My laptop's default lid closing behaviour is set to suspend.
After lifting the laptop, the wifi and trackpad are disabled.
How do I restart them right after lifting the lid.
The wifi is usually able to be fixed by writing a systemd service. I have worked on many of those issues. The trackpad issue could probably be fixed in the same way, but I have never worked on that issue and am unfamiliar with the particulars of that end.
Here are some links with pertinent information:
You will find many other posts on this topic if you search the forum. Here are some other links:
https://archived.forum.manjaro.org/t/surface-pro-1796-wifi-not-resuming-after-suspend/48133/47
Here are some external links with excellent systemd reference material:
Please post:
inxi -Fxxz
Information on how to properly post hardware specs and logs:
Please format any terminal output with three backticks before and after, as shown in this picture:
Thanks for writing such a comprehensive answer.
➜ ~ inxi -Fxxz
System: Host: Amnesiac Kernel: 4.19.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Desktop: KDE Plasma 5.14.5
tk: Qt 5.12.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Hewlett-Packard product: HP Pavilion Notebook v: Type1ProductConfigId serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 8096 v: 89.33 serial: <filter> UEFI: Insyde v: F.80 date: 06/14/2016
Battery: ID-1: BAT0 charge: 18.2 Wh condition: 37.8/37.8 Wh (100%) volts: 14.3/14.6 model: Hewlett-Packard Primary
serial: <filter> status: Discharging
CPU: Topology: Dual Core model: Intel Core i7-5500U bits: 64 type: MT MCP arch: Broadwell rev: 4 L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19161
Speed: 798 MHz min/max: 500/3000 MHz Core speeds (MHz): 1: 798 2: 799 3: 798 4: 799
Graphics: Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:1616
Device-2: NVIDIA GM108M [GeForce 940M] driver: N/A bus ID: 0a:00.0 chip ID: 10de:1347
Display: x11 server: X.Org 1.20.3 driver: intel compositor: kwin_x11 resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2) v: 4.5 Mesa 18.3.2 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:9ca0
Sound Server: ALSA v: k4.19.16-1-MANJARO
Network: Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtl8723be v: kernel
port: 5000 bus ID: 08:00.0 chip ID: 10ec:b723
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000
bus ID: 09:00.0 chip ID: 10ec:8136
Drives: Local Storage: total: 931.51 GiB used: 43.47 GiB (4.7%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 97.93 GiB used: 43.36 GiB (44.3%) fs: ext4 dev: /dev/sda11
Sensors: System Temperatures: cpu: 40.0 C mobo: N/A
Info: Processes: 209 Uptime: 1h 03m Memory: 7.71 GiB used: 2.14 GiB (27.7%) Init: systemd v: 239 Compilers:
gcc: 8.2.1 Shell: zsh v: 5.6.2 running in: konsole inxi: 3.0.30
This adapter is a litany of horrors. Which adapter driver are you using.
Upgrade to kernel 4.20 through Manjaro Settings Manager.
Please do this troubleshooting:
- Boot to your session/DE
- Record your session details
loginctl show-session $XDG_SESSION_ID > mysession.log
- Let your system suspend, or manually suspend (however your issue would appear)
- Wake up your system and record again your session to the same file
echo "====After suspend====" >> mysession.log
loginctl show-session $XDG_SESSION_ID >> mysession.log
- Post
mysession.log
➜ ~ cat mysession.log
Id=1
User=1000
Name=arpit
Timestamp=Wed 2019-01-30 21:12:37 IST
TimestampMonotonic=26401304
VTNr=1
Seat=seat0
Display=:0
Remote=no
Service=sddm-autologin
Desktop=KDE
Scope=session-1.scope
Leader=709
Audit=1
Type=x11
Class=user
Active=yes
State=active
IdleHint=no
IdleSinceHint=0
IdleSinceHintMonotonic=0
LockedHint=no
Id=1
User=1000
Name=arpit
VTNr=1
Seat=seat0
Display=:0
Remote=no
Desktop=KDE
Leader=709
Audit=1
Type=x11
Class=user
Active=yes
State=active
IdleHint=no
IdleSinceHint=0
LockedHint=no
Upgrading the kernel did not help. The issue still persists.
Sorry, no fish in the net...
About your wifi, either restart NetworkManager, or use one of @tbg service units
sudo systemctl restart NetworkManager
About your trackpad, check if changing TTY back and forth will make it wake.
- After suspend, Ctrl+Alt+F3 and then Ctrl+Alt+F1 (or other "Fx" depending..)
Please post the output of the following command:
hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" | grep -v "Config Status"
➜ ~ hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" | grep -v "Config Status"
Model: "Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller"
Driver: "r8169"
Device File: eno1
Link detected: no
Driver Status: r8169 is active
Driver Activation Cmd: "modprobe r8169"
Model: "Realtek RTL8723BE PCIe Wireless Network Adapter"
Driver: "rtl8723be"
Device File: wlo1
Link detected: yes
Driver Status: rtl8723be is active
Driver Activation Cmd: "modprobe rtl8723be"
Model: "Realtek Bluetooth Radio"
Driver: "btusb"
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
Both of these solutions don't work.
What solutions. Post what you tried. If you tried to fix this with a service file then post the unit (s) you used.
Please give details when you have tested different solutions. If you are running commands post both the input and output and all errors received. You cannot possibly expect anyone to troubleshoot your issues when you provide no details on your troubleshooting efforts.
Here are two service units that should enable your wifi when you resume.
You will need to enable both services after you create the service files.
Suspend unit:
#/etc/systemd/system/network-suspend.service
#sudo systemctl enable network-suspend.service
#sudo systemctl start network-suspend.service
#sudo systemctl status network-suspend.service
#sudo systemctl daemon-reload
[Unit]
Description=Network suspend service
Before=sleep.target
StopWhenUnneeded=yes
[Service]
User=root
Type=oneshot
RemainAfterExit=yes
ExecStart=/usr/bin/sudo -u $USER /bin/bash -lc 'nmcli networking off'
ExecStart=/usr/bin/sleep 1
ExecStart=/usr/bin/systemctl stop NetworkManager
ExecStart=/usr/bin/ip link set wlo1 down
ExecStartPost=/usr/bin/modprobe -r rtl8723be
[Install]
WantedBy=sleep.target
Resume unit:
#/etc/systemd/system/network-resume.service
#sudo systemctl enable network-resume.service
#sudo systemctl start network-resume.service
#sudo systemctl status network-resume.service
[Unit]
Description=Network resume service
After=suspend.target
[Service]
User=root
Type=oneshot
RemainAfterExit=yes
ExecStartPre=/usr/bin/sleep 10
ExecStart=/usr/bin/modprobe rtl8723be
ExecStart=/usr/bin/sleep 2
ExecStart=/usr/bin/ip link set wlo1 up
ExecStart=/usr/bin/systemctl start NetworkManager
ExecStart=/usr/bin/sudo -u $USER /bin/bash -lc 'nmcli networking on'
ExecStart=/usr/bin/sudo -u $USER /bin/bash -lc 'nmcli r wifi off'
ExecStart=/usr/bin/sudo -u $USER /bin/bash -lc 'nmcli r wifi on'
[Install]
WantedBy=suspend.target
If you have any further questions regarding writing, enabling, or checking the current status of your service please read the links posted several times already on this thread.
