Hello Everyone,
As the topic suggests, I've tried multiple avenues to add the scanner of my all-in-one printer, the Brother MFC-9130CW.
So far I have successfully added print capability using the AUR MFC-9130CW driver, printer-config command, CUPS, etc.
For scanning I have gone to the brother website and added the brother scan utility. I cannot get recognized in document scanner (simple-scan) or xsane.
Vuescan DOES work, but I do not wish to purchase it if I can help it.
Any ideas?
Sincerely,
Brian
System: Kernel: 5.7.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: Gnome 3.36.4 wm: gnome-shell
dm: GDM 3.36.3 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: X570 Taichi serial: <filter> UEFI: American Megatrends v: P1.10 date: 06/12/2019
Memory: RAM: total: 15.56 GiB used: 2.61 GiB (16.8%)
CPU: Topology: 6-Core model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen L2 cache: 3072 KiB bogomips: 91234
Speed: 2002 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 2050 2: 1996 3: 2209 4: 2212 5: 2627
6: 2208 7: 2203 8: 2209 9: 2022 10: 1941 11: 2930 12: 2211
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht
hw_pstate ibpb ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev
sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
Graphics: Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: Micro-Star MSI driver: nvidia v: 440.100 bus ID: 0e:00.0
chip ID: 10de:1e81
Display: x11 server: X.org 1.20.8 driver: nvidia compositor: gnome-shell resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce RTX 2080 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes
Audio: Device-1: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 0e:00.1
chip ID: 10de:10f8
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 10:00.4 chip ID: 1022:1487
Device-3: SteelSeries ApS SteelSeries Arctis 7 type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-4:3
chip ID: 1038:1260
Sound Server: ALSA v: k5.7.9-1-MANJARO
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 06:00.0 chip ID: 8086:2723
IF: wlp6s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: 5.6.0-k port: f000 bus ID: 08:00.0
chip ID: 8086:1539
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives: Local Storage: total: 2.04 TiB used: 73.51 GiB (3.5%)
ID-1: /dev/nvme0n1 vendor: Corsair model: Force MP600 size: 931.51 GiB speed: 63.2 Gb/s lanes: 4 serial: <filter>
rev: EGFM11.1 scheme: MBR
ID-2: /dev/sda vendor: Mushkin model: MKNSSDCR120GB size: 111.79 GiB speed: 6.0 Gb/s serial: <filter> rev: BBF0
scheme: GPT
ID-3: /dev/sdb type: USB vendor: Toshiba model: MQ04UBF100 size: 931.51 GiB rotation: 5400 rpm serial: <filter>
scheme: MBR
ID-4: /dev/sdc type: USB vendor: SanDisk model: Ultra size: 114.61 GiB serial: <filter> rev: 1.00 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BDDVDRW CH08LS10 rev: 2.00 dev-links: cdrom
Features: speed: 125 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
RAID: Message: No RAID data was found.
Partition: ID-1: / size: 109.24 GiB used: 68.35 GiB (62.6%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 3c5e582a-2994-49be-9c92-2c94d2228689
ID-2: /boot/efi size: 299.4 MiB used: 25.3 MiB (8.4%) fs: vfat dev: /dev/sda1 label: N/A uuid: 86D8-2786
ID-3: /run/media/carne/6A3F-7584 size: 114.58 GiB used: 100.0 MiB (0.1%) fs: vfat dev: /dev/sdc1 label: N/A
uuid: 6A3F-7584
ID-4: /run/media/carne/UEFI_NTFS size: 494 KiB used: 468 KiB (94.7%) fs: vfat dev: /dev/sdb2 label: UEFI_NTFS
uuid: 0A8D-A13D
ID-5: /run/media/carne/Windows USB size: 931.51 GiB used: 5.04 GiB (0.5%) fs: ntfs dev: /dev/sdb1
label: Windows USB uuid: 3D0E0680180368E8
ID-6: /var/lib/snapd/snap/core18/1880 raw size: 55.0 MiB size: <root required> used: <root required> fs: squashfs
dev: /dev/loop3 label: N/A uuid: N/A
ID-7: /var/lib/snapd/snap/gtk-common-themes/1506 raw size: 62.1 MiB size: <root required> used: <root required>
fs: squashfs dev: /dev/loop4 label: N/A uuid: N/A
ID-8: /var/lib/snapd/snap/leagueoflegends/76 raw size: 92 KiB size: <root required> used: <root required>
fs: squashfs dev: /dev/loop1 label: N/A uuid: N/A
ID-9: /var/lib/snapd/snap/snapd/8542 raw size: 29.9 MiB size: <root required> used: <root required> fs: squashfs
dev: /dev/loop0 label: N/A uuid: N/A
ID-10: /var/lib/snapd/snap/wine-platform-5-staging/11 raw size: 212.0 MiB size: <root required>
used: <root required> fs: squashfs dev: /dev/loop6 label: N/A uuid: N/A
ID-11: /var/lib/snapd/snap/wine-platform-5-staging/7 raw size: 89.7 MiB size: <root required> used: <root required>
fs: squashfs dev: /dev/loop2 label: N/A uuid: N/A
ID-12: /var/lib/snapd/snap/wine-platform-runtime/145 raw size: 226.7 MiB size: <root required>
used: <root required> fs: squashfs dev: /dev/loop7 label: N/A uuid: N/A
ID-13: /var/lib/snapd/snap/wine-platform-runtime/156 raw size: 226.9 MiB size: <root required>
used: <root required> fs: squashfs dev: /dev/loop5 label: N/A uuid: N/A
Unmounted: ID-1: /dev/nvme0n1p1 size: 579.0 MiB fs: vfat label: N/A uuid: 19B7-5016
ID-2: /dev/nvme0n1p2 size: 930.95 GiB fs: ntfs label: FF7DISC1 uuid: 74B0BCE4B0BCADCC
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 05e3:0608
Device-1: 3-4:3 info: SteelSeries ApS SteelSeries Arctis 7 type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid
interfaces: 6 rev: 1.1 speed: 12 Mb/s chip ID: 1038:1260
Device-2: 3-5:4 info: Corsair Corsair Gaming K55 RGB Keyboard type: Keyboard,HID driver: hid-generic,usbhid
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 1b1c:1b3d serial: <filter>
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Device-3: 4-2:2 info: SanDisk Ultra type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s
chip ID: 0781:5581 serial: <filter>
Hub: 5-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-4: 5-2:2 info: Intel type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0029
Hub: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Device-5: 6-3:2 info: Toshiba America Canvio Advance 2TB model DTC920 type: Mass Storage driver: usb-storage
interfaces: 1 rev: 3.0 speed: 5 Gb/s chip ID: 0480:0821 serial: <filter>
Hub: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 9-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-6: 9-3:2 info: Logitech G203 Gaming Mouse type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 046d:c084 serial: <filter>
Device-7: 9-4:3 info: SCM Microsystems SCR331 SmartCard Reader type: Smart Card driver: usbfs interfaces: 1
rev: 2.0 speed: 12 Mb/s chip ID: 04e6:e001 serial: <filter>
Hub: 10-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 47.9 C mobo: N/A gpu: nvidia temp: 31 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Info: Processes: 375 Uptime: 2h 03m Init: systemd v: 245 Compilers: gcc: 10.1.0 Shell: zsh v: 5.8 running in: terminator
inxi: 3.0.37
