Posting this here because I am not sure if it is 100% a Manjaro problem per se.
Thunderbird available in the stable branch does not seem to like Google's security token, which prevents Gmail IMAP from working all together. Thunderbird does open a window to go through Google's security steps, including 2-step verification via SMS, but the app gets never registered and Thunderbird does not get IMAP access.
Reproduction steps (stable):
- Install Thunderbird
sudo pacman -Syu thunderbird
- Input your Gmail info (OAuth2).
Thunderbird installed via Flatpak does work just fine, so it is clearly an app-version issue. Any suggestions or info you might have regarding this issue?
Thanks.
