Trouble with Function Keys
Hey there,
I'm pretty new to Manjaro and I just installed it on my Convertible and my PC. I'm using the KDE Edition and I'm having some issues with my keyboard. My Keyboard has an FN-Key, and Brightness Up and Down Keys. When I go to Setting>Shortcuts, the Brightness Keys are set to Brightness Down for Brightness Down and Brightness Up for Brightness up.
The Problem now seems to be that Manjaro treats all 3 Keys the same, recognizes them as Brightness Down. When I press FN, it toggles between F1/F2 and Brightness Control but also decreases Brightness. When I press Brightness Up, it also turns Brightness Down instead of increasing it.
Do you have any suggestions on how to deal with this problem? I could not find anything helpful while researching.
Greetings,
Jannis
welcom to the forum, can you please provide more info, please post output of these commands.
inxi -Fxxxz
hwinfo --keyboard
lsmod | grep -Ei 'kbd|wmi|laptop|i8042|serio'
please use the </> button when posting terminal output so it's formatted properly. you can also do this with 3 backtics ``` above and below posted output.
Hey, here are the outputs of the commands:
inxi -Fxxxz:
System:    Host: jannis-matebook-e Kernel: 4.19.45-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: KDE Plasma 5.15.5
           tk: Qt 5.12.3 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Detachable System: HUAWEI product: HUAWEI MateBook E v: 2.1 serial: <filter> Chassis: type: 32
           serial: <filter>
           Mobo: HUAWEI model: HUAWEI MateBook E v: 2.1 serial: <filter> UEFI: HUAWEI v: 2.07 date: 10/31/2018
Battery:   ID-1: BAT0 charge: 29.4 Wh condition: 29.4/32.7 Wh (90%) volts: 8.6/7.6 model: Cartier BASE-BAT type: Unknown
           serial: <filter> status: Full cycles: 203
CPU:       Topology: Dual Core model: Intel Core i5-7Y54 bits: 64 type: MT MCP arch: Kaby Lake rev: 9 L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12868
           Speed: 600 MHz min/max: 400/3200 MHz Core speeds (MHz): 1: 600 2: 600 3: 600 4: 600
Graphics:  Device-1: Intel HD Graphics 615 vendor: Huawei driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:591e
           Display: x11 server: X.Org 1.20.4 driver: intel unloaded: modesetting alternate: fbdev,vesa compositor: kwin_x11
           resolution: 2160x1440~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 615 (Kaby Lake GT2) v: 4.5 Mesa 19.0.4 compat-v: 3.0
           direct render: Yes
Audio:     Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging Unit vendor: Huawei driver: N/A
           bus ID: 00:05.0 chip ID: 8086:1919
           Device-2: Intel vendor: Huawei driver: N/A bus ID: 00:14.3 chip ID: 8086:9d32
           Device-3: Intel Sunrise Point-LP HD Audio vendor: Huawei driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           chip ID: 8086:9d71
           Sound Server: ALSA v: k4.19.45-1-MANJARO
Network:   Device-1: Intel Wireless 8265 / 8275 vendor: Huawei driver: iwlwifi v: kernel port: 3040 bus ID: 01:00.0
           chip ID: 8086:24fd
           IF-ID-1: anbox0 state: up speed: N/A duplex: N/A mac: <filter>
           IF-ID-2: vethN3U7HU state: up speed: 10000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 238.47 GiB used: 61.87 GiB (25.9%)
           ID-1: /dev/sda vendor: SanDisk model: SD8SN8U256G1027 size: 238.47 GiB speed: 6.0 Gb/s serial: <filter> rev: 0000
           scheme: GPT
Partition: ID-1: / size: 225.63 GiB used: 61.86 GiB (27.4%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 7.92 GiB used: 14.8 MiB (0.2%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 44.0 C mobo: N/A
Info:      Processes: 253 Uptime: 8m Memory: 3.60 GiB used: 1.72 GiB (47.8%) Init: systemd v: 242 Compilers: gcc: 8.3.0
           Shell: bash v: 5.0.7 running in: konsole inxi: 3.0.34
hwinfo --keyboard:
12: USB 00.0: 10800 Keyboard
  [Created at usb.122]
  Unique ID: 2UT6.H_+HStFlrc1
  Parent ID: k4bc.2DFUsyrieMD
  SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0
  SysFS BusID: 1-3:1.0
  Hardware Class: keyboard
  Model: "Huawei USB-HID KB MS"
  Hotplug: USB
  Vendor: usb 0x12d1 "Huawei Technologies Co., Ltd."
  Device: usb 0x1097 "USB-HID KB MS"
  Revision: "2.00"
  Driver: "usbhid"
  Driver Modules: "usbhid"
  Device File: /dev/input/event4
  Device Files: /dev/input/event4, /dev/input/by-id/usb-HOLTEK_USB-HID_KB_MS-event-kbd, /dev/input/by-path/pci-0000:00:14.0-usb-0:3:1.0-event-kbd
  Device Number: char 13:68
  Speed: 12 Mbps
  Module Alias: "usb:v12D1p1097d0200dc00dsc00dp00ic03isc01ip01in00"
  Driver Info #0:
    XkbRules: xfree86
    XkbModel: pc104
  Config Status: cfg=new, avail=yes, need=no, active=unknown
  Attached to: #13 (Hub)
18: PS/2 00.0: 10800 Keyboard
  [Created at input.226]
  Unique ID: 9ui9.+49ps10DtUF
  Model: "AT Translated Set 2 keyboard"
  Vendor: 0x0001
  Device: 0x0001 "AT Translated Set 2 keyboard"
  Compatible to: int 0x0211 0x0001
  Device File: /dev/input/event3
  Device Files: /dev/input/event3, /dev/input/by-path/platform-i8042-serio-0-event-kbd
  Device Number: char 13:67
  Driver Info #0:
    XkbRules: xfree86
    XkbModel: pc104
lsmod | grep -Ei 'kdb|wmi|laptop|i8042|serio' :
wmi_bmof               16384  0
intel_wmi_thunderbolt    16384  0
wmi                    28672  2 intel_wmi_thunderbolt,wmi_bmof
serio_raw              16384  0
i8042                  32768  0
serio                  28672  4 serio_raw,atkbd,i8042
