Sudoers setting not working
Just did a fresh install of manjaro i3 minimal 20.0.3
this is the groups my username belongs to
groups $USERNAME
wheel lp sys network power autologin vijay
this is the line i uncommented in sudoers
## Same thing without a password
 %wheel ALL=(ALL) NOPASSWD: ALL
i even tried using my username instead of group name
$USERNAME ALL=(ALL) NOPASSWD: ALL
but its still asking me for password for any sudo command.
sudo nano
[sudo] password for $USERNAME:
i didn't change anything in the system other than installing firefox and removing palemoon. I even tried rebooting. Just removing the # used to work in arch, do i need to do something else?
For some unknown reason (in the past, anyway) Manjaro put an override in.
Look in /etc/sudoers.d/ I'll bet you'll find a file that has:
%wheel ALL=(ALL) ALL
Delete that file, and you'll be good to go.
It worked like a charm. Thanks a lot.
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
