Hi there,
I got this problem where my laptop more often then not doesn't come back from suspend. The screen just stays black and cutting the power is the only way to the machine going again. It's not always the case and I have not been able to reproduce it consistently. I am a bit clueless how to troubleshoot this. My specs:
inxi -Fxz
Host: Matamos Kernel: 5.4.15-2-MANJARO x86_64 bits: 64 compiler: gcc
v: 9.2.0 Desktop: Gnome 3.34.3 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20KV0008MH v: ThinkPad E585
serial: <filter>
Mobo: LENOVO model: 20KV0008MH v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: R0UET76W (1.56 ) date: 11/05/2019
ID-1: BAT0 charge: 28.4 Wh condition: 40.5/45.0 Wh (90%)
model: LGC 01AV445 status: Discharging
Topology: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen L2 cache: 2048 KiB
bogomips: 31949
Speed: 1583 MHz min/max: 1600/2000 MHz Core speeds (MHz): 1: 2131 2: 2280
3: 2089 4: 2060 5: 1513 6: 1485 7: 1459 8: 1489
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel bus ID: 05:00.0
Display: x11 server: X.Org 1.20.7 driver: amdgpu
resolution: 1920x1080~60Hz
OpenGL: renderer: AMD RAVEN (DRM 3.35.0 5.4.15-2-MANJARO LLVM 9.0.1)
v: 4.5 Mesa 19.3.2 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 05:00.1
Device-2: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 05:00.6
Sound Server: ALSA v: k5.4.15-2-MANJARO
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 02:00.0
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 2000
bus ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Local Storage: total: 704.24 GiB used: 70.88 GiB (10.1%)
ID-1: /dev/nvme0n1 vendor: Lenovo model: LENSE30256GMSP34MEAT3TA
ID-2: /dev/sda vendor: Western Digital model: WDS500G2B0A-00SM50
ID-1: / size: 123.50 GiB used: 70.86 GiB (57.4%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 55.4 C mobo: 0.0 C gpu: amdgpu temp: 55 C
Fan Speeds (RPM): cpu: 0
Processes: 252 Uptime: 6m Memory: 15.33 GiB used: 2.46 GiB (16.0%)
Init: systemd Compilers: gcc: 9.2.0 Shell: zsh v: 5.7.1 inxi: 3.0.37
