Thunderbird crashes on launch after latest upgrade
I just applied the latest Manjaro update with pacman -syyuu on my KDE Plasma system, and then rebooted. Everything worked great except for one thing: now Thunderbird crashes on launch.
Console output is bare (it just says "Segmentation fault (core dumped)"), but running with LD_DEBUG=files reveals that it's failing to find some GTK libraries:
$  LD_DEBUG=files thunderbird  2>&1 | grep -i error
      3447:     file=libgpg-error.so.0 [0];  needed by /usr/lib/libgcrypt.so.20 [0]
      3447:     file=libgpg-error.so.0 [0];  generating link map
      3447:     calling init: /usr/lib/libgpg-error.so.0
      3447:     /usr/lib/thunderbird/thunderbird: error: symbol lookup error: undefined symbol: nspr_use_zone_allocator (fatal)
      3447:     /usr/lib/thunderbird/thunderbird: error: symbol lookup error: undefined symbol: gtk_progress_get_type (fatal)
      3447:     /usr/lib/gtk-3.0/modules/libcanberra-gtk-module.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      3447:     /usr/lib/gtk-3.0/modules/libcanberra-gtk-module.so: error: symbol lookup error: undefined symbol: gtk_progress_get_type (fatal)
      3447:     /usr/lib/gtk-3.0/modules/libcanberra-gtk-module.so: error: symbol lookup error: undefined symbol: gtk_module_display_init (fatal)
      3447:     /usr/lib/gio/modules/libgvfsdbus.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      3447:     /usr/lib/gio/modules/libgvfsdbus.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      3447:     /usr/lib/gio/modules/libgvfsdbus.so: error: symbol lookup error: undefined symbol: g_io_gvfsdbus_load (fatal)
      3447:     /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-png.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      3447:     /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-png.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      3447:     /usr/lib/thunderbird/thunderbird: error: symbol lookup error: undefined symbol: copyfile (fatal)
JavaScript error: chrome://gdata-provider/content/gdata-migration.js, line 5: NS_ERROR_NOT_AVAILABLE: Component returned failure code: 0x80040111 (NS_ERROR_NOT_AVAILABLE) [nsIXPCComponents_Utils.import]
      3447:     /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      3447:     /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      3447:     /usr/lib/gio/modules/libdconfsettings.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      3447:     /usr/lib/gio/modules/libdconfsettings.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      3447:     /usr/lib/gio/modules/libdconfsettings.so: error: symbol lookup error: undefined symbol: g_io_dconfsettings_load (fatal)
      3447:     /usr/lib/gio/modules/libgsettingsgconfbackend.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      3447:     /usr/lib/gio/modules/libgsettingsgconfbackend.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      3447:     /usr/lib/gio/modules/libgsettingsgconfbackend.so: error: symbol lookup error: undefined symbol: g_io_gsettingsgconfbackend_load (fatal)
Seems like maybe something's busted or not installed in the GTK stack?
System specs:
System:    Host: Spectre Kernel: 4.19.24-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Desktop: KDE Plasma 5.15.1
           Distro: Manjaro Linux
Machine:   Type: Convertible System: HP product: HP Spectre x360 Convertible 13-w0XX v: N/A serial: <root required>
           Mobo: HP model: 827E v: 94.27 serial: <root required> UEFI: American Megatrends v: F.04 date: 09/26/2016
Battery:   ID-1: BAT0 charge: 39.0 Wh condition: 48.3/48.3 Wh (100%) model: Hewlett-Packard Primary status: Charging
CPU:       Topology: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Kaby Lake rev: 9 L2 cache: 4096 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23240
           Speed: 800 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics:  Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
           Display: x11 server: X.Org 1.20.3 driver: intel unloaded: modesetting resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2) v: 4.5 Mesa 18.3.3 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           Sound Server: ALSA v: k4.19.24-1-MANJARO
Network:   Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f040 bus ID: 01:00.0
           IF: wlp1s0 state: up mac: 00:28:f8:05:60:db
Drives:    Local Storage: total: 238.47 GiB used: 177.85 GiB (74.6%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLV256HCHP-000H1 size: 238.47 GiB
Partition: ID-1: / size: 38.20 GiB used: 25.85 GiB (67.7%) fs: ext4 dev: /dev/nvme0n1p3
           ID-2: /home size: 187.34 GiB used: 151.99 GiB (81.1%) fs: ext4 dev: /dev/nvme0n1p4
           ID-3: swap-1 size: 7.81 GiB used: 1024 KiB (0.0%) fs: swap dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 42.0 C mobo: N/A
Info:      Processes: 187 Uptime: 30m Memory: 7.67 GiB used: 2.25 GiB (29.3%) Init: systemd Compilers: gcc: 8.2.1 Shell: bash
           v: 5.0.0 inxi: 3.0.30
Have you tried uninstalling then re-installing Thunderbird. I assume there is an alternate "git" version of Thunderbird in the AUR. It might be worth testing the git (developmental) version for improvement.
Almost the same on testing and unstable
(don't have a stable KDE Plasma install at the moment), but Thunderbird opens
      1453:     file=libgpg-error.so.0 [0];  needed by /usr/lib/libgcrypt.so.20 [0]
      1453:     file=libgpg-error.so.0 [0];  generating link map
      1453:     calling init: /usr/lib/libgpg-error.so.0
      1453:     /usr/lib/thunderbird/thunderbird: error: symbol lookup error: undefined symbol: nspr_use_zone_allocator (fatal)
      1453:     /usr/lib/thunderbird/thunderbird: error: symbol lookup error: undefined symbol: gtk_progress_get_type (fatal)
      1453:     /usr/lib/gtk-3.0/modules/libcanberra-gtk-module.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      1453:     /usr/lib/gtk-3.0/modules/libcanberra-gtk-module.so: error: symbol lookup error: undefined symbol: gtk_progress_get_type (fatal)
      1453:     /usr/lib/gtk-3.0/modules/libcanberra-gtk-module.so: error: symbol lookup error: undefined symbol: gtk_module_display_init (fatal)
      1453:     /usr/lib/gio/modules/libgvfsdbus.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      1453:     /usr/lib/gio/modules/libgvfsdbus.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      1453:     /usr/lib/gio/modules/libgvfsdbus.so: error: symbol lookup error: undefined symbol: g_io_gvfsdbus_load (fatal)
      1453:     /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      1453:     /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
(thunderbird:1453): Gtk-WARNING **: 22:05:13.160: Theme parsing error: <data>:1:34: Expected ')' in color definition
(thunderbird:1453): Gtk-WARNING **: 22:05:13.160: Theme parsing error: <data>:1:77: Expected ')' in color definition
      1453:     /usr/lib/gio/modules/libdconfsettings.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      1453:     /usr/lib/gio/modules/libdconfsettings.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      1453:     /usr/lib/gio/modules/libdconfsettings.so: error: symbol lookup error: undefined symbol: g_io_dconfsettings_load (fatal)
      1453:     /usr/lib/thunderbird/thunderbird: error: symbol lookup error: undefined symbol: copyfile (fatal)
      1453:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_open (fatal)
      1453:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_destroy (fatal)
      1453:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_change_device (fatal)
      1453:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_change_props (fatal)
      1453:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_play (fatal)
      1453:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_cancel (fatal)
      1453:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_cache (fatal)
      1453:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_playing (fatal)
      1453:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: pulse_driver_playing (fatal)
      1453:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_driver_playing (fatal)
I wonder if is gdk-pixbuf2 or more packages ...
I use thunderbird for work...
This scared me, even though on unstable, so I checked ... seems fine here (on KDE)
[I get some negligible gtk and addon warnings in log, but nothing else]
gdk-pixbuf2 was indeed not installed, but installing it didn't make any difference.
I made a test on fresh install arch linux and i noticed that thunderbird was complaining about appmenu-gtk-module too, but was still loading. Once i installed appmenu-gtk-module and launching thunderbird ended in a segmentation fault. Removing that package made thunderbird work again, still trowing those "complains" but working :slight_smile:
Same i could reproduce on Manjaro stable.
For me the appmenu-gtk-modulepackage is not related. I get the same crash regardless of whether or not it's installed.
Hi @Pointedstick, have you managed to solve this issue? I just installed Manjaro on my laptop and I'm getting the same problem. I can start thunderbird with a bare profile, but as soon as I add a new email account it segfaults. The strange thing for me is that I did not encounter any error on my desktop running the exact same kernel and the same Manjaro version.
No, I'm afraid I never did. :frowning:
Which version of Thunderbird are you using ?
I have installed stable version of Manjaro KDE and Thunderbird 60.6.1.
But I have no crash problems with TB.
I'm also on Thunderbird 60.6.1. The same issue appears even when I run Thunderbird with Snap.
I tried running Thunderbird using a new account on my machine and it does not crash, so it seems that there are some user-specific files that are causing the segmentation fault. Anyone knows which user-specific files and directories are used by Thunderbird (other than $HOME/.thunderbird)?
Thunderbird only uses /home//.thunderbird.
You can try to rescue the settings of the email accounts and then deleting the folder .thunderbird.
No need for the sledgehammer. Simply rename it.
Some thunderbird files might also reside in ~/.mozilla.
I already did try and delete that folder, hence why I said 'other than $HOME/.thunderbird'. Anyway, that does not solve the issue. Starting TB with a new user (either by deleting .thunderbird or with the --ProfileManager flag) does not cause segmentation fault, but as soon as I add a new email account (I tested Gmail and my Department's mail), the crash occurs. When doing this using a different Linux user it works flawlessly.
Troubleshooting Thunderbird is essentially the same as Firefox:
Please post some log/output.
This is the output when creating a new empty Thunderbird profile (-P flag) and adding my Department's email. The crash occurs right after setting up my email address.
LD_DEBUG=files thunderbird -P 2>&1 | grep -i error        <<<
      4388:     file=libgpg-error.so.0 [0];  needed by /usr/lib/libgcrypt.so.20 [0]
      4388:     file=libgpg-error.so.0 [0];  generating link map
      4388:     calling init: /usr/lib/libgpg-error.so.0
      4388:     /usr/lib/thunderbird/thunderbird: error: symbol lookup error: undefined symbol: nspr_use_zone_allocator (fatal)
      4388:     /usr/lib/thunderbird/thunderbird: error: symbol lookup error: undefined symbol: gtk_progress_get_type (fatal)
      4388:     /usr/lib/gtk-3.0/modules/libcanberra-gtk-module.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      4388:     /usr/lib/gtk-3.0/modules/libcanberra-gtk-module.so: error: symbol lookup error: undefined symbol: gtk_progress_get_type (fatal)
      4388:     /usr/lib/gtk-3.0/modules/libcanberra-gtk-module.so: error: symbol lookup error: undefined symbol: gtk_module_display_init (fatal)
      4388:     /usr/lib/gtk-3.0/modules/libappmenu-gtk-module.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      4388:     /usr/lib/gtk-3.0/modules/libappmenu-gtk-module.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      4388:     /usr/lib/gtk-3.0/modules/libappmenu-gtk-module.so: error: symbol lookup error: undefined symbol: gtk_progress_get_type (fatal)
      4388:     /usr/lib/gtk-3.0/modules/libappmenu-gtk-module.so: error: symbol lookup error: undefined symbol: gtk_module_display_init (fatal)
      4388:     /usr/lib/gio/modules/libgvfsdbus.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      4388:     /usr/lib/gio/modules/libgvfsdbus.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      4388:     /usr/lib/gio/modules/libgvfsdbus.so: error: symbol lookup error: undefined symbol: g_io_gvfsdbus_load (fatal)
      4388:     /usr/lib/gio/modules/libdconfsettings.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      4388:     /usr/lib/gio/modules/libdconfsettings.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      4388:     /usr/lib/gio/modules/libdconfsettings.so: error: symbol lookup error: undefined symbol: g_io_dconfsettings_load (fatal)
      4388:     /usr/lib/gio/modules/libgsettingsgconfbackend.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      4388:     /usr/lib/gio/modules/libgsettingsgconfbackend.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
      4388:     /usr/lib/gio/modules/libgsettingsgconfbackend.so: error: symbol lookup error: undefined symbol: g_io_gsettingsgconfbackend_load (fatal)
      4388:     /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-png.so: error: symbol lookup error: undefined symbol: g_module_check_init (fatal)
      4388:     /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-png.so: error: symbol lookup error: undefined symbol: g_module_unload (fatal)
(thunderbird:4388): Gtk-WARNING **: 15:16:53.677: Theme parsing error: <data>:1:34: Expected ')' in color definition
(thunderbird:4388): Gtk-WARNING **: 15:16:53.677: Theme parsing error: <data>:1:77: Expected ')' in color definition
JavaScript error: jar:file:///usr/lib/thunderbird/omni.ja!/components/XULStore.js, line 65: Error: Can't find profile directory.
      4388:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_open (fatal)
      4388:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_destroy (fatal)
      4388:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_change_device (fatal)
      4388:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_change_props (fatal)
      4388:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_play (fatal)
      4388:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_cancel (fatal)
      4388:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_cache (fatal)
      4388:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_pulse_driver_playing (fatal)
      4388:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: pulse_driver_playing (fatal)
      4388:     /usr/lib/libcanberra-0.30/libcanberra-pulse.so: error: symbol lookup error: undefined symbol: libcanberra_pulse_LTX_driver_playing (fatal)
      4388:     /usr/lib/thunderbird/thunderbird: error: symbol lookup error: undefined symbol: copyfile (fatal)
(thunderbird:4388): Gtk-WARNING **: 15:17:08.083: Theme parsing error: <data>:1:34: Expected ')' in color definition
(thunderbird:4388): Gtk-WARNING **: 15:17:08.083: Theme parsing error: <data>:1:77: Expected ')' in color definition
[1]    4388 segmentation fault (core dumped)  LD_DEBUG=files thunderbird -P 2>&1 |
       4389 done                              grep --color=auto --exclude-dir={.bzr,CVS,.git,.hg,.svn} -i error
Yep, I see the same behavior as @geeanlooca.
What version of GTK3 do you have?
Which branch are you on?
What package versions of the other modules do you have?
Are any of the packages Manjaro-packaged overlay packages?
gianluca@t480 [15:23:45] [~]
-> % pacman -Si gtk3        <<<
Repository      : extra
Version         : 1:3.24.8-1
Description     : GObject-based multi-platform GUI toolkit
Architecture    : x86_64
URL             : https://www.gtk.org/
Licenses        : LGPL
Groups          : None
Provides        : gtk3-print-backends
Depends On      : atk  cairo  libxcursor  libxinerama  libxrandr  libxi  libepoxy  gdk-pixbuf2  dconf  libxcomposite  libxdamage  pango  shared-mime-info  at-spi2-atk
                  wayland  libxkbcommon  adwaita-icon-theme  json-glib  librsvg  wayland-protocols  desktop-file-utils  mesa  cantarell-fonts  colord  rest  libcups
                  libcanberra  fribidi  gtk-update-icon-cache
Optional Deps   : None
Conflicts With  : gtk3-print-backends
Replaces        : gtk3-print-backends<=3.22.26-1
Download Size   : 10,69 MiB
Installed Size  : 73,21 MiB
Packager        : Jan Alexander Steffens (heftig) <jan.steffens@gmail.com>
Build Date      : gio 11 apr 2019 01:12:48 CEST
Validated By    : MD5 Sum  SHA-256 Sum  Signature
I'm currently on testing as I was curious to see if there were more recent versions of TB available. I had the same issue when on the stable branch.
  • libcanberra - 0.30+2+gc0620e4-2
  • libgpg-error - 1.36-1
  • gdk-pixbuf2 - 2.38.1-1
  • appmenu-gtk-module - 0.7.1-1
I could not find the name of the other modules listed in the output, however I'm up to date with the testing branch.
I'm sorry but I don't know how to answer this question, can you clarify what you mean?
1:3.24.7+25+g17665f06e3-1
The default one, I guess? I haven't changed anything with any repos.
Which other modules? Everything on my system is up-to-date.
I'm afraid I don't know what this means, but if the answer could only be yes if I went out of my way to do something, then the answer is no. :slight_smile:
