Systemd window unresposive af
Howdy y'all. I have a problem with systemd window being absolutely unresposive after the window pops up. I waited for more than 30 mins to see if it would change, but nope, it's still stuck silly. Systemd then shows an afterimage of the background image (see screenshot), and i can't intreract with it at all. I'd like to solve the problem if there is a solution to this.
systemd
System info:
System:    Host: SirHonk Kernel: 5.6.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
           Desktop: KDE Plasma 5.18.5 Distro: Manjaro Linux
Machine:   Type: Laptop System: Acer product: Aspire A315-51 v: V1.03 serial: <root required>
           Mobo: SKL model: Venusaur_KL v: V1.03 serial: <root required> UEFI: Insyde v: 1.03
           date: 05/23/2017
Battery:   ID-1: BAT1 charge: 30.2 Wh condition: 30.2/37.0 Wh (82%) model: PANASONIC AP16M5J status: Full
CPU:       Topology: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake rev: 3
           L2 cache: 3072 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 16006
           Speed: 2000 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 2000 2: 2000 3: 2000 4: 2000
Graphics:  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Acer Incorporated ALI driver: i915
           v: kernel bus ID: 00:02.0
           Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.0.7 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
           v: kernel bus ID: 00:1f.3
           Sound Server: ALSA v: k5.6.16-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI
           driver: r8169 v: kernel port: 3000 bus ID: 02:00.1
           IF: enp2s0f1 state: down mac: d8:c4:97:04:45:68
           Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lite-On
           driver: ath10k_pci v: kernel port: 3000 bus ID: 03:00.0
           IF: wlp3s0 state: up mac: e8:2a:44:ba:9a:4b
Drives:    Local Storage: total: 931.51 GiB used: 120.08 GiB (12.9%)
           ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-21Z10T0 size: 931.51 GiB
Partition: ID-1: / size: 245.08 GiB used: 120.08 GiB (49.0%) fs: ext4 dev: /dev/sda8
Sensors:   System Temperatures: cpu: 43.5 C mobo: N/A
Info:      Processes: 242 Uptime: 13m Memory: 7.66 GiB used: 2.58 GiB (33.7%) Init: systemd Compilers:
           gcc: 10.1.0 clang: 10.0.0 Shell: bash v: 5.0.17 inxi: 3.0.37
You can try starting it from a terminal to see if it's spewing some errors:
$ systemsettings5 kcm_systemd
Okay that might've helped to make a lead:
kf5.ki18n: "Plural argument to message {1 unit} not supplied before conversion."
kf5.ki18n: "Plural argument to message {1 active} not supplied before conversion."
kf5.ki18n: "Plural argument to message {1 displayed} not supplied before conversion."
Refreshing system units...
This error just keeps repeating...Refreshing non-stop.
That looks to me like there is some internationalization problem. Does it come up properly if your users language is overridden?
$ LANG=C systemsettings5 kcm_systemd
No unfortunately not, the error still persists. Strange :confused:
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
