The manjaro-chroot command does not detect my installed Manjaro
Hello, folks. This is my first contribution here.
I crashed my Manjaro Linux system yesterday replacing systemd with openrc. So I've been spending hours to fix my installed Manjaro 64 bits XFCE, with a Manjaro 64 bits XFCE live pendrive. When I was logged in at the live session, at Terminal manjaro-chroot accuses:
[manjaro@manjaro ~]$ sudo manjaro-chroot -a
==> ERROR: You can't mount 0!
I tried to use mhwd-chroot too and it shows:
[manjaro manjaro]# mhwd-chroot
xfce4-terminal -e mhwd-chroot-shell
No linux system found !
[manjaro manjaro]#
What is the problem with the commands above?
The Manjaro installation in my PC was installed with a Manjaro Illyria 18.0.4 live pendrive. Under the latest Manjaro Architect, via TTY, with LUKS encryption for the root partition.
For the root partition the blkid command shows:
[manjaro@manjaro ~]$ blkid | grep crypto
/dev/sdb2: UUID="a large number" TYPE="crypto_LUKS" PARTUUID="a small number"
And it returns problems with a simple mount command. I can't even open the LUKS encryption via Terminal:
[manjaro@manjaro ~]$ cryptsetup luksOpen /dev/sdb2 ManjaroRootPartition
Device /dev/sdb2 does not exist or access is denied.
I've been already looking for support about the problem:
but there's no solution there.
What can I do?
Thanks for appreciatte.
PS: the manjaro-chroot command could once detected a Windows installation that I really have in my laptop, but not the Manjaro installation.
Try simply pressing Enter or answering with 1 regardless of presented option
Select system to mount [0-0]
PS: Please enclose terminal output with three backticks
or use the </> button. Makes for better readability.
Mount your partitions manually under /mnt and run
manjaro-chroot /mnt
You can list your partitions with lsblk. Mounting your root and efi partitions looks something like this:
mount /dev/sda2 /mnt
mount /dev/sda1 /mnt/boot/efi
Actually, just run this with sudo before using manjaro-chroot
In this point
I put the bash prompt at the final to show intentionally there were no more messages from manjaro-chroot. Press Enter did not help anything.
The manjaro-chroot does not return any messages. Not even
or other thing.
Sorry, man :joy::rofl::sweat_smile:
The cryptsetup command was unable to unlock the crypto_LUKS partition. :scream::sob::disappointed_relieved:
This answer somewhat finished the problem. (I guess) Manjaro Architect Installations prevents LUKS partitions to be recognize by other Linux systems. I don't know which part of installation Manjaro Architect does it. But there's a solution for this, using graphical interface on a Manjaro live session.
  1. I logged in at a Manjaro live session
  2. I mount the Manjaro Installation root partition using Thunar (it prompts me the LUKS password and I done this) (gnome-disk-utility does it good too)
  3. HERE IS THE MAGIC TRICK no one says on Internet out there: DEDICATED LINUX INSTALLATIONS does not follows most Linux tips on Linux Q&A universe. What is "dedicated Linux installations"? This installations where /var, /boot, /opt, /usr etc is apart the root directory (/). In my case I needed to previously mount /boot at the Manjaro Installation root partition (installed on the hard disk).
The Manjaro root partition mounted using Thunar was mounted at
/run/media/manjaro/AVeryLargeNumber/
So I mounted MANUALLY the Manjaro Installation (not the live session) boot partition at the folder "Boot" available at Manjaro Installation root partition. I did this using the mount command:
sudo mount /dev/sdb1 /run/media/manjaro/AVeryLargeNumber/boot
After all this problem to make recognizable the Manjaro Installation to the Manjaro live session, I execute:
sudo manjaro-chroot /run/media/manjaro/AVeryLargeNumber/
and it worked. With all this job, I finally executed the manjaro-chroot command successfully.
So the problem in this case was how to mount the entire Manjaro Installation to manjaro-chroot detect it.
Sorry to explain all the story but there's a lack of didactic explanations about how to mount a Linux installed system to this system receive maintenance.
Thanks all you for reading. I promise to answer all in one answer next time.
:clap::pray::facepunch:
