Known issues and solutions
"warning: systemd: local (239.3XX-X) is newer than core (239.6-4)" What do I do?
You have to downgrade at least to 239.6-4 otherwise you will have a broken system as 239.3XX-X is NOT compiled against the new libidn2 package. You can do the downgrade with pamac upgrade --enable-downgrade
or sudo pacman -Syyuu
"warning: systemd: local (240.275-1) is newer than core (239.6-4)" What do I do?
systemd packages has been downgraded again to an older version. Hence, as long as the version installed on your system will be on a higher version, you'll receive a warning.
If you already have systemd 240.275 on your system and you have no problem with it, you can just ignore the warning and continue to use systemd 240.275. There's no need to do any action.
If you are still interested to downgrade systemd to 239.6, you can do the downgrade with pamac upgrade --enable-downgrade
Need to merge configurations with pacdiff
This update brings some changes in system configuration files. Use sudo pacdiff
to review and merge properly.
Notifications looking weird in XFCE
Since the package dunst includes now dunstfy in the main package notifications may not displayed properly in XFCE. Please uninstall that package to solve that issue. Normally not needed in that edition.
Items from previous update sets
I can't open Nemo with elevated privileges (as root)
Workaround found: Use the dbus-x11
package instead of the regular dbus
package. This package is available in the official repositories and provides dbus compiled without the --without-x
option.
To replace dbus
with dbus-x11
package, simply install dbus-x11
with your favorite package manager: dbus
will be replaced by dbus-x11
Pamac: "Failed to commit transaction - Transaction not prepared" at the end
So far, it has only been a false alarm: updates are applied successfully.
AMD-Ucode introduction
Unless you've already done this previously, All users of AMD-APUs/CPUs should install this update like this:
sudo pacman -Syyu
sudo pacman -S amd-ucode
sudo pacman -R intel-ucode
sudo update-grub
Step 3 is optional.
Rebuilding fontconfig cache: failed to write cache
Please ignore this message. Upstream already works on a solution. More about the issue here.
LibreOffice has no window decoration in KDE
New line export SAL_USE_VCLPLUGIN=gtk3_kde5
, once merged into existing /etc/profile.d/libreoffice-fresh.sh
, fixes a moderately longterm issue. If it doesn't work for you, you may use gtk
instead of gtk3_kde5
as UI framework.
Installing glibc (2.28-4) breaks the dependency “glibc=2.27” required by lib32-glibc
Install the update either:
- from terminal:
sudo pacman -Syu
or;
- with Octopi instead of Pamac.
Something using Perl/Python/glibc broke
Rebuilds needed!
- If it's an AUR package, try to reinstall it from AUR. It most likely needs to be rebuilt.
- If it's a repo package, please report and check back regularly for updates.
I've lost a Thunderbird addon/feature
Thunderbird 60 disables incompatible addons by default. There's an about:config
switch should you want to force-enable the addon, but many addons simply will not work with the newer Quantum-based Thunderbird.
Read more about Thunderbird 60 here: Thunderbird 60
Firefox - WebGL not working anymore
You may try the following solution:
Open about:config
and set security.sandbox.content.read_path_whitelist
to /sys/
libutf8proc>=2.1.1-3 update may require manual intervention
This should normally be automatically fixed via manjaro-system update.
The libutf8proc package prior to version 2.1.1-3 had an incorrect soname link. This has been fixed in 2.1.1-3, so the upgrade will need to overwrite the untracked soname link created by ldconfig. If you get an error
libutf8proc: /usr/lib/libutf8proc.so.2 exists in filesystem
when updating, use
pacman -Suy --overwrite usr/lib/libutf8proc.so.2
to perform the upgrade.
Pamac: "Invalid or corrupted package."
If you receive an "Invalid or corrupted package." error message with Pamac and if the details contains an output similar to the following:
Details
Starting full system upgrade...
Preparing...
Resolving dependencies...
Checking inter-conflicts...
Downloading...
Downloading manjaro-system-20180716-1-any.pkg.tar.xz...
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Upgrading manjaro-system (20180702-1 -> 20180716-1)...
==> Fix libutf8proc upgrade ...
resolving dependencies...
Packages (1) libutf8proc-2.1.1-4
Total Download Size: 0.05 MiB
Total Installed Size: 0.32 MiB
Net Upgrade Size: 0.00 MiB
:: Retrieving packages...
downloading libutf8proc-2.1.1-4-x86_64.pkg.tar.xz...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
upgrading libutf8proc...
(1/1) Arming ConditionNeedsUpdate...
Warning: lock file missing /var/lib/pacman/db.lck
Error: could not open file /var/lib/pacman/local/libutf8proc-2.1.1-2/files: No such file or directory
Warning: could not fully load metadata for package libutf8proc-2.1.1-2
Failed to prepare transaction:
invalid or corrupted package
Try the following steps: close Pamac window first, then launch it again and start the update procedure again. It should continue from where it left off.
Issues with folder view widget in KDE v5.13
KDE introduced a new setting for icon sizes. Now you're able to define also the size for your panel. If you have a high-DPI display, you may want to increase the value. This will fix the display issue with given widget.
Pulseaudio changes
With this update we have a /etc/pulse/default.pa.pacnew
. It may be necessary to merge (some lines related to “GSettings” in /etc/pulse/default.pa
) if 'default.pa' has been customised.
File conflict engrampa.tap
thunar-archive-plugin: /usr/lib/xfce4/thunar-archive-plugin/engrampa.tap exists in filesystem (owned by engrampa-thunar-plugin)
thunar-archive-plugin has added native support for the Engrampa archive manager. engrampa-thunar-plugin is no longer needed. Remove engrampa-thunar-plugin to continue with the update.
