System: Kernel: 5.4.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=11946327-7561-4e0c-b1b6-d43661ce6b47 rw quiet apparmor=1
Desktop: KDE Plasma 5.17.4 tk: Qt 5.14.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx serial: <filter> UEFI: American Megatrends
v: 2901 date: 10/16/2019
CPU: Topology: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86256
Speed: 2401 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2401 2: 1714 3: 2118 4: 2195 5: 1775
6: 1985 7: 1884 8: 2199 9: 2991 10: 1839 11: 1846 12: 2177
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: eVga.com. driver: nouveau v: kernel bus ID: 09:00.0
chip ID: 10de:1c82
Display: x11 server: X.Org 1.20.6 driver: nouveau unloaded: modesetting alternate: fbdev,nv,vesa
compositor: kwin_x11 resolution: 1920x1080~60Hz
OpenGL: renderer: NV137 v: 4.3 Mesa 19.3.1 direct render: Yes
Audio: Device-1: NVIDIA GP107GL High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus ID: 09:00.1
chip ID: 10de:0fb9
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 0b:00.3 chip ID: 1022:1457
Device-3: Kingston HyperX Virtual Surround Sound type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-5:4
chip ID: 0951:16a4 serial: <filter>
Device-4: Texas Instruments PCM2902 Audio Codec type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-6:5
chip ID: 08bb:2902
Sound Server: ALSA v: k5.4.6-2-MANJARO
Network: Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: 5.6.0-k port: e000 bus ID: 04:00.0
chip ID: 8086:1539
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 2.05 TiB used: 8.25 GiB (0.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 250GB size: 232.89 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 1B2QEXE7 scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST1000DM003-1SB102 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC43 scheme: MBR
ID-3: /dev/sdb type: USB vendor: Seagate model: Expansion size: 931.51 GiB block size: physical: 4096 B
logical: 512 B serial: <filter> rev: 0708 scheme: MBR
Partition: ID-1: / raw size: 26.29 GiB size: 25.75 GiB (97.95%) used: 8.22 GiB (31.9%) fs: ext4 dev: /dev/nvme0n1p5
Sensors: System Temperatures: cpu: 42.2 C mobo: N/A gpu: nouveau temp: 31 C
Info: Processes: 300 Uptime: 1m Memory: 15.63 GiB used: 1.64 GiB (10.5%) Init: systemd v: 242 Compilers: gcc: 9.2.0
Shell: bash v: 5.0.11 running in: konsole inxi: 3.0.37
I recently got Manjaro KDE for experimenting and dualbooted it with my Windows 10.
there has been a problem though: when i try to install nvidia drivers and uninstall linux drivers i get stuck at TCP SYSTEM STARTUP/SHUTDOWN every time i boot, it fixes itself, when i uninstall nvidia Drivers and reinstall video-linux with mhwd. I looked online but couldn't find a solution how to remove noveau and not get a error .
