Updated Wallpapers from Kyria and Jhuraya where not installed
Hi Team,
Firstly thank you for the Kyria update. I'm using the xfce (minimal from architect iso) edition.
I have observed that, the latest wallpapers for Kyria and Jhuraya were not installed on my system after the update.
In the /usr/share/backgrounds, I only have the "illyria-default" and "illyria-default-lockscreen" wallpapers. Any idea, why new wallpapers were not added to my system. Or if I have to manually install any specific package for the same.
Snapshot for your refernce:
Here's the output of inxi -Fxzc0:
$ inxi -Fxzc0
System:    Host: MyPC Kernel: 5.5.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0 Desktop: Xfce 4.14.2
           Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 81SY v: Lenovo Legion Y540-15IRH-PG0 serial: <filter>
           Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN serial: <filter> UEFI: LENOVO v: BHCN32WW date: 08/29/2019
Battery:   ID-1: BAT0 charge: 31.3 Wh condition: 53.0/52.5 Wh (101%) model: LGC L17L3PG1 status: Unknown
CPU:       Topology: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 8192 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38408
           Speed: 900 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900 8: 900
Graphics:  Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo driver: nvidia v: 440.59 bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.7 driver: modesetting,nvidia resolution: 1920x1080~60Hz
           OpenGL: renderer: GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 440.59 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 01:00.1
           Sound Server: ALSA v: k5.5.2-1-MANJARO
Network:   Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000 bus ID: 00:14.3
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 3000
           bus ID: 07:00.0
           IF: enp7s0 state: down mac: <filter>
Drives:    Local Storage: total: 476.94 GiB used: 103.55 GiB (21.7%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB
Partition: ID-1: / size: 242.35 GiB used: 62.95 GiB (26.0%) fs: ext4 dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 54.0 C mobo: N/A gpu: nvidia temp: 45 C
Info:      Processes: 245 Uptime: 1h 48m Memory: 7.66 GiB used: 2.96 GiB (38.6%) Init: systemd Compilers: gcc: 9.2.1
           Shell: bash v: 5.0.16 inxi: 3.0.37
Thanks & Regards,
UserManjaro
install wallpapers-juhraya
there isn't one for Kyria yet as far as I'm aware. The new KDE wallpaper is part of the Breath2 theme set. you can install it if you like Breath2-wallpaper
Thanks for replay :slight_smile:
This will install Jhuraya wallpapers, but shouldn't it be installed by default with Jhuraya updates (if this is official package and part of the release)?
As for Kyria if I remember correctly, during RC1 and RC2 devs mentioned having new wallpapers along with Matcha Themes. That is why I'm a bit confused.
https://archived.forum.manjaro.org/t/manjaro-xfce-19-0-rc2-released/124874
And just to be sure, I hope the Matcha they mentioned is the one installed in my system:
no idea about new matcha wallpapers, please ask in that announcement thread by replying to the first post quoting that particular snippet of information. updating between releases doesn't draw in new packages because a lot of users would start complaining about unwanted bloat if that happened. it's always up to the end user to decide what new stuff to add. the rolling aspect to updates is more the core features and applications you already installed, tweaks to the look and any new features created by manjaro developers for a new release are always optional.
Ok. I'll ask in the announcement thread.
I thought, since they had mentioned it in the update list, they would have included it. But what you say is true and is the most important aspect of linux and rolling release distros.
Thanks. Have a good day.
New packages - added to repo and used with a release - is not installed in an automated manner.
A Manjaro update never installs new packages unless it is a dependency of an existing package.
Ok. That clears why Jhuraya wallpaper package was not installed.
Thanks.
