I have installed VirtManager+KVM+ QEMU and have used it without issues with Windows 10. But recently is giving me this network 'default' is not active error. I have deleted and reinstalled the VM but the error continue. It only allowed to boot up after I change the Virtual Network Interface> Network source> from Virtual network 'default' : NAT (Inactive) to Host device wlp13s0: macvtap BUT the windows vm does not have internet.
The error started after I installed Jellyfin.
Error starting domain: Requested operation is not valid: network 'default' is not active
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 75, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 111, in tmpcb
callback(*args, **kwargs)
File "/usr/share/virt-manager/virtManager/object/libvirtobject.py", line 66, in newfn
ret = fn(self, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/object/domain.py", line 1279, in startup
self._backend.create()
File "/usr/lib/python3.8/site-packages/libvirt.py", line 1234, in create
if ret == -1: raise libvirtError ('virDomainCreate() failed', dom=self)
libvirt.libvirtError: Requested operation is not valid: network 'default' is not active
My machine:
$ inxi -Fxxxz
System: Host: joel-AMDRYZEN Kernel: 5.6.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: KDE Plasma 5.18.5
tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: X570 Steel Legend serial: <filter> UEFI: American Megatrends v: P2.20
date: 11/26/2019
CPU: Topology: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 115232
Speed: 2541 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2541 2: 3034 3: 2976 4: 2184 5: 2263
6: 2899 7: 2076 8: 3356 9: 2001 10: 2164 11: 2199 12: 2099 13: 2049 14: 2219 15: 3087 16: 3658
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: XFX Pine
driver: amdgpu v: kernel bus ID: 06:00.0 chip ID: 1002:731f
Display: x11 server: X.Org 1.20.8 driver: amdgpu FAILED: ati unloaded: modesetting,radeon alternate: fbdev,vesa
compositor: kwin_x11 resolution: 2560x1440~144Hz
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.36.0 5.6.16-1-MANJARO LLVM 10.0.0) v: 4.6 Mesa 20.0.7
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 06:00.1
chip ID: 1002:ab38
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 12:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.6.16-1-MANJARO
Network: Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: 5.6.0-k port: e000 bus ID: 0b:00.0
chip ID: 8086:1539
IF: enp11s0 state: down mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: e000 bus ID: 0d:00.0 chip ID: 8086:2526
IF: wlp13s0 state: up mac: <filter>
Drives: Local Storage: total: 2.29 TiB used: 344.62 GiB (14.7%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: 002C scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD20EZAZ-00GGJB0 size: 1.82 TiB speed: 6.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: 0A80 scheme: GPT
Partition: ID-1: / size: 459.50 GiB used: 193.94 GiB (42.2%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 59.1 C mobo: N/A gpu: amdgpu temp: 58 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 740
Info: Processes: 353 Uptime: 26m Memory: 15.57 GiB used: 2.19 GiB (14.1%) Init: systemd v: 245 Compilers: gcc: 10.1.0
Shell: bash v: 5.0.17 running in: konsole inxi: 3.0.37
