Startech PCIe 4 port USB 3.0 extender PEXUSB3S44V on MSI TRX40 not working
Hey everyone.
I have a weird issue, which I don't fully understand.
I have a couple of 4 port Startech PCIe USB 3.0 extender cards with 4 dedicated channels (PEXUSB3S44V).
They somehow don't get recognized in Linux in combination with an MSI TRX40 + Threadripper 3960X. The same Linux works together with the cards on another machine, and the cards work on any machine (that I tried) with Windows.
computer A:
  • MB: MSI TRX40
  • CPU: AMD Threadripper 3960X
computer B:
  • MB: MSI 7752 (super old, around 7 years, but I successfully tried other machines as well)
  • CPU: i5
computer A + windows = yes
computer A + linux = no
computer B + linux = yes
computer B + windows = yes
In Linux I tried Kernel 4.4 4.14 4.15 4.18 5.3 and 5.4
I also tried Manjaro and Ubuntu, and Windows 10.
I move the harddrives from one computer to the other. procedure:
  1. Linux hard drive and cards in computer A -> not working!
  2. power off computer A
  3. remove Linux hard drive and cards from computer A
  4. insert Linux hard drive and cards in computer B
  5. power on computer B
  6. Linux hard drive and cards in computer B -> working!
  7. power off computer B
  8. remove Linux hard drive and cards from computer B
  9. insert Linux hard drive and cards in computer A
  10. power on computer A
  11. Linux hard drive and cards in computer A -> not working!
  12. power off computer A
  13. remove only Linux hard drive from computer A
  14. insert Windows hard drive in computer A
  15. power on computer A
  16. Windows hard drive and cards in computer A -> working!
inxi -Fxzc0
sudo dmesg
I know that my wifi card (AX200) does not work as well, but... that is less crucial in my current setup, because I can use a cable. The cards are breaking my neck though.. Any help is greatly appreciated!
I also tried btw all of the 4 PCIe slots, and yes, I powered them. I assume it is a linux driver issue, since in windows everything works just fine. Or could it be a BIOS setting?
Here is the manual, on page 63 are advanced settings.
I tried setting the card at PCIe SlotX Lanes Configuration to "Auto", and "4x4x4x4" and "4x4".
I hope this is possible to figure out...
you can add
sudo pacman -S linux54-headers
sudo mhwd-kernel -i linux56
lspci -v
lsusb -vt
reboot , press Esc for Grub
and choose in detail kernel version
thanks for your reply!
ha, so I might need another kernel version for it to work?
the cards do show up with lspci
cropped output:
$ lspci -v
4c:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02) (prog-if 30 [XHCI])
	Subsystem: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller
	Flags: bus master, fast devsel, latency 0, IRQ 132
	Memory at e6b00000 (64-bit, non-prefetchable) [size=8K]
	Capabilities: [50] Power Management version 3
	Capabilities: [70] MSI: Enable- Count=1/8 Maskable- 64bit+
	Capabilities: [90] MSI-X: Enable+ Count=8 Masked-
	Capabilities: [a0] Express Endpoint, MSI 00
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [150] Latency Tolerance Reporting
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
4d:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02) (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 41
	Memory at e6a00000 (64-bit, non-prefetchable) [size=8K]
4e:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02) (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 43
	Memory at e6900000 (64-bit, non-prefetchable) [size=8K]
4f:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02) (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 157
	Memory at e6800000 (64-bit, non-prefetchable) [size=8K]
$ lspci -vt
 +-[0000:40]-+-00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
 |           +-00.2  Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
 |           +-01.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
 |           +-01.1-[41-49]----00.0-[42-49]--+-02.0-[43]----00.0  ASMedia Technology Inc. Device 3242
 |           |                               +-04.0-[44]----00.0  Intel Corporation I211 Gigabit Network Connection
 |           |                               +-05.0-[45]----00.0  Intel Corporation I211 Gigabit Network Connection
 |           |                               +-06.0-[46]----00.0  Intel Corporation Wi-Fi 6 AX200
 |           |                               +-08.0-[47]--+-00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
 |           |                               |            +-00.1  Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
 |           |                               |            \-00.3  Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
 |           |                               +-09.0-[48]----00.0  Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
 |           |                               \-0a.0-[49]----00.0  Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
 |           +-01.3-[4a-4f]----00.0-[4b-4f]--+-01.0-[4c]----00.0  Renesas Technology Corp. uPD720202 USB 3.0 Host Controller
 |           |                               +-02.0-[4d]----00.0  Renesas Technology Corp. uPD720202 USB 3.0 Host Controller
 |           |                               +-03.0-[4e]----00.0  Renesas Technology Corp. uPD720202 USB 3.0 Host Controller
 |           |                               \-04.0-[4f]----00.0  Renesas Technology Corp. uPD720202 USB 3.0 Host Controller
full:
$ lspci -v
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
	Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
	Flags: fast devsel, NUMA node 0
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
	Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
	Flags: fast devsel, IRQ 30, NUMA node 0
	Capabilities: [40] Secure device <?>
	Capabilities: [64] MSI: Enable+ Count=1/4 Maskable- 64bit+
	Capabilities: [74] HyperTransport: MSI Mapping Enable+ Fixed+
	Capabilities: [c8] Vendor Specific Information: Len=18 <?>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 32, NUMA node 0
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: [disabled]
	Memory behind bridge: [disabled]
	Prefetchable memory behind bridge: [disabled]
	Capabilities: [58] Express Root Port (Slot-), MSI 00
	Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
	Capabilities: [c8] HyperTransport: MSI Mapping Enable+ Fixed+
	Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
	Capabilities: [150] Advanced Error Reporting
	Capabilities: [270] Secondary PCI Express
	Capabilities: [2a0] Access Control Services
	Capabilities: [400] Data Link Feature <?>
	Capabilities: [410] Physical Layer 16.0 GT/s <?>
	Capabilities: [440] Lane Margining at the Receiver <?>
	Kernel driver in use: pcieport
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 33, NUMA node 0
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	Memory behind bridge: fd000000-fd0fffff [size=1M]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
	Subsystem: Micro-Star International Co., Ltd. [MSI] FCH SMBus Controller
	Flags: 66MHz, medium devsel, NUMA node 0
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
	Subsystem: Micro-Star International Co., Ltd. [MSI] FCH LPC Bridge
	Flags: bus master, 66MHz, medium devsel, latency 0, NUMA node 0
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 3
	Kernel driver in use: k10temp
	Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 7
01:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
	Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
	Capabilities: [48] Vendor Specific Information: Len=08 <?>
	Capabilities: [64] Express Endpoint, MSI 00
02:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
	Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
02:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller (prog-if 30 [XHCI])
	Subsystem: Micro-Star International Co., Ltd. [MSI] Starship USB 3.0 Host Controller
	Flags: bus master, fast devsel, latency 0, IRQ 96, NUMA node 0
	Memory at fd000000 (64-bit, non-prefetchable) [size=1M]
	Capabilities: [a0] MSI: Enable- Count=1/8 Maskable- 64bit+
	Capabilities: [c0] MSI-X: Enable+ Count=8 Masked-
	Capabilities: [370] Transaction Processing Hints
20:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
	Flags: fast devsel
20:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
	Flags: fast devsel, IRQ 29
20:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
20:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
20:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
20:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 34
	Bus: primary=20, secondary=21, subordinate=21, sec-latency=0
	I/O behind bridge: 00006000-00006fff [size=4K]
	Memory behind bridge: e0000000-e10fffff [size=17M]
	Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff [size=288M]
	Capabilities: [58] Express Root Port (Slot+), MSI 00
	Capabilities: [c0] Subsystem: Device 7c60:1462
	Capabilities: [370] L1 PM Substates
	Capabilities: [380] Downstream Port Containment
	Capabilities: [3c4] Designated Vendor-Specific <?>
20:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
20:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
20:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
20:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 36
	Bus: primary=20, secondary=22, subordinate=22, sec-latency=0
20:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
20:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 37
	Bus: primary=20, secondary=23, subordinate=23, sec-latency=0
	Memory behind bridge: e1200000-e14fffff [size=3M]
21:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: Gigabyte Technology Co., Ltd GP102 [GeForce GTX 1080 Ti]
	Flags: bus master, fast devsel, latency 0, IRQ 182
	Memory at e0000000 (32-bit, non-prefetchable) [size=16M]
	Memory at c0000000 (64-bit, prefetchable) [size=256M]
	Memory at d0000000 (64-bit, prefetchable) [size=32M]
	I/O ports at 6000 [size=128]
	Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
	Capabilities: [60] Power Management version 3
	Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [78] Express Legacy Endpoint, MSI 00
	Capabilities: [100] Virtual Channel
	Capabilities: [250] Latency Tolerance Reporting
	Capabilities: [128] Power Budgeting <?>
	Capabilities: [420] Advanced Error Reporting
	Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
	Capabilities: [900] Secondary PCI Express
	Kernel driver in use: nvidia
	Kernel modules: nouveau, nvidia_drm, nvidia
21:00.1 Audio device: NVIDIA Corporation GP102 HDMI Audio Controller (rev a1)
	Subsystem: Gigabyte Technology Co., Ltd GP102 HDMI Audio Controller
	Flags: bus master, fast devsel, latency 0, IRQ 181
	Memory at e1080000 (32-bit, non-prefetchable) [size=16K]
	Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [78] Express Endpoint, MSI 00
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
22:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
	Flags: fast devsel
23:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
	Flags: fast devsel
23:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
	Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
	Flags: bus master, fast devsel, latency 0, IRQ 168
	Memory at e1300000 (32-bit, non-prefetchable) [size=1M]
	Memory at e1408000 (32-bit, non-prefetchable) [size=8K]
	Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [c0] MSI-X: Enable+ Count=2 Masked-
	Kernel driver in use: ccp
	Kernel modules: ccp
23:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 105
	Memory at e1200000 (64-bit, non-prefetchable) [size=1M]
23:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
	Subsystem: Micro-Star International Co., Ltd. [MSI] Starship/Matisse HD Audio Controller
	Flags: fast devsel, IRQ 11
	Memory at e1400000 (32-bit, non-prefetchable) [disabled] [size=32K]
40:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
	Flags: fast devsel
40:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
	Flags: fast devsel, IRQ 28
40:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
40:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 38
	Bus: primary=40, secondary=41, subordinate=49, sec-latency=0
	I/O behind bridge: 00008000-00009fff [size=8K]
	Memory behind bridge: e6000000-e67fffff [size=8M]
40:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 39
	Bus: primary=40, secondary=4a, subordinate=4f, sec-latency=0
	Memory behind bridge: e6800000-e6bfffff [size=4M]
40:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
40:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
40:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 40
	Bus: primary=40, secondary=50, subordinate=50, sec-latency=0
	Memory behind bridge: e6c00000-e6cfffff [size=1M]
40:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
40:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
40:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
40:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 42
	Bus: primary=40, secondary=51, subordinate=51, sec-latency=0
40:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
40:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 44
	Bus: primary=40, secondary=52, subordinate=52, sec-latency=0
41:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse Switch Upstream (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 26
	Bus: primary=41, secondary=42, subordinate=49, sec-latency=0
	Capabilities: [58] Express Upstream Port, MSI 00
42:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 45
	Bus: primary=42, secondary=43, subordinate=43, sec-latency=0
	Memory behind bridge: e6700000-e67fffff [size=1M]
	Capabilities: [58] Express Downstream Port (Slot+), MSI 00
42:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 46
	Bus: primary=42, secondary=44, subordinate=44, sec-latency=0
	I/O behind bridge: 00009000-00009fff [size=4K]
	Memory behind bridge: e6600000-e66fffff [size=1M]
42:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 47
	Bus: primary=42, secondary=45, subordinate=45, sec-latency=0
	I/O behind bridge: 00008000-00008fff [size=4K]
	Memory behind bridge: e6500000-e65fffff [size=1M]
42:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 48
	Bus: primary=42, secondary=46, subordinate=46, sec-latency=0
	Memory behind bridge: e6400000-e64fffff [size=1M]
42:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 49
	Bus: primary=42, secondary=47, subordinate=47, sec-latency=0
	Memory behind bridge: e6000000-e61fffff [size=2M]
	Capabilities: [58] Express Downstream Port (Slot-), MSI 00
	Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
42:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 51
	Bus: primary=42, secondary=48, subordinate=48, sec-latency=0
	Memory behind bridge: e6300000-e63fffff [size=1M]
42:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 53
	Bus: primary=42, secondary=49, subordinate=49, sec-latency=0
	Memory behind bridge: e6200000-e62fffff [size=1M]
43:00.0 USB controller: ASMedia Technology Inc. Device 3242 (prog-if 30 [XHCI])
	Subsystem: Micro-Star International Co., Ltd. [MSI] Device 7c60
	Flags: bus master, fast devsel, latency 0, IRQ 52
	Memory at e6700000 (64-bit, non-prefetchable) [size=32K]
	Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
	Capabilities: [68] MSI-X: Enable+ Count=8 Masked-
	Capabilities: [78] Power Management version 3
	Capabilities: [80] Express Legacy Endpoint, MSI 00
	Capabilities: [c0] Subsystem: ASMedia Technology Inc. Device 0201
	Capabilities: [200] Secondary PCI Express
	Capabilities: [300] Latency Tolerance Reporting
	Capabilities: [400] L1 PM Substates
44:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
	DeviceName: Onboard LAN RTL8111
	Subsystem: Micro-Star International Co., Ltd. [MSI] I211 Gigabit Network Connection
	Memory at e6600000 (32-bit, non-prefetchable) [size=128K]
	I/O ports at 9000 [disabled] [size=32]
	Memory at e6620000 (32-bit, non-prefetchable) [size=16K]
	Capabilities: [40] Power Management version 3
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
	Capabilities: [70] MSI-X: Enable+ Count=5 Masked-
	Capabilities: [140] Device Serial Number 00-d8-61-ff-ff-d3-23-32
	Capabilities: [1a0] Transaction Processing Hints
	Kernel driver in use: igb
	Kernel modules: igb
45:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
	Flags: bus master, fast devsel, latency 0, IRQ 50
	Memory at e6500000 (32-bit, non-prefetchable) [size=128K]
	I/O ports at 8000 [disabled] [size=32]
	Memory at e6520000 (32-bit, non-prefetchable) [size=16K]
	Capabilities: [140] Device Serial Number 00-d8-61-ff-ff-d3-23-33
	Kernel modules: igb
46:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
	DeviceName: Onboard LAN RTL8125
	Subsystem: Intel Corporation Wi-Fi 6 AX200
	Flags: fast devsel, IRQ 52
	Memory at e6400000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [c8] Power Management version 3
	Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [40] Express Endpoint, MSI 00
	Capabilities: [80] MSI-X: Enable- Count=16 Masked-
	Capabilities: [14c] Latency Tolerance Reporting
	Capabilities: [154] L1 PM Substates
	Kernel modules: iwlwifi
47:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
	Flags: fast devsel
47:00.1 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller (prog-if 30 [XHCI])
	Subsystem: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
	Flags: bus master, fast devsel, latency 0, IRQ 123
	Memory at e6100000 (64-bit, non-prefetchable) [size=1M]
47:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller (prog-if 30 [XHCI])
	Memory at e6000000 (64-bit, non-prefetchable) [size=1M]
48:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51) (prog-if 01 [AHCI 1.0])
	DeviceName: X570/590 SATA0
	Subsystem: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
	Flags: bus master, fast devsel, latency 0, IRQ 114
	Memory at e6300000 (32-bit, non-prefetchable) [size=2K]
	Capabilities: [a0] MSI: Enable+ Count=1/16 Maskable- 64bit+
	Capabilities: [d0] SATA HBA v1.0
	Kernel driver in use: ahci
	Kernel modules: ahci
49:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51) (prog-if 01 [AHCI 1.0])
	DeviceName: X570/590 SATA1
	Flags: bus master, fast devsel, latency 0, IRQ 166
	Memory at e6200000 (32-bit, non-prefetchable) [size=2K]
4a:00.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
	Bus: primary=4a, secondary=4b, subordinate=4f, sec-latency=0
	Capabilities: [5c] Vital Product Data
	Capabilities: [64] Vendor Specific Information: Len=34 <?>
	Capabilities: [b0] Subsystem: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch
	Capabilities: [c0] Express Upstream Port, MSI 00
	Capabilities: [140] Virtual Channel
	Capabilities: [20c] Power Budgeting <?>
	Capabilities: [230] Latency Tolerance Reporting
	Capabilities: [240] L1 PM Substates
4b:01.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 54
	Bus: primary=4b, secondary=4c, subordinate=4c, sec-latency=0
	Memory behind bridge: e6b00000-e6bfffff [size=1M]
	Capabilities: [4c] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [c0] Express Downstream Port (Slot+), MSI 00
	Capabilities: [220] Access Control Services
4b:02.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 55
	Bus: primary=4b, secondary=4d, subordinate=4d, sec-latency=0
	Memory behind bridge: e6a00000-e6afffff [size=1M]
4b:03.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 56
	Bus: primary=4b, secondary=4e, subordinate=4e, sec-latency=0
	Memory behind bridge: e6900000-e69fffff [size=1M]
4b:04.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 57
	Bus: primary=4b, secondary=4f, subordinate=4f, sec-latency=0
	Memory behind bridge: e6800000-e68fffff [size=1M]
50:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 (prog-if 02 [NVM Express])
	Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
	Flags: bus master, fast devsel, latency 0, IRQ 62, NUMA node 0
	Memory at e6c00000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Endpoint, MSI 00
	Capabilities: [b0] MSI-X: Enable+ Count=33 Masked-
	Capabilities: [148] Device Serial Number 00-00-00-00-00-00-00-00
	Capabilities: [158] Power Budgeting <?>
	Capabilities: [168] Secondary PCI Express
	Capabilities: [188] Latency Tolerance Reporting
	Capabilities: [190] L1 PM Substates
	Kernel driver in use: nvme
51:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
	Flags: fast devsel
52:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
	Flags: fast devsel
60:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
	Flags: fast devsel
60:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
	Flags: fast devsel, IRQ 27
60:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
60:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
60:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
60:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
60:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
60:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
60:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 59
	Bus: primary=60, secondary=61, subordinate=61, sec-latency=0
60:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
	Flags: fast devsel
60:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 61
	Bus: primary=60, secondary=62, subordinate=62, sec-latency=0
61:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
	Flags: fast devsel
62:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
	Flags: fast devsel
$ lspci -vt
-+-[0000:60]-+-00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
 |           +-02.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
 |           +-03.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
 |           +-04.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
 |           +-05.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
 |           +-07.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
 |           +-07.1-[61]----00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
 |           +-08.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
 |           \-08.1-[62]----00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
 |           +-03.1-[50]----00.0  Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
 |           +-07.1-[51]----00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
 |           \-08.1-[52]----00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
 +-[0000:20]-+-00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
 |           +-03.1-[21]--+-00.0  NVIDIA Corporation GP102 [GeForce GTX 1080 Ti]
 |           |            \-00.1  NVIDIA Corporation GP102 HDMI Audio Controller
 |           +-07.1-[22]----00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
 |           \-08.1-[23]--+-00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
 |                        +-00.1  Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
 |                        +-00.3  Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller
 |                        \-00.4  Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
 \-[0000:00]-+-00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
             +-07.1-[01]----00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
             +-08.1-[02]--+-00.0  Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
             |            \-00.3  Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller
             +-14.0  Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller
             +-14.3  Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge
             +-18.0  Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 0
             +-18.1  Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 1
             +-18.2  Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 2
             +-18.3  Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 3
             +-18.4  Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 4
             +-18.5  Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 5
             +-18.6  Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 6
             \-18.7  Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 7
I rebooted and tried new kernel (5.6.11), the cards don't show up yet. I'll try all others again
ah, just saw you asked for lsusb -vt
I don't think it's showing up here
$ lsusb -vt
/:  Bus 18.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
    ID 1d6b:0003 Linux Foundation 3.0 root hub
/:  Bus 17.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
    ID 1d6b:0002 Linux Foundation 2.0 root hub
/:  Bus 16.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/:  Bus 15.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
/:  Bus 14.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/:  Bus 13.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
/:  Bus 12.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/:  Bus 11.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
/:  Bus 10.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/:  Bus 09.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 480M
    |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
        ID 046d:c52b Logitech, Inc. Unifying Receiver
    |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 1: Dev 2, If 2, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 5: Dev 3, If 0, Class=Wireless, Driver=, 12M
        ID 8087:0029 Intel Corp.
    |__ Port 5: Dev 3, If 1, Class=Wireless, Driver=, 12M
    |__ Port 6: Dev 4, If 0, Class=Hub, Driver=hub/4p, 480M
        ID 05e3:0608 Genesys Logic, Inc. Hub
        |__ Port 2: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 12M
            ID 1e71:170e NZXT
/:  Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 480M
    |__ Port 2: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 480M
        ID 13fe:4100 Kingston Technology Company Inc. Flash drive
    |__ Port 5: Dev 3, If 0, Class=Audio, Driver=snd-usb-audio, 480M
        ID 0db0:543d Micro Star International
    |__ Port 5: Dev 3, If 1, Class=Audio, Driver=snd-usb-audio, 480M
    |__ Port 5: Dev 3, If 2, Class=Audio, Driver=snd-usb-audio, 480M
    |__ Port 5: Dev 3, If 3, Class=Audio, Driver=snd-usb-audio, 480M
    |__ Port 5: Dev 3, If 4, Class=Audio, Driver=snd-usb-audio, 480M
    |__ Port 5: Dev 3, If 5, Class=Audio, Driver=snd-usb-audio, 480M
    |__ Port 5: Dev 3, If 6, Class=Audio, Driver=snd-usb-audio, 480M
    |__ Port 5: Dev 3, If 7, Class=Human Interface Device, Driver=usbhid, 480M
    |__ Port 6: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
        ID 1462:7c60 Micro Star International
/:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 5000M
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
    |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
        ID 03f0:094a HP, Inc Optical Mouse [672662-001]
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
can you add on boot Grub
(e) dit , uses arrows and add
"iommu=pt" and F10 ( only for this boot )
[    4.066139] xhci_hcd 0000:4c:00.0: xHCI Host Controller
[    4.066143] xhci_hcd 0000:4c:00.0: new USB bus registered, assigned bus number 11
[    4.066162] xhci_hcd 0000:4c:00.0: Zeroing 64bit base registers, expecting fault
[    4.192165] xhci_hcd 0000:4c:00.0: hcc params 0x014051cf hci version 0x100 quirks 0x0000000100000090
[    4.192458] usb usb11: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    4.192459] usb usb11: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.192460] usb usb11: Product: xHCI Host Controller
[    4.192460] usb usb11: Manufacturer: Linux 5.4.39-1-MANJARO xhci-hcd
[    4.192461] usb usb11: SerialNumber: 0000:4c:00.0
[    4.192523] hub 11-0:1.0: USB hub found
[    4.192529] hub 11-0:1.0: 2 ports detected
[    4.192618] xhci_hcd 0000:4c:00.0: xHCI Host Controller
[    4.192619] xhci_hcd 0000:4c:00.0: new USB bus registered, assigned bus number 12
[    4.192621] xhci_hcd 0000:4c:00.0: Host supports USB 3.0 SuperSpeed
[    4.195717] usb usb12: We don't know the algorithms for LPM for this host, disabling LPM. <-- this
4 times
okay tried that but no change.
$ dmesg
... output cropped
[   16.553940] xhci_hcd 0000:4d:00.0: Abort failed to stop command ring: -110
[   16.553947] xhci_hcd 0000:4d:00.0: xHCI host controller not responding, assume dead
[   16.553950] xhci_hcd 0000:4d:00.0: HC died; cleaning up
[   16.553957] xhci_hcd 0000:4d:00.0: WARNING: Host System Error
[   16.553965] xhci_hcd 0000:4d:00.0: Error while assigning device slot ID
[   16.553967] xhci_hcd 0000:4d:00.0: Max number of devices this xHCI host supports is 32.
[   16.553970] usb usb14-port1: couldn't allocate usb_device
[   21.553990] xhci_hcd 0000:4c:00.0: Abort failed to stop command ring: -110
[   21.553996] xhci_hcd 0000:4c:00.0: xHCI host controller not responding, assume dead
[   21.553999] xhci_hcd 0000:4c:00.0: HC died; cleaning up
[   21.554008] xhci_hcd 0000:4c:00.0: WARNING: Host System Error
[   21.554011] xhci_hcd 0000:4c:00.0: Error while assigning device slot ID
[   21.554014] xhci_hcd 0000:4c:00.0: Max number of devices this xHCI host supports is 32.
[   21.554015] usb usb12-port1: couldn't allocate usb_device
[   21.577214] PM: Image not found (code -22)
[   26.554071] xhci_hcd 0000:4f:00.0: Abort failed to stop command ring: -110
[   26.554077] xhci_hcd 0000:4f:00.0: xHCI host controller not responding, assume dead
[   26.554080] xhci_hcd 0000:4f:00.0: HC died; cleaning up
[   26.554090] xhci_hcd 0000:4f:00.0: WARNING: Host System Error
[   26.554092] xhci_hcd 0000:4f:00.0: Error while assigning device slot ID
[   26.554094] xhci_hcd 0000:4f:00.0: Max number of devices this xHCI host supports is 32.
[   26.554095] usb usb18-port1: couldn't allocate usb_device
[   31.554108] xhci_hcd 0000:4e:00.0: Abort failed to stop command ring: -110
[   31.554114] xhci_hcd 0000:4e:00.0: xHCI host controller not responding, assume dead
[   31.554117] xhci_hcd 0000:4e:00.0: HC died; cleaning up
[   31.554122] xhci_hcd 0000:4e:00.0: WARNING: Host System Error
[   31.554128] xhci_hcd 0000:4e:00.0: Error while assigning device slot ID
[   31.554130] xhci_hcd 0000:4e:00.0: Max number of devices this xHCI host supports is 32.
[   31.554131] usb usb16-port1: couldn't allocate usb_device
so try
"iommu=soft"
same result, same dmesg errors
you have reached the max number usb device
--> bug report for threadripper & additional PCI - USB3 card
oh, so this is likely to be unfixable, I have to give up and file a bug report?
you cannot use your pci card at this time
okay, thank you for your help!
