Hi all,
I am new to Manjaro and am experiencing the issue, that my Thinkpad L390 Yoga (Windows 10 Dual Boot) stalls at bootup (even after cold booting after shutting down Manjaro) before the splash screen if the power supply (USB-C) is plugged in. When that happens the fans are running at maximum and the screen is shut off.
If the power supply is not plugged in there are no issues booting. If I plug the power supply in after the splash screen there are no issues as well.
When running Windows and rebooting (or cold booting after shutting down Windows) the issue does not present itself at all.
So far I have tried the following:
- checked settings in UEFI and Windows: Fast Boot = disabled, Secure Boot = disabled, CSM = disabled
- updated firmware to latest
- updated Manjaro packages
- upgraded kernel from 5.4.28-1 to 5.5.13-1
Sadly to no avail.
system:
inxi -Fxxxza --no-host
System: Kernel: 5.5.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.5-x86_64 root=UUID=1cbaeb68-2530-4023-aa15-77150eafd221 rw quiet
udev.log_priority=3
Desktop: KDE Plasma 5.18.3 tk: Qt 5.14.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Convertible System: LENOVO product: 20NT0011GE v: ThinkPad L390 Yoga serial: <filter> Chassis: type: 31
serial: <filter>
Mobo: LENOVO model: 20NT0011GE v: SDK0J40697 WIN serial: <filter> UEFI: LENOVO v: R10ET44W (1.29 ) date: 03/03/2020
Battery: ID-1: BAT0 charge: 44.9 Wh condition: 44.9/45.0 Wh (100%) volts: 12.5/11.1 model: LGC 01AV481 type: Li-poly
serial: <filter> status: Unknown cycles: 3
CPU: Topology: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 8E (142)
stepping: C (12) microcode: CA L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28808
Speed: 800 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 801 8: 800
Graphics: Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
Display: x11 server: X.Org 1.20.7 driver: intel unloaded: modesetting alternate: fbdev,vesa compositor: kwin_x11
tty: N/A
OpenGL: renderer: Mesa DRI Intel UHD Graphics (Whiskey Lake 3x8 GT2) v: 4.6 Mesa 19.3.5 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:9dc8
Sound Server: ALSA v: k5.5.13-1-MANJARO
Network: Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel port: 2000 bus ID: 00:14.3
chip ID: 8086:9df0
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: 3.2.6-k port: efa0 bus ID: 00:1f.6
chip ID: 8086:15be
IF: enp0s31f6 state: down mac: <filter>
Drives: Local Storage: total: 238.47 GiB used: 19.95 GiB (8.4%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKKF256G8L size: 238.47 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: L11P scheme: GPT
Partition: ID-1: / raw size: 117.19 GiB size: 114.85 GiB (98.00%) used: 19.92 GiB (17.3%) fs: ext4 dev: /dev/nvme0n1p5
Sensors: System Temperatures: cpu: 49.0 C mobo: 1.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 230 Uptime: 14m Memory: 7.53 GiB used: 1.41 GiB (18.7%) Init: systemd v: 244 Compilers: gcc: 9.3.0
Shell: bash v: 5.0.16 running in: yakuake inxi: 3.0.37
journalctl shows some errors from the previous boot attempts, but I am not sure if they are related:
journalctl -b0 | grep Suspend
Mär 28 17:00:55 Laptop-Gereon kded5[666]: kscreen.kded: PowerDevil SuspendSession action not available!
journalctl -p2 -b0
-- Logs begin at Sat 2020-03-28 12:35:50 CET, end at Sat 2020-03-28 17:04:43 CET. --
Mär 28 17:00:22 Laptop-Gereon kernel: Disabling IRQ #31
journalctl -p2 -b1
Mär 28 16:08:04 Laptop-Gereon kernel: Disabling IRQ #31
Mär 28 16:58:37 Laptop-Gereon kernel: watchdog: watchdog0: watchdog did not stop!
Any help would be much appreciated!
