Hi!
This is my first post here
I am determined to install Manjaro (i3 edition) on my new desktop PC. It has no chipset, but an AMD ryzen 5 3600 and a RTX 2060 Super from Nvidia.
I also own a portable computer which does have a chipset.
I can successfully boot Manjaro on my portable computer but unfortunately, I can't get to boot it completely on my desktop computer.
I am selecting the french keyboard disposition, the french language (fr-fr) and the non-free drivers.
After hitting the "boot" button, after a bit of loading, I am getting stuck on the "Started TLP system startup/shutdown" message.
This is really annoying and I have been trying to fix it for the whole week now. I tried a lot of solutions involving to change the kernel parameters at boot time, but this didn't change anything.
I disabled CSM and secure boot in the BIOS, and Fast Boot directly from Windows since I cannot find the option directly in my BIOS. I also checked the SHA of the downloaded image.
I am not wanting to use architect, I would like to use the normal way.
I think that this is maybe related to my graphic card, but why is Manjaro not supported on RTX cards?
I thank you all in advance for your help, I really need it!
