Is it possible to have the splash screen shows up upon resuming from hibernation?
Right now, I only get a black screen with blinking cursor. Once I move my mouse, then the login box would appear, allowing me to login and resume.
I don't know with the splash type feedback - but you may be able to get some feedback - just know - the suggestion affects an ordinary boot as well.
As root - edit the file /etc/default/grub
sudo nano /etc/default/grub
remove quiet and udev.log_priority=3 - save the file and rebuild grub.
sudo update-grub
Note: On newer - fast hardware with NVMe or SSD it will be a tradeoff as the boot may be slightly slower due to the time taken to produce the console output.
