Time is inaccurate and causing visual issues
When I set the timezone as EDT, it is slightly off by 1 minute and 1 second (now I wouldn't mind this too much and idk if the time being off is completely related) which I believe is causing my Firefox to mess up time for example, 2020-08-08_17-45, I have not found any way to fix this and I was hoping that someone might be able to figure out why this is going on, all help is appreciated, thanks in advance!
Dual-booting with windows, I presume? Otherwise,
why are you doing/having to do this?
Nope, I am not Dual-booting with windows!
I set the timezone to EDT because the clock got it wrong when it auto configured itself
Ok then, this should fix you up:
https://wiki.archlinux.org/index.php/Systemd-timesyncd
I went through the whole guide but it did not help, it has incorrectly changed my time again and hasn't fixed the issue I am having, do you know what the issue might be?
EDIT: So it half fixed it
It incorrectly set my time but after I set it to the proper timezone, it seems to be aligned with the time I should be getting and fixed the 4 hours issue in the screenshot above
Outputs of:
  1. timedatectl show-timesync --all
  2. timedatectl status
  3. timedatectl timesync-status
