[Testing Update] 2020-05-01 - Kernels, Mesa 20.0.6, Gnome 3.36.2, Pamac 9.5beta, AMDVLK 20.Q2.2
Todays updates installed, rebooted and so far all seems good. Nice job again.
Everything seems to be working, also getting from login to desktop seems fater on KDE. Thanks for the update.
6 posts were split to a new topic: Using debtap to install gufw
Downgraded to the GUFW version from stable on stable-staging
After locking the screen, I was experiencing graphical corruption in a Plasma Xorg session. I tried to take a screenshot, but it appeared normal. The glitches stopped after I followed the instructions (posted below) from the KDE forum to disable and restart the compositor. I believe it is a regression due to this update because it never happened before.
How to disable and restart the compositor in Plasma Xorg session:
qdbus org.kde.KWin /Compositor suspend
qdbus org.kde.KWin /Compositor resume
EDIT: inxi -Fxxxz
System:    Host: bens-laptop Kernel: 5.6.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
           Desktop: KDE Plasma 5.18.4 tk: Qt 5.14.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: HP product: HP Laptop 17-by1xxx v: Type1ProductConfigId serial: <filter>
           Chassis: type: 10 serial: <filter>
           Mobo: HP model: 8530 v: 17.21 serial: <filter> UEFI: Insyde v: F.53 date: 12/13/2019
Battery:   ID-1: BAT0 charge: 36.6 Wh condition: 36.6/36.6 Wh (100%) volts: 13.1/11.6
           model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Full
CPU:       Topology: Dual Core model: Intel Core i3-8145U bits: 64 type: MT MCP arch: Kaby Lake rev: C
           L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 18406
           Speed: 1909 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 2642 2: 2714 3: 2716 4: 2851
Graphics:  Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
           chip ID: 8086:3ea0
           Display: x11 server: X.Org 1.20.8 driver: modesetting alternate: fbdev,intel,vesa
           compositor: kwin_x11 resolution: 1600x900~60Hz
           OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.0.6 direct render: Yes
Audio:     Device-1: Intel Cannon Point-LP High Definition Audio vendor: Hewlett-Packard
           driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:9dc8
           Sound Server: ALSA v: k5.6.8-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
           driver: r8169 v: kernel port: 4000 bus ID: 02:00.0 chip ID: 10ec:8168
           Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
           driver: rtl8821ce v: N/A port: 3000 bus ID: 03:00.0 chip ID: 10ec:c821
Drives:    Local Storage: total: 931.51 GiB used: 275.15 GiB (29.5%)
           ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-60Z10T0 size: 931.51 GiB speed: 6.0 Gb/s
           rotation: 5400 rpm serial: <filter> rev: 1A04 scheme: GPT
RAID:      Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060
           bus ID: 00:17.0 chip ID: 8086.282a rev: 30
Partition: ID-1: / size: 823.24 GiB used: 275.08 GiB (33.4%) fs: btrfs dev: /dev/sda6
           ID-2: /home size: 823.24 GiB used: 275.08 GiB (33.4%) fs: btrfs dev: /dev/sda6
           ID-3: swap-1 size: 8.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 43.0 C mobo: 0.0 C
Info:      Processes: 210 Uptime: 1h 52m Memory: 7.67 GiB used: 2.61 GiB (34.0%) Init: systemd v: 245
           Compilers: gcc: 9.3.0 Shell: bash v: 5.0.16 running in: konsole inxi: 3.0.37
I tried this as well, unfortunately, it did not work. For me still the only option is to downgrade the manjaro-kde-settings package.
update went smooth
I don't experience any issues with lockscreen (maybe it's only on intel? ), but to suspend and resume the compositor, you can also use alt+shift+f12 :slight_smile:
The corruption first happened on the lock screen, but it continued after unlocking, until I suspended and resumed the compositor.
I just checked the list of updates. The manjaro-kde-settings was not even included in this update
Maybe it was pushed in between? According to the package name "manjaro-kde-settings-20200430-1" it was not pushed with the update from the 29th April. I got it with this update, even if it is not listed as part of it. Package which is working for me is from 20200424.
Try to downgrade it on your machine and you will see if it is the culprit or not.
I can't speak to your system but I got that by itself.
Consider adding drawing as a preinstalled app. I've been missing something simple like paint where I could crop my screenshots or highlight things. It's really lightweight and does it's job.
