Touchpad not working and recognized as mouse
I have installed Manjaro, and Debian to my device, but I couldn't make the touchpad work.
My device is recognized by the system and appears in the Mouse and Touchpad menu, but is completely dead.
My problem is similar to this other topic: Touchpad SYNA3602 (0911:5288) not working at all
The difference is that my liboutput list-devices output does not show any errors.
It seems like the touchpad is recognized as a mouse rather than a touchpad.
I tried updating the kernel to 4.15 and the problem persists.
Outputs:
libinput list-devices (no errors are shown)
sudo libinput list-devices
Device:           HTMicroelectronics Goodix Fingerprint Device
Kernel:           /dev/input/event9
Group:            7
Seat:             seat0, default
Capabilities:     pointer
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      disabled
Nat.scrolling:    disabled
Middle emulation: disabled
Calibration:      n/a
Scroll methods:   button
Click methods:    none
Disable-w-typing: n/a
Accel profiles:   flat *adaptive
Rotation:         n/a
$ xinput --list
⎡ Virtual core pointer                    	id=2	[master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              	id=4	[slave  pointer  (2)]
⎜   ↳ HTMicroelectronics Goodix Fingerprint Device 	id=11	[slave  pointer  (2)]
⎜   ↳ Microsoft Microsoft® 2.4GHz Transceiver v6.0	id=13	[slave  pointer  (2)]
⎜   ↳ Microsoft Microsoft® 2.4GHz Transceiver v6.0	id=14	[slave  pointer  (2)]
⎜   ↳ Goodix Capacitive TouchScreen           	id=15	[slave  pointer  (2)]
⎣ Virtual core keyboard                   	id=3	[master keyboard (2)]
    ↳ Virtual core XTEST keyboard             	id=5	[slave  keyboard (3)]
    ↳ Power Button                            	id=6	[slave  keyboard (3)]
    ↳ Video Bus                               	id=7	[slave  keyboard (3)]
    ↳ Power Button                            	id=8	[slave  keyboard (3)]
    ↳ Sleep Button                            	id=9	[slave  keyboard (3)]
    ↳ USB 2.0 PC Camera: PC Camera            	id=10	[slave  keyboard (3)]
    ↳ Microsoft Microsoft® 2.4GHz Transceiver v6.0	id=12	[slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard            	id=16	[slave  keyboard (3)]
    ↳ Microsoft Microsoft® 2.4GHz Transceiver v6.0	id=17	[slave  keyboard (3)]
    ↳ Microsoft Microsoft® 2.4GHz Transceiver v6.0	id=18	[slave  keyboard (3)]
    ↳ Goodix Capacitive TouchScreen           	id=19	[slave  keyboard (3)]
$ xinput -list-props "HTMicroelectronics Goodix Fingerprint Device "
Device 'HTMicroelectronics Goodix Fingerprint Device ':
	Device Enabled (143):	1
	Coordinate Transformation Matrix (145):	1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
	libinput Accel Speed (278):	0.333333
	libinput Accel Speed Default (279):	0.000000
	libinput Accel Profiles Available (280):	1, 1
	libinput Accel Profile Enabled (281):	1, 0
	libinput Accel Profile Enabled Default (282):	1, 0
	libinput Natural Scrolling Enabled (283):	0
	libinput Natural Scrolling Enabled Default (284):	0
	libinput Send Events Modes Available (263):	1, 0
	libinput Send Events Mode Enabled (264):	0, 0
	libinput Send Events Mode Enabled Default (265):	0, 0
	libinput Left Handed Enabled (285):	0
	libinput Left Handed Enabled Default (286):	0
	libinput Scroll Methods Available (287):	0, 0, 1
	libinput Scroll Method Enabled (288):	0, 0, 0
	libinput Scroll Method Enabled Default (289):	0, 0, 0
	libinput Button Scrolling Button (290):	2
	libinput Button Scrolling Button Default (291):	2
	libinput Middle Emulation Enabled (292):	0
	libinput Middle Emulation Enabled Default (293):	0
	Device Node (266):	"/dev/input/event9"
	Device Product ID (267):	10182, 22336
	libinput Drag Lock Buttons (294):	<no items>
	libinput Horizontal Scroll Enabled (295):	1
$ cat /var/log/Xorg.0.log | grep -i mouse
[     9.100] (==) modeset(0): Silken mouse enabled
[     9.613] (II) event9  - (II) HTMicroelectronics Goodix Fingerprint Device : (II) is tagged by udev as: Mouse
[     9.644] (II) XINPUT: Adding extended input device "HTMicroelectronics Goodix Fingerprint Device " (type: MOUSE, id 11)
[     9.645] (II) event9  - (II) HTMicroelectronics Goodix Fingerprint Device : (II) is tagged by udev as: Mouse
[     9.645] (II) config/udev: Adding input device HTMicroelectronics Goodix Fingerprint Device  (/dev/input/mouse1)
[     9.661] (II) event7  - (II) Microsoft Microsoft® 2.4GHz Transceiver v6.0: (II) is tagged by udev as: Keyboard Mouse
[     9.676] (II) XINPUT: Adding extended input device "Microsoft Microsoft® 2.4GHz Transceiver v6.0" (type: MOUSE, id 13)
[     9.676] (II) event7  - (II) Microsoft Microsoft® 2.4GHz Transceiver v6.0: (II) is tagged by udev as: Keyboard Mouse
[     9.677] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v6.0 (/dev/input/mouse0)
[     9.696] (II) XINPUT: Adding extended input device "Microsoft Microsoft® 2.4GHz Transceiver v6.0" (type: MOUSE, id 14)
[     9.733] (II) config/udev: Adding input device Goodix Capacitive TouchScreen (/dev/input/mouse2)
EDIT: The touchpad works in Windows 10. The touchpad has a Fingerprint sensor in it, that is why it is called Fingerprint Device
I'm having the same problem, but it it's not just the trackpad that won't work, every usb device I plug in won't recognize my cursor.
@Vahndera, then it is unlikely the same cause. Create a separate topic with similarly extensive information about your system, please!
@klox, can you provide the same output from Debian so we can compare.
I removed Debian already. But I tried a liveUSB of Linux Mint and the output is the same - xinput has the same name, same id. Xorg output is also the same.
I couldn't run libinput command.
I tried to follow this https://wiki.ubuntu.com/DebuggingTouchpadDetection/evtest but evtest shows nothing.
Can you post
hwinfo --keyboard
hwinfo --mouse
hwinfo --fingerprint
I would like to get more exact model information to srart search.
Nowadays I tend to blame everything on Wayland. You are not, by chance, running GNOME w/Wayland, are you?
Also, libinput has been real flaky lately, according to some very recent Arch forums posts, so you might consider switching over to libsynaptics.
regards
I reinstalled Windows on dualboot and now the device is not shown in xinput anymore. The touchpad and fingerprint is working in Windows.
$ xinput
⎜   ↳ Goodix Capacitive TouchScreen           	id=11	[slave  pointer  (2)]
⎜   ↳ Microsoft Microsoft® 2.4GHz Transceiver v6.0	id=17	[slave  pointer  (2)]
    ↳ AT Translated Set 2 keyboard            	id=12	[slave  keyboard (3)]
    ↳ Goodix Capacitive TouchScreen           	id=13	[slave  keyboard (3)]
    ↳ Microsoft Microsoft® 2.4GHz Transceiver v6.0	id=15	[slave  keyboard (3)]
    ↳ Microsoft Microsoft® 2.4GHz Transceiver v6.0	id=16	[slave  keyboard (3)]
And it is displayed as other in hwinfo
$ hwinfo --short
cpu:
                       Intel(R) Core(TM) m3-7Y30 CPU @ 1.00GHz, 2485 MHz
                       Intel(R) Core(TM) m3-7Y30 CPU @ 1.00GHz, 2450 MHz
                       Intel(R) Core(TM) m3-7Y30 CPU @ 1.00GHz, 2550 MHz
keyboard:
  /dev/input/event16   Microsoft Nano Transceiver v1.0 for Bluetooth
  /dev/input/event4    AT Translated Set 2 keyboard
mouse:
  /dev/input/mice      Microsoft Nano Transceiver v1.0 for Bluetooth
  /dev/input/mice      Goodix Capacitive TouchScreen
monitor:
                       LC133LF4L01
graphics card:
                       Intel VGA compatible controller
sound:
                       Intel Audio device
storage:
                       Intel Sunrise Point-LP SATA Controller [AHCI mode]
network:
  wlp1s0               Intel Wireless 3165
network interface:
  wlp1s0               Ethernet network interface
  lo                   Loopback network interface
disk:
  /dev/sdb             SanDisk Cruzer Blade
  /dev/sda             Teclast 128GB NS
partition:
  /dev/sdb1            Partition
  /dev/sda1            Partition
  /dev/sda2            Partition
  /dev/sda3            Partition
  /dev/sda4            Partition
  /dev/sda5            Partition
  /dev/sda6            Partition
usb controller:
                       Intel Sunrise Point-LP USB 3.0 xHCI Controller
bios:
                       BIOS
bridge:
                       Intel Host bridge
                       Intel Sunrise Point-LP PCI Express Root Port #9
                       Intel ISA bridge
hub:
                       Genesys Logic Hub
                       Linux Foundation 2.0 root hub
                       Linux Foundation 3.0 root hub
memory:
                       Main Memory
bluetooth:
                       Intel Bluetooth Device
unknown:
                       FPU
                       DMA controller
                       PIC
                       Keyboard controller
                       Intel Sunrise Point-LP Serial IO UART Controller #0
                       Intel Sunrise Point-LP Serial IO I2C Controller #2
                       Intel Sunrise Point-LP Serial IO I2C Controller #0
                       Intel Sunrise Point-LP Thermal subsystem
                       Intel Sunrise Point-LP SMBus
                       Intel Sunrise Point-LP PMC
                       Intel Skylake Gaussian Mixture Model
                       Intel Sunrise Point-LP Serial IO I2C Controller #1
                       Intel Sunrise Point-LP Secure Digital IO Controller
                       Intel SD Host controller
                       Intel Skylake Processor Thermal Subsystem
                       Intel Sunrise Point-LP CSME HECI #1
  /dev/input/event7    Alcor Micro USB 2.0 PC Camera
                       Realtek RTS5129 Card Reader Controller
  /dev/input/event18   Microsoft Nano Transceiver v1.0 for Bluetooth
$ hwinfo --keyboard
23: USB 00.0: 10800 Keyboard
  [Created at usb.122]
  Unique ID: POWV.TfZyh3JdFUB
  Parent ID: k4bc.2DFUsyrieMD
  SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0
  SysFS BusID: 1-9:1.0
  Hardware Class: keyboard
  Model: "Microsoft Nano Transceiver v1.0 for Bluetooth"
  Hotplug: USB
  Vendor: usb 0x045e "Microsoft Corp."
  Device: usb 0x0745 "Nano Transceiver v1.0 for Bluetooth"
  Revision: "2.51"
  Driver: "usbhid"
  Driver Modules: "usbhid"
  Device File: /dev/input/event16
  Device Files: /dev/input/event16, /dev/input/by-id/usb-Microsoft_Microsoft®_2.4GHz_Transceiver_v6.0-event-kbd, /dev/input/by-path/pci-0000:00:14.0-usb-0:9:1.0-event-kbd
  Device Number: char 13:80
  Speed: 12 Mbps
  Module Alias: "usb:v045Ep0745d0251dc00dsc00dp00ic03isc01ip01in00"
  Driver Info #0:
    XkbRules: xfree86
    XkbModel: pc104
  Config Status: cfg=new, avail=yes, need=no, active=unknown
  Attached to: #17 (Hub)
26: PS/2 00.0: 10800 Keyboard
  [Created at input.226]
  Unique ID: c3zD.+49ps10DtUF
  Model: "AT Translated Set 2 keyboard"
  Vendor: 0x0001
  Device: 0x0001 "AT Translated Set 2 keyboard"
  Compatible to: int 0x0211 0x0001
  Device File: /dev/input/event4
  Device Number: char 13:68
  Driver Info #0:
    XkbRules: xfree86
    XkbModel: pc104
$ hwinfo --mouse
30: USB 00.1: 10503 USB Mouse
  Unique ID: sZmZ.iuCQC3hq4TB
  SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1
  SysFS BusID: 1-9:1.1
  Hardware Class: mouse
  Hotplug: USB
  Revision: "2.51"
  Compatible to: int 0x0210 0x0045
  Driver: "usbhid"
  Device File: /dev/input/mice (/dev/input/mouse1)
  Device Files: /dev/input/mice, /dev/input/mouse1, /dev/input/event17, /dev/input/by-id/usb-Microsoft_Microsoft®_2.4GHz_Transceiver_v6.0-if01-event-mouse, /dev/input/by-path/pci-0000:00:14.0-usb-0:9:1.1-event-mouse, /dev/input/by-id/usb-Microsoft_Microsoft®_2.4GHz_Transceiver_v6.0-if01-mouse, /dev/input/by-path/pci-0000:00:14.0-usb-0:9:1.1-mouse
  Device Number: char 13:63 (char 13:33)
  Speed: 12 Mbps
  Module Alias: "usb:v045Ep0745d0251dc00dsc00dp00ic03isc01ip02in01"
  Driver Info #0:
    Buttons: 5
    Wheels: 4
    XFree86 Protocol: explorerps/2
    GPM Protocol: exps2
  Attached to: #34 (Hub)
44: PS/2 00.0: 10500 PS/2 Mouse
  [Created at input.249]
  Unique ID: AH6Q.4LP6853tyN5
  Model: "Goodix Capacitive TouchScreen"
  Vendor: 0x0416
  Device: 0x2397 "Goodix Capacitive TouchScreen"
  Compatible to: int 0x0210 0x0000
  Device File: /dev/input/mice (/dev/input/mouse0)
  Device Files: /dev/input/mice, /dev/input/mouse0, /dev/input/event6, /dev/input/by-path/pci-0000:00:15.1-platform-i2c_designware.1-event
  Device Number: char 13:63 (char 13:32)
  Driver Info #0:
    Buttons: 0
    Wheels: 0
    GPM Protocol: exps2
$ hwinfo --fingerprint
I tried different distros and DE, none of them worked.
I checked in Windows, and the touchpad is separate from the Goodix Figerprint. So I guess my touchpad was never recognized by xinput or libinput in the first place. I looked for its drivers in Windows and it displays an identifier 'SYNA3602.. something'
When I search for SYNA3602 in dmesg I see this:
i2c_hid i2c-SYNA3602:00: unexpected HID descriptor bcdVersion (0x00ff)
I saw some related problems when searching fo SYNA3602 on the web, but in general the device is listed in xinput -list or libinput-list-devices, but mine doesn't.
Any ideas?
What's the model of the whole computer?
inxi -F
$ inxi -F
Resuming in non X mode: xrandr not found. For package install advice run: inxi --recommends
System:    Host: manjaro Kernel: 4.14.19-1-MANJARO x86_64 bits: 64
           Desktop: N/A Distro: Manjaro Linux
Machine:   Device: laptop System: TECLAST product: F6 Pro serial: N/A
           Mobo: TECLAST model: F6 Pro serial: N/A
           UEFI: TECLAST v: S5K2_A1 tPAD 3.10 date: 11/16/2017
Battery    BAT0: charge: 48.4 Wh 99.9% condition: 48.4/50.0 Wh (97%)
CPU:       Dual core Intel Core m3-7Y30 (-MT-MCP-) cache: 4096 KB
           clock speeds: max: 2600 MHz 1: 500 MHz 2: 500 MHz 3: 500 MHz
           4: 500 MHz
Graphics:  Card: Intel Device 591e
           Display Server: N/A drivers: intel (unloaded: modesetting)
           tty size: 80x24
Audio:     Card-1 Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
           Card-2 Alcor Micro driver: USB Audio
           Sound: Advanced Linux Sound Architecture v: k4.14.19-1-MANJARO
Network:   Card: Intel Wireless 3165 driver: iwlwifi
           IF: wlp1s0 state: down mac: 96:4a:d9:52:e9:ca
Drives:    HDD Total Size: NA (-)
           ID-1: /dev/sda model: Teclast_128GB_NS size: 128.0GB
           ID-2: USB /dev/sdb model: Cruzer_Blade size: 15.7GB
Partition: ID-1: / size: 5.8G used: 22M (1%) fs: overlay dev: N/A
Sensors:   System Temperatures: cpu: 34.5C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 170 Uptime: 2 min Memory: 464.8/7893.9MB Init: systemd
           Client: Shell (bash) inxi: 2.3.56
obs: I ran this command from a live USB
Latest reports on the Arch boards is that libinput is once again busted, and it is/was for me also in Arch + GNOME. Workaround was to downgrade to the previous, working libinput.
But I saw a very similar post regarding a fingerprint reader (Yours? Tsk, tsk, don't post in Arch unless you run Arch), and the user was trying and failing to compile a driver for it. I thought about suggesting to that poster to make ensure they had...
pacman -S --needed base-devel
..installed but did not, as any competent Archer would have already known and done so.
regards
I am trying to use my touchpad in Manjaro + XFCE and I don't really care about my fingerprint not working.
About downgrading libinput or installing synaptics; could that solve the touchpad problem, even if it is not listed in hwinfo or cat /proc/bus/input/devices? If so, what is the expected/working libinput version?
Install the package downgrade then run
downgrade xf86-input-libinput
Try all versions starting with the newest.
But I would definitely try to search "TECLAST F6 Pro" + "linux" + "touchpad".
On this forum:
someones says it works with compiled kernel version that can be found here:
https://people.canonical.com/~khfeng/lp1728244-testing/
Can you try?
There is a way to try it on our manjaro distro?
Thank you. I have bookmarked your post.
The laptops I sell got updated so I no longer have the issue and - I cannot test it as I do not have one to test on.
I will see if I can make time to have a look at it.
Regards
hi have the same problem on Schneider SCL142ALM
inxi -F
  Host: schneider-pc Kernel: 4.14.57-1-MANJARO x86_64 bits: 64 Desktop: N/A
  Type: Laptop System: SCHNEIDER product: SCL142ALM v: N/A
  serial: <root required>
  Mobo: N/A model: N/A serial: <root required> UEFI: American Megatrends
  v: 2.6.40_P20S2M251L1T0P1F0G0C0_18Bit_FixEDID date: 01/29/2018
  ID-1: BAT0 charge: 22.3 Wh condition: 36.5/36.5 Wh (100%)
  Topology: Dual Core model: Intel Celeron N3350 bits: 64 type: MCP
  L2 cache: 1024 KiB
  Speed: 2288 MHz min/max: 800/2400 MHz Core speeds (MHz): 1: 2157 2: 2122
  Card-1: Intel driver: i915 v: kernel
  Display: x11 server: X.Org 1.19.6 driver: intel resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 500 (Broxton 2x6)
  v: 4.5 Mesa 18.1.4
  Card-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
  Sound Server: ALSA v: k4.14.57-1-MANJARO
  Card-1: Intel Wireless 3165 driver: iwlwifi
  IF: wlp1s0 state: up mac: f8:63:3f:84:46:a8
  Local Storage: total: 29.12 GiB used: 7.73 GiB (26.6%)
  ID-1: /dev/mmcblk0 model: DF4032 size: 29.12 GiB
  ID-1: / size: 20.26 GiB used: 7.73 GiB (38.2%) fs: ext4
  dev: /dev/mmcblk0p2
  ID-2: swap-1 size: 8.12 GiB used: 0 KiB (0.0%) fs: swap
  dev: /dev/mmcblk0p3
  System Temperatures: cpu: 56.0 C mobo: N/A
  Processes: 168 Uptime: 9m Memory: 3.69 GiB used: 1.29 GiB (34.9%)
  Shell: bash inxi: 3.0.18
Device:           Video Bus
Kernel:           /dev/input/event6
Group:            1
Capabilities:     keyboard
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Middle emulation: n/a
Calibration:      n/a
Scroll methods:   none
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           Lid Switch
Kernel:           /dev/input/event3
Group:            2
Capabilities:     switch
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           Power Button
Kernel:           /dev/input/event4
Group:            3
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH HDMI/DP,pcm=3
Kernel:           /dev/input/event10
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH HDMI/DP,pcm=7
Kernel:           /dev/input/event11
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH HDMI/DP,pcm=8
Kernel:           /dev/input/event12
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH HDMI/DP,pcm=9
Kernel:           /dev/input/event13
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH HDMI/DP,pcm=10
Kernel:           /dev/input/event14
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH Mic
Kernel:           /dev/input/event8
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH Headphone
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           Areson Corp. USB Device
Kernel:           /dev/input/event15
Group:            5
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Calibration:      n/a
Click methods:    none
Rotation:         n/a
Device:           USB 2.0 Camera : USB 2.0 Camera
Kernel:           /dev/input/event7
Group:            6
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           Intel HID events
Group:            7
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           Intel HID 5 button array
Kernel:           /dev/input/event2
Group:            8
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           AT Translated Set 2 keyboard
Kernel:           /dev/input/event0
Group:            9
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Have try kernel 4.14 / 4.17 / 4.18
On boot have this error :
if you have any idea ?
Cordialy
@klox: the issue with the SYNA3602 touchpad is kinda fixed with KDE v18.0-beta-4. You can get it from here. More info about your problem here.
@liberodark: always post hwinfo --mouse and dmesg content, so we are able to help.
Im on XFCE x64 manjaro 17.1.11 is ok?
