Takes time to boot up my System.
systemd-analyze
Startup finished in 6.988s (firmware) + 11.254s (loader) + 3.218s (kernel) + 28.817s (userspace) = 50.278s
graphical.target reached after 26.083s in userspace
systemd-analyze blame
9.375s polkit.service
8.426s snapd.service
7.458s lvm2-monitor.service
7.124s dev-sda2.device
4.227s avahi-daemon.service
4.180s bluetooth.service
4.160s NetworkManager.service
4.155s linux-module-cleanup.service
4.135s wpa_supplicant.service
4.127s systemd-logind.service
2.747s systemd-udevd.service
2.731s tlp.service
2.611s apparmor.service
1.927s systemd-journal-flush.service
1.234s systemd-random-seed.service
1.233s systemd-tmpfiles-setup-dev.service
1.231s systemd-backlight@backlight:intel_backlight.service
1.070s boot-efi.mount
 861ms systemd-fsck@dev-disk-by\x2duuid-9772\x2dC912.service
 844ms ModemManager.service
 804ms udisks2.service
 787ms systemd-rfkill.service
 727ms upower.service
 676ms systemd-modules-load.service
 650ms systemd-timesyncd.service
 637ms systemd-tmpfiles-setup.service
 628ms systemd-journald.service
 591ms snapd.apparmor.service
 561ms var-lib-snapd-snap-core-8935.mount
 489ms dev-loop4.device
 425ms systemd-udev-trigger.service
 411ms var-lib-snapd-snap-core18-1754.mount
 369ms var-lib-snapd-snap-core-9066.mount
 312ms systemd-sysctl.service
 208ms systemd-update-utmp.service
 207ms dev-loop2.device
 182ms rtkit-daemon.service
 182ms systemd-tmpfiles-clean.service
 163ms dev-hugepages.mount
 160ms dev-mqueue.mount
 158ms sys-kernel-debug.mount
 135ms var-lib-snapd-snap-core18-1705.mount
 129ms dev-loop3.device
 119ms tmp.mount
 113ms kmod-static-nodes.service
 112ms var-lib-snapd-snap-sublime\x2dtext-85.mount
  92ms user@1000.service
  76ms systemd-user-sessions.service
  52ms systemd-remount-fs.service
  20ms modprobe@drm.service
  16ms sys-kernel-config.mount
  13ms user-runtime-dir@1000.service
   4ms sys-fs-fuse-connections.mount
   2ms dev-loop1.device
   2ms dev-loop0.device
   1ms snapd.socket
System info
System:    Host: GrimReaper Kernel: 5.6.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: KDE Plasma 5.18.4
           Distro: Manjaro Linux
Machine:   Type: Laptop System: ASUSTeK product: P553UJ v: 1.0 serial: <filter>
           Mobo: ASUSTeK model: P553UJ v: 1.0 serial: <filter> UEFI: ASUSTeK v: P553UJ.305 date: 04/20/2019
Battery:   ID-1: BAT0 charge: 40.7 Wh condition: 57.9/72.4 Wh (80%) model: ASUSTeK ASUS Battery status: Charging
CPU:       Topology: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake rev: 3 L2 cache: 3072 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19204
           Speed: 800 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 797 2: 788 3: 796 4: 790
Graphics:  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA GK208BM [GeForce 920M] vendor: ASUSTeK driver: nouveau v: kernel bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.8 driver: intel,nouveau unloaded: modesetting resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.0.5 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1
           Sound Server: ALSA v: k5.6.7-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
           bus ID: 02:00.0
           Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: AzureWave driver: ath10k_pci v: kernel
           port: d000 bus ID: 03:00.0
Drives:    Local Storage: total: 931.51 GiB used: 78.74 GiB (8.5%)
           ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541010A7E630 size: 931.51 GiB
Partition: ID-1: / size: 915.60 GiB used: 78.74 GiB (8.6%) fs: ext4 dev: /dev/sda2
Sensors:   System Temperatures: cpu: 57.0 C mobo: N/A gpu: nouveau temp: 59 C
           Fan Speeds (RPM): cpu: 3000
Info:      Processes: 184 Uptime: 48m Memory: 7.67 GiB used: 2.40 GiB (31.3%) Init: systemd Compilers: gcc: 9.3.0 Shell: bash
           v: 5.0.16 inxi: 3.0.37
neofetch
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   shuvo@GrimReaper
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   ----------------
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   OS: Manjaro Linux x86_64
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Host: P553UJ 1.0
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ            β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Kernel: 5.6.7-1-MANJARO
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Uptime: 48 mins
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Packages: 1314 (pacman), 4 (snap)
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Shell: bash 5.0.16
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Resolution: 1366x768
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   DE: Plasma
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   WM: KWin
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   WM Theme: Sweet-Dark
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Theme: Sweet [Plasma], Breath-Dark [GTK2/3]
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Icons: Tela-dark [Plasma], Tela-dark [GTK2/3]
                               Terminal: konsole
                               Terminal Font: Source Code Pro 11
                               CPU: Intel i5-6200U (4) @ 2.800GHz
                               GPU: Intel Skylake GT2 [HD Graphics 520]
                               GPU: NVIDIA GeForce 920M
                               Memory: 1322MiB / 7856MiB
Why snapd and polkit take this much time? Is it normal? Can I disable the polkit.service? What would happen if I did?
I don't have SSD
yeah it is too much it is after reboot? Try shutdown and then start if it will be better.
~ >>> systemd-analyze blame
679ms systemd-logind.service
676ms lvm2-monitor.service
639ms tlp.service
572ms dev-sda1.device
499ms upower.service
404ms systemd-udevd.service
389ms systemd-timesyncd.service
337ms systemd-modules-load.service
320ms systemd-machined.service
290ms systemd-journald.service
280ms apparmor.service
263ms systemd-random-seed.service
182ms udisks2.service
155ms ufw.service
112ms polkit.service
 90ms user@1000.service
 87ms systemd-journal-flush.service
 72ms systemd-udev-trigger.service
 52ms NetworkManager.service
 49ms geoclue.service
 39ms ModemManager.service
 33ms accounts-daemon.service
 32ms colord.service
 23ms systemd-tmpfiles-setup.service
 20ms systemd-tmpfiles-setup-dev.service
 18ms wpa_supplicant.service
 15ms systemd-tmpfiles-clean.service
 14ms systemd-update-utmp.service
 13ms systemd-rfkill.service
 13ms gdm.service
 12ms bluetooth.service
 11ms user-runtime-dir@1000.service
 10ms linux-module-cleanup.service
  8ms systemd-sysctl.service
  8ms dev-hugepages.mount
  7ms dev-mqueue.mount
  7ms systemd-remount-fs.service
  6ms sys-kernel-debug.mount
  6ms systemd-backlight@backlight:intel_backlight.service
  5ms kmod-static-nodes.service
  5ms systemd-user-sessions.service
  4ms rtkit-daemon.service
  3ms sys-fs-fuse-connections.mount
  3ms sys-kernel-config.mount
edit
buy SSD
SSD are much faster look at lvm2 yours and mine I have standard 2,5" SSD not nvme.
It happens everytime I boot. I rebooted several time. But that doesn't help.
Yes standard 2,5" SSD worth the money.
