Unlocking fail from monitors off
I use a yubikey with a static password in one of the slots for logging in & sudo. For a long time, I could activate it when sitting down at my computer with the monitors turned off and my session would unlock. Within the past few months that stopped working, I just get an "Unlocking Failed" message above the password field when the monitors turn on.
I have no issues if I first wake up my monitors then activate my yubi. I've tried grepping journalctl but haven't found anything. Is there anywhere else I can look to find a root cause? Or maybe someone else has figured out my admittedly small use case problem.
My inxi -Fzxc0
System:    Host: polak-express Kernel: 5.6.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: KDE Plasma 5.18.5
Distro: Manjaro Linux
Machine:   Type: Desktop System: Micro-Star product: MS-7C35 v: 1.0 serial: <filter>
Mobo: Micro-Star model: MEG X570 ACE (MS-7C35) v: 1.0 serial: <filter> UEFI: American Megatrends v: 1.80
date: 01/16/2020
Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3 charge: 100% (should be ignored)
status: Discharging
CPU:       Topology: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 115245
Speed: 2170 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 2170 2: 3071 3: 4197 4: 2207 5: 2193 6: 3787 7: 3880
8: 2208 9: 4281 10: 2285 11: 2166 12: 2591 13: 2826 14: 2514 15: 2159 16: 2658
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: Tul
driver: amdgpu v: kernel bus ID: 2f:00.0
Display: x11 server: X.Org 1.20.8 driver: amdgpu FAILED: ati unloaded: modesetting,radeon tty: N/A
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.36.0 5.6.11-1-MANJARO LLVM 10.0.0) v: 4.6 Mesa 20.0.6
direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 2f:00.1
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 31:00.4
Device-3: Razer USA Razer USB Audio Controller type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-1:2
Sound Server: ALSA v: k5.6.11-1-MANJARO
Network:   Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb v: 5.6.0-k port: e000 bus ID: 26:00.0
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus ID: 27:00.0
IF: enp39s0 state: down mac: <filter>
IF-ID-1: br-d8b3cd08f321 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: veth795c295 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: veth7f5b953 state: up speed: 10000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 8.42 TiB used: 2.34 TiB (27.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
ID-2: /dev/sda vendor: Samsung model: SSD 840 EVO 500GB size: 465.76 GiB
ID-3: /dev/sdb vendor: Western Digital model: WD30EZRZ-00GXCB0 size: 2.73 TiB
ID-4: /dev/sdc vendor: Seagate model: ST4000DM004-2CV104 size: 3.64 TiB
ID-5: /dev/sdd vendor: Western Digital model: WDS500G2B0A-00SM50 size: 465.76 GiB
ID-6: /dev/sde type: USB vendor: Samsung model: Flash Drive FIT size: 239.02 GiB
Partition: ID-1: / size: 66.79 GiB used: 35.48 GiB (53.1%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /home size: 848.12 GiB used: 82.73 GiB (9.8%) fs: ext4 dev: /dev/nvme0n1p3
Sensors:   System Temperatures: cpu: 58.1 C mobo: 34.0 C gpu: amdgpu temp: 44 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0 fan-3: 0 fan-4: 0 fan-5: 0 fan-6: 2160 fan-7: 0 gpu: amdgpu fan: 0
Info:      Processes: 464 Uptime: 1d 23h 05m Memory: 31.37 GiB used: 13.75 GiB (43.8%) Init: systemd Compilers: gcc: 9.3.0
clang: 10.0.0 Shell: zsh v: 5.8 inxi: 3.0.37
