The update for QT broke it pretty much, don't know how to revert to previous update, should have set up time shift
System: Kernel: 5.4.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=4f7d1f50-f7a1-4ed5-81e6-e7664001829c rw quiet apparmor=1
Desktop: KDE Plasma 5.17.4 tk: Qt 5.14.0 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 4177QKU v: ThinkPad T420 serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 4177QKU serial: <filter> UEFI: LENOVO v: 83ET82WW (1.52 ) date: 06/04/2018
Battery: ID-1: BAT0 charge: 10.7 Wh condition: 10.7/47.5 Wh (22%) volts: 11.9/10.8 model: SANYO 42T4791 type: Li-ion
serial: <filter> status: Full
CPU: Topology: Dual Core model: Intel Core i5-2410M bits: 64 type: MT MCP arch: Sandy Bridge family: 6 model-id: 2A (42)
stepping: 7 microcode: 2F L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18349
Speed: 809 MHz min/max: 800/2900 MHz Core speeds (MHz): 1: 799 2: 798 3: 815 4: 805
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:0116
Display: x11 server: X.Org 1.20.6 driver: intel unloaded: modesetting alternate: fbdev,vesa compositor: kwin_x11
resolution: 1600x900~60Hz
OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 19.3.1 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:1c20
Sound Server: ALSA v: k5.4.2-1-MANJARO
Network: Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520 driver: e1000e v: 3.2.6-k port: 5080
bus ID: 00:19.0 chip ID: 8086:1502
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Wireless-N 1000 [Condor Peak] driver: iwlwifi v: kernel port: efa0 bus ID: 03:00.0
chip ID: 8086:0084
Drives: Local Storage: total: 223.57 GiB used: 13.22 GiB (5.9%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDA240G size: 223.57 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 00RL scheme: GPT
Partition: ID-1: / raw size: 223.28 GiB size: 218.77 GiB (97.98%) used: 13.22 GiB (6.0%) fs: ext4 dev: /dev/sda2
Sensors: System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3216
Info: Processes: 206 Uptime: 3d 22h 57m Memory: 7.66 GiB used: 4.02 GiB (52.4%) Init: systemd v: 242 Compilers:
gcc: 9.2.0 Shell: bash v: 5.0.11 running in: konsole inxi: 3.0.37 ```
