-inxi at bottom-
Hi guys,
I've recently upgraded to Thunderbird 68.10.0-1 have have since been unable to start it.
When attempting to start it in the terminal it returns the below error.
[sean@NEWDESTINY ~]$ thunderbird
Segmentation fault (core dumped)
-I have checked htop and found no other Thunderbird processes are running and I also have no issues with Firefox 78.0.2 (64-bit).
-Reinstalling Thunderbird provides no change.
-thunderbird -safe-mode = Returns the same segmentation fault error.
-pacman -U used to downgrade to Thunderbird 68.7.0 from cache. Code returned when attempting to start:
1595497281852 addons.xpi-utils WARN Add-on {e2fda1a4-762b-4020-b5ad-a41df1933103} is not compatible with application version.
1595497281853 addons.xpi-utils WARN Add-on {e2fda1a4-762b-4020-b5ad-a41df1933103} is not compatible with application version.
1595497281855 addons.xpi-utils WARN Add-on {e2fda1a4-762b-4020-b5ad-a41df1933103} is not compatible with application version.
[sean@NEWDESTINY ~]$ thunderbird -safe-mode
1595497290872 addons.xpi-utils WARN Add-on {e2fda1a4-762b-4020-b5ad-a41df1933103} is not compatible with application version.
1595497290873 addons.xpi-utils WARN Add-on {e2fda1a4-762b-4020-b5ad-a41df1933103} is not compatible with application version.
1595497290874 addons.xpi-utils WARN Add-on {e2fda1a4-762b-4020-b5ad-a41df1933103} is not compatible with application version.
[sean@NEWDESTINY ~]$ thunderbird -v
Thunderbird 68.7.0
-Gziping the add-on mentioned above in ~/.thunderbird/.......... removes it's mention when starting in the terminal but still does not result in the application starting and still returns segmentation fault for v68.7.0 and v68.10.0-1
-Setting GTK_USE_PORTAL to 1 or 0 has no affect on either version https://bugzilla.mozilla.org/show_bug.cgi?id=1514605
[sean@NEWDESTINY .thunderbird]$ GTK_USE_PORTAL=1 thunderbird
[sean@NEWDESTINY .thunderbird]$ GTK_USE_PORTAL=0 thunderbird
-Troubleshooting Firefox Steps available for Thunderbird have no affect on the issue. There is no thunderbird profile folder @ /home/sean/.cache/mozilla with ls -a and I had already tried -safe-mode from an earlier step.
Any help would be appreciated.
[sean@NEWDESTINY ~]$ inxi -Fx
System: Host: NEWDESTINY Kernel: 5.4.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: Xfce 4.14.2
Distro: Manjaro Linux
Machine: Type: Desktop System: MSI product: MS-7850 v: 1.0 serial: <root required>
Mobo: MSI model: Z97 PC Mate(MS-7850) v: 1.0 serial: <root required> UEFI [Legacy]: American Megatrends v: 4.11
date: 02/16/2016
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master charge: 100% (should be ignored)
status: Discharging
CPU: Topology: Quad Core model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell rev: 3 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 64026
Speed: 900 MHz min/max: 800/4400 MHz Core speeds (MHz): 1: 900 2: 899 3: 900 4: 900 5: 900 6: 901 7: 900 8: 900
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1080] driver: nvidia v: 430.64 bus ID: 01:00.0
Display: x11 server: X.org 1.20.8 driver: nvidia resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 430.64 direct render: Yes
Audio: Device-1: Intel 9 Series Family HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-3: Kingston HyperX 7.1 Audio type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-3:3
Sound Server: ALSA v: k5.4.52-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8168
v: 8.048.03-NAPI port: d000 bus ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: d8:cb:8a:3b:90:d3
Device-2: Microsoft Xbox 360 Wireless Adapter type: USB driver: xpad bus ID: 2-2:2
Drives: Local Storage: total: 4.88 TiB used: 75.27 GiB (1.5%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDA120G size: 111.79 GiB
ID-2: /dev/sdb vendor: Seagate model: ST1000DX001-1CM162 size: 931.51 GiB
ID-3: /dev/sdc vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
ID-4: /dev/sdd vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
ID-5: /dev/sde vendor: Seagate model: ST2000DX002-2DV164 size: 1.82 TiB
ID-6: /dev/sdf type: USB vendor: Western Digital model: WD10EURX-63FH1Y0 size: 931.48 GiB
Partition: ID-1: / size: 109.53 GiB used: 75.27 GiB (68.7%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 16.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdd3
Sensors: System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 49 C
Info: Processes: 231 Uptime: 17m Memory: 15.59 GiB used: 2.12 GiB (13.6%) Init: systemd Compilers: gcc: 10.1.0
clang: 10.0.0 Shell: bash v: 5.0.18 inxi: 3.0.37
