Touchpad not working properly in KDE Plasma
Yesterday I installed Manjaro KDE on my laptop and I noticed, that the toucpad isn't working properly. I can do left/right click, but I'm not able to move the mouse cursor or scroll up and down. In the KDE Systemsettings app I can change the options for the touchpad (buttons, sliders, etc.), but the first line at the top where it says "Device: SYNA7DB5:00 06CB:7DB7 Touchpad" is greyed out. Could this be a driver issue? Does anyone how to gett it working properly?
Please provide from terminal:
inxi -Fxxxza --no-host
In principle i think is the same issue as described here
https://bugzilla.kernel.org/show_bug.cgi?id=205745
So, update the system, test with a different kernel too.
This is the output:
  Kernel: 5.7.0-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
  root=UUID=4162dd6a-20d2-408c-b413-484f213d17c4 rw quiet apparmor=1
  security=apparmor resume=UUID=20f14307-f739-4ac8-8c8d-d550588d864b
  udev.log_priority=3
  Desktop: KDE Plasma 5.18.5 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Laptop System: Acer product: Aspire F5-573G v: V1.12 serial: <filter>
  Mobo: Acer model: Captain_SK v: V1.12 serial: <filter> UEFI: Insyde v: 1.12
  date: 08/02/2016
  Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
  arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: CA
  L2 cache: 3072 KiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21607
  Speed: 500 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 500 2: 500 3: 500
  4: 500
  Type: l1tf
  Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:5916
  Device-2: NVIDIA GM107 [GeForce 940MX] vendor: Acer Incorporated ALI
  driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:179c
  Display: x11 server: X.Org 1.20.8 driver: intel,nouveau unloaded: modesetting
  alternate: fbdev,nv,vesa compositor: kwin_x11 resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.0.7
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:9d71
  Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
  vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus ID: 01:00.1
  chip ID: 10de:0fbc
  Sound Server: ALSA v: k5.7.0-3-MANJARO
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: Lite-On driver: ath10k_pci v: kernel port: 4000 bus ID: 03:00.0
  chip ID: 168c:0042
  vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
  bus ID: 04:00.1 chip ID: 10ec:8168
  IF: enp4s0f1 state: down mac: <filter>
  Local Storage: total: 1.03 TiB used: 233.45 GiB (22.2%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB block size:
  physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm
  serial: <filter> rev: 5J scheme: GPT
  ID-2: /dev/sdb vendor: SK Hynix model: HFS128G39TND-N210A size: 119.24 GiB
  block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
  rev: 1P10 scheme: GPT
  ID-1: / raw size: 110.15 GiB size: 107.92 GiB (97.98%) used: 13.33 GiB (12.4%)
  fs: ext4 dev: /dev/sdb2
  ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap
  swappiness: 60 (default) cache pressure: 100 (default) dev: /dev/sdb3
  System Temperatures: cpu: 57.0 C mobo: N/A
  Processes: 222 Uptime: 2m Memory: 7.65 GiB used: 1.30 GiB (17.1%) Init: systemd
  v: 245 Compilers: gcc: 10.1.0 Shell: bash v: 5.0.17 running in: konsole
  inxi: 3.0.37
After reading a bit about it, it seems that model has a Synaptics touchpad. It should work with libinput, but maybe not, so try to follow this:
https://wiki.archlinux.org/index.php/Touchpad_Synaptics
So my system is up to date (stable branch), I tried with kernel 5.6 and 5.7. I also installed the xf86-input-synaptics package. Sometimes it works when I boot the system and move cursor right after seeing the it for the first time. But when I stop moving the cursor, it won't move the cursor again and only left and right click are working.
