Surface Pro 3 loses network connection randomly
Installed Manjaro on a Surface Pro 3 and it loses wifi connection randomly. Have already put the router on channel 48 locked.
When it loses connection I cannot reconnect, it does not find a network anymore. Reboot seems the only thing that works but after a while it loses connection again.
 inxi --full --verbosity=7 --filter --no-host
  Kernel: 5.6.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: Gnome 3.36.2 wm: gnome-shell dm: GDM 3.34.1 Distro: Manjaro Linux
  Type: Laptop System: Microsoft product: Surface Pro 4
  v: D:0B:08F:1C:03P:38 serial: <filter> Chassis: type: 9 serial: <filter>
  Mobo: Microsoft model: Surface Pro 4 serial: <filter> UEFI: Microsoft
  v: 108.2706.768 date: 04/18/2019
  ID-1: BAT1 charge: 18.4 Wh condition: 31.5/38.2 Wh (82%) volts: 7.5/7.5
  model: SMP X910527 type: Li-ion serial: <filter> status: Discharging
  cycles: 298
  RAM: total: 7.70 GiB used: 2.30 GiB (29.8%)
  RAM Report:
  Topology: Dual Core model: Intel Core i5-6300U bits: 64 type: MT MCP
  arch: Skylake rev: 3 L2 cache: 3072 KiB bogomips: 20004
  Speed: 600 MHz min/max: 400/3000 MHz Core speeds (MHz): 1: 600 2: 600
  3: 600 4: 600
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
  art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp
  hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
  pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep
  smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Microsoft
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:1916
  Display: x11 server: X.org 1.20.8 driver: i915 compositor: gnome-shell
  resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.0.6
  direct render: Yes
  Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
  Unit
  driver: ipu3-imgu bus ID: 00:05.0 chip ID: 8086:1919
  Device-2: Intel driver: ipu3-cio2 bus ID: 00:14.3 chip ID: 8086:9d32
  Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
  bus ID: 00:1f.3 chip ID: 8086:9d70
  Sound Server: ALSA v: k5.6.12-1-MANJARO
  Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless driver: mwifiex_pcie
  v: 1.0 port: 3000 bus ID: 02:00.0 chip ID: 11ab:2b38
  Device-2: Marvell Bluetooth and Wireless LAN Composite Device type: USB
  driver: btusb bus ID: 1-5:3 chip ID: 1286:204c serial: <filter>
  Local Storage: total: 238.47 GiB used: 61.11 GiB (25.6%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZFLV256HCHP-000MV
  size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: BXV75M0Q
  scheme: GPT
  ID-1: / size: 38.87 GiB used: 19.63 GiB (50.5%) fs: ext4
  dev: /dev/nvme0n1p5 label: N/A uuid: 1bd3cf9d-7ad8-422c-977c-f542aaed055a
  ID-2: /boot/efi size: 256.0 MiB used: 32.9 MiB (12.9%) fs: vfat
  dev: /dev/nvme0n1p1 label: SYSTEM uuid: 2213-6205
  ID-3: /mnt/DEA024B4A0249555 size: 70.09 GiB used: 41.45 GiB (59.1%)
  fs: ntfs dev: /dev/nvme0n1p4 label: N/A uuid: DEA024B4A0249555
  ID-4: /var/lib/snapd/snap/core/9066 raw size: 93.9 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop3
  label: N/A uuid: N/A
  ID-5: /var/lib/snapd/snap/core18/1754 raw size: 54.9 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop2
  ID-6: /var/lib/snapd/snap/gtk-common-themes/1506 raw size: 62.1 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop0
  ID-7: /var/lib/snapd/snap/mailspring/468 raw size: 193.0 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop1
  ID-1: /dev/nvme0n1p2 size: 128.0 MiB fs: <root required> label: N/A
  uuid: N/A
  ID-2: /dev/nvme0n1p3 size: 89.20 GiB fs: ntfs label: Windows
  uuid: B6C6F47EC6F43FE3
  Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  speed: 480 Mb/s chip ID: 1d6b:0002
  Device-1: 1-5:3 info: Marvell Bluetooth and Wireless LAN Composite Device
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 480 Mb/s
  Device-2: 1-7:2 info: Microsoft Surface Type Cover type: HID
  driver: hid-multitouch,usbhid interfaces: 2 rev: 2.1 speed: 12 Mb/s
  chip ID: 045e:07e4
  Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  chip ID: 1d6b:0003
  System Temperatures: cpu: 31.0 C mobo: 0.0 C
  Processes: 230 Uptime: 13m Init: systemd v: 245 Compilers: gcc: N/A
  Shell: bash v: 5.0.16 running in: gnome-terminal inxi: 3.0.37
I could not get
dmesg | grep eth
dmesg: read kernel buffer failed: Operation not permitted
[d0zer@surface-manjaro ~]$ sudo dmesg | grep eth
[sudo] password for d0zer:
[    0.000000] microcode: microcode updated early to revision 0xd6, date = 2019-10-03
[    0.000000] Linux version 5.6.12-1-MANJARO (builder@c0eb6fb44348) (gcc version 9.3.0 (Arch Linux 9.3.0-1)) #1 SMP PREEMPT Sun May 10 14:36:43 UTC 2020
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64 root=UUID=1bd3cf9d-7ad8-422c-977c-f542aaed055a rw quiet apparmor=1 security=apparmor udev.log_priority=3
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Hygon HygonGenuine
[    0.000000]   Centaur CentaurHauls
[    0.000000]   zhaoxin   Shanghai
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000008aa08fff] usable
[    0.000000] BIOS-e820: [mem 0x000000008aa09000-0x000000008aa09fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000008aa0a000-0x000000008aa0afff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008aa0b000-0x000000008bdb0fff] usable
[    0.000000] BIOS-e820: [mem 0x000000008bdb1000-0x000000008be2bfff] type 20
[    0.000000] BIOS-e820: [mem 0x000000008be2c000-0x000000008be9efff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008be9f000-0x000000008bec4fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000008bec5000-0x000000008befefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000008beff000-0x000000008befffff] usable
[    0.000000] BIOS-e820: [mem 0x000000008bf00000-0x000000008f7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000026f7fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.70 by MSFT
[    0.000000] efi:  ACPI=0x8befe000  ACPI 2.0=0x8befe014  TPMFinalLog=0x8bebc000  SMBIOS=0x8be36000  SMBIOS 3.0=0x8be34000  MEMATTR=0x88f6e018  ESRT=0x8be37698
[    0.000000] SMBIOS 3.1.1 present.
[    0.000000] DMI: Microsoft Corporation Surface Pro 4/Surface Pro 4, BIOS 108.2706.768 04/18/2019
[    0.000000] tsc: Detected 2500.000 MHz processor
[    0.001835] tsc: Detected 2499.952 MHz TSC
[    0.001835] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.001837] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.001843] last_pfn = 0x26f800 max_arch_pfn = 0x400000000
[    0.001851] MTRR default type: write-back
[    0.001852] MTRR fixed ranges enabled:
[    0.001853]   00000-9FFFF write-back
[    0.001854]   A0000-BFFFF uncachable
[    0.001855]   C0000-FFFFF write-protect
[    0.001855] MTRR variable ranges enabled:
[    0.001857]   0 base 00C0000000 mask 7FC0000000 uncachable
[    0.001858]   1 base 00A0000000 mask 7FE0000000 uncachable
[    0.001859]   2 base 0090000000 mask 7FF0000000 uncachable
[    0.001860]   3 base 008E000000 mask 7FFE000000 uncachable
[    0.001860]   4 base 008D000000 mask 7FFF000000 uncachable
[    0.001861]   5 disabled
[    0.001862]   6 disabled
[    0.001862]   7 disabled
[    0.001863]   8 disabled
[    0.001863]   9 disabled
[    0.002432] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.002702] last_pfn = 0x8bf00 max_arch_pfn = 0x400000000
[    0.017896] esrt: Reserving ESRT space from 0x000000008be37698 to 0x000000008be37798.
[    0.017917] check: Scanning 1 areas for low memory corruption
[    0.017921] Using GB pages for direct mapping
[    0.017923] BRK [0x169401000, 0x169401fff] PGTABLE
[    0.017925] BRK [0x169402000, 0x169402fff] PGTABLE
[    0.017926] BRK [0x169403000, 0x169403fff] PGTABLE
[    0.017968] BRK [0x169404000, 0x169404fff] PGTABLE
[    0.017970] BRK [0x169405000, 0x169405fff] PGTABLE
[    0.018185] BRK [0x169406000, 0x169406fff] PGTABLE
[    0.018237] BRK [0x169407000, 0x169407fff] PGTABLE
[    0.018401] BRK [0x169408000, 0x169408fff] PGTABLE
[    0.018461] BRK [0x169409000, 0x169409fff] PGTABLE
[    0.018550] Secure boot could not be determined
[    0.018551] RAMDISK: [mem 0x3691b000-0x37484fff]
[    0.018564] ACPI: Early table checksum verification disabled
[    0.018567] ACPI: RSDP 0x000000008BEFE014 000024 (v02 MSFT  )
[    0.018570] ACPI: XSDT 0x000000008BEFD0E8 0000B4 (v01 MSFT   MSFT     00000000 MSFT 0000005F)
[    0.018575] ACPI: FACP 0x000000008BEF4000 00010C (v05 MSFT   MSFT     00000000 MSFT 0000005F)
[    0.018581] ACPI: DSDT 0x000000008BED8000 01764F (v02 MSFT   MSFT     00000000 INTL 20160422)
[    0.018584] ACPI: FACS 0x000000008BEA5000 000040
[    0.018588] ACPI: BBRT 0x000000008BEFC000 00002C (v01 MSFT   MSFT     00000002 MSFT 0000005F)
[    0.018594] ACPI: SSDT 0x000000008BEFB000 000577 (v02 MSFT   Tpm2Tabl 00001000 INTL 20160422)
[    0.018597] ACPI: TPM2 0x000000008BEFA000 000034 (v03 MSFT   MSFT     00000002 MSFT 0000005F)
[    0.018599] ACPI: MSDM 0x000000008BEF9000 000055 (v01 MSFT            00000001 MSFT 00000001)
[    0.018602] ACPI: SSDT 0x000000008BEF5000 00312B (v02 SaSsdt SaSsdt   00003000 INTL 20160422)
[    0.018605] ACPI: HPET 0x000000008BEF3000 000038 (v01 MSFT   MSFT     00000001 MSFT 0000005F)
[    0.018608] ACPI: APIC 0x000000008BEF2000 00012C (v03 MSFT   MSFT     00000001 MSFT 0000005F)
[    0.018611] ACPI: MCFG 0x000000008BEF1000 00003C (v01 MSFT   MSFT     00000001 MSFT 0000005F)
[    0.018614] ACPI: LPIT 0x000000008BEF0000 000094 (v01 MSFT   MSFT     00000000 MSFT 0000005F)
[    0.018616] ACPI: SSDT 0x000000008BED5000 00260B (v02 MSFT   RTD3APNV 00001000 INTL 20160422)
[    0.018619] ACPI: SSDT 0x000000008BED4000 0008CD (v02 MSFT   xh_ap000 00000000 INTL 20160422)
[    0.018622] ACPI: SSDT 0x000000008BED2000 0017AE (v02 CpuRef CpuSsdt  00003000 INTL 20160422)
[    0.018625] ACPI: DMAR 0x000000008BED1000 000138 (v01 MSFT   MSFT     00000001 INTL 00000001)
[    0.018627] ACPI: NHLT 0x000000008BED0000 00002D (v00 MSFT   MSFT     00000002 MSFT 0000005F)
[    0.018630] ACPI: FPDT 0x000000008BECF000 000034 (v01 MSFT   MSFT     00000002 MSFT 0000005F)
[    0.018633] ACPI: BGRT 0x000000008BECE000 000038 (v01 MSFT   MSFT     00000002 MSFT 0000005F)
[    0.018635] ACPI: WSMT 0x000000008BECD000 000028 (v01 MSFT   MSFT     00000002 MSFT 0000005F)
[    0.018644] ACPI: Local APIC address 0xfee00000
[    0.018841] No NUMA configuration found
[    0.018842] Faking a node at [mem 0x0000000000000000-0x000000026f7fffff]
[    0.018846] NODE_DATA(0) allocated [mem 0x26f7fc000-0x26f7fffff]
[    0.018869] Zone ranges:
[    0.018870]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.018872]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.018873]   Normal   [mem 0x0000000100000000-0x000000026f7fffff]
[    0.018874]   Device   empty
[    0.018875] Movable zone start for each node
[    0.018875] Early memory node ranges
[    0.018876]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.018877]   node   0: [mem 0x0000000000059000-0x000000000009dfff]
[    0.018878]   node   0: [mem 0x0000000000100000-0x000000008aa08fff]
[    0.018879]   node   0: [mem 0x000000008aa0b000-0x000000008bdb0fff]
[    0.018879]   node   0: [mem 0x000000008beff000-0x000000008befffff]
[    0.018880]   node   0: [mem 0x0000000100000000-0x000000026f7fffff]
[    0.019088] Zeroed struct page in unavailable ranges: 19124 pages
[    0.019090] Initmem setup node 0 [mem 0x0000000000001000-0x000000026f7fffff]
[    0.019091] On node 0 totalpages: 2078028
[    0.019092]   DMA zone: 64 pages used for memmap
[    0.019093]   DMA zone: 23 pages reserved
[    0.019094]   DMA zone: 3996 pages, LIFO batch:0
[    0.019161]   DMA32 zone: 8887 pages used for memmap
[    0.019161]   DMA32 zone: 568752 pages, LIFO batch:63
[    0.027892]   Normal zone: 23520 pages used for memmap
[    0.027893]   Normal zone: 1505280 pages, LIFO batch:63
[    0.049880] Reserving Intel graphics memory at [mem 0x8d800000-0x8f7fffff]
[    0.050390] ACPI: PM-Timer IO Port: 0x1808
[    0.050392] ACPI: Local APIC address 0xfee00000
[    0.050398] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.050399] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.050399] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.050400] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.050400] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.050401] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.050402] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.050402] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.050403] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.050404] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.050404] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.050405] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.050405] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.050406] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.050407] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.050407] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.050434] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.050437] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.050438] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.050439] ACPI: IRQ0 used by override.
[    0.050440] ACPI: IRQ9 used by override.
[    0.050442] Using ACPI (MADT) for SMP configuration information
[    0.050444] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.050451] e820: update [mem 0x88f21000-0x88f53fff] usable ==> reserved
[    0.050459] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.050475] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.050477] PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.050478] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x000fffff]
[    0.050480] PM: hibernation: Registered nosave memory: [mem 0x88f21000-0x88f53fff]
[    0.050481] PM: hibernation: Registered nosave memory: [mem 0x8aa09000-0x8aa09fff]
[    0.050482] PM: hibernation: Registered nosave memory: [mem 0x8aa0a000-0x8aa0afff]
[    0.050483] PM: hibernation: Registered nosave memory: [mem 0x8bdb1000-0x8be2bfff]
[    0.050484] PM: hibernation: Registered nosave memory: [mem 0x8be2c000-0x8be9efff]
[    0.050485] PM: hibernation: Registered nosave memory: [mem 0x8be9f000-0x8bec4fff]
[    0.050485] PM: hibernation: Registered nosave memory: [mem 0x8bec5000-0x8befefff]
[    0.050487] PM: hibernation: Registered nosave memory: [mem 0x8bf00000-0x8f7fffff]
[    0.050487] PM: hibernation: Registered nosave memory: [mem 0x8f800000-0xdfffffff]
[    0.050488] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.050488] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfe00ffff]
[    0.050489] PM: hibernation: Registered nosave memory: [mem 0xfe010000-0xfe010fff]
[    0.050489] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xffffffff]
[    0.050491] [mem 0x8f800000-0xdfffffff] available for PCI devices
[    0.050492] Booting paravirtualized kernel on bare hardware
[    0.050495] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.055472] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[    0.055618] percpu: Embedded 57 pages/cpu s196608 r8192 d28672 u524288
[    0.055625] pcpu-alloc: s196608 r8192 d28672 u524288 alloc=1*2097152
[    0.055625] pcpu-alloc: [0] 0 1 2 3
[    0.055644] Built 1 zonelists, mobility grouping on.  Total pages: 2045534
[    0.055645] Policy zone: Normal
[    0.055646] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64 root=UUID=1bd3cf9d-7ad8-422c-977c-f542aaed055a rw quiet apparmor=1 security=apparmor udev.log_priority=3
[    0.056173] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.056380] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.056431] mem auto-init: stack:byref_all, heap alloc:on, heap free:off
[    0.077272] Memory: 7998044K/8312112K available (12291K kernel code, 1464K rwdata, 4568K rodata, 1628K init, 3204K bss, 314068K reserved, 0K cma-reserved)
[    0.077280] random: get_random_u64 called from __kmem_cache_create+0x3e/0x520 with crng_init=0
[    0.077394] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.077406] Kernel/User page tables isolation: enabled
[    0.077420] ftrace: allocating 40232 entries in 158 pages
[    0.094399] ftrace: allocated 158 pages with 5 groups
[    0.094498] rcu: Preemptible hierarchical RCU implementation.
[    0.094499] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.094500] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[    0.094501] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.094501] 	Tasks RCU enabled.
[    0.094502] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.094503] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.097400] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[    0.097783] Console: colour dummy device 80x25
[    0.097787] printk: console [tty0] enabled
[    0.097803] ACPI: Core revision 20200110
[    0.098077] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.098154] APIC: Switch to symmetric I/O mode setup
[    0.098156] DMAR: Host address width 39
[    0.098157] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.098163] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 7e3ff0505e
[    0.098164] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.098168] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.098169] DMAR: RMRR base: 0x0000003e2e0000 end: 0x0000003e2fffff
[    0.098171] DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x000000003e2e0000-0x000000003e2fffff], contact BIOS vendor for fixes
[    0.098172] DMAR: [Firmware Bug]: Your BIOS is broken; bad RMRR [0x000000003e2e0000-0x000000003e2fffff]
               BIOS vendor: Microsoft Corporation; Ver: 108.2706.768; Product Version: D:0B:08F:1C:03P:38
[    0.098173] DMAR: RMRR base: 0x0000008d000000 end: 0x0000008f7fffff
[    0.098174] DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
[    0.098175] DMAR: ANDD device: 2 name: \_SB.PCI0.I2C1
[    0.098175] DMAR: ANDD device: 3 name: \_SB.PCI0.I2C2
[    0.098176] DMAR: ANDD device: 4 name: \_SB.PCI0.I2C3
[    0.098177] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.098178] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.098179] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.099737] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.099739] x2apic enabled
[    0.099753] Switched APIC routing to cluster x2apic.
[    0.103818] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.118092] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x24090c9bc00, max_idle_ns: 440795288559 ns
[    0.118097] Calibrating delay loop (skipped), value calculated using timer frequency.. 5001.23 BogoMIPS (lpj=8333173)
[    0.118099] pid_max: default: 32768 minimum: 301
[    0.121015] LSM: Security Framework initializing
[    0.121022] Yama: becoming mindful.
[    0.121042] AppArmor: AppArmor initialized
[    0.121065] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.121077] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.121088] *** VALIDATE tmpfs ***
[    0.121236] *** VALIDATE proc ***
[    0.121278] *** VALIDATE cgroup ***
[    0.121279] *** VALIDATE cgroup2 ***
[    0.121329] mce: CPU0: Thermal monitoring enabled (TM1)
[    0.121348] process: using mwait in idle threads
[    0.121353] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.121354] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.121357] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.121359] Spectre V2 : Mitigation: Full generic retpoline
[    0.121359] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.121360] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.121361] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.121362] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.121363] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.121366] TAA: Mitigation: Clear CPU buffers
[    0.121367] MDS: Mitigation: Clear CPU buffers
[    0.121729] Freeing SMP alternatives memory: 32K
[    0.123183] TSC deadline timer enabled
[    0.123190] smpboot: CPU0: Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz (family: 0x6, model: 0x4e, stepping: 0x3)
[    0.141464] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.141494] ... version:                4
[    0.141498] ... bit width:              48
[    0.141500] ... generic registers:      4
[    0.141505] ... value mask:             0000ffffffffffff
[    0.141508] ... max period:             00007fffffffffff
[    0.141511] ... fixed-purpose events:   3
[    0.141514] ... event mask:             000000070000000f
[    0.148110] rcu: Hierarchical SRCU implementation.
[    0.171625] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.178123] smp: Bringing up secondary CPUs ...
[    0.218167] x86: Booting SMP configuration:
[    0.218172] .... node  #0, CPUs:      #1 #2
[    0.258638] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.258638] TAA CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/tsx_async_abort.html for more details.
[    0.298178]  #3
[    0.298594] smp: Brought up 1 node, 4 CPUs
[    0.298594] smpboot: Max logical packages: 1
[    0.298594] smpboot: Total of 4 processors activated (20007.93 BogoMIPS)
[    0.299920] devtmpfs: initialized
[    0.299920] x86/mm: Memory block size: 128MB
[    0.301468] PM: Registering ACPI NVS region [mem 0x8aa09000-0x8aa09fff] (4096 bytes)
[    0.301469] PM: Registering ACPI NVS region [mem 0x8be9f000-0x8bec4fff] (155648 bytes)
[    0.301570] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.301570] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.301570] pinctrl core: initialized pinctrl subsystem
[    0.301665] PM: RTC time: 08:43:44, date: 2020-05-20
[    0.301670] thermal_sys: Registered thermal governor 'fair_share'
[    0.301670] thermal_sys: Registered thermal governor 'bang_bang'
[    0.301671] thermal_sys: Registered thermal governor 'step_wise'
[    0.301672] thermal_sys: Registered thermal governor 'user_space'
[    0.301672] thermal_sys: Registered thermal governor 'power_allocator'
[    0.301740] NET: Registered protocol family 16
[    0.301740] audit: initializing netlink subsys (disabled)
[    0.301740] audit: type=2000 audit(1589964224.203:1): state=initialized audit_enabled=0 res=1
[    0.301740] cpuidle: using governor ladder
[    0.301740] cpuidle: using governor menu
[    0.301740] ACPI: bus type PCI registered
[    0.301740] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.301740] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.301740] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.301740] PCI: Using configuration type 1 for base access
[    0.301981] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.302710] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.302710] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.304872] ACPI: Added _OSI(Module Device)
[    0.304873] ACPI: Added _OSI(Processor Device)
[    0.304874] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.304875] ACPI: Added _OSI(Processor Aggregator Device)
[    0.304876] ACPI: Added _OSI(Linux-Dell-Video)
[    0.304877] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.304878] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.340469] ACPI: 6 ACPI AML tables successfully acquired and loaded
[    0.343541] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.347331] ACPI: Dynamic OEM Table Load:
[    0.347346] ACPI: SSDT 0xFFFF99A1E5E4A000 000672 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.349080] ACPI: \_PR_.PR00: _OSC native thermal LVT Acked
[    0.350213] ACPI: Dynamic OEM Table Load:
[    0.350219] ACPI: SSDT 0xFFFF99A1E5832800 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.351856] ACPI: Dynamic OEM Table Load:
[    0.351860] ACPI: SSDT 0xFFFF99A1E5ACF600 0000BA (v02 PmRef  Cpu0Hwp  00003000 INTL 20160422)
[    0.353390] ACPI: Dynamic OEM Table Load:
[    0.353395] ACPI: SSDT 0xFFFF99A1E5E4E800 000628 (v02 PmRef  HwpLvt   00003000 INTL 20160422)
[    0.355410] ACPI: Dynamic OEM Table Load:
[    0.355419] ACPI: SSDT 0xFFFF99A1E5E9B000 000D14 (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.357924] ACPI: Dynamic OEM Table Load:
[    0.357930] ACPI: SSDT 0xFFFF99A1E5830800 000317 (v02 PmRef  ApHwp    00003000 INTL 20160422)
[    0.359609] ACPI: Dynamic OEM Table Load:
[    0.359614] ACPI: SSDT 0xFFFF99A1E5831C00 00030A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.362739] ACPI: EC: EC started
[    0.362740] ACPI: EC: interrupt blocked
[    0.365833] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.365834] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    0.365835] ACPI: Interpreter enabled
[    0.365885] ACPI: (supports S0 S4 S5)
[    0.365886] ACPI: Using IOAPIC for interrupt routing
[    0.365933] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.366612] ACPI: Enabled 11 GPEs in block 00 to 7F
[    0.376182] ACPI: Power Resource [PX01] (on)
[    0.376283] ACPI: Power Resource [PX02] (on)
[    0.376372] ACPI: Power Resource [PX03] (on)
[    0.376459] ACPI: Power Resource [PX04] (on)
[    0.376545] ACPI: Power Resource [PX05] (on)
[    0.376632] ACPI: Power Resource [PX06] (on)
[    0.376721] ACPI: Power Resource [PX07] (on)
[    0.378816] ACPI: Power Resource [USBC] (on)
[    0.379050] ACPI: Power Resource [PAUD] (on)
[    0.381539] ACPI: Power Resource [PXP] (off)
[    0.384271] ACPI: Power Resource [PXP] (off)
[    0.384562] ACPI: Power Resource [PRWF] (on)
[    0.394882] ACPI: Power Resource [CAMP] (on)
[    0.401373] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.401379] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.404777] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[    0.407379] PCI host bridge to bus 0000:00
[    0.407381] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.407382] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.407384] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.407385] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[    0.407386] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[    0.407387] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[    0.407388] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[    0.407389] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.407390] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.407391] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.407392] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.407393] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    0.407394] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    0.407396] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[    0.407397] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[    0.407398] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[    0.407399] pci_bus 0000:00: root bus resource [mem 0x8f800000-0xdfffffff window]
[    0.407400] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.407401] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.407413] pci 0000:00:00.0: [8086:1904] type 00 class 0x060000
[    0.408401] pci 0000:00:02.0: [8086:1916] type 00 class 0x030000
[    0.408413] pci 0000:00:02.0: reg 0x10: [mem 0xa0000000-0xa0ffffff 64bit]
[    0.408419] pci 0000:00:02.0: reg 0x18: [mem 0x90000000-0x9fffffff 64bit pref]
[    0.408423] pci 0000:00:02.0: reg 0x20: [io  0x4000-0x403f]
[    0.408439] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.409456] pci 0000:00:05.0: [8086:1919] type 00 class 0x048000
[    0.409468] pci 0000:00:05.0: reg 0x10: [mem 0xa1000000-0xa13fffff 64bit]
[    0.410466] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[    0.410478] pci 0000:00:08.0: reg 0x10: [mem 0xa1738000-0xa1738fff 64bit]
[    0.411479] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
[    0.411501] pci 0000:00:14.0: reg 0x10: [mem 0xa1700000-0xa170ffff 64bit]
[    0.411572] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.412650] pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000
[    0.412675] pci 0000:00:14.2: reg 0x10: [mem 0xa1739000-0xa1739fff 64bit]
[    0.413722] pci 0000:00:14.3: [8086:9d32] type 00 class 0x048000
[    0.413836] pci 0000:00:14.3: reg 0x10: [mem 0xa1710000-0xa171ffff 64bit]
[    0.415240] pci 0000:00:15.0: [8086:9d60] type 00 class 0x118000
[    0.415503] pci 0000:00:15.0: reg 0x10: [mem 0xa173a000-0xa173afff 64bit]
[    0.417417] pci 0000:00:15.1: [8086:9d61] type 00 class 0x118000
[    0.417680] pci 0000:00:15.1: reg 0x10: [mem 0xa173b000-0xa173bfff 64bit]
[    0.419592] pci 0000:00:15.2: [8086:9d62] type 00 class 0x118000
[    0.419856] pci 0000:00:15.2: reg 0x10: [mem 0xa173c000-0xa173cfff 64bit]
[    0.421770] pci 0000:00:15.3: [8086:9d63] type 00 class 0x118000
[    0.422033] pci 0000:00:15.3: reg 0x10: [mem 0xa173d000-0xa173dfff 64bit]
[    0.423874] pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000
[    0.423903] pci 0000:00:16.0: reg 0x10: [mem 0xa173e000-0xa173efff 64bit]
[    0.423982] pci 0000:00:16.0: PME# supported from D3hot
[    0.425017] pci 0000:00:16.4: [8086:9d3e] type 00 class 0x078000
[    0.425047] pci 0000:00:16.4: reg 0x10: [mem 0xa173f000-0xa173ffff 64bit]
[    0.425125] pci 0000:00:16.4: PME# supported from D3hot
[    0.426102] pci 0000:00:1c.0: [8086:9d14] type 01 class 0x060400
[    0.426193] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.427284] pci 0000:00:1d.0: [8086:9d18] type 01 class 0x060400
[    0.427375] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.428469] pci 0000:00:1f.0: [8086:9d48] type 00 class 0x060100
[    0.429578] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
[    0.429595] pci 0000:00:1f.2: reg 0x10: [mem 0xa1734000-0xa1737fff]
[    0.430630] pci 0000:00:1f.3: [8086:9d70] type 00 class 0x040380
[    0.430657] pci 0000:00:1f.3: reg 0x10: [mem 0xa1730000-0xa1733fff 64bit]
[    0.430683] pci 0000:00:1f.3: reg 0x20: [mem 0xa1720000-0xa172ffff 64bit]
[    0.430734] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.431940] pci 0000:01:00.0: [144d:a802] type 00 class 0x010802
[    0.431970] pci 0000:01:00.0: reg 0x10: [mem 0xa1600000-0xa1603fff 64bit]
[    0.431979] pci 0000:01:00.0: reg 0x18: [io  0x3000-0x30ff]
[    0.432137] pci 0000:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8 GT/s x2 link at 0000:00:1c.0 (capable of 31.504 Gb/s with 8 GT/s x4 link)
[    0.432223] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.432226] pci 0000:00:1c.0:   bridge window [io  0x3000-0x3fff]
[    0.432229] pci 0000:00:1c.0:   bridge window [mem 0xa1600000-0xa16fffff]
[    0.432375] pci 0000:02:00.0: [11ab:2b38] type 00 class 0x020000
[    0.432420] pci 0000:02:00.0: reg 0x10: [mem 0xa1500000-0xa15fffff 64bit pref]
[    0.432438] pci 0000:02:00.0: reg 0x18: [mem 0xa1400000-0xa14fffff 64bit pref]
[    0.432582] pci 0000:02:00.0: supports D1 D2
[    0.432583] pci 0000:02:00.0: PME# supported from D0 D1 D3hot D3cold
[    0.432876] pci 0000:00:1d.0: PCI bridge to [bus 02]
[    0.432883] pci 0000:00:1d.0:   bridge window [mem 0xa1400000-0xa15fffff 64bit pref]
[    0.438726] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.438726] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.438770] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.438849] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.438929] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.439007] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.439085] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.439170] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.448098] ACPI Warning: GPE type mismatch (level/edge) (20200110/evxface-791)
[    0.448098] ACPI: EC: interrupt unblocked
[    0.448098] ACPI: EC: event unblocked
[    0.448098] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.448098] ACPI: EC: GPE=0x50
[    0.448098] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions and events
[    0.448098] iommu: Default domain type: Translated
[    0.448101] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.448103] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.448107] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.448108] vgaarb: loaded
[    0.448287] SCSI subsystem initialized
[    0.448550] libata version 3.00 loaded.
[    0.448555] ACPI: bus type USB registered
[    0.448566] usbcore: registered new interface driver usbfs
[    0.448571] usbcore: registered new interface driver hub
[    0.448587] usbcore: registered new device driver usb
[    0.448613] pps_core: LinuxPPS API ver. 1 registered
[    0.448613] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.448615] PTP clock support registered
[    0.448621] EDAC MC: Ver: 3.0.0
[    0.448776] Registered efivars operations
[    0.451449] PCI: Using ACPI for IRQ routing
[    0.484772] PCI: pci_cache_line_size set to 64 bytes
[    0.485196] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.485197] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.485198] e820: reserve RAM buffer [mem 0x88f21000-0x8bffffff]
[    0.485200] e820: reserve RAM buffer [mem 0x8aa09000-0x8bffffff]
[    0.485201] e820: reserve RAM buffer [mem 0x8bdb1000-0x8bffffff]
[    0.485202] e820: reserve RAM buffer [mem 0x8bf00000-0x8bffffff]
[    0.485203] e820: reserve RAM buffer [mem 0x26f800000-0x26fffffff]
[    0.485318] NetLabel: Initializing
[    0.485319] NetLabel:  domain hash size = 128
[    0.485319] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.485331] NetLabel:  unlabeled traffic allowed by default
[    0.485403] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.485407] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.488339] clocksource: Switched to clocksource tsc-early
[    0.502692] *** VALIDATE bpf ***
[    0.502793] VFS: Disk quotas dquot_6.6.0
[    0.502808] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.502841] *** VALIDATE ramfs ***
[    0.502845] *** VALIDATE hugetlbfs ***
[    0.502967] AppArmor: AppArmor Filesystem Enabled
[    0.503005] pnp: PnP ACPI init
[    0.503359] system 00:00: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.503361] system 00:00: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.503363] system 00:00: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.503364] system 00:00: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.503366] system 00:00: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.503367] system 00:00: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.503368] system 00:00: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.503373] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.529168] system 00:01: [io  0x2000-0x20fe] has been reserved
[    0.529172] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.542570] system 00:02: [io  0x0680-0x069f] has been reserved
[    0.542572] system 00:02: [io  0xffff] has been reserved
[    0.542573] system 00:02: [io  0xffff] has been reserved
[    0.542574] system 00:02: [io  0xffff] has been reserved
[    0.542576] system 00:02: [io  0x1800-0x18fe] has been reserved
[    0.542577] system 00:02: [io  0x164e-0x164f] has been reserved
[    0.542581] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.546874] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.546920] system 00:04: [io  0x1854-0x1857] has been reserved
[    0.546924] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.558977] random: fast init done
[    0.632945] system 00:05: [mem 0xfe020000-0xfe021fff] has been reserved
[    0.632946] system 00:05: [mem 0xfe022000-0xfe023fff] has been reserved
[    0.632948] system 00:05: [mem 0xfe024000-0xfe025fff] has been reserved
[    0.632949] system 00:05: [mem 0xfe026000-0xfe027fff] has been reserved
[    0.632951] system 00:05: [mem 0xfe028000-0xfe029fff] has been reserved
[    0.632952] system 00:05: [mem 0xfe02a000-0xfe02bfff] has been reserved
[    0.632953] system 00:05: [mem 0xfe02c000-0xfe02dfff] has been reserved
[    0.632955] system 00:05: [mem 0xfe02e000-0xfe02ffff] has been reserved
[    0.632956] system 00:05: [mem 0xfe030000-0xfe031fff] has been reserved
[    0.632957] system 00:05: [mem 0xfe032000-0xfe033fff] has been reserved
[    0.632959] system 00:05: [mem 0xfe034000-0xfe035fff] has been reserved
[    0.632963] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.674919] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.674921] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.674922] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.674923] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[    0.674925] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.674926] system 00:06: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.674927] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.674929] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    0.674930] system 00:06: [mem 0xfee00000-0xfeefffff] has been reserved
[    0.674931] system 00:06: [mem 0x8f800000-0x8f81ffff] has been reserved
[    0.674935] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.694912] pnp: PnP ACPI: found 7 devices
[    0.700993] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.701037] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.701041] pci 0000:00:1c.0:   bridge window [io  0x3000-0x3fff]
[    0.701050] pci 0000:00:1c.0:   bridge window [mem 0xa1600000-0xa16fffff]
[    0.701066] pci 0000:00:1d.0: PCI bridge to [bus 02]
[    0.701081] pci 0000:00:1d.0:   bridge window [mem 0xa1400000-0xa15fffff 64bit pref]
[    0.701101] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.701102] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.701104] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.701105] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    0.701107] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    0.701108] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    0.701110] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[    0.701111] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[    0.701112] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[    0.701114] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[    0.701115] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[    0.701117] pci_bus 0000:00: resource 15 [mem 0x000e0000-0x000e3fff window]
[    0.701118] pci_bus 0000:00: resource 16 [mem 0x000e4000-0x000e7fff window]
[    0.701119] pci_bus 0000:00: resource 17 [mem 0x000e8000-0x000ebfff window]
[    0.701121] pci_bus 0000:00: resource 18 [mem 0x000ec000-0x000effff window]
[    0.701122] pci_bus 0000:00: resource 19 [mem 0x000f0000-0x000fffff window]
[    0.701124] pci_bus 0000:00: resource 20 [mem 0x8f800000-0xdfffffff window]
[    0.701125] pci_bus 0000:00: resource 21 [mem 0xfd000000-0xfe7fffff window]
[    0.701127] pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
[    0.701128] pci_bus 0000:01: resource 1 [mem 0xa1600000-0xa16fffff]
[    0.701130] pci_bus 0000:02: resource 2 [mem 0xa1400000-0xa15fffff 64bit pref]
[    0.701320] NET: Registered protocol family 2
[    0.701623] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.701671] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.701842] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.701965] TCP: Hash tables configured (established 65536 bind 65536)
[    0.702018] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.702054] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.702150] NET: Registered protocol family 1
[    0.702154] NET: Registered protocol family 44
[    0.702167] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.702840] PCI: CLS 0 bytes, default 64
[    0.702887] Trying to unpack rootfs image as initramfs...
[    0.845867] Freeing initrd memory: 11688K
[    0.845907] DMAR: ACPI device "device:72" under DMAR at fed91000 as 00:15.0
[    0.845910] DMAR: ACPI device "device:73" under DMAR at fed91000 as 00:15.1
[    0.845913] DMAR: ACPI device "device:74" under DMAR at fed91000 as 00:15.2
[    0.845915] DMAR: ACPI device "device:75" under DMAR at fed91000 as 00:15.3
[    0.868164] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.868172] software IO TLB: mapped [mem 0x84931000-0x88931000] (64MB)
[    0.868372] check: Scanning for low memory corruption every 60 seconds
[    0.868705] Initialise system trusted keyrings
[    0.868714] Key type blacklist registered
[    0.868759] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[    0.869974] zbud: loaded
[    0.874869] Key type asymmetric registered
[    0.874870] Asymmetric key parser 'x509' registered
[    0.874880] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.874919] io scheduler mq-deadline registered
[    0.874920] io scheduler kyber registered
[    0.874948] io scheduler bfq registered
[    0.875412] pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
[    0.875659] pcieport 0000:00:1d.0: PME: Signaling with IRQ 123
[    0.875759] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.875845] efifb: probing for efifb
[    0.875863] efifb: showing boot graphics
[    0.877354] efifb: framebuffer at 0x90000000, using 19520k, total 19520k
[    0.877355] efifb: mode is 2736x1824x32, linelength=10944, pages=1
[    0.877355] efifb: scrolling: redraw
[    0.877357] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.877407] fbcon: Deferring console take-over
[    0.877408] fb0: EFI VGA frame buffer device
[    0.877415] intel_idle: MWAIT substates: 0x11142120
[    0.877416] intel_idle: v0.4.1 model 0x4E
[    0.877654] intel_idle: lapic_timer_reliable_states 0xffffffff
[    0.877770] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[    0.877790] ACPI: Lid Switch [LID0]
[    0.893146] thermal LNXTHERM:00: registered as thermal_zone0
[    0.893148] ACPI: Thermal Zone [TZ00] (33 C)
[    0.906329] thermal LNXTHERM:01: registered as thermal_zone1
[    0.906330] ACPI: Thermal Zone [TZ01] (0 C)
[    0.919640] thermal LNXTHERM:02: registered as thermal_zone2
[    0.919641] ACPI: Thermal Zone [TZ02] (31 C)
[    0.931668] thermal LNXTHERM:03: registered as thermal_zone3
[    0.931669] ACPI: Thermal Zone [TZ03] (31 C)
[    0.932064] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.932634] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.932635] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    0.933177] nvme nvme0: pci function 0000:01:00.0
[    0.933238] usbcore: registered new interface driver usbserial_generic
[    0.933241] usbserial: USB Serial support registered for generic
[    0.933267] rtc_cmos 00:03: RTC can wake from S4
[    0.933777] rtc_cmos 00:03: registered as rtc0
[    0.933791] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram
[    0.933857] intel_pstate: Intel P-state driver initializing
[    0.934117] intel_pstate: HWP enabled
[    0.934194] ledtrig-cpu: registered to indicate activity on CPUs
[    0.934261] intel_pmc_core INT33A1:00:  initialized
[    0.934326] drop_monitor: Initializing network drop monitor service
[    0.934465] NET: Registered protocol family 10
[    0.941346] Segment Routing with IPv6
[    0.941369] NET: Registered protocol family 17
[    0.941602] RAS: Correctable Errors collector initialized.
[    0.941641] microcode: sig=0x406e3, pf=0x80, revision=0xd6
[    0.941684] microcode: Microcode Update Driver: v2.2.
[    0.941689] IPI shorthand broadcast: enabled
[    0.941695] sched_clock: Marking stable (941302844, 378106)->(944585493, -2904543)
[    0.941766] registered taskstats version 1
[    0.941777] Loading compiled-in X.509 certificates
[    0.945476] Loaded X.509 cert 'Build time autogenerated kernel key: c3803c29c23fac4886c43c787ceed70bbb9178ef'
[    0.945508] zswap: loaded using pool lzo/zbud
[    0.945624] Key type ._fscrypt registered
[    0.945625] Key type .fscrypt registered
[    0.945625] Key type fscrypt-provisioning registered
[    0.952069] Key type big_key registered
[    0.952073] AppArmor: AppArmor sha1 policy hashing enabled
[    0.952969] PM:   Magic number: 4:29:726
[    0.953133] rtc_cmos 00:03: setting system clock to 2020-05-20T08:43:44 UTC (1589964224)
[    1.041491] nvme nvme0: 4/0/0 default/read/poll queues
[    1.044800]  nvme0n1: p1 p2 p3 p4 p5
[    1.047874] Freeing unused decrypted memory: 2040K
[    1.048506] Freeing unused kernel image (initmem) memory: 1628K
[    1.065030] Write protecting the kernel read-only data: 20480k
[    1.066252] Freeing unused kernel image (text/rodata gap) memory: 2044K
[    1.066975] Freeing unused kernel image (rodata/data gap) memory: 1576K
[    1.128331] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.128333] x86/mm: Checking user space page tables
[    1.163206] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.163208] Run /init as init process
[    1.163209]   with arguments:
[    1.163210]     /init
[    1.163210]   with environment:
[    1.163211]     HOME=/
[    1.163211]     TERM=linux
[    1.163212]     BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64
[    1.273564] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.273571] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.274642] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
[    1.274956] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.275328] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.06
[    1.275330] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.275331] usb usb1: Product: xHCI Host Controller
[    1.275332] usb usb1: Manufacturer: Linux 5.6.12-1-MANJARO xhci-hcd
[    1.275334] usb usb1: SerialNumber: 0000:00:14.0
[    1.275559] hub 1-0:1.0: USB hub found
[    1.275578] hub 1-0:1.0: 12 ports detected
[    1.278790] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.278795] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.278800] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    1.278848] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.06
[    1.278850] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.278852] usb usb2: Product: xHCI Host Controller
[    1.278853] usb usb2: Manufacturer: Linux 5.6.12-1-MANJARO xhci-hcd
[    1.278854] usb usb2: SerialNumber: 0000:00:14.0
[    1.279133] hub 2-0:1.0: USB hub found
[    1.279144] hub 2-0:1.0: 6 ports detected
[    1.461522] EXT4-fs (nvme0n1p5): recovery complete
[    1.465644] EXT4-fs (nvme0n1p5): mounted filesystem with ordered data mode. Opts: (null)
[    1.611471] usb 1-7: new full-speed USB device number 2 using xhci_hcd
[    1.708809] systemd[1]: systemd 245.5-2-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    1.725233] systemd[1]: Detected architecture x86-64.
[    1.753004] systemd[1]: Set hostname to <surface-manjaro>.
[    1.753370] usb 1-7: New USB device found, idVendor=045e, idProduct=07e4, bcdDevice= 2.07
[    1.753373] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.753376] usb 1-7: Product: Surface Type Cover
[    1.753377] usb 1-7: Manufacturer: Microsoft
[    1.884949] tsc: Refined TSC clocksource calibration: 2496.004 MHz
[    1.884965] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x23fa7af7c80, max_idle_ns: 440795241955 ns
[    1.885003] clocksource: Switched to clocksource tsc
[    2.030057] systemd[1]: Created slice system-getty.slice.
[    2.030253] systemd[1]: Created slice system-modprobe.slice.
[    2.030418] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    2.030645] systemd[1]: Created slice User and Session Slice.
[    2.030698] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    2.030735] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.030882] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    2.030903] systemd[1]: Reached target Local Encrypted Volumes.
[    2.030909] systemd[1]: Reached target Login Prompts.
[    2.030924] systemd[1]: Reached target Slices.
[    2.030934] systemd[1]: Reached target Swap.
[    2.030991] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    2.031078] systemd[1]: Listening on LVM2 metadata daemon socket.
[    2.031137] systemd[1]: Listening on LVM2 poll daemon socket.
[    2.032484] systemd[1]: Listening on Process Core Dump Socket.
[    2.032527] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    2.032665] systemd[1]: Listening on Journal Audit Socket.
[    2.032741] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.032826] systemd[1]: Listening on Journal Socket.
[    2.032906] systemd[1]: Listening on udev Control Socket.
[    2.032956] systemd[1]: Listening on udev Kernel Socket.
[    2.033698] systemd[1]: Mounting Huge Pages File System...
[    2.034571] systemd[1]: Mounting POSIX Message Queue File System...
[    2.035540] systemd[1]: Mounting Kernel Debug File System...
[    2.036771] systemd[1]: Mounting Kernel Trace File System...
[    2.038490] systemd[1]: Mounting Temporary Directory (/tmp)...
[    2.039839] systemd[1]: Starting Load AppArmor profiles...
[    2.041020] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    2.042011] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    2.043137] systemd[1]: Starting Load Kernel Module drm...
[    2.045887] systemd[1]: Starting Set Up Additional Binary Formats...
[    2.045931] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    2.047154] systemd[1]: Starting Journal Service...
[    2.051630] systemd[1]: Starting Load Kernel Modules...
[    2.053142] systemd[1]: Starting Remount Root and Kernel File Systems...
[    2.055006] systemd[1]: Starting udev Coldplug all Devices...
[    2.058240] systemd[1]: Mounted Huge Pages File System.
[    2.058774] systemd[1]: Mounted POSIX Message Queue File System.
[    2.058938] systemd[1]: Mounted Kernel Debug File System.
[    2.059174] systemd[1]: Mounted Kernel Trace File System.
[    2.059313] systemd[1]: Mounted Temporary Directory (/tmp).
[    2.060371] Linux agpgart interface v0.103
[    2.061428] random: lvm: uninitialized urandom read (4 bytes read)
[    2.064152] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    2.065344] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 263 (systemd-binfmt)
[    2.068515] EXT4-fs (nvme0n1p5): re-mounted. Opts: (null)
[    2.070169] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[    2.071454] systemd[1]: Started LVM2 metadata daemon.
[    2.073476] systemd[1]: Finished Remount Root and Kernel File Systems.
[    2.073657] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[    2.088429] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    2.089509] systemd[1]: Starting Load/Save Random Seed...
[    2.089563] systemd[1]: Condition check resulted in Create System Users being skipped.
[    2.090874] systemd[1]: Starting Create Static Device Nodes in /dev...
[    2.092683] systemd[1]: Finished Load Kernel Modules.
[    2.092908] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[    2.093161] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    2.094256] systemd[1]: Mounting Kernel Configuration File System...
[    2.095983] systemd[1]: Starting Apply Kernel Variables...
[    2.098438] systemd[1]: Mounted Kernel Configuration File System.
[    2.101353] systemd[1]: Finished Set Up Additional Binary Formats.
[    2.113325] systemd[1]: Finished Apply Kernel Variables.
[    2.119593] systemd[1]: Starting CLI Netfilter Manager...
[    2.119967] systemd[1]: modprobe@drm.service: Succeeded.
[    2.120448] systemd[1]: Finished Load Kernel Module drm.
[    2.121241] systemd[1]: Finished Create Static Device Nodes in /dev.
[    2.122910] systemd[1]: Starting udev Kernel Device Manager...
[    2.144302] systemd[1]: Finished CLI Netfilter Manager.
[    2.175133] systemd[1]: Finished udev Coldplug all Devices.
[    2.306914] audit: type=1400 audit(1589964225.848:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=309 comm="apparmor_parser"
[    2.490758] systemd[1]: Started Journal Service.
[    2.490840] audit: type=1130 audit(1589964226.031:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.500173] systemd-journald[264]: Received client request to flush runtime journal.
[    2.547589] audit: type=1400 audit(1589964226.088:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="mysqld_akonadi" pid=316 comm="apparmor_parser"
[    2.594731] audit: type=1130 audit(1589964226.135:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.625437] audit: type=1130 audit(1589964226.168:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.641388] audit: type=1400 audit(1589964226.178:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=325 comm="apparmor_parser"
[    2.643111] audit: type=1400 audit(1589964226.185:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=325 comm="apparmor_parser"
[    2.857751] audit: type=1400 audit(1589964226.398:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="postgresql_akonadi" pid=356 comm="apparmor_parser"
[    2.889454] ACPI: AC Adapter [ADP1] (off-line)
[    2.897107] input: Surface Pro 3/4 Buttons as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19/PNP0C09:00/MSHW0040:00/input/input1
[    2.897137] surface_pro3_button MSHW0040:00: Surface Pro 3/4 Buttons [VGBI]
[    2.902166] tpm_tis IFX0562:00: 2.0 TPM (device-id 0x1A, rev-id 16)
[    2.989356] battery: ACPI: Battery Slot [BAT1] (battery present)
[    3.100263] random: mktemp: uninitialized urandom read (6 bytes read)
[    3.118310] random: tlp-readconfs: uninitialized urandom read (4 bytes read)
[    3.118386] random: tlp-readconfs: uninitialized urandom read (4 bytes read)
[    3.139066] mc: Linux media interface: v0.10
[    3.154826] hid: raw HID events driver (C) Jiri Kosina
[    3.160204] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    3.160541] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    3.184534] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    3.185267] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    3.200059] intel-lpss 0000:00:15.2: enabling device (0000 -> 0002)
[    3.200391] idma64 idma64.2: Found Intel integrated DMA 64-bit
[    3.220888] intel-lpss 0000:00:15.3: enabling device (0000 -> 0002)
[    3.221239] idma64 idma64.3: Found Intel integrated DMA 64-bit
[    3.229956] i2c_hid i2c-MSHW0030:00: i2c-MSHW0030:00 supply vdd not found, using dummy regulator
[    3.229977] i2c_hid i2c-MSHW0030:00: i2c-MSHW0030:00 supply vddl not found, using dummy regulator
[    3.251447] random: crng init done
[    3.263924] videodev: Linux video capture interface: v2.00
[    3.268420] audit: type=1130 audit(1589964226.811:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.279083] mei_me 0000:00:16.0: enabling device (0004 -> 0006)
[    3.425665] ipu3_imgu: module is from the staging directory, the quality is unknown, you have been warned.
[    3.431027] input: PC Speaker as /devices/platform/pcspkr/input/input2
[    3.443176] ipu3-cio2 0000:00:14.3: enabling device (0000 -> 0002)
[    3.443388] ipu3-cio2 0000:00:14.3: device 0x9d32 (rev: 0x1)
[    3.444072] ipu3-imgu 0000:00:05.0: enabling device (0000 -> 0002)
[    3.444258] ipu3-imgu 0000:00:05.0: device 0x1919 (rev: 0x1)
[    3.444275] ipu3-imgu 0000:00:05.0: physical base address 0x00000000a1000000, 4194304 bytes
[    3.444396] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[    3.444398] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    3.444398] RAPL PMU: hw unit of domain package 2^-14 Joules
[    3.444399] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    3.444400] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    3.444401] RAPL PMU: hw unit of domain psys 2^-14 Joules
[    3.507836] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.549949] ipu3-imgu 0000:00:05.0: loaded firmware version irci_irci_ecr-master_20161208_0213_20170112_1500, 17 binaries, 1212984 bytes
[    3.550351] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.684285] fuse: init (API version 7.31)
[    3.684317] *** VALIDATE fuseblk ***
[    3.684321] *** VALIDATE fuse ***
[    3.706622] cryptd: max_cpu_qlen set to 1000
[    3.731735] loop: module loaded
[    3.738560] AVX2 version of gcm_enc/dec engaged.
[    3.738561] AES CTR mode by8 optimization enabled
[    3.848249] hid-generic 0018:045E:0915.0001: hidraw0: I2C HID v1.00 Device [MSHW0030:00 045E:0915] on i2c-MSHW0030:00
[    3.881647] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    3.904192] mwifiex_pcie 0000:02:00.0: enabling device (0000 -> 0002)
[    3.904417] mwifiex_pcie: PCI memory map Virt0: 00000000525bca7a PCI memory map Virt2: 000000001766aa2c
[    3.988283] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[    3.988299] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    4.361040] checking generic (90000000 1310000) vs hw (a0000000 1000000)
[    4.361042] checking generic (90000000 1310000) vs hw (90000000 10000000)
[    4.361044] fb0: switching to inteldrmfb from EFI VGA
[    4.378895] i915 0000:00:02.0: vgaarb: deactivate vga console
[    4.454786] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.454788] [drm] Driver supports precise vblank timestamp query.
[    4.458960] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    4.460820] [drm] Finished loading DMC firmware i915/skl_dmc_ver1_27.bin (v1.27)
[    4.505518] [drm] Initialized i915 1.6.0 20200114 for 0000:00:02.0 on minor 0
[    4.509510] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    4.510142] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
[    4.543595] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    4.613749] fbcon: i915drmfb (fb0) is primary device
[    4.613750] fbcon: Deferring console take-over
[    4.613754] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[    4.730905] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC298: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    4.730908] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    4.730911] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    4.730915] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    4.730917] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    4.730919] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x18
[    4.730921] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    4.865291] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input4
[    4.865532] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input5
[    4.865839] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input6
[    4.866074] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input7
[    4.866300] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[    4.866534] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
[    4.866763] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[    5.016646] intel_rapl_common: Found RAPL domain package
[    5.016649] intel_rapl_common: Found RAPL domain core
[    5.016651] intel_rapl_common: Found RAPL domain uncore
[    5.016652] intel_rapl_common: Found RAPL domain dram
[    5.225126] mwifiex_pcie 0000:02:00.0: info: FW download over, size 723540 bytes
[    5.311785] kauditd_printk_skb: 23 callbacks suppressed
[    5.311788] audit: type=1130 audit(1589964228.855:33): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=linux-module-cleanup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.311959] audit: type=1131 audit(1589964228.855:34): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=linux-module-cleanup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.348241] input: Microsoft Surface Type Cover Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input11
[    5.364451] audit: type=1130 audit(1589964228.905:35): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.378123] audit: type=1334 audit(1589964228.918:36): prog-id=9 op=LOAD
[    5.378350] audit: type=1334 audit(1589964228.921:37): prog-id=10 op=LOAD
[    5.404959] input: Microsoft Surface Type Cover Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input12
[    5.405097] input: Microsoft Surface Type Cover Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input13
[    5.405197] input: Microsoft Surface Type Cover as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input14
[    5.405299] input: Microsoft Surface Type Cover Touchpad as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input15
[    5.405395] input: Microsoft Surface Type Cover as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input16
[    5.405490] input: Microsoft Surface Type Cover as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input17
[    5.405585] input: Microsoft Surface Type Cover as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input18
[    5.405790] hid-generic 0003:045E:07E4.0002: input,hiddev0,hidraw0: USB HID v1.11 Keyboard [Microsoft Surface Type Cover] on usb-0000:00:14.0-7/input0
[    5.405837] usbcore: registered new interface driver usbhid
[    5.405838] usbhid: USB HID core driver
[    5.454117] audit: type=1130 audit(1589964228.995:38): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.519851] audit: type=1130 audit(1589964229.061:39): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.597338] audit: type=1130 audit(1589964229.138:40): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.619859] input: Microsoft Surface Type Cover Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input20
[    5.674924] input: Microsoft Surface Type Cover Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input21
[    5.675032] input: Microsoft Surface Type Cover Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input22
[    5.675113] input: Microsoft Surface Type Cover UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input23
[    5.675190] input: Microsoft Surface Type Cover Touchpad as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input24
[    5.675265] input: Microsoft Surface Type Cover UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input25
[    5.675335] input: Microsoft Surface Type Cover UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input26
[    5.675419] input: Microsoft Surface Type Cover UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:045E:07E4.0002/input/input27
[    5.675550] hid-multitouch 0003:045E:07E4.0002: input,hiddev0,hidraw0: USB HID v1.11 Keyboard [Microsoft Surface Type Cover] on usb-0000:00:14.0-7/input0
[    5.692853] mousedev: PS/2 mouse device common for all mice
[    5.948556] audit: type=1130 audit(1589964229.491:41): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.958128] usb 1-5: new high-speed USB device number 3 using xhci_hcd
[    5.998750] audit: type=1130 audit(1589964229.541:42): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.033813] fbcon: Taking over console
[    6.056152] Console: switching to colour frame buffer device 171x57
[    6.100705] usb 1-5: New USB device found, idVendor=1286, idProduct=204c, bcdDevice=32.01
[    6.100708] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.100711] usb 1-5: Product: Bluetooth and Wireless LAN Composite Device
[    6.100713] usb 1-5: Manufacturer: Marvell
[    6.100715] usb 1-5: SerialNumber: 0000000000000000
[    6.191539] mwifiex_pcie 0000:02:00.0: WLAN FW is active
[    6.248511] mwifiex_pcie 0000:02:00.0: Unknown api_id: 4
[    6.277368] mwifiex_pcie 0000:02:00.0: info: MWIFIEX VERSION: mwifiex 1.0 (15.68.19.p21)
[    6.277372] mwifiex_pcie 0000:02:00.0: driver_version = mwifiex 1.0 (15.68.19.p21)
[    6.284514] mwifiex_pcie 0000:02:00.0 wlp2s0: renamed from mlan0
[    6.978763] [drm] Reducing the compressed framebuffer size. This may lead to less power savings than a non-reduced-size. Try to increase stolen memory size if available in BIOS.
[    6.978945] Bluetooth: Core ver 2.22
[    6.978982] NET: Registered protocol family 31
[    6.978984] Bluetooth: HCI device and connection manager initialized
[    6.978990] Bluetooth: HCI socket layer initialized
[    6.978994] Bluetooth: L2CAP socket layer initialized
[    6.979001] Bluetooth: SCO socket layer initialized
[    7.019868] usbcore: registered new interface driver btusb
[    7.022965] Bluetooth: hci0: unexpected event for opcode 0x0000
[    7.025929] Bluetooth: hci0: unexpected event for opcode 0x0000
[    7.100748] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.100753] Bluetooth: BNEP filters: protocol multicast
[    7.100761] Bluetooth: BNEP socket layer initialized
[    7.214181] NET: Registered protocol family 38
[   10.326379] rfkill: input handler disabled
[   10.455333] kauditd_printk_skb: 29 callbacks suppressed
[   10.455336] audit: type=1130 audit(1589964233.998:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   10.570793] Bluetooth: RFCOMM TTY layer initialized
[   10.570800] Bluetooth: RFCOMM socket layer initialized
[   10.570807] Bluetooth: RFCOMM ver 1.11
[   10.705163] audit: type=1130 audit(1589964234.248:73): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   12.054076] audit: type=1131 audit(1589964235.595:74): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   12.818554] mwifiex_pcie 0000:02:00.0: info: trying to associate to 'Crab' bssid 74:d0:2b:1a:85:c8
[   12.847392] mwifiex_pcie 0000:02:00.0: info: associated to bssid 74:d0:2b:1a:85:c8 successfully
[   12.866601] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[   16.009541] audit: type=1131 audit(1589964239.551:75): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   16.184888] audit: type=1130 audit(1589964239.725:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=nmb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   16.392106] audit: type=1100 audit(1589964239.935:77): pid=1179 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="d0zer" exe="/usr/lib/gdm-session-worker" hostname=surface-manjaro addr=? terminal=/dev/tty1 res=success'
[   16.402724] audit: type=1101 audit(1589964239.945:78): pid=1179 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="d0zer" exe="/usr/lib/gdm-session-worker" hostname=surface-manjaro addr=? terminal=/dev/tty1 res=success'
[   16.407004] audit: type=1103 audit(1589964239.948:79): pid=1179 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="d0zer" exe="/usr/lib/gdm-session-worker" hostname=surface-manjaro addr=? terminal=/dev/tty1 res=success'
[   16.428293] audit: type=1006 audit(1589964239.971:80): pid=1179 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[   16.434210] audit: type=1130 audit(1589964239.971:81): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=smb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   16.490099] audit: type=1130 audit(1589964240.031:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   16.500882] audit: type=1101 audit(1589964240.041:83): pid=1191 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="d0zer" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   16.500913] audit: type=1103 audit(1589964240.041:84): pid=1191 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="d0zer" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[   17.031650] rfkill: input handler enabled
[   20.969559] rfkill: input handler disabled
[   32.112822] kauditd_printk_skb: 13 callbacks suppressed
[   32.112829] audit: type=1111 audit(1589964255.655:98): pid=747 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=bfe6af8d-2526-452b-b655-6648117222c2 name="CookingLobster" pid=1438 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[   32.184633] audit: type=1130 audit(1589964255.725:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   32.454568] mwifiex_pcie 0000:02:00.0: info: successfully disconnected from 74:d0:2b:1a:85:c8: reason code 3
[   38.199458] mwifiex_pcie 0000:02:00.0: info: trying to associate to 'CookingLobster' bssid e4:f4:c6:00:00:04
[   38.243553] mwifiex_pcie 0000:02:00.0: invalid AID value 0x0; bits 15:14 not set
[   38.243560] mwifiex_pcie 0000:02:00.0: ASSOC_RESP: failed,	status code=12 err=0x1011 a_id=0x0
[   38.243564] mwifiex_pcie 0000:02:00.0: assoc failure: reason Unknown connect failure
[   38.243674] mwifiex_pcie 0000:02:00.0: info: association to bssid e4:f4:c6:00:00:04 failed
[   41.011678] audit: type=1131 audit(1589964264.555:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   41.401339] mwifiex_pcie 0000:02:00.0: info: trying to associate to 'CookingLobster' bssid e4:f4:c6:00:00:04
[   41.442578] mwifiex_pcie 0000:02:00.0: invalid AID value 0x0; bits 15:14 not set
[   41.442590] mwifiex_pcie 0000:02:00.0: ASSOC_RESP: failed,	status code=12 err=0x1011 a_id=0x0
[   41.442596] mwifiex_pcie 0000:02:00.0: assoc failure: reason Unknown connect failure
[   41.442660] mwifiex_pcie 0000:02:00.0: info: association to bssid e4:f4:c6:00:00:04 failed
[   42.010617] audit: type=1131 audit(1589964265.551:101): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   45.011224] mwifiex_pcie 0000:02:00.0: info: trying to associate to 'CookingLobster' bssid e4:f4:c6:00:00:04
[   45.054257] mwifiex_pcie 0000:02:00.0: invalid AID value 0x0; bits 15:14 not set
[   45.054265] mwifiex_pcie 0000:02:00.0: ASSOC_RESP: failed,	status code=12 err=0x1011 a_id=0x0
[   45.054268] mwifiex_pcie 0000:02:00.0: assoc failure: reason Unknown connect failure
[   45.054383] mwifiex_pcie 0000:02:00.0: info: association to bssid e4:f4:c6:00:00:04 failed
[   49.066421] mwifiex_pcie 0000:02:00.0: info: trying to associate to 'CookingLobster' bssid e4:f4:c6:00:00:04
[   49.106222] mwifiex_pcie 0000:02:00.0: invalid AID value 0x0; bits 15:14 not set
[   49.106228] mwifiex_pcie 0000:02:00.0: ASSOC_RESP: failed,	status code=12 err=0x1011 a_id=0x0
[   49.106230] mwifiex_pcie 0000:02:00.0: assoc failure: reason Unknown connect failure
[   49.106250] mwifiex_pcie 0000:02:00.0: info: association to bssid e4:f4:c6:00:00:04 failed
[   51.090086] audit: type=1131 audit(1589964274.631:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   51.135005] audit: type=1334 audit(1589964274.678:103): prog-id=10 op=UNLOAD
[   51.135023] audit: type=1334 audit(1589964274.678:104): prog-id=9 op=UNLOAD
[   51.288065] audit: type=1131 audit(1589964274.828:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   51.338264] audit: type=1334 audit(1589964274.881:106): prog-id=13 op=UNLOAD
[   51.338270] audit: type=1334 audit(1589964274.881:107): prog-id=12 op=UNLOAD
[   59.119464] mwifiex_pcie 0000:02:00.0: info: trying to associate to 'CookingLobster' bssid e4:f4:c6:00:00:04
[   60.157864] mwifiex_pcie 0000:02:00.0: ASSOC_RESP: failed,	status code=2 err=0xfffc a_id=0x3fff
[   60.157873] mwifiex_pcie 0000:02:00.0: assoc failure: reason CONNECT_ERR_ASSOC_ERR_TIMEOUT
[   60.157878] mwifiex_pcie 0000:02:00.0: ASSOC_RESP: AUTH timeout
[   60.157937] mwifiex_pcie 0000:02:00.0: info: association to bssid e4:f4:c6:00:00:04 failed
[   66.157144] mwifiex_pcie 0000:02:00.0: info: trying to associate to 'CookingLobster' bssid e4:f4:c6:00:00:04
[   66.222207] mwifiex_pcie 0000:02:00.0: invalid AID value 0x0; bits 15:14 not set
[   66.222219] mwifiex_pcie 0000:02:00.0: ASSOC_RESP: failed,	status code=12 err=0x1011 a_id=0x0
[   66.222225] mwifiex_pcie 0000:02:00.0: assoc failure: reason Unknown connect failure
[   66.222360] mwifiex_pcie 0000:02:00.0: info: association to bssid e4:f4:c6:00:00:04 failed
[   70.018422] audit: type=1131 audit(1589964293.561:108): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   79.304640] mwifiex_pcie 0000:02:00.0: info: trying to associate to 'CookingLobster' bssid e4:f4:c6:00:00:04
[   79.344851] mwifiex_pcie 0000:02:00.0: invalid AID value 0x0; bits 15:14 not set
[   79.344862] mwifiex_pcie 0000:02:00.0: ASSOC_RESP: failed,	status code=12 err=0x1011 a_id=0x0
[   79.344867] mwifiex_pcie 0000:02:00.0: assoc failure: reason Unknown connect failure
[   79.344927] mwifiex_pcie 0000:02:00.0: info: association to bssid e4:f4:c6:00:00:04 failed
[   85.037512] audit: type=1130 audit(1589964308.578:109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   85.048040] audit: type=1111 audit(1589964308.588:110): pid=747 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=radio-control arg="wireless-enabled" pid=1438 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[   90.048873] audit: type=1131 audit(1589964313.591:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   90.226550] audit: type=1111 audit(1589964313.768:112): pid=747 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=radio-control arg="wireless-enabled" pid=1864 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[   90.270414] audit: type=1130 audit(1589964313.811:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   93.071284] audit: type=1111 audit(1589964316.611:114): pid=747 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=radio-control arg="wwan-enabled" pid=1607 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[   94.606798] audit: type=1111 audit(1589964318.148:115): pid=747 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=radio-control arg="wwan-enabled" pid=1607 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[   94.727373] debugfs: File 'force_bredr_smp' in directory 'hci0' already present!
[   99.569685] audit: type=1131 audit(1589964323.111:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  101.130683] mwifiex_pcie 0000:02:00.0: info: trying to associate to 'Crab' bssid 74:d0:2b:1a:85:c8
[  101.162565] mwifiex_pcie 0000:02:00.0: info: associated to bssid 74:d0:2b:1a:85:c8 successfully
[  101.183957] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[  103.326016] audit: type=1130 audit(1589964326.868:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  114.015616] audit: type=1131 audit(1589964337.558:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  212.848380] audit: type=1334 audit(1589964436.740:119): prog-id=17 op=LOAD
[  212.848694] audit: type=1334 audit(1589964436.740:120): prog-id=18 op=LOAD
[  213.794043] audit: type=1130 audit(1589964437.686:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  214.494617] audit: type=1400 audit(1589964438.386:122): apparmor="DENIED" operation="open" profile="mysqld_akonadi" name="/sys/block/" pid=2664 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[  237.668481] audit: type=1334 audit(1589964461.569:123): prog-id=19 op=LOAD
[  237.668549] audit: type=1334 audit(1589964461.569:124): prog-id=20 op=LOAD
[  238.334468] audit: type=1130 audit(1589964462.236:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  243.819176] audit: type=1131 audit(1589964467.722:126): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  243.839522] audit: type=1334 audit(1589964467.742:127): prog-id=18 op=UNLOAD
[  243.839540] audit: type=1334 audit(1589964467.742:128): prog-id=17 op=UNLOAD
[  268.378330] audit: type=1131 audit(1589964492.290:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  268.412726] audit: type=1334 audit(1589964492.327:130): prog-id=20 op=UNLOAD
[  268.412745] audit: type=1334 audit(1589964492.327:131): prog-id=19 op=UNLOAD
[  905.281745] audit: type=1130 audit(1589965129.205:132): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  905.281793] audit: type=1131 audit(1589965129.205:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  927.714245] audit: type=1130 audit(1589965151.639:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  930.398235] audit: type=1100 audit(1589965154.322:135): pid=3625 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="d0zer" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  930.398949] audit: type=1101 audit(1589965154.322:136): pid=3625 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="d0zer" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  930.399829] audit: type=1110 audit(1589965154.322:137): pid=3625 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  930.408939] audit: type=1105 audit(1589965154.332:138): pid=3625 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  930.440095] audit: type=1106 audit(1589965154.362:139): pid=3625 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  930.440433] audit: type=1104 audit(1589965154.366:140): pid=3625 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  934.499638] audit: type=1101 audit(1589965158.422:141): pid=3633 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="d0zer" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  934.499961] audit: type=1110 audit(1589965158.422:142): pid=3633 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  934.504167] audit: type=1105 audit(1589965158.429:143): pid=3633 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  934.517306] audit: type=1106 audit(1589965158.442:144): pid=3633 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  934.517477] audit: type=1104 audit(1589965158.442:145): pid=3633 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  945.298945] audit: type=1101 audit(1589965169.223:146): pid=3636 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="d0zer" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  945.299621] audit: type=1110 audit(1589965169.223:147): pid=3636 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  945.312030] audit: type=1105 audit(1589965169.236:148): pid=3636 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[d0zer@surface-manjaro ~]$
journalctl
-- Logs begin at Fri 2020-05-01 20:32:10 CEST, end at Wed 2020-05-20 11:30:12 C>
mei 01 20:32:10 surface-manjaro kernel: microcode: microcode updated early to r>
mei 01 20:32:10 surface-manjaro kernel: Linux version 5.6.7-1-MANJARO (builder@>
mei 01 20:32:10 surface-manjaro kernel: Command line: BOOT_IMAGE=/boot/vmlinuz->
mei 01 20:32:10 surface-manjaro kernel: KERNEL supported cpus:
mei 01 20:32:10 surface-manjaro kernel:   Intel GenuineIntel
mei 01 20:32:10 surface-manjaro kernel:   AMD AuthenticAMD
mei 01 20:32:10 surface-manjaro kernel:   Hygon HygonGenuine
mei 01 20:32:10 surface-manjaro kernel:   Centaur CentaurHauls
mei 01 20:32:10 surface-manjaro kernel:   zhaoxin   Shanghai
mei 01 20:32:10 surface-manjaro kernel: x86/fpu: Supporting XSAVE feature 0x001>
mei 01 20:32:10 surface-manjaro kernel: x86/fpu: Supporting XSAVE feature 0x002>
mei 01 20:32:10 surface-manjaro kernel: x86/fpu: Supporting XSAVE feature 0x004>
mei 01 20:32:10 surface-manjaro kernel: x86/fpu: Supporting XSAVE feature 0x008>
mei 01 20:32:10 surface-manjaro kernel: x86/fpu: Supporting XSAVE feature 0x010>
mei 01 20:32:10 surface-manjaro kernel: x86/fpu: xstate_offset[2]:  576, xstate>
mei 01 20:32:10 surface-manjaro kernel: x86/fpu: xstate_offset[3]:  832, xstate>
mei 01 20:32:10 surface-manjaro kernel: x86/fpu: xstate_offset[4]:  896, xstate>
mei 01 20:32:10 surface-manjaro kernel: x86/fpu: Enabled xstate features 0x1f, >
mei 01 20:32:10 surface-manjaro kernel: BIOS-provided physical RAM map:
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x0000000000000000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x0000000000058000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x0000000000059000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x000000000009e000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x0000000000100000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x000000008aa09000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x000000008aa0a000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x000000008aa0b000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x000000008bdb1000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x000000008be2c000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x000000008be9f000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x000000008bec5000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x000000008beff000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x000000008bf00000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x00000000e0000000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x00000000fe010000-0x00>
mei 01 20:32:10 surface-manjaro kernel: BIOS-e820: [mem 0x0000000100000000-0x00>
mei 01 20:32:10 surface-manjaro kernel: NX (Execute Disable) protection: active
mei 01 20:32:10 surface-manjaro kernel: efi: EFI v2.70 by MSFT
mei 01 20:32:10 surface-manjaro kernel: efi:  ACPI=0x8befe000  ACPI 2.0=0x8befe>
You may want to read this thread
Is there a bios update since last year?
if so, update your bios.
Have you tested alternate kernels?
If not, test 3 alternate kernels.
Some things you can try:
Disable IPv6
Disable/blacklist bluetooth/btusb
Disable Network Manager's WiFi power saving features with the following command:
 echo -e "[connection]\nwifi.powersave = 0" | sudo tee /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
As a last resort you could write a service to auto restart your downed connection.
You would need to substitute wlp2s0 for wlp3s0 and mwifiex_pcie for
rtl8723be in the script I have linked used in the service.
Thanks a lot I will try this. Sorry for the late reply!
Often Connman will be able to maintain a connection where NetworkManager loses the connection regularly. You could try switching to Connman as an alternative connection manager.
