I have to change the dependencies of that package to openjpeg2 and recompile or something else?
