System reboots out of nowhere
Right after seemingly solving my ZFS issue an new one hit me.
My system is rebooted when I return to it.
journalcrt
Mär 10 14:52:14 I-KNOW-YOU.torgato.de kscreenlocker_greet[19050]: couldn't lock local file
Mär 10 14:55:14 I-KNOW-YOU.torgato.de org_kde_powerdevil[3129]: powerdevil: Kbd backlight brightness value:  0
Mär 10 14:55:41 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST10000VN0004_1ZD101_ZA2246CJ org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 23168
Mär 10 14:55:41 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST3000DM001_1CH166_Z1F3QLA4 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 23171
Mär 10 14:55:41 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/WDC_WD30EFRX_68EUZN0_WD_WCC4N1354676 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 23173
Mär 10 14:59:47 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST3000DM001_1CH166_Z1F3QLA4 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 26135
Mär 10 14:59:47 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/WDC_WD30EFRX_68EUZN0_WD_WCC4N1354676 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 26136
Mär 10 15:04:38 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST3000DM001_1CH166_Z1F3QLA4 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 29823
Mär 10 15:04:38 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/WDC_WD30EFRX_68EUZN0_WD_WCC4N1354676 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 29825
Mär 10 15:04:50 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST3000DM001_1CH166_Z1F3QLA4 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 30122
Mär 10 15:04:50 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/WDC_WD30EFRX_68EUZN0_WD_WCC4N1354676 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 30124
Mär 10 15:04:56 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST10000VN0004_1ZD101_ZA2246CJ org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 30270
Mär 10 15:04:56 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST3000DM001_1CH166_Z1F3QLA4 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 30273
Mär 10 15:04:56 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/WDC_WD30EFRX_68EUZN0_WD_WCC4N1354676 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 30275
Mär 10 15:05:59 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/WDC_WD30EFRX_68EUZN0_WD_WCC4N1354676 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 31322
Mär 10 15:07:38 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST10000VN0004_1ZD101_ZA2246CJ org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 32512
Mär 10 15:07:38 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST3000DM001_1CH166_Z1F3QLA4 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 32515
Mär 10 15:07:38 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/WDC_WD30EFRX_68EUZN0_WD_WCC4N1354676 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 32517
Mär 10 15:13:56 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST10000VN0004_1ZD101_ZA2246CJ org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 5527
Mär 10 15:13:56 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST3000DM001_1CH166_Z1F3QLA4 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 5530
Mär 10 15:13:56 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/WDC_WD30EFRX_68EUZN0_WD_WCC4N1354676 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 5532
Mär 10 15:14:35 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/WDC_WD30EFRX_68EUZN0_WD_WCC4N1354676 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 5998
Mär 10 15:15:09 I-KNOW-YOU.torgato.de org_kde_powerdevil[3129]: powerdevil: Can't contact ck
Mär 10 15:15:09 I-KNOW-YOU.torgato.de org_kde_powerdevil[3129]: powerdevil: Suspend session triggered with QMap(("GraceFade", QVariant(bool, true))("Type", QVariant(uint, 32)))
Mär 10 15:15:14 I-KNOW-YOU.torgato.de org_kde_powerdevil[3129]: powerdevil: Can't contact ck
Mär 10 15:15:14 I-KNOW-YOU.torgato.de org_kde_powerdevil[3129]: powerdevil: Suspend session triggered with QMap(("SkipFade", QVariant(bool, true))("Type", QVariant(uint, 32)))
Mär 10 15:18:44 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST10000VN0004_1ZD101_ZA2246CJ org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 9054
Mär 10 15:18:44 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/ST3000DM001_1CH166_Z1F3QLA4 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 9056
Mär 10 15:18:44 I-KNOW-YOU.torgato.de plasmashell[2447]: Process "qdbus --system org.freedesktop.UDisks2 /org/freedesktop/UDisks2/drives/WDC_WD30EFRX_68EUZN0_WD_WCC4N1354676 org.freedesktop.UDisks2.Drive.Ata.SmartTemperature" already running. Pid: 9058
-- Reboot --
I have a cat and a child, so I can't be 100% sure that it was not unintentional intentional :slight_smile: But I doubt it.
Do the logs indicate what happened? or can I enable additional logs, to see what causes a reboot?
It seems to me, only a suspend is triggered and leads to reboot. I updated the latest powerdevil package and rebooted since I did.
PS: additional errors in my logs at other times that might relate to it
Mär 10 15:23:57 I-KNOW-YOU.torgato.de kernel: .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13
Mär 10 15:23:57 I-KNOW-YOU.torgato.de kernel: mce: [Hardware Error]: Machine check events logged
Mär 10 15:23:57 I-KNOW-YOU.torgato.de kernel: mce: [Hardware Error]: CPU 13: Machine Check: 0 Bank 5: bea0000000000108
Mär 10 15:23:57 I-KNOW-YOU.torgato.de kernel: mce: [Hardware Error]: TSC 0 ADDR 1ffffbb600a86 MISC d012000101000000 SYND 4d000000 IPID 500b000000000
Mär 10 15:23:57 I-KNOW-YOU.torgato.de kernel: mce: [Hardware Error]: PROCESSOR 2:800f11 TIME 1552227830 SOCKET 0 APIC d microcode 8001129
Mär 10 15:23:57 I-KNOW-YOU.torgato.de kernel: ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20180810/tbfadt-624)
Mär 10 15:23:57 I-KNOW-YOU.torgato.de kernel: sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
Mär 10 15:23:57 I-KNOW-YOU.torgato.de kernel: sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
Mär 10 15:23:57 I-KNOW-YOU.torgato.de kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
I would place my bet on the cat (mine does it 3 times a day) but someone might have another idea. What's up with that smart temp thing? Try to get your sdd temperature. I've had one system shutdown years ago because the hdd overheated but I wouldn't expect seeing something like that in 2019.
Try hddtemp
I have a plasma widget that monitors all my system temps. Mainly I installed it as my new Radeon RX580 got so damn loud while gaming and I wanted to better understand whats happening.
Screenshot_20190310_201617
I guess this is where it came from.
About the cat theory, I do not see a proper shutdown in the logs. Shouldn't it be there?
It seems you did something wrong when "solving" the other issue.
I would suggest you troubleshoot/confirm there. If it is not relevant, then post what you have found.
All I did was setting the disk io-scheduler to "none" to solve the other issue.
But in all that the powerdevil package was updated and atm I am suspecting it to cause this new problem.
Will a critical overheat reboot or shutdown the system? I believe it would shut it down.
A critical overheat will "throw" the system into a reboot. A hard reboot.
Ask me how I know :grin:
PS: at least with processor and gpu. Can't remember what happened with the hdd overheat. Was over 10 years ago.
Remove your mouse and that problem should go away. :joy:
My cat is more into "trackpads"
A good way to access temperature induced reboot was to power on the computer. It would reboot after say one minute, the next time was only like 30 seconds before reboot and subsequent reboots were shorter and shorted spaced. Clear sign that a CPU fan failed for example.
You case seems different but without a record of the shutdown process, it definitely looks like a hard reboot
considering the entries in the logs and powerdevil being a power management daemon, and that this problem started after an update of powerdevil??? seems like the place to start.
disable powerdevil and if problem is gone, then problem is powerdevil or an option of powerdevil anyway. im not familiar with powerdevil, i never used it before but it seems like a good start.
sudo systemctl disable powerdevil (just a guess)
During my previous issue I set my energy management to lock my PC after 30 minutes, so it continues to run longer.
Now I changed it back to hibernating and the issue has not happened again until now.
Throwing some random stuff out here. I had a similar situation several years ago with a desktop PC and it ended up being an underpowered PSU. I put in an aftermarket power supply and the OS ran fine after that. How much juice can your PSU give?
Collermaster 700W 80+ Gold
WOL, Wake on Lan? NAS, PVR (Receiver) ...
Is something (always connected to charge a battery (Smartphone)?
NSA, CIA, FBI, Hacker ... :smiley:
They are currently all stunned, not knowing how to act under Trump :smiley: So maybe the Danish Agency.
Perhaps related?
Well, I indeed have bluetooth issues. Sometimes my adapter is missing completely until reboot/hibernate cycle. And if I connect a certain keyboard my system crashes. So maybe.
But beside that my system is finally stable with automatic hibernating set and I am a bit tired of hunting problems, so I will tackle the bluetooth issue next time.
