For me it sometimes works, sometimes not, firefox-kde here.
Not in my Gnome.
Though I just noticed I can't add a second workspace.
I toggled custom/dynamic and there was no response, like I changed nothing
Is rebooting an accepted troubleshooting method in Testing??
Ediit: That looks like a joke? or a bug.
I swithed to my second account in xfce and the background wallpaper setting cannot be set independently on 2 workspaces.
Yes I toggled the checkbox "Apply to all workspaces".. Again like it is deaf.!!
Edit-2: Changing from Compiz to xfwm4 the wallpapers could change independently, so false alarm, or a compiz problem. I remember that you could have different wallpapers with Compiz in xfce without the wallpaper plugin enabled. The xfce wallpapers can be handled by compiz if I enable the Wallpaper plugin.
Edit 3: After re-login into Gnome there is no problem with the workspaces (so far).
I am really new to Gnome. When do we need to re-login generally, or maybe restart Gnome (Alt+F2 r [Enter])?
Me niether, I am unable to change VPN connections using 1.10.0-1, downgrading to 1.8.4-1 was my workaround also.
No issues to report so far. Seems I was saved from the network issues in Plasma (fingers crossed). Currently running with 4.14.
For GNOME it's fine. Thoughts and prayers to our KDE folks for this update <3
