Thunderbolt dock authorized, but not working
Hi,
recently my thunderbolt-3-dock stopped working.
I am not sure, what the main cause could be. Meanwhile there was a bios update, which could be a good cause-candidate btw.
I connected, authorized (boltctl) and removed the device multiple times, tested different thunderbolt-security settings, but nothing worked.
Only the external display is working, connected over displayport.
In Windows the dock still works as expected.
Is there some kind of another "reset" I could try, to make it work again?
System:    Host: luke-pc Kernel: 5.7.0-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: i3 4.18.1
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Schenker product: XMG FUSION 15 (XFU15L19) v: Late 2019 serial: <root required>
           Mobo: Intel model: LAPQC71A v: K54899-303 serial: <root required> UEFI: Intel v: QCCFL357.0114.2020.0401.1544
           date: 04/01/2020
Battery:   ID-1: BAT0 charge: 62.6 Wh condition: 93.5/93.5 Wh (100%) model: standard status: Charging
CPU:       Topology: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 12.0 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62431
           Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
           9: 800 10: 801 11: 800 12: 800
Graphics:  Device-1: Intel UHD Graphics 630 driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Intel driver: N/A bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.8 driver: intel resolution: 1920x1080~144Hz
           OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.0.7 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           Sound Server: ALSA v: k5.7.0-3-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Intel driver: r8169 v: kernel port: 3000
           bus ID: 3d:00.0
           IF: enp61s0 state: up speed: 1000 Mbps duplex: full mac: b0:25:aa:33:16:bd
           Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000 bus ID: 3e:00.0
           IF: wlp62s0 state: up mac: 94:e6:f7:a4:27:57
           IF-ID-1: lxdbr0 state: down mac: 9a:eb:a7:67:25:91
Drives:    Local Storage: total: 894.25 GiB used: 351.68 GiB (39.3%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 500GB size: 465.76 GiB
           ID-2: /dev/nvme1n1 vendor: Corsair model: Force MP510 size: 894.25 GiB
Partition: ID-1: / size: 457.16 GiB used: 89.72 GiB (19.6%) fs: ext4 dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 64.0 C mobo: 47.0 C
Info:      Processes: 291 Uptime: 11m Memory: 15.49 GiB used: 1.98 GiB (12.8%) Init: systemd Compilers: gcc: 10.1.0 Shell: zsh
           v: 5.8 inxi: 3.0.37
So it turns out, that it is got something to do with the latest BIOS update (114).
But no one knows, what exactly causes the issue.
Can you maybe take a look at the output of dmesg and see anything thunderbolt related after you try to connect/configure/etc. the device? If you run dmesg -w, you can see the kernel message buffer in real time, so that way it might be easier to know which messages appeared when you did something.
Sorry, I encountered your comment only now...
The output of dmesg, when connecting/disconnecting the thunderbolt dock is just this:
[18898.693324] pcieport 0000:00:1b.0: EDR: ACPI event 0x2 received
[18939.945435] pcieport 0000:00:1b.0: EDR: ACPI event 0x2 received
And does the device appear anywhere in the settings after you connect it?
