Unable to get a display out with a Manjaro Virtual Machine through VFIO - 5700 XT
Hey all, I seemingly cannot get my video card to output anything with PCI passthrough. I have a 5700 XT.
These are the things I have done:
  1. Went through all the PCI Passhthrough steps, and have gotten my 5700 XT working great in a windows virtual machine.
  2. Installed the latest Manjaro Gnome, I have been using VNC to install all updates and set everything up. Upgraded kernel and applied all updates.
Now, I have been trying to see what could be the issue. I have some information:
lspci -vv shows:
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] (rev c1) (prog-if 00 [VGA controller])
	Subsystem: XFX Pine Group Inc. Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
	Physical Slot: 0
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 35
	Region 0: Memory at d0000000 (64-bit, prefetchable) [size=256M]
	Region 2: Memory at e0000000 (64-bit, prefetchable) [size=2M]
	Region 4: I/O ports at 5000 [size=256]
	Region 5: Memory at fe800000 (32-bit, non-prefetchable) [size=512K]
	Expansion ROM at fe880000 [disabled] [size=512K]
	Capabilities: [48] Vendor Specific Information: Len=08 <?>
	Capabilities: [50] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1+,D2+,D3hot+,D3cold+)
		Status: D3 NoSoftRst+ PME-Enable+ DSel=0 DScale=0 PME-
	Capabilities: [64] Express (v2) Legacy Endpoint, MSI 00
		DevCap:	MaxPayload 256 bytes, PhantFunc 0, Latency L0s <4us, L1 unlimited
			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
		DevCtl:	CorrErr- NonFatalErr- FatalErr- UnsupReq-
			RlxdOrd- ExtTag+ PhantFunc- AuxPwr- NoSnoop+
			MaxPayload 128 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
		LnkCap:	Port #0, Speed 16GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk+
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 16GT/s (ok), Width x16 (ok)
			TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, NROPrPrP-, LTR+
			 10BitTagComp+, 10BitTagReq+, OBFF Not Supported, ExtFmt+, EETLPPrefix+, MaxEETLPPrefixes 1
			 EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
			 FRS-
			 AtomicOpsCap: 32bit+ 64bit+ 128bitCAS-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
			 AtomicOpsCtl: ReqEn-
		LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance De-emphasis: -6dB
		LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+, EqualizationPhase1+
			 EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
	Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 00000000fee06000  Data: 4022
	Capabilities: [100 v1] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
	Capabilities: [150 v2] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
		AERCap:	First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
			MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
		HeaderLog: 00000000 00000000 00000000 00000000
	Capabilities: [240 v1] Power Budgeting <?>
	Capabilities: [2a0 v1] Access Control Services
		ACSCap:	SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
		ACSCtl:	SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
	Capabilities: [2b0 v1] Address Translation Service (ATS)
		ATSCap:	Invalidate Queue Depth: 00
		ATSCtl:	Enable+, Smallest Translation Unit: 00
	Capabilities: [2c0 v1] Page Request Interface (PRI)
		PRICtl: Enable- Reset-
		PRISta: RF- UPRGI- Stopped+
		Page Request Capacity: 00000100, Page Request Allocation: 00000000
	Capabilities: [320 v1] Latency Tolerance Reporting
		Max snoop latency: 0ns
		Max no snoop latency: 0ns
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
So I see that the driver is loaded.
xrandr --listmonitors only shows my vnc monitor
xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x41 cap: 0x0 crtcs: 1 outputs: 1 associated providers: 0 name:modesetting
Provider 1: id: 0x7a cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 6 outputs: 4 associated providers: 0 name:AMD Radeon RX 5700 XT @ pci:0000:01:00.0
dmesg | grep amd
[    3.191426] [drm] amdgpu kernel modesetting enabled.
[    3.220725] amdgpu 0000:01:00.0: VRAM: 8176M 0x0000008000000000 - 0x00000081FEFFFFFF (8176M used)
[    3.220726] amdgpu 0000:01:00.0: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
[    3.220757] [drm] amdgpu: 8176M of VRAM memory ready
[    3.220759] [drm] amdgpu: 8176M of GTT memory ready.
[    3.621388] amdgpu 0000:01:00.0: sos fw version = 0x100050.
[    3.621390] amdgpu 0000:01:00.0: sos fw version = 0x100050.
[    3.820180] amdgpu 0000:01:00.0: RAS: optional ras ta ucode is not available
[    4.044273] amdgpu 0000:01:00.0: fb1: amdgpudrmfb frame buffer device
[    4.044322] amdgpu 0000:01:00.0: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[    4.044323] amdgpu 0000:01:00.0: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[    4.044324] amdgpu 0000:01:00.0: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[    4.044325] amdgpu 0000:01:00.0: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[    4.044327] amdgpu 0000:01:00.0: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[    4.044328] amdgpu 0000:01:00.0: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[    4.044329] amdgpu 0000:01:00.0: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[    4.044330] amdgpu 0000:01:00.0: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[    4.044331] amdgpu 0000:01:00.0: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[    4.044332] amdgpu 0000:01:00.0: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[    4.044333] amdgpu 0000:01:00.0: ring sdma0 uses VM inv eng 12 on hub 0
[    4.044334] amdgpu 0000:01:00.0: ring sdma1 uses VM inv eng 13 on hub 0
[    4.044335] amdgpu 0000:01:00.0: ring vcn_dec uses VM inv eng 0 on hub 1
[    4.044336] amdgpu 0000:01:00.0: ring vcn_enc0 uses VM inv eng 1 on hub 1
[    4.044337] amdgpu 0000:01:00.0: ring vcn_enc1 uses VM inv eng 4 on hub 1
[    4.044338] amdgpu 0000:01:00.0: ring jpeg_dec uses VM inv eng 5 on hub 1
[    4.044919] [drm] Initialized amdgpu 3.37.0 20150101 for 0000:01:00.0 on minor 1
cat /home/xxx/.local/share/xorg/Xorg.0.log
[     4.724] (--) Log file renamed from "/home/xxx/.local/share/xorg/Xorg.pid-1010.log" to "/home/xxx/.local/share/xorg/Xorg.0.log"
[     4.725] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[     4.726]
X.Org X Server 1.20.8
[     4.726] Build Operating System: Linux Manjaro Linux
[     4.726] Current Operating System: Linux xxx-virt 5.7.0-3-MANJARO #1 SMP PREEMPT Wed Jun 3 03:15:33 UTC 2020 x86_64
[     4.726] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=3c532e01-dbce-4454-be04-80a4f64100b3 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[     4.726] Build Date: 03 June 2020  10:02:55AM
[     4.726]
[     4.726] Current version of pixman: 0.40.0
[     4.726] 	Before reporting problems, check http://wiki.x.org
[     4.726] Markers: (--) probed, (**) from config file, (==) default setting,
[     4.726] (==) Log file: "/home/xxx/.local/share/xorg/Xorg.0.log", Time: Fri Jul 17 09:49:17 2020
[     4.728] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     4.728] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     4.730] (==) No Layout section.  Using the first Screen section.
[     4.730] (==) No screen section available. Using defaults.
[     4.730] (**) |-->Screen "Default Screen Section" (0)
[     4.730] (**) |   |-->Monitor "<default monitor>"
[     4.730] (==) No monitor specified for screen "Default Screen Section".
[     4.730] (==) Automatically adding devices
[     4.730] (==) Automatically enabling devices
[     4.730] (==) Automatically adding GPU devices
[     4.730] (==) Automatically binding GPU devices
[     4.730] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     4.732] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     4.732] 	Entry deleted from font path.
[     4.732] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     4.732] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     4.732] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     4.733] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     4.733] 	Entry deleted from font path.
[     4.733] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     4.733] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     4.733] (==) ModulePath set to "/usr/lib/xorg/modules"
[     4.733] (II) The server relies on udev to provide the list of input devices.
[     4.733] (II) Module ABI versions:
[     4.733] 	X.Org ANSI C Emulation: 0.4
[     4.733] 	X.Org Video Driver: 24.1
[     4.733] 	X.Org XInput driver : 24.1
[     4.733] 	X.Org Server Extension : 10.0
[     4.733] (++) using VT number 2
[     4.735] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[     4.736] (II) xfree86: Adding drm device (/dev/dri/card0)
[     4.737] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[     4.737] (II) xfree86: Adding drm device (/dev/dri/card1)
[     4.738] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[     4.741] (--) PCI:*(0@0:1:0) 1234:1111:1af4:1100 rev 2, Mem @ 0xf0000000/16777216, 0xfea14000/4096, BIOS @ 0x????????/131072
[     4.741] (--) PCI: (1@0:0:0) 1002:731f:1682:5701 rev 193, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfe800000/524288, I/O @ 0x00005000/256, BIOS @ 0x????????/524288
[     4.741] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     4.741] (II) LoadModule: "glx"
[     4.743] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     4.754] (II) Module glx: vendor="X.Org Foundation"
[     4.754] 	compiled for 1.20.8, module version = 1.0.0
[     4.754] 	ABI class: X.Org Server Extension, version 10.0
[     4.754] (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
[     4.754] 	loading driver: amdgpu
[     4.754] (==) Matched amdgpu as autoconfigured driver 0
[     4.754] (==) Matched ati as autoconfigured driver 1
[     4.754] (==) Matched modesetting as autoconfigured driver 2
[     4.754] (==) Matched fbdev as autoconfigured driver 3
[     4.754] (==) Matched vesa as autoconfigured driver 4
[     4.754] (==) Assigned the driver to the xf86ConfigLayout
[     4.754] (II) LoadModule: "amdgpu"
[     4.754] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[     4.759] (II) Module amdgpu: vendor="X.Org Foundation"
[     4.759] 	compiled for 1.20.8, module version = 19.1.0
[     4.759] 	Module class: X.Org Video Driver
[     4.759] 	ABI class: X.Org Video Driver, version 24.1
[     4.759] (II) LoadModule: "ati"
[     4.759] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[     4.759] (II) Module ati: vendor="X.Org Foundation"
[     4.760] (II) LoadModule: "modesetting"
[     4.760] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     4.761] (II) Module modesetting: vendor="X.Org Foundation"
[     4.761] 	compiled for 1.20.8, module version = 1.20.8
[     4.761] 	Module class: X.Org Video Driver
[     4.761] 	ABI class: X.Org Video Driver, version 24.1
[     4.761] (II) LoadModule: "fbdev"
[     4.762] (WW) Warning, couldn't open module fbdev
[     4.762] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     4.762] (II) LoadModule: "vesa"
[     4.762] (WW) Warning, couldn't open module vesa
[     4.762] (EE) Failed to load module "vesa" (module does not exist, 0)
[     4.762] (II) AMDGPU: Driver for AMD Radeon:
	All GPUs supported by the amdgpu kernel driver
[     4.762] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     4.762] (II) modeset(0): using drv /dev/dri/card0
[     4.763] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[     4.763] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     4.763] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[     4.763] (==) modeset(0): RGB weight 888
[     4.763] (==) modeset(0): Default visual is TrueColor
[     4.763] (II) Loading sub module "glamoregl"
[     4.763] (II) LoadModule: "glamoregl"
[     4.763] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     4.771] (II) Module glamoregl: vendor="X.Org Foundation"
[     4.771] 	compiled for 1.20.8, module version = 1.0.1
[     4.771] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     5.019] (II) modeset(0): Refusing to try glamor on llvmpipe
[     5.025] (EE) modeset(0): glamor initialization failed
[     5.025] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[     5.026] (II) modeset(0): Output Virtual-1 has no monitor section
[     5.027] (II) modeset(0): EDID for output Virtual-1
[     5.027] (II) modeset(0): Manufacturer: RHT  Model: 1234  Serial#: 0
[     5.027] (II) modeset(0): Year: 2014  Week: 42
[     5.027] (II) modeset(0): EDID Version: 1.4
[     5.027] (II) modeset(0): Digital Display Input
[     5.027] (II) modeset(0): 8 bits per channel
[     5.027] (II) modeset(0): Digital interface is DisplayPort
[     5.027] (II) modeset(0): Max Image Size [cm]: horiz.: 26  vert.: 19
[     5.027] (II) modeset(0): Gamma: 2.20
[     5.027] (II) modeset(0): No DPMS capabilities specified
[     5.027] (II) modeset(0): Supported color encodings: RGB 4:4:4
[     5.027] (II) modeset(0): Default color space is primary color space
[     5.027] (II) modeset(0): First detailed timing is preferred mode
[     5.027] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[     5.027] (II) modeset(0): redX: 0.640 redY: 0.330   greenX: 0.300 greenY: 0.600
[     5.027] (II) modeset(0): blueX: 0.150 blueY: 0.060   whiteX: 0.312 whiteY: 0.329
[     5.027] (II) modeset(0): Supported established timings:
[     5.027] (II) modeset(0): 640x480@60Hz
[     5.027] (II) modeset(0): 800x600@60Hz
[     5.027] (II) modeset(0): 1024x768@60Hz
[     5.027] (II) modeset(0): Manufacturer's mask: 0
[     5.027] (II) modeset(0): Supported standard timings:
[     5.027] (II) modeset(0): #0: hsize: 2048  vsize 1152  refresh: 60  vid: 49377
[     5.027] (II) modeset(0): #1: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[     5.027] (II) modeset(0): Supported detailed timing:
[     5.027] (II) modeset(0): clock: 82.3 MHz   Image Size:  403 x 302 mm
[     5.027] (II) modeset(0): h_active: 1024  h_sync: 1280  h_sync_end 1310 h_blank_end 1382 h_border: 0
[     5.027] (II) modeset(0): v_active: 768  v_sync: 771  v_sync_end 774 v_blanking: 794 v_border: 0
[     5.027] (II) modeset(0): Ranges: V min: 50 V max: 125 Hz, H min: 30 H max: 160 kHz, PixClock max 1205 MHz
[     5.027] (II) modeset(0): Monitor name: QEMU Monitor
[     5.027] (II) modeset(0): Established timings III: (not decoded)
[     5.027] (II) modeset(0): Number of EDID sections to follow: 1
[     5.027] (II) modeset(0): EDID (in hex):
[     5.027] (II) modeset(0): 	00ffffffffffff004914341200000000
[     5.027] (II) modeset(0): 	2a180104a51a137806ee91a3544c9926
[     5.027] (II) modeset(0): 	0f5054210800e1c0d1c0010101010101
[     5.027] (II) modeset(0): 	0101010101012520006641001a30001e
[     5.028] (II) modeset(0): 	3340932e11000018000000fd00327d1e
[     5.028] (II) modeset(0): 	a078010a202020202020000000fc0051
[     5.028] (II) modeset(0): 	454d55204d6f6e69746f720a000000f7
[     5.028] (II) modeset(0): 	000a004aa22429200000000000000132
[     5.028] (II) modeset(0): 	02030a00457d6560591f000000000000
[     5.028] (II) modeset(0): 	00000000000000000000000000000000
[     5.028] (II) modeset(0): 	000000000000000000000000000000f2
[     5.028] (II) modeset(0): Printing probed modes for output Virtual-1
[     5.028] (II) modeset(0): Modeline "1024x768"x75.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[     5.028] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 -hsync -vsync (67.5 kHz e)
[     5.028] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     5.028] (II) modeset(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     5.028] (II) modeset(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     5.028] (II) modeset(0): Modeline "1400x1050"x60.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[     5.028] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     5.028] (II) modeset(0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[     5.028] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[     5.028] (II) modeset(0): Modeline "1360x768"x60.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[     5.028] (II) modeset(0): Modeline "1280x768"x59.9   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[     5.028] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     5.028] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     5.028] (II) modeset(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     5.028] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     5.028] (II) modeset(0): Output Virtual-1 connected
[     5.028] (II) modeset(0): Using exact sizes for initial modes
[     5.028] (II) modeset(0): Output Virtual-1 using initial mode 1024x768 +0+0
[     5.028] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[     5.028] (==) modeset(0): DPI set to (96, 96)
[     5.028] (II) Loading sub module "fb"
[     5.028] (II) LoadModule: "fb"
[     5.028] (II) Loading /usr/lib/xorg/modules/libfb.so
[     5.029] (II) Module fb: vendor="X.Org Foundation"
[     5.029] 	compiled for 1.20.8, module version = 1.0.0
[     5.029] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     5.029] (==) AMDGPU(G0): Depth 24, (--) framebuffer bpp 32
[     5.029] (II) AMDGPU(G0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[     5.029] (==) AMDGPU(G0): Default visual is TrueColor
[     5.029] (==) AMDGPU(G0): RGB weight 888
[     5.029] (II) AMDGPU(G0): Using 8 bits per RGB (8 bit DAC)
[     5.029] (--) AMDGPU(G0): Chipset: "AMD Radeon RX 5700 XT" (ChipID = 0x731f)
[     5.029] (II) Loading sub module "fb"
[     5.029] (II) LoadModule: "fb"
[     5.029] (II) Loading /usr/lib/xorg/modules/libfb.so
[     5.029] (II) Loading sub module "dri2"
[     5.029] (II) LoadModule: "dri2"
[     5.029] (II) Module "dri2" already built-in
[     5.052] (II) Loading sub module "glamoregl"
[     5.052] (II) LoadModule: "glamoregl"
[     5.052] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     5.052] (II) Module glamoregl: vendor="X.Org Foundation"
[     5.052] 	compiled for 1.20.8, module version = 1.0.1
[     5.052] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     5.066] (II) AMDGPU(G0): glamor X acceleration enabled on AMD Radeon RX 5700 XT (NAVI10, DRM 3.37.0, 5.7.0-3-MANJARO, LLVM 10.0.0)
[     5.066] (II) AMDGPU(G0): glamor detected, initialising EGL layer.
[     5.066] (==) AMDGPU(G0): TearFree property default: auto
[     5.067] (II) AMDGPU(G0): Output DisplayPort-1-0 has no monitor section
[     5.067] (II) AMDGPU(G0): Output DisplayPort-1-1 has no monitor section
[     5.068] (II) AMDGPU(G0): Output DisplayPort-1-2 has no monitor section
[     5.068] (II) AMDGPU(G0): Output HDMI-A-1-0 has no monitor section
[     5.084] (II) AMDGPU(G0): EDID for output DisplayPort-1-0
[     5.084] (II) AMDGPU(G0): Manufacturer: ACI  Model: 23f7  Serial#: 63045
[     5.084] (II) AMDGPU(G0): Year: 2010  Week: 42
[     5.084] (II) AMDGPU(G0): EDID Version: 1.4
[     5.084] (II) AMDGPU(G0): Digital Display Input
[     5.084] (II) AMDGPU(G0): 8 bits per channel
[     5.084] (II) AMDGPU(G0): Digital interface is DisplayPort
[     5.084] (II) AMDGPU(G0): Max Image Size [cm]: horiz.: 51  vert.: 29
[     5.084] (II) AMDGPU(G0): Gamma: 2.20
[     5.084] (II) AMDGPU(G0): DPMS capabilities: Off
[     5.084] (II) AMDGPU(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[     5.084] (II) AMDGPU(G0): First detailed timing is preferred mode
[     5.084] (II) AMDGPU(G0): Preferred mode is native pixel format and refresh rate
[     5.084] (II) AMDGPU(G0): redX: 0.644 redY: 0.336   greenX: 0.295 greenY: 0.614
[     5.084] (II) AMDGPU(G0): blueX: 0.146 blueY: 0.072   whiteX: 0.313 whiteY: 0.329
[     5.084] (II) AMDGPU(G0): Supported established timings:
[     5.084] (II) AMDGPU(G0): 720x400@70Hz
[     5.084] (II) AMDGPU(G0): 640x480@60Hz
[     5.084] (II) AMDGPU(G0): 640x480@67Hz
[     5.084] (II) AMDGPU(G0): 640x480@75Hz
[     5.084] (II) AMDGPU(G0): 800x600@56Hz
[     5.084] (II) AMDGPU(G0): 800x600@60Hz
[     5.084] (II) AMDGPU(G0): 800x600@72Hz
[     5.084] (II) AMDGPU(G0): 800x600@75Hz
[     5.084] (II) AMDGPU(G0): 832x624@75Hz
[     5.084] (II) AMDGPU(G0): 1024x768@60Hz
[     5.084] (II) AMDGPU(G0): 1024x768@70Hz
[     5.084] (II) AMDGPU(G0): 1024x768@75Hz
[     5.084] (II) AMDGPU(G0): 1280x1024@75Hz
[     5.084] (II) AMDGPU(G0): Manufacturer's mask: 0
[     5.084] (II) AMDGPU(G0): Supported standard timings:
[     5.084] (II) AMDGPU(G0): #0: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[     5.084] (II) AMDGPU(G0): #1: hsize: 1280  vsize 960  refresh: 60  vid: 16513
[     5.084] (II) AMDGPU(G0): #2: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     5.084] (II) AMDGPU(G0): #3: hsize: 1440  vsize 900  refresh: 60  vid: 149
[     5.084] (II) AMDGPU(G0): #4: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[     5.084] (II) AMDGPU(G0): Supported detailed timing:
[     5.084] (II) AMDGPU(G0): clock: 148.5 MHz   Image Size:  509 x 286 mm
[     5.084] (II) AMDGPU(G0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     5.085] (II) AMDGPU(G0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[     5.085] (II) AMDGPU(G0): Ranges: V min: 50 V max: 122 Hz, H min: 24 H max: 140 kHz, PixClock max 295 MHz
[     5.085] (II) AMDGPU(G0): Monitor name: ASUS VG236
[     5.085] (II) AMDGPU(G0): Serial No: AALMTF063045
[     5.085] (II) AMDGPU(G0): Supported detailed timing:
[     5.085] (II) AMDGPU(G0): clock: 235.5 MHz   Image Size:  509 x 286 mm
[     5.085] (II) AMDGPU(G0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2080 h_border: 0
[     5.085] (II) AMDGPU(G0): v_active: 1080  v_sync: 1083  v_sync_end 1088 v_blanking: 1133 v_border: 0
[     5.085] (II) AMDGPU(G0): clock: 260.2 MHz   Image Size:  509 x 286 mm
[     5.085] (II) AMDGPU(G0): v_active: 1080  v_sync: 1083  v_sync_end 1088 v_blanking: 1138 v_border: 0
[     5.085] (II) AMDGPU(G0): clock: 285.5 MHz   Image Size:  509 x 286 mm
[     5.085] (II) AMDGPU(G0): v_active: 1080  v_sync: 1083  v_sync_end 1088 v_blanking: 1144 v_border: 0
[     5.085] (II) AMDGPU(G0): Number of EDID sections to follow: 1
[     5.085] (II) AMDGPU(G0): EDID (in hex):
[     5.085] (II) AMDGPU(G0): 	00ffffffffffff000469f72345f60000
[     5.085] (II) AMDGPU(G0): 	2a140104a5331d782ac965a4564b9d25
[     5.085] (II) AMDGPU(G0): 	125054b7ef0081c0814081809500b300
[     5.085] (II) AMDGPU(G0): 	010101010101023a801871382d40582c
[     5.085] (II) AMDGPU(G0): 	4500fd1e1100001e000000fd00327a18
[     5.085] (II) AMDGPU(G0): 	8c1d000a202020202020000000fc0041
[     5.085] (II) AMDGPU(G0): 	5355532056473233360a2020000000ff
[     5.085] (II) AMDGPU(G0): 	0041414c4d54463036333034350a018c
[     5.085] (II) AMDGPU(G0): 	02010400fe5b80a07038354030203500
[     5.085] (II) AMDGPU(G0): 	fd1e1100001ea96580a070383a403020
[     5.085] (II) AMDGPU(G0): 	3500fd1e1100001e866f80a070384040
[     5.085] (II) AMDGPU(G0): 	30203500fd1e1100001e000000000000
[     5.085] (II) AMDGPU(G0): 	00000000000000000000000000000000
[     5.085] (II) AMDGPU(G0): 	00000000000000000000000000000069
[     5.085] (II) AMDGPU(G0): Printing probed modes for output DisplayPort-1-0
[     5.085] (II) AMDGPU(G0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[     5.085] (II) AMDGPU(G0): Modeline "1920x1080"x120.0  285.50  1920 1968 2000 2080  1080 1083 1088 1144 +hsync +vsync (137.3 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1920x1080"x109.9  260.25  1920 1968 2000 2080  1080 1083 1088 1138 +hsync +vsync (125.1 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1920x1080"x99.9  235.50  1920 1968 2000 2080  1080 1083 1088 1133 +hsync +vsync (113.2 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1280x800"x60.0  148.50  1280 2008 2052 2200  800 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     5.085] (II) AMDGPU(G0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     5.085] (II) AMDGPU(G0): EDID for output DisplayPort-1-1
[     5.086] (II) AMDGPU(G0): EDID for output DisplayPort-1-2
[     5.086] (II) AMDGPU(G0): Manufacturer: ACI  Model: 23f2  Serial#: 197110
[     5.086] (II) AMDGPU(G0): Year: 2011  Week: 47
[     5.086] (II) AMDGPU(G0): EDID Version: 1.3
[     5.086] (II) AMDGPU(G0): Digital Display Input
[     5.086] (II) AMDGPU(G0): Max Image Size [cm]: horiz.: 52  vert.: 29
[     5.086] (II) AMDGPU(G0): Gamma: 2.20
[     5.086] (II) AMDGPU(G0): DPMS capabilities: Off
[     5.086] (II) AMDGPU(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[     5.086] (II) AMDGPU(G0): First detailed timing is preferred mode
[     5.086] (II) AMDGPU(G0): redX: 0.644 redY: 0.332   greenX: 0.286 greenY: 0.601
[     5.086] (II) AMDGPU(G0): blueX: 0.152 blueY: 0.076   whiteX: 0.312 whiteY: 0.328
[     5.086] (II) AMDGPU(G0): Supported established timings:
[     5.086] (II) AMDGPU(G0): 720x400@70Hz
[     5.086] (II) AMDGPU(G0): 640x480@60Hz
[     5.086] (II) AMDGPU(G0): 640x480@67Hz
[     5.086] (II) AMDGPU(G0): 640x480@72Hz
[     5.086] (II) AMDGPU(G0): 640x480@75Hz
[     5.086] (II) AMDGPU(G0): 800x600@56Hz
[     5.086] (II) AMDGPU(G0): 800x600@60Hz
[     5.086] (II) AMDGPU(G0): 800x600@72Hz
[     5.086] (II) AMDGPU(G0): 800x600@75Hz
[     5.086] (II) AMDGPU(G0): 832x624@75Hz
[     5.086] (II) AMDGPU(G0): 1024x768@60Hz
[     5.086] (II) AMDGPU(G0): 1024x768@70Hz
[     5.086] (II) AMDGPU(G0): 1024x768@75Hz
[     5.086] (II) AMDGPU(G0): 1280x1024@75Hz
[     5.086] (II) AMDGPU(G0): Manufacturer's mask: 0
[     5.086] (II) AMDGPU(G0): Supported standard timings:
[     5.086] (II) AMDGPU(G0): #0: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[     5.086] (II) AMDGPU(G0): #1: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     5.086] (II) AMDGPU(G0): #2: hsize: 1440  vsize 900  refresh: 60  vid: 149
[     5.086] (II) AMDGPU(G0): #3: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[     5.086] (II) AMDGPU(G0): #4: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[     5.086] (II) AMDGPU(G0): Supported detailed timing:
[     5.086] (II) AMDGPU(G0): clock: 148.5 MHz   Image Size:  521 x 293 mm
[     5.086] (II) AMDGPU(G0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     5.086] (II) AMDGPU(G0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[     5.086] (II) AMDGPU(G0): Serial No: BBLMTF197110
[     5.086] (II) AMDGPU(G0): Ranges: V min: 55 V max: 75 Hz, H min: 30 H max: 85 kHz, PixClock max 165 MHz
[     5.086] (II) AMDGPU(G0): Monitor name: ASUS VH236H
[     5.086] (II) AMDGPU(G0): EDID (in hex):
[     5.086] (II) AMDGPU(G0): 	00ffffffffffff000469f223f6010300
[     5.086] (II) AMDGPU(G0): 	2f15010380341d782ac720a455499927
[     5.086] (II) AMDGPU(G0): 	135054bfef00714f81809500b300d1c0
[     5.086] (II) AMDGPU(G0): 	010101010101023a801871382d40582c
[     5.086] (II) AMDGPU(G0): 	450009252100001e000000ff0042424c
[     5.086] (II) AMDGPU(G0): 	4d54463139373131300a000000fd0037
[     5.086] (II) AMDGPU(G0): 	4b1e5510000a202020202020000000fc
[     5.086] (II) AMDGPU(G0): 	0041535553205648323336480a2000ff
[     5.086] (II) AMDGPU(G0): Printing probed modes for output DisplayPort-1-2
[     5.086] (II) AMDGPU(G0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[     5.086] (II) AMDGPU(G0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "1280x800"x60.0  148.50  1280 2008 2052 2200  800 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "1280x720"x60.0  148.50  1280 2008 2052 2200  720 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     5.086] (II) AMDGPU(G0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     5.086] (II) AMDGPU(G0): EDID for output HDMI-A-1-0
[     5.086] (II) AMDGPU(G0): mem size init: gart size :1fe6b0000 vram size: s:1fd93e000 visible:f64c000
[     5.086] (==) AMDGPU(G0): DPI set to (96, 96)
[     5.086] (==) AMDGPU(G0): Using gamma correction (1.0, 1.0, 1.0)
[     5.086] (II) Loading sub module "ramdac"
[     5.086] (II) LoadModule: "ramdac"
[     5.086] (II) Module "ramdac" already built-in
[     5.087] (==) modeset(0): Backing store enabled
[     5.087] (==) modeset(0): Silken mouse disabled
[     5.088] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[     5.088] (==) modeset(0): DPMS enabled
[     5.088] (II) AMDGPU(G0): [DRI2] Setup complete
[     5.088] (II) AMDGPU(G0): [DRI2]   DRI driver: radeonsi
[     5.088] (II) AMDGPU(G0): [DRI2]   VDPAU driver: radeonsi
[     5.089] (II) AMDGPU(G0): Front buffer pitch: 4096 bytes
[     5.089] (==) AMDGPU(G0): Backing store enabled
[     5.089] (II) AMDGPU(G0): Direct rendering enabled
[     5.108] (II) AMDGPU(G0): Use GLAMOR acceleration.
[     5.109] (II) AMDGPU(G0): Acceleration enabled
[     5.109] (==) AMDGPU(G0): DPMS enabled
[     5.109] (==) AMDGPU(G0): Silken mouse disabled
[     5.134] (II) Initializing extension Generic Event Extension
[     5.134] (II) Initializing extension SHAPE
[     5.134] (II) Initializing extension MIT-SHM
[     5.134] (II) Initializing extension XInputExtension
[     5.134] (II) Initializing extension XTEST
[     5.134] (II) Initializing extension BIG-REQUESTS
[     5.134] (II) Initializing extension SYNC
[     5.134] (II) Initializing extension XKEYBOARD
[     5.135] (II) Initializing extension XC-MISC
[     5.135] (II) Initializing extension SECURITY
[     5.135] (II) Initializing extension XFIXES
[     5.135] (II) Initializing extension RENDER
[     5.135] (II) Initializing extension RANDR
[     5.135] (II) Initializing extension COMPOSITE
[     5.135] (II) Initializing extension DAMAGE
[     5.135] (II) Initializing extension MIT-SCREEN-SAVER
[     5.135] (II) Initializing extension DOUBLE-BUFFER
[     5.135] (II) Initializing extension RECORD
[     5.135] (II) Initializing extension DPMS
[     5.135] (II) Initializing extension Present
[     5.135] (II) Initializing extension DRI3
[     5.135] (II) Initializing extension X-Resource
[     5.135] (II) Initializing extension XVideo
[     5.135] (II) Initializing extension XVideo-MotionCompensation
[     5.135] (II) Initializing extension GLX
[     5.135] (II) AIGLX: Screen 0 is not DRI2 capable
[     5.140] (II) IGLX: Loaded and initialized swrast
[     5.140] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[     5.140] (II) Initializing extension XFree86-VidModeExtension
[     5.140] (II) Initializing extension XFree86-DGA
[     5.140] (II) Initializing extension XFree86-DRI
[     5.140] (II) Initializing extension DRI2
[     5.303] (II) modeset(0): Damage tracking initialized
[     5.303] (II) modeset(0): Setting screen physical size to 270 x 203
[     5.351] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     5.351] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     5.351] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     5.351] (**) Power Button: Applying InputClass "system-keyboard"
[     5.351] (II) LoadModule: "libinput"
[     5.351] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     5.356] (II) Module libinput: vendor="X.Org Foundation"
[     5.356] 	compiled for 1.20.8, module version = 0.30.0
[     5.356] 	Module class: X.Org XInput Driver
[     5.356] 	ABI class: X.Org XInput driver, version 24.1
[     5.356] (II) Using input driver 'libinput' for 'Power Button'
[     5.357] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 21 paused 0
[     5.357] (**) Power Button: always reports core events
[     5.357] (**) Option "Device" "/dev/input/event0"
[     5.357] (**) Option "_source" "server/udev"
[     5.365] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     5.365] (II) event0  - Power Button: device is a keyboard
[     5.365] (II) event0  - Power Button: device removed
[     5.365] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input0/event0"
[     5.365] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     5.365] (**) Option "xkb_model" "pc105"
[     5.365] (**) Option "xkb_layout" "us"
[     5.366] (II) event0  - Power Button: device is a keyboard
[     5.366] (II) config/udev: Adding input device QEMU QEMU USB Tablet (/dev/input/event4)
[     5.366] (**) QEMU QEMU USB Tablet: Applying InputClass "evdev pointer catchall"
[     5.366] (**) QEMU QEMU USB Tablet: Applying InputClass "libinput pointer catchall"
[     5.366] (II) Using input driver 'libinput' for 'QEMU QEMU USB Tablet'
[     5.423] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 24 paused 0
[     5.423] (**) QEMU QEMU USB Tablet: always reports core events
[     5.423] (**) Option "Device" "/dev/input/event4"
[     5.423] (**) Option "_source" "server/udev"
[     5.424] (II) event4  - QEMU QEMU USB Tablet: is tagged by udev as: Mouse
[     5.425] (II) event4  - QEMU QEMU USB Tablet: device is a pointer
[     5.425] (II) event4  - QEMU QEMU USB Tablet: device removed
[     5.425] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1:1.0/0003:0627:0001.0001/input/input5/event4"
[     5.425] (II) XINPUT: Adding extended input device "QEMU QEMU USB Tablet" (type: MOUSE, id 7)
[     5.425] (**) Option "AccelerationScheme" "none"
[     5.425] (**) QEMU QEMU USB Tablet: (accel) selected scheme none/0
[     5.425] (**) QEMU QEMU USB Tablet: (accel) acceleration factor: 2.000
[     5.425] (**) QEMU QEMU USB Tablet: (accel) acceleration threshold: 4
[     5.426] (II) event4  - QEMU QEMU USB Tablet: is tagged by udev as: Mouse
[     5.426] (II) event4  - QEMU QEMU USB Tablet: device is a pointer
[     5.427] (II) config/udev: Adding input device QEMU QEMU USB Tablet (/dev/input/mouse1)
[     5.427] (II) No input driver specified, ignoring this device.
[     5.427] (II) This device may have been added with another device file.
[     5.429] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event1)
[     5.429] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[     5.429] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[     5.429] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[     5.429] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[     5.429] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 25 paused 0
[     5.429] (**) AT Translated Set 2 keyboard: always reports core events
[     5.429] (**) Option "Device" "/dev/input/event1"
[     5.430] (**) Option "_source" "server/udev"
[     5.430] (II) event1  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     5.430] (II) event1  - AT Translated Set 2 keyboard: device is a keyboard
[     5.431] (II) event1  - AT Translated Set 2 keyboard: device removed
[     5.431] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input1/event1"
[     5.431] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 8)
[     5.431] (**) Option "xkb_model" "pc105"
[     5.431] (**) Option "xkb_layout" "us"
[     5.431] (II) event1  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     5.432] (II) event1  - AT Translated Set 2 keyboard: device is a keyboard
[     5.432] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/event3)
[     5.432] (**) ImExPS/2 Generic Explorer Mouse: Applying InputClass "evdev pointer catchall"
[     5.432] (**) ImExPS/2 Generic Explorer Mouse: Applying InputClass "libinput pointer catchall"
[     5.432] (II) Using input driver 'libinput' for 'ImExPS/2 Generic Explorer Mouse'
[     5.433] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 26 paused 0
[     5.433] (**) ImExPS/2 Generic Explorer Mouse: always reports core events
[     5.433] (**) Option "Device" "/dev/input/event3"
[     5.433] (**) Option "_source" "server/udev"
[     5.434] (II) event3  - ImExPS/2 Generic Explorer Mouse: is tagged by udev as: Mouse
[     5.434] (II) event3  - ImExPS/2 Generic Explorer Mouse: device is a pointer
[     5.434] (II) event3  - ImExPS/2 Generic Explorer Mouse: device removed
[     5.434] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input4/event3"
[     5.434] (II) XINPUT: Adding extended input device "ImExPS/2 Generic Explorer Mouse" (type: MOUSE, id 9)
[     5.434] (**) Option "AccelerationScheme" "none"
[     5.434] (**) ImExPS/2 Generic Explorer Mouse: (accel) selected scheme none/0
[     5.434] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration factor: 2.000
[     5.434] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration threshold: 4
[     5.435] (II) event3  - ImExPS/2 Generic Explorer Mouse: is tagged by udev as: Mouse
[     5.435] (II) event3  - ImExPS/2 Generic Explorer Mouse: device is a pointer
[     5.436] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/mouse0)
[     5.436] (II) No input driver specified, ignoring this device.
[     5.436] (II) This device may have been added with another device file.
[     5.436] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[     5.490] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse (/dev/input/mouse2)
[     5.491] (II) No input driver specified, ignoring this device.
[     5.491] (II) This device may have been added with another device file.
[     5.495] (II) config/udev: Adding input device Winbond Electronics Corp Hermon USB hidmouse Device (/dev/input/mouse3)
[     5.495] (II) No input driver specified, ignoring this device.
[     5.495] (II) This device may have been added with another device file.
[     5.518] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse Keyboard (/dev/input/event6)
[     5.518] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[     5.518] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[     5.518] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[     5.518] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse Keyboard'
[     5.519] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 23 paused 0
[     5.519] (**) Logitech G502 HERO Gaming Mouse Keyboard: always reports core events
[     5.519] (**) Option "Device" "/dev/input/event6"
[     5.519] (**) Option "_source" "server/udev"
[     5.521] (II) event6  - Logitech G502 HERO Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[     5.521] (II) event6  - Logitech G502 HERO Gaming Mouse Keyboard: device is a keyboard
[     5.521] (II) event6  - Logitech G502 HERO Gaming Mouse Keyboard: device removed
[     5.521] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:046D:C08B.0003/input/input7/event6"
[     5.521] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse Keyboard" (type: KEYBOARD, id 10)
[     5.521] (**) Option "xkb_model" "pc105"
[     5.521] (**) Option "xkb_layout" "us"
[     5.523] (II) event6  - Logitech G502 HERO Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[     5.523] (II) event6  - Logitech G502 HERO Gaming Mouse Keyboard: device is a keyboard
[     5.528] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse System Control (/dev/input/event8)
[     5.528] (**) Logitech G502 HERO Gaming Mouse System Control: Applying InputClass "evdev keyboard catchall"
[     5.528] (**) Logitech G502 HERO Gaming Mouse System Control: Applying InputClass "libinput keyboard catchall"
[     5.528] (**) Logitech G502 HERO Gaming Mouse System Control: Applying InputClass "system-keyboard"
[     5.528] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse System Control'
[     5.529] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 27 paused 0
[     5.529] (**) Logitech G502 HERO Gaming Mouse System Control: always reports core events
[     5.529] (**) Option "Device" "/dev/input/event8"
[     5.529] (**) Option "_source" "server/udev"
[     5.530] (II) event8  - Logitech G502 HERO Gaming Mouse System Control: is tagged by udev as: Keyboard
[     5.530] (II) event8  - Logitech G502 HERO Gaming Mouse System Control: device is a keyboard
[     5.531] (II) event8  - Logitech G502 HERO Gaming Mouse System Control: device removed
[     5.531] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:046D:C08B.0003/input/input9/event8"
[     5.531] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse System Control" (type: KEYBOARD, id 11)
[     5.531] (**) Option "xkb_model" "pc105"
[     5.531] (**) Option "xkb_layout" "us"
[     5.532] (II) event8  - Logitech G502 HERO Gaming Mouse System Control: is tagged by udev as: Keyboard
[     5.532] (II) event8  - Logitech G502 HERO Gaming Mouse System Control: device is a keyboard
[     5.548] (II) config/udev: Adding input device Logitech Logitech G710 Keyboard (/dev/input/event14)
[     5.549] (**) Logitech Logitech G710 Keyboard: Applying InputClass "evdev keyboard catchall"
[     5.549] (**) Logitech Logitech G710 Keyboard: Applying InputClass "libinput keyboard catchall"
[     5.549] (**) Logitech Logitech G710 Keyboard: Applying InputClass "system-keyboard"
[     5.549] (II) Using input driver 'libinput' for 'Logitech Logitech G710 Keyboard'
[     5.597] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 28 paused 0
[     5.597] (**) Logitech Logitech G710 Keyboard: always reports core events
[     5.597] (**) Option "Device" "/dev/input/event14"
[     5.597] (**) Option "_source" "server/udev"
[     5.598] (II) event14 - Logitech Logitech G710 Keyboard: is tagged by udev as: Keyboard
[     5.598] (II) event14 - Logitech Logitech G710 Keyboard: device is a keyboard
[     5.599] (II) event14 - Logitech Logitech G710 Keyboard: device removed
[     5.599] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.3/3-1.3:1.1/0003:046D:C24D.0008/input/input19/event14"
[     5.599] (II) XINPUT: Adding extended input device "Logitech Logitech G710 Keyboard" (type: KEYBOARD, id 12)
[     5.599] (**) Option "xkb_model" "pc105"
[     5.599] (**) Option "xkb_layout" "us"
[     5.600] (II) event14 - Logitech Logitech G710 Keyboard: is tagged by udev as: Keyboard
[     5.600] (II) event14 - Logitech Logitech G710 Keyboard: device is a keyboard
[     5.601] (II) config/udev: Adding input device Logitech Logitech G710 Keyboard Consumer Control (/dev/input/event15)
[     5.601] (**) Logitech Logitech G710 Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.601] (**) Logitech Logitech G710 Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.601] (**) Logitech Logitech G710 Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     5.601] (II) Using input driver 'libinput' for 'Logitech Logitech G710 Keyboard Consumer Control'
[     5.602] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 29 paused 0
[     5.602] (**) Logitech Logitech G710 Keyboard Consumer Control: always reports core events
[     5.602] (**) Option "Device" "/dev/input/event15"
[     5.602] (**) Option "_source" "server/udev"
[     5.603] (II) event15 - Logitech Logitech G710 Keyboard Consumer Control: is tagged by udev as: Keyboard
[     5.603] (II) event15 - Logitech Logitech G710 Keyboard Consumer Control: device is a keyboard
[     5.603] (II) event15 - Logitech Logitech G710 Keyboard Consumer Control: device removed
[     5.604] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.3/3-1.3:1.1/0003:046D:C24D.0008/input/input20/event15"
[     5.604] (II) XINPUT: Adding extended input device "Logitech Logitech G710 Keyboard Consumer Control" (type: KEYBOARD, id 13)
[     5.604] (**) Option "xkb_model" "pc105"
[     5.604] (**) Option "xkb_layout" "us"
[     5.605] (II) event15 - Logitech Logitech G710 Keyboard Consumer Control: is tagged by udev as: Keyboard
[     5.605] (II) event15 - Logitech Logitech G710 Keyboard Consumer Control: device is a keyboard
[     5.606] (II) config/udev: Adding input device Logitech Logitech G710 Keyboard (/dev/input/event13)
[     5.606] (**) Logitech Logitech G710 Keyboard: Applying InputClass "evdev keyboard catchall"
[     5.606] (**) Logitech Logitech G710 Keyboard: Applying InputClass "libinput keyboard catchall"
[     5.606] (**) Logitech Logitech G710 Keyboard: Applying InputClass "system-keyboard"
[     5.606] (II) Using input driver 'libinput' for 'Logitech Logitech G710 Keyboard'
[     5.606] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 30 paused 0
[     5.606] (**) Logitech Logitech G710 Keyboard: always reports core events
[     5.606] (**) Option "Device" "/dev/input/event13"
[     5.606] (**) Option "_source" "server/udev"
[     5.608] (II) event13 - Logitech Logitech G710 Keyboard: is tagged by udev as: Keyboard
[     5.608] (II) event13 - Logitech Logitech G710 Keyboard: device is a keyboard
[     5.608] (II) event13 - Logitech Logitech G710 Keyboard: device removed
[     5.608] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.3/3-1.3:1.0/0003:046D:C24D.0007/input/input18/event13"
[     5.608] (II) XINPUT: Adding extended input device "Logitech Logitech G710 Keyboard" (type: KEYBOARD, id 14)
[     5.608] (**) Option "xkb_model" "pc105"
[     5.608] (**) Option "xkb_layout" "us"
[     5.610] (II) event13 - Logitech Logitech G710 Keyboard: is tagged by udev as: Keyboard
[     5.610] (II) event13 - Logitech Logitech G710 Keyboard: device is a keyboard
[     5.610] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse Consumer Control (/dev/input/event7)
[     5.610] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.610] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.610] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[     5.610] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse Consumer Control'
[     5.611] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 31 paused 0
[     5.611] (**) Logitech G502 HERO Gaming Mouse Consumer Control: always reports core events
[     5.611] (**) Option "Device" "/dev/input/event7"
[     5.611] (**) Option "_source" "server/udev"
[     5.613] (II) event7  - Logitech G502 HERO Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[     5.613] (II) event7  - Logitech G502 HERO Gaming Mouse Consumer Control: device is a keyboard
[     5.613] (II) event7  - Logitech G502 HERO Gaming Mouse Consumer Control: device removed
[     5.613] (II) libinput: Logitech G502 HERO Gaming Mouse Consumer Control: needs a virtual subdevice
[     5.613] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:046D:C08B.0003/input/input8/event7"
[     5.613] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse Consumer Control" (type: MOUSE, id 15)
[     5.613] (**) Option "AccelerationScheme" "none"
[     5.613] (**) Logitech G502 HERO Gaming Mouse Consumer Control: (accel) selected scheme none/0
[     5.613] (**) Logitech G502 HERO Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
[     5.613] (**) Logitech G502 HERO Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
[     5.614] (II) event7  - Logitech G502 HERO Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[     5.614] (II) event7  - Logitech G502 HERO Gaming Mouse Consumer Control: device is a keyboard
[     5.615] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.615] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.615] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[     5.615] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse Consumer Control'
[     5.615] (II) systemd-logind: returning pre-existing fd for /dev/input/event7 13:71
[     5.615] (**) Logitech G502 HERO Gaming Mouse Consumer Control: always reports core events
[     5.615] (**) Option "Device" "/dev/input/event7"
[     5.615] (**) Option "_source" "_driver/libinput"
[     5.615] (II) libinput: Logitech G502 HERO Gaming Mouse Consumer Control: is a virtual subdevice
[     5.615] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:046D:C08B.0003/input/input8/event7"
[     5.615] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse Consumer Control" (type: KEYBOARD, id 16)
[     5.615] (**) Option "xkb_model" "pc105"
[     5.615] (**) Option "xkb_layout" "us"
[     5.615] (II) config/udev: Adding input device Winbond Electronics Corp Hermon USB hidmouse Device (/dev/input/event10)
[     5.615] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "evdev keyboard catchall"
[     5.615] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "libinput keyboard catchall"
[     5.615] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "system-keyboard"
[     5.615] (II) Using input driver 'libinput' for 'Winbond Electronics Corp Hermon USB hidmouse Device'
[     5.616] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 32 paused 0
[     5.616] (**) Winbond Electronics Corp Hermon USB hidmouse Device: always reports core events
[     5.616] (**) Option "Device" "/dev/input/event10"
[     5.616] (**) Option "_source" "server/udev"
[     5.618] (II) event10 - Winbond Electronics Corp Hermon USB hidmouse Device: is tagged by udev as: Keyboard
[     5.618] (II) event10 - Winbond Electronics Corp Hermon USB hidmouse Device: device is a keyboard
[     5.618] (II) event10 - Winbond Electronics Corp Hermon USB hidmouse Device: device removed
[     5.618] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:1b.0/usb4/4-1/4-1.6/4-1.6:1.1/0003:0557:2221.0005/input/input13/event10"
[     5.618] (II) XINPUT: Adding extended input device "Winbond Electronics Corp Hermon USB hidmouse Device" (type: KEYBOARD, id 17)
[     5.618] (**) Option "xkb_model" "pc105"
[     5.618] (**) Option "xkb_layout" "us"
[     5.620] (II) event10 - Winbond Electronics Corp Hermon USB hidmouse Device: is tagged by udev as: Keyboard
[     5.620] (II) event10 - Winbond Electronics Corp Hermon USB hidmouse Device: device is a keyboard
[     5.621] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse (/dev/input/event5)
[     5.621] (**) Logitech G502 HERO Gaming Mouse: Applying InputClass "evdev pointer catchall"
[     5.621] (**) Logitech G502 HERO Gaming Mouse: Applying InputClass "libinput pointer catchall"
[     5.621] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse'
[     5.676] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 33 paused 0
[     5.676] (**) Logitech G502 HERO Gaming Mouse: always reports core events
[     5.676] (**) Option "Device" "/dev/input/event5"
[     5.676] (**) Option "_source" "server/udev"
[     5.678] (II) event5  - Logitech G502 HERO Gaming Mouse: is tagged by udev as: Mouse
[     5.678] (II) event5  - Logitech G502 HERO Gaming Mouse: device is a pointer
[     5.678] (II) event5  - Logitech G502 HERO Gaming Mouse: device removed
[     5.678] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.1/3-1.1:1.0/0003:046D:C08B.0002/input/input6/event5"
[     5.678] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse" (type: MOUSE, id 18)
[     5.678] (**) Option "AccelerationScheme" "none"
[     5.678] (**) Logitech G502 HERO Gaming Mouse: (accel) selected scheme none/0
[     5.678] (**) Logitech G502 HERO Gaming Mouse: (accel) acceleration factor: 2.000
[     5.678] (**) Logitech G502 HERO Gaming Mouse: (accel) acceleration threshold: 4
[     5.679] (II) event5  - Logitech G502 HERO Gaming Mouse: is tagged by udev as: Mouse
[     5.680] (II) event5  - Logitech G502 HERO Gaming Mouse: device is a pointer
[     5.680] (II) config/udev: Adding input device Winbond Electronics Corp Hermon USB hidmouse Device (/dev/input/event9)
[     5.680] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "evdev pointer catchall"
[     5.680] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "libinput pointer catchall"
[     5.680] (II) Using input driver 'libinput' for 'Winbond Electronics Corp Hermon USB hidmouse Device'
[     5.736] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 34 paused 0
[     5.736] (**) Winbond Electronics Corp Hermon USB hidmouse Device: always reports core events
[     5.736] (**) Option "Device" "/dev/input/event9"
[     5.736] (**) Option "_source" "server/udev"
[     5.738] (II) event9  - Winbond Electronics Corp Hermon USB hidmouse Device: is tagged by udev as: Mouse
[     5.738] (II) event9  - Winbond Electronics Corp Hermon USB hidmouse Device: device is a pointer
[     5.738] (II) event9  - Winbond Electronics Corp Hermon USB hidmouse Device: device removed
[     5.738] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:1b.0/usb4/4-1/4-1.6/4-1.6:1.0/0003:0557:2221.0004/input/input12/event9"
[     5.738] (II) XINPUT: Adding extended input device "Winbond Electronics Corp Hermon USB hidmouse Device" (type: MOUSE, id 19)
[     5.738] (**) Option "AccelerationScheme" "none"
[     5.738] (**) Winbond Electronics Corp Hermon USB hidmouse Device: (accel) selected scheme none/0
[     5.738] (**) Winbond Electronics Corp Hermon USB hidmouse Device: (accel) acceleration factor: 2.000
[     5.738] (**) Winbond Electronics Corp Hermon USB hidmouse Device: (accel) acceleration threshold: 4
[     5.740] (II) event9  - Winbond Electronics Corp Hermon USB hidmouse Device: is tagged by udev as: Mouse
[     5.740] (II) event9  - Winbond Electronics Corp Hermon USB hidmouse Device: device is a pointer
[     5.880] (II) config/udev: Adding input device Logitech G432 Gaming Headset (/dev/input/event12)
[     5.880] (**) Logitech G432 Gaming Headset: Applying InputClass "evdev keyboard catchall"
[     5.880] (**) Logitech G432 Gaming Headset: Applying InputClass "libinput keyboard catchall"
[     5.880] (**) Logitech G432 Gaming Headset: Applying InputClass "system-keyboard"
[     5.880] (II) Using input driver 'libinput' for 'Logitech G432 Gaming Headset'
[     5.957] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 37 paused 0
[     5.957] (**) Logitech G432 Gaming Headset: always reports core events
[     5.957] (**) Option "Device" "/dev/input/event12"
[     5.957] (**) Option "_source" "server/udev"
[     5.958] (II) event12 - Logitech G432 Gaming Headset: is tagged by udev as: Keyboard
[     5.959] (II) event12 - Logitech G432 Gaming Headset: device is a keyboard
[     5.959] (II) event12 - Logitech G432 Gaming Headset: device removed
[     5.959] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.2/3-1.2:1.3/0003:046D:0A9C.0006/input/input15/event12"
[     5.959] (II) XINPUT: Adding extended input device "Logitech G432 Gaming Headset" (type: KEYBOARD, id 20)
[     5.959] (**) Option "xkb_model" "pc105"
[     5.959] (**) Option "xkb_layout" "us"
[     5.960] (II) event12 - Logitech G432 Gaming Headset: is tagged by udev as: Keyboard
[     5.960] (II) event12 - Logitech G432 Gaming Headset: device is a keyboard
[     5.961] (II) config/udev: Adding input device Logitech G432 Gaming Headset Consumer Control (/dev/input/event11)
[     5.961] (**) Logitech G432 Gaming Headset Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.961] (**) Logitech G432 Gaming Headset Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.961] (**) Logitech G432 Gaming Headset Consumer Control: Applying InputClass "system-keyboard"
[     5.961] (II) Using input driver 'libinput' for 'Logitech G432 Gaming Headset Consumer Control'
[     6.037] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 38 paused 0
[     6.037] (**) Logitech G432 Gaming Headset Consumer Control: always reports core events
[     6.037] (**) Option "Device" "/dev/input/event11"
[     6.037] (**) Option "_source" "server/udev"
[     6.038] (II) event11 - Logitech G432 Gaming Headset Consumer Control: is tagged by udev as: Keyboard
[     6.038] (II) event11 - Logitech G432 Gaming Headset Consumer Control: device is a keyboard
[     6.038] (II) event11 - Logitech G432 Gaming Headset Consumer Control: device removed
[     6.038] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.2/3-1.2:1.3/0003:046D:0A9C.0006/input/input14/event11"
[     6.038] (II) XINPUT: Adding extended input device "Logitech G432 Gaming Headset Consumer Control" (type: KEYBOARD, id 21)
[     6.038] (**) Option "xkb_model" "pc105"
[     6.038] (**) Option "xkb_layout" "us"
[     6.039] (II) event11 - Logitech G432 Gaming Headset Consumer Control: is tagged by udev as: Keyboard
[     6.039] (II) event11 - Logitech G432 Gaming Headset Consumer Control: device is a keyboard
[     6.461] (II) modeset(0): EDID vendor "RHT", prod id 4660
[     6.461] (II) modeset(0): Using EDID range info for horizontal sync
[     6.461] (II) modeset(0): Using EDID range info for vertical refresh
[     6.461] (II) modeset(0): Printing DDC gathered Modelines:
[     6.461] (II) modeset(0): Modeline "1024x768"x0.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[     6.461] (II) modeset(0): Modeline "1280x768"x0.0   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[     6.461] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[     6.461] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     6.461] (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[     6.461] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[     6.461] (II) modeset(0): Modeline "1400x1050"x0.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[     6.461] (II) modeset(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     6.461] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     6.461] (II) modeset(0): Modeline "1792x1344"x0.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[     6.461] (II) modeset(0): Modeline "1856x1392"x0.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[     6.461] (II) modeset(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[     6.461] (II) modeset(0): Modeline "1920x1440"x0.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[     6.461] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     6.461] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     6.461] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     6.461] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     6.461] (II) modeset(0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[     6.461] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[     6.664] (II) modeset(0): Disabling kernel dirty updates, not required.
[   215.410] (II) modeset(0): EDID vendor "RHT", prod id 4660
[   215.410] (II) modeset(0): Using hsync ranges from config file
[   215.410] (II) modeset(0): Using vrefresh ranges from config file
[   215.410] (II) modeset(0): Printing DDC gathered Modelines:
[   215.410] (II) modeset(0): Modeline "1024x768"x0.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[   215.410] (II) modeset(0): Modeline "1280x768"x0.0   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[   215.410] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   215.410] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   215.410] (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[   215.410] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   215.410] (II) modeset(0): Modeline "1400x1050"x0.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[   215.410] (II) modeset(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   215.410] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[   215.410] (II) modeset(0): Modeline "1792x1344"x0.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[   215.410] (II) modeset(0): Modeline "1856x1392"x0.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[   215.410] (II) modeset(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[   215.410] (II) modeset(0): Modeline "1920x1440"x0.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[   215.410] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   215.410] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   215.410] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   215.410] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   215.410] (II) modeset(0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[   215.410] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[   215.411] (II) modeset(0): EDID vendor "RHT", prod id 4660
[   215.411] (II) modeset(0): Using hsync ranges from config file
[   215.411] (II) modeset(0): Using vrefresh ranges from config file
[   215.411] (II) modeset(0): Printing DDC gathered Modelines:
[   215.411] (II) modeset(0): Modeline "1024x768"x0.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[   215.411] (II) modeset(0): Modeline "1280x768"x0.0   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[   215.411] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   215.411] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   215.411] (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[   215.411] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   215.411] (II) modeset(0): Modeline "1400x1050"x0.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[   215.411] (II) modeset(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   215.411] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[   215.411] (II) modeset(0): Modeline "1792x1344"x0.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[   215.411] (II) modeset(0): Modeline "1856x1392"x0.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[   215.411] (II) modeset(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[   215.411] (II) modeset(0): Modeline "1920x1440"x0.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[   215.411] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   215.411] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   215.411] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   215.411] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   215.411] (II) modeset(0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[   215.411] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[   501.628] (II) modeset(0): EDID vendor "RHT", prod id 4660
[   501.628] (II) modeset(0): Using hsync ranges from config file
[   501.628] (II) modeset(0): Using vrefresh ranges from config file
[   501.628] (II) modeset(0): Printing DDC gathered Modelines:
[   501.628] (II) modeset(0): Modeline "1024x768"x0.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[   501.628] (II) modeset(0): Modeline "1280x768"x0.0   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[   501.628] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   501.628] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   501.628] (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[   501.628] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   501.628] (II) modeset(0): Modeline "1400x1050"x0.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[   501.628] (II) modeset(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   501.628] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[   501.628] (II) modeset(0): Modeline "1792x1344"x0.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[   501.628] (II) modeset(0): Modeline "1856x1392"x0.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[   501.628] (II) modeset(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[   501.628] (II) modeset(0): Modeline "1920x1440"x0.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[   501.628] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   501.628] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   501.628] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   501.628] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   501.628] (II) modeset(0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[   501.628] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[   501.629] (II) modeset(0): EDID vendor "RHT", prod id 4660
[   501.629] (II) modeset(0): Using hsync ranges from config file
[   501.629] (II) modeset(0): Using vrefresh ranges from config file
[   501.629] (II) modeset(0): Printing DDC gathered Modelines:
[   501.629] (II) modeset(0): Modeline "1024x768"x0.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[   501.629] (II) modeset(0): Modeline "1280x768"x0.0   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[   501.629] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   501.629] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   501.629] (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[   501.629] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   501.629] (II) modeset(0): Modeline "1400x1050"x0.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[   501.629] (II) modeset(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   501.629] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[   501.629] (II) modeset(0): Modeline "1792x1344"x0.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[   501.629] (II) modeset(0): Modeline "1856x1392"x0.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[   501.629] (II) modeset(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[   501.629] (II) modeset(0): Modeline "1920x1440"x0.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[   501.629] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   501.629] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   501.629] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   501.629] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   501.629] (II) modeset(0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[   501.629] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[   580.349] (II) modeset(0): EDID vendor "RHT", prod id 4660
[   580.350] (II) modeset(0): Using hsync ranges from config file
[   580.350] (II) modeset(0): Using vrefresh ranges from config file
[   580.350] (II) modeset(0): Printing DDC gathered Modelines:
[   580.350] (II) modeset(0): Modeline "1024x768"x0.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[   580.350] (II) modeset(0): Modeline "1280x768"x0.0   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[   580.350] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   580.350] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   580.350] (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[   580.350] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   580.350] (II) modeset(0): Modeline "1400x1050"x0.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[   580.350] (II) modeset(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   580.350] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[   580.350] (II) modeset(0): Modeline "1792x1344"x0.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[   580.350] (II) modeset(0): Modeline "1856x1392"x0.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[   580.350] (II) modeset(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[   580.350] (II) modeset(0): Modeline "1920x1440"x0.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[   580.350] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   580.350] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   580.350] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   580.350] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   580.350] (II) modeset(0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[   580.350] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[   590.816] (II) modeset(0): Allocate new frame buffer 1920x1080 stride
[   590.879] (II) modeset(0): EDID vendor "RHT", prod id 4660
[   590.879] (II) modeset(0): Using hsync ranges from config file
[   590.879] (II) modeset(0): Using vrefresh ranges from config file
[   590.879] (II) modeset(0): Printing DDC gathered Modelines:
[   590.879] (II) modeset(0): Modeline "1024x768"x0.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[   590.879] (II) modeset(0): Modeline "1280x768"x0.0   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[   590.879] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   590.879] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   590.879] (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[   590.879] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   590.879] (II) modeset(0): Modeline "1400x1050"x0.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[   590.879] (II) modeset(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   590.879] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[   590.879] (II) modeset(0): Modeline "1792x1344"x0.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[   590.879] (II) modeset(0): Modeline "1856x1392"x0.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[   590.879] (II) modeset(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[   590.879] (II) modeset(0): Modeline "1920x1440"x0.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[   590.879] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   590.879] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   590.879] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   590.879] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   590.879] (II) modeset(0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[   590.879] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[   590.898] (II) modeset(0): EDID vendor "RHT", prod id 4660
[   590.898] (II) modeset(0): Using hsync ranges from config file
[   590.898] (II) modeset(0): Using vrefresh ranges from config file
[   590.898] (II) modeset(0): Printing DDC gathered Modelines:
[   590.898] (II) modeset(0): Modeline "1024x768"x0.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[   590.898] (II) modeset(0): Modeline "1280x768"x0.0   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[   590.898] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   590.898] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   590.898] (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[   590.898] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   590.898] (II) modeset(0): Modeline "1400x1050"x0.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[   590.898] (II) modeset(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   590.898] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[   590.898] (II) modeset(0): Modeline "1792x1344"x0.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[   590.898] (II) modeset(0): Modeline "1856x1392"x0.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[   590.898] (II) modeset(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[   590.898] (II) modeset(0): Modeline "1920x1440"x0.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[   590.898] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   590.898] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   590.898] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   590.898] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   590.898] (II) modeset(0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[   590.898] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[   707.190] (II) modeset(0): EDID vendor "RHT", prod id 4660
[   707.190] (II) modeset(0): Using hsync ranges from config file
[   707.190] (II) modeset(0): Using vrefresh ranges from config file
[   707.190] (II) modeset(0): Printing DDC gathered Modelines:
[   707.190] (II) modeset(0): Modeline "1024x768"x0.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[   707.190] (II) modeset(0): Modeline "1280x768"x0.0   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[   707.190] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   707.190] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   707.190] (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[   707.190] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   707.190] (II) modeset(0): Modeline "1400x1050"x0.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[   707.190] (II) modeset(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   707.190] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[   707.190] (II) modeset(0): Modeline "1792x1344"x0.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[   707.190] (II) modeset(0): Modeline "1856x1392"x0.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[   707.190] (II) modeset(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[   707.190] (II) modeset(0): Modeline "1920x1440"x0.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[   707.190] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   707.190] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   707.190] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   707.190] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   707.190] (II) modeset(0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[   707.190] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[   707.191] (II) modeset(0): EDID vendor "RHT", prod id 4660
[   707.191] (II) modeset(0): Using hsync ranges from config file
[   707.191] (II) modeset(0): Using vrefresh ranges from config file
[   707.191] (II) modeset(0): Printing DDC gathered Modelines:
[   707.191] (II) modeset(0): Modeline "1024x768"x0.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[   707.191] (II) modeset(0): Modeline "1280x768"x0.0   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[   707.191] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   707.191] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   707.191] (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[   707.191] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   707.191] (II) modeset(0): Modeline "1400x1050"x0.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[   707.191] (II) modeset(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   707.191] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[   707.191] (II) modeset(0): Modeline "1792x1344"x0.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[   707.191] (II) modeset(0): Modeline "1856x1392"x0.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[   707.191] (II) modeset(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[   707.191] (II) modeset(0): Modeline "1920x1440"x0.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[   707.191] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   707.191] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   707.191] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   707.191] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   707.191] (II) modeset(0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[   707.191] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[  1477.125] (II) modeset(0): EDID vendor "RHT", prod id 4660
[  1477.125] (II) modeset(0): Using hsync ranges from config file
[  1477.125] (II) modeset(0): Using vrefresh ranges from config file
[  1477.125] (II) modeset(0): Printing DDC gathered Modelines:
[  1477.125] (II) modeset(0): Modeline "1024x768"x0.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[  1477.125] (II) modeset(0): Modeline "1280x768"x0.0   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[  1477.125] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[  1477.125] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[  1477.125] (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[  1477.125] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[  1477.125] (II) modeset(0): Modeline "1400x1050"x0.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[  1477.125] (II) modeset(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[  1477.125] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[  1477.125] (II) modeset(0): Modeline "1792x1344"x0.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[  1477.125] (II) modeset(0): Modeline "1856x1392"x0.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[  1477.125] (II) modeset(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[  1477.125] (II) modeset(0): Modeline "1920x1440"x0.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[  1477.125] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[  1477.125] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[  1477.125] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[  1477.125] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[  1477.125] (II) modeset(0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[  1477.125] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[  1477.127] (II) modeset(0): EDID vendor "RHT", prod id 4660
[  1477.128] (II) modeset(0): Using hsync ranges from config file
[  1477.128] (II) modeset(0): Using vrefresh ranges from config file
[  1477.128] (II) modeset(0): Printing DDC gathered Modelines:
[  1477.128] (II) modeset(0): Modeline "1024x768"x0.0   82.29  1024 1280 1310 1382  768 771 774 794 -hsync -vsync (59.5 kHz eP)
[  1477.128] (II) modeset(0): Modeline "1280x768"x0.0   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[  1477.128] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[  1477.128] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[  1477.128] (II) modeset(0): Modeline "1360x768"x0.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[  1477.128] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[  1477.128] (II) modeset(0): Modeline "1400x1050"x0.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[  1477.128] (II) modeset(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[  1477.128] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[  1477.128] (II) modeset(0): Modeline "1792x1344"x0.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[  1477.128] (II) modeset(0): Modeline "1856x1392"x0.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[  1477.128] (II) modeset(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[  1477.128] (II) modeset(0): Modeline "1920x1440"x0.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[  1477.128] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[  1477.128] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[  1477.128] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[  1477.128] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[  1477.128] (II) modeset(0): Modeline "2048x1152"x60.0  197.97  2048 2184 2408 2768  1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[  1477.128] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
Solved!!!
This seemingly is a strange error with “reusing” a Linux virtual machine with a new graphics card. After trying a RTX 2060 and having the exact same issue, I learned that the issue was not with the 5700 XT, but with the host OS.
Anyways, the solution was to delete the virtual machine and recreate it, simple as that. Can’t believe I didn’t try that sooner, reason being was that installing the new card within windows 10 worked just fine, I didn’t have to recreate that virtual machine. Hopefully someone finds this information useful.
After creating a whole new VM, manjaro booted flawlessly.
