VM - Qemu, Libguestfs, hivex, ruby - hivex can't find ruby
Okay, I'm newbie, following guides and steps of people who walked the road before me, reading a lot - rarely commenting and even more rarely making post (my second post ever in Linux group) !
The situation:
I'm following that guide for VM - https://computingforgeeks.com/complete-installation-of-kvmqemu-and-virt-manager-on-arch-linux-and-manjaro/
The error appear right after installing yaourt ! When I tell yaourt that i need libguestfs - it split that error:
[nigzi@nigzi500 ~]$ yaourt -S --noconfirm --needed libguestfs
==> Downloading libguestfs PKGBUILD from AUR...
x .SRCINFO
x PKGBUILD
x appliance.install
x update-libguestfs-appliance
skalkoto commented on <a href="#comment-681675" class="date">2019-02-10 22:24</a>
rwmjones commented on <a href="#comment-684484" class="date">2019-03-04 07:35</a>
adrien1018 commented on <a href="#comment-686330" class="date">2019-03-17 09:40</a>
xwhiteknuckle22 commented on <a href="#comment-712288" class="date">2019-10-18 05:12</a>
rwmjones commented on <a href="#comment-712304" class="date">2019-10-18 08:03</a>
libguestfs 1.40.2-1  (2019-03-08 22:25)
( Unsupported package: Potentially dangerous ! )
==> libguestfs dependencies:
 - qemu-headless (already installed) [makedepend]
 - augeas (already installed)
 - libvirt (already installed) [makedepend]
 - fuse (already installed)
 - file (already installed)
 - wget (already installed)
 - jansson (already installed) [makedepend]
 - pcre (already installed) [makedepend]
 - libxml2 (already installed) [makedepend]
 - python2 (already installed) [makedepend]
 - perl (already installed) [makedepend]
 - ocaml-findlib (already installed) [makedepend]
 - ocaml (already installed) [makedepend]
 - hivex>=1.3.2 (building from AUR)
 - libconfig (package found) [makedepend]
 - cpio (package found)
 - cdrkit (package found) [makedepend]
 - gperf (package found) [makedepend]
 - perl-string-shellquote (package found) [makedepend]
 - perl-libintl-perl (package found) [makedepend]
 - perl-sys-virt (package found) [makedepend]
 - perl-module-build (package found) [makedepend]
==> Continue building libguestfs ? [Y/n]
==> Building and installing package
==> Install or build missing dependencies for libguestfs:
error: target not found: hivex>=1.3.2
==> Restart building libguestfs ? [y/N]
==> [nigzi@nigzi500 ~]$
Then i try to install hivex with pamac-manager
Cloning hivex-git build files...
Checking hivex-git dependencies...
Preparing...
Building hivex-git...
==> Making package: hivex-git v1.3.18.r0.gdbcdd14-1 (23.10.2019 (ср) 23:01:08 EEST)
==> Retrieving sources...
  -> Updating hivex git repo...
Fetching origin
==> Validating source files with md5sums...
    hivex ... Skipped
==> Extracting sources...
  -> Creating working copy of hivex git repo...
Cloning into 'hivex'...
done.
==> Starting pkgver()...
==> Removing existing $pkgdir/ directory...
==> Starting build()...
# Ensure that whenever we pull in a gnulib update or otherwise change to a
# different version (i.e., when switching branches), we also rerun ./bootstrap.
curr_status=.git-module-status
t=$(git submodule status)
if test "$t" = "$(cat $curr_status 2>/dev/null)"; then
    : # good, it's up to date
else
    echo running bootstrap...
    ./bootstrap && echo "$t" > $curr_status
fi
./bootstrap: getting gnulib files...
Submodule '.gnulib' (git://git.sv.gnu.org/gnulib.git) registered for path '.gnulib'
Cloning into '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/.gnulib'...
Submodule path '.gnulib': checked out '34881aff4043847f2640d90cf9aa325cc3ad08d6'
Copying file ABOUT-NLS
Creating directory build-aux
Copying file build-aux/config.rpath
Copying file m4/codeset.m4
Copying file m4/gettext.m4
Copying file m4/glibc2.m4
Copying file m4/glibc21.m4
Copying file m4/iconv.m4
Copying file m4/intdiv0.m4
Copying file m4/intl.m4
Copying file m4/intldir.m4
Copying file m4/intlmacosx.m4
Copying file m4/intmax.m4
Copying file m4/inttypes-pri.m4
Copying file m4/inttypes_h.m4
Copying file m4/lcmessage.m4
Copying file m4/lib-ld.m4
Copying file m4/lib-link.m4
Copying file m4/lib-prefix.m4
Copying file m4/lock.m4
Copying file m4/longlong.m4
Copying file m4/nls.m4
Copying file m4/po.m4
Copying file m4/printf-posix.m4
Copying file m4/progtest.m4
Copying file m4/size_max.m4
Copying file m4/stdint_h.m4
Copying file m4/uintmax_t.m4
Copying file m4/visibility.m4
Copying file m4/wchar_t.m4
Copying file m4/wint_t.m4
Copying file m4/xsize.m4
Copying file po/Makefile.in.in
Copying file po/Makevars.template
Copying file po/Rules-quot
Copying file po/boldquot.sed
Copying file po/en@boldquot.header
Copying file po/en@quot.header
Copying file po/insert-header.sin
Copying file po/quot.sed
Copying file po/remove-potcdate.sin
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, 'build-aux'.
libtoolize: copying file 'build-aux/config.guess'
libtoolize: copying file 'build-aux/config.sub'
libtoolize: copying file 'build-aux/install-sh'
libtoolize: copying file 'build-aux/ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'm4'.
libtoolize: copying file 'm4/libtool.m4'
libtoolize: copying file 'm4/ltoptions.m4'
libtoolize: copying file 'm4/ltsugar.m4'
libtoolize: copying file 'm4/ltversion.m4'
libtoolize: copying file 'm4/lt~obsolete.m4'
./bootstrap: Creating po/Makevars from po/Makevars.template ...
Module list with included dependencies (indented):
    absolute-header
    accept
    accept-tests
    alloca
    alloca-opt
    alloca-opt-tests
    arpa_inet
    arpa_inet-tests
    assure
    binary-io
    binary-io-tests
    bind
    bind-tests
  byteswap
    byteswap-tests
  c-ctype
    c-ctype-tests
    cloexec
    cloexec-tests
    close
    close-tests
    connect
    connect-tests
    ctype
    ctype-tests
    dirname-lgpl
    dosname
    double-slash-root
    dup2
    dup2-tests
    environ
    environ-tests
    errno
    errno-tests
    error
    exitfail
    extensions
    extern-inline
  fcntl
    fcntl-h
    fcntl-h-tests
    fcntl-tests
    fd-hook
    fdopen
    fdopen-tests
    fgetc-tests
    filename
    float
    float-tests
    fpieee
    fpucw
    fputc-tests
    fread-tests
    fstat
    fstat-tests
    ftruncate
    ftruncate-tests
  full-read
  full-write
    fwrite-tests
    getcwd-lgpl
    getcwd-lgpl-tests
    getdtablesize
    getdtablesize-tests
    getopt-gnu
    getopt-gnu-tests
    getopt-posix
    getopt-posix-tests
    getpagesize
    getprogname
    getprogname-tests
    gettext-h
    gettimeofday
    gettimeofday-tests
  gitlog-to-changelog
  gnu-make
  gnumakefile
    havelib
  iconv
    iconv-tests
  ignore-value
    ignore-value-tests
    include_next
    inet_pton
    inet_pton-tests
    intprops
    intprops-tests
  inttypes
    inttypes-incomplete
    inttypes-tests
    ioctl
    ioctl-tests
    isblank
    isblank-tests
    largefile
    limits-h
    limits-h-tests
    listen
    listen-tests
    localtime-buffer
  lock
    lock-tests
    lstat
    lstat-tests
  maintainer-makefile
    malloc-posix
    malloca
    malloca-tests
  manywarnings
    memchr
    memchr-tests
    msvc-inval
    msvc-nothrow
    multiarch
    nanosleep
    nanosleep-tests
    netinet_in
    netinet_in-tests
    nocrash
    open
    open-tests
    pathmax
    pathmax-tests
    perror
    perror-tests
    pipe-posix
    pipe-posix-tests
  progname
    pthread_sigmask
    pthread_sigmask-tests
    putenv
    raise
    raise-tests
    read
    read-tests
    safe-read
    safe-write
    same-inode
    select
    select-tests
    setenv
    setenv-tests
    setsockopt
    setsockopt-tests
    sigaction
    sigaction-tests
    signal-h
    signal-h-tests
    sigprocmask
    sigprocmask-tests
    size_max
    sleep
    sleep-tests
    snippet/_Noreturn
    snippet/arg-nonnull
    snippet/c++defs
    snippet/warn-on-use
    socket
    socketlib
    sockets
    sockets-tests
    socklen
    ssize_t
    stat
    stat-tests
    stat-time
    stat-time-tests
    stdalign
    stdalign-tests
    stdbool
    stdbool-tests
    stddef
    stddef-tests
    stdint
    stdint-tests
    stdio
    stdio-tests
    stdlib
    stdlib-tests
    strerror
    strerror-override
    strerror-tests
    strerror_r-posix
    strerror_r-posix-tests
    string
    string-tests
  strndup
    strnlen
    strnlen-tests
    strtoll
    strtoll-tests
    strtoull
    strtoull-tests
    symlink
    symlink-tests
    sys_ioctl
    sys_ioctl-tests
    sys_select
    sys_select-tests
    sys_socket
    sys_socket-tests
    sys_stat
    sys_stat-tests
    sys_time
    sys_time-tests
    sys_types
    sys_types-tests
    sys_uio
    sys_uio-tests
    test-framework-sh
    test-framework-sh-tests
    thread
    thread-tests
    threadlib
    time
    time-tests
    unistd
    unistd-tests
    unsetenv
    unsetenv-tests
    useless-if-before-free
    usleep
    usleep-tests
    vasnprintf
    vasnprintf-tests
  vasprintf
    vasprintf-tests
  vc-list-files
    vc-list-files-tests
    verify
    verify-tests
  warnings
    wchar
    wchar-tests
    write
    write-tests
    xalloc-oversized
    xsize
  xstrtol
    xstrtol-tests
  xstrtoll
    xstrtoll-tests
    yield
Notice from module error:
  If you are using GNU gettext version 0.16.1 or older, add the following options
  to XGETTEXT_OPTIONS in your po/Makevars:
    --flag=error:3:c-format --flag=error_at_line:5:c-format
Notice from module vasprintf:
    --flag=asprintf:2:c-format --flag=vasprintf:2:c-format
File list:
  build-aux/gitlog-to-changelog
  build-aux/useless-if-before-free
  build-aux/vc-list-files
  lib/_Noreturn.h
  lib/alloca.in.h
  lib/arg-nonnull.h
  lib/asnprintf.c
  lib/asprintf.c
  lib/assure.h
  lib/basename-lgpl.c
  lib/byteswap.in.h
  lib/c++defs.h
  lib/c-ctype.c
  lib/c-ctype.h
  lib/close.c
  lib/dirname-lgpl.c
  lib/dirname.h
  lib/dosname.h
  lib/dup2.c
  lib/errno.in.h
  lib/error.c
  lib/error.h
  lib/exitfail.c
  lib/exitfail.h
  lib/fcntl.c
  lib/fcntl.in.h
  lib/fd-hook.c
  lib/fd-hook.h
  lib/float+.h
  lib/float.c
  lib/float.in.h
  lib/full-read.c
  lib/full-read.h
  lib/full-write.c
  lib/full-write.h
  lib/getdtablesize.c
  lib/getopt-cdefs.in.h
  lib/getopt-core.h
  lib/getopt-ext.h
  lib/getopt-pfx-core.h
  lib/getopt-pfx-ext.h
  lib/getopt.c
  lib/getopt.in.h
  lib/getopt1.c
  lib/getopt_int.h
  lib/getprogname.c
  lib/getprogname.h
  lib/gettext.h
  lib/glthread/lock.c
  lib/glthread/lock.h
  lib/glthread/threadlib.c
  lib/ignore-value.h
  lib/intprops.h
  lib/inttypes.in.h
  lib/itold.c
  lib/limits.in.h
  lib/malloc.c
  lib/memchr.c
  lib/memchr.valgrind
  lib/msvc-inval.c
  lib/msvc-inval.h
  lib/msvc-nothrow.c
  lib/msvc-nothrow.h
  lib/printf-args.c
  lib/printf-args.h
  lib/printf-parse.c
  lib/printf-parse.h
  lib/progname.c
  lib/progname.h
  lib/raise.c
  lib/read.c
  lib/safe-read.c
  lib/safe-read.h
  lib/safe-write.c
  lib/safe-write.h
  lib/signal.in.h
  lib/size_max.h
  lib/stdbool.in.h
  lib/stddef.in.h
  lib/stdint.in.h
  lib/stdio.in.h
  lib/stdlib.in.h
  lib/strerror-override.c
  lib/strerror-override.h
  lib/strerror.c
  lib/string.in.h
  lib/stripslash.c
  lib/strndup.c
  lib/strnlen.c
  lib/strtol.c
  lib/strtoll.c
  lib/strtoul.c
  lib/strtoull.c
  lib/sys-limits.h
  lib/sys_types.in.h
  lib/unistd.c
  lib/unistd.in.h
  lib/vasnprintf.c
  lib/vasnprintf.h
  lib/vasprintf.c
  lib/verify.h
  lib/warn-on-use.h
  lib/wchar.in.h
  lib/write.c
  lib/xsize.c
  lib/xsize.h
  lib/xstrtol-error.c
  lib/xstrtol.c
  lib/xstrtol.h
  lib/xstrtoll.c
  lib/xstrtoul.c
  lib/xstrtoull.c
  m4/00gnulib.m4
  m4/absolute-header.m4
  m4/alloca.m4
  m4/arpa_inet_h.m4
  m4/byteswap.m4
  m4/close.m4
  m4/ctype.m4
  m4/dirname.m4
  m4/double-slash-root.m4
  m4/dup2.m4
  m4/eealloc.m4
  m4/environ.m4
  m4/errno_h.m4
  m4/error.m4
  m4/exponentd.m4
  m4/extensions.m4
  m4/extern-inline.m4
  m4/fcntl-o.m4
  m4/fcntl.m4
  m4/fcntl_h.m4
  m4/fdopen.m4
  m4/float_h.m4
  m4/fpieee.m4
  m4/fstat.m4
  m4/ftruncate.m4
  m4/getcwd.m4
  m4/getdtablesize.m4
  m4/getopt.m4
  m4/getpagesize.m4
  m4/getprogname.m4
  m4/gettimeofday.m4
  m4/gnu-make.m4
  m4/gnulib-common.m4
  m4/host-cpu-c-abi.m4
  m4/iconv.m4
  m4/include_next.m4
  m4/inet_pton.m4
  m4/intmax_t.m4
  m4/inttypes-pri.m4
  m4/inttypes.m4
  m4/inttypes_h.m4
  m4/ioctl.m4
  m4/isblank.m4
  m4/largefile.m4
  m4/lib-ld.m4
  m4/lib-link.m4
  m4/lib-prefix.m4
  m4/limits-h.m4
  m4/localtime-buffer.m4
  m4/lock.m4
  m4/longlong.m4
  m4/lstat.m4
  m4/malloc.m4
  m4/malloca.m4
  m4/manywarnings-c++.m4
  m4/manywarnings.m4
  m4/math_h.m4
  m4/memchr.m4
  m4/mmap-anon.m4
  m4/mode_t.m4
  m4/msvc-inval.m4
  m4/msvc-nothrow.m4
  m4/multiarch.m4
  m4/nanosleep.m4
  m4/netinet_in_h.m4
  m4/nocrash.m4
  m4/off_t.m4
  m4/open-cloexec.m4
  m4/open.m4
  m4/pathmax.m4
  m4/perror.m4
  m4/pipe.m4
  m4/printf.m4
  m4/pthread_rwlock_rdlock.m4
  m4/pthread_sigmask.m4
  m4/putenv.m4
  m4/raise.m4
  m4/read.m4
  m4/safe-read.m4
  m4/safe-write.m4
  m4/select.m4
  m4/setenv.m4
  m4/sigaction.m4
  m4/signal_h.m4
  m4/signalblocking.m4
  m4/size_max.m4
  m4/sleep.m4
  m4/socketlib.m4
  m4/sockets.m4
  m4/socklen.m4
  m4/sockpfaf.m4
  m4/ssize_t.m4
  m4/stat-time.m4
  m4/stat.m4
  m4/stdalign.m4
  m4/stdbool.m4
  m4/stddef_h.m4
  m4/stdint.m4
  m4/stdint_h.m4
  m4/stdio_h.m4
  m4/stdlib_h.m4
  m4/strerror.m4
  m4/strerror_r.m4
  m4/string_h.m4
  m4/strndup.m4
  m4/strnlen.m4
  m4/strtoll.m4
  m4/strtoull.m4
  m4/symlink.m4
  m4/sys_ioctl_h.m4
  m4/sys_select_h.m4
  m4/sys_socket_h.m4
  m4/sys_stat_h.m4
  m4/sys_time_h.m4
  m4/sys_types_h.m4
  m4/sys_uio_h.m4
  m4/thread.m4
  m4/threadlib.m4
  m4/time_h.m4
  m4/unistd_h.m4
  m4/usleep.m4
  m4/vasnprintf.m4
  m4/vasprintf.m4
  m4/warn-on-use.m4
  m4/warnings.m4
  m4/wchar_h.m4
  m4/wchar_t.m4
  m4/wint_t.m4
  m4/write.m4
  m4/xsize.m4
  m4/xstrtol.m4
  m4/yield.m4
  tests/init.sh
  tests/macros.h
  tests/nap.h
  tests/signature.h
  tests/test-accept.c
  tests/test-alloca-opt.c
  tests/test-arpa_inet.c
  tests/test-binary-io.c
  tests/test-binary-io.sh
  tests/test-bind.c
  tests/test-byteswap.c
  tests/test-c-ctype.c
  tests/test-cloexec.c
  tests/test-close.c
  tests/test-connect.c
  tests/test-ctype.c
  tests/test-dup2.c
  tests/test-environ.c
  tests/test-errno.c
  tests/test-fcntl-h.c
  tests/test-fcntl.c
  tests/test-fdopen.c
  tests/test-fgetc.c
  tests/test-float.c
  tests/test-fputc.c
  tests/test-fread.c
  tests/test-fstat.c
  tests/test-ftruncate.c
  tests/test-ftruncate.sh
  tests/test-fwrite.c
  tests/test-getcwd-lgpl.c
  tests/test-getdtablesize.c
  tests/test-getopt-gnu.c
  tests/test-getopt-main.h
  tests/test-getopt-posix.c
  tests/test-getopt.h
  tests/test-getopt_long.h
  tests/test-getprogname.c
  tests/test-gettimeofday.c
  tests/test-iconv.c
  tests/test-ignore-value.c
  tests/test-inet_pton.c
  tests/test-init.sh
  tests/test-intprops.c
  tests/test-inttypes.c
  tests/test-ioctl.c
  tests/test-isblank.c
  tests/test-limits-h.c
  tests/test-listen.c
  tests/test-lock.c
  tests/test-lstat.c
  tests/test-lstat.h
  tests/test-malloca.c
  tests/test-memchr.c
  tests/test-nanosleep.c
  tests/test-netinet_in.c
  tests/test-once.c
  tests/test-open.c
  tests/test-open.h
  tests/test-pathmax.c
  tests/test-perror.c
  tests/test-perror.sh
  tests/test-perror2.c
  tests/test-pipe.c
  tests/test-pthread_sigmask1.c
  tests/test-pthread_sigmask2.c
  tests/test-raise.c
  tests/test-read.c
  tests/test-rwlock1.c
  tests/test-select-fd.c
  tests/test-select-in.sh
  tests/test-select-out.sh
  tests/test-select-stdin.c
  tests/test-select.c
  tests/test-select.h
  tests/test-setenv.c
  tests/test-setsockopt.c
  tests/test-sigaction.c
  tests/test-signal-h.c
  tests/test-sigprocmask.c
  tests/test-sleep.c
  tests/test-sockets.c
  tests/test-stat-time.c
  tests/test-stat.c
  tests/test-stat.h
  tests/test-stdalign.c
  tests/test-stdbool.c
  tests/test-stddef.c
  tests/test-stdint.c
  tests/test-stdio.c
  tests/test-stdlib.c
  tests/test-strerror.c
  tests/test-strerror_r.c
  tests/test-string.c
  tests/test-strnlen.c
  tests/test-strtoll.c
  tests/test-strtoull.c
  tests/test-symlink.c
  tests/test-symlink.h
  tests/test-sys_ioctl.c
  tests/test-sys_select.c
  tests/test-sys_socket.c
  tests/test-sys_stat.c
  tests/test-sys_time.c
  tests/test-sys_types.c
  tests/test-sys_uio.c
  tests/test-sys_wait.h
  tests/test-thread_create.c
  tests/test-thread_self.c
  tests/test-time.c
  tests/test-unistd.c
  tests/test-unsetenv.c
  tests/test-usleep.c
  tests/test-vasnprintf.c
  tests/test-vasprintf.c
  tests/test-vc-list-files-cvs.sh
  tests/test-vc-list-files-git.sh
  tests/test-verify-try.c
  tests/test-verify.c
  tests/test-verify.sh
  tests/test-wchar.c
  tests/test-write.c
  tests/test-xstrtol.c
  tests/test-xstrtol.sh
  tests/test-xstrtoll.c
  tests/test-xstrtoll.sh
  tests/test-xstrtoul.c
  tests/test-xstrtoull.c
  tests/zerosize-ptr.h
  lib/_Noreturn.h -> tests/_Noreturn.h
  lib/accept.c -> tests/accept.c
  lib/alloca.c -> tests/alloca.c
  lib/arg-nonnull.h -> tests/arg-nonnull.h
  lib/arpa_inet.in.h -> tests/arpa_inet.in.h
  lib/binary-io.c -> tests/binary-io.c
  lib/binary-io.h -> tests/binary-io.h
  lib/bind.c -> tests/bind.c
  lib/c++defs.h -> tests/c++defs.h
  lib/cloexec.c -> tests/cloexec.c
  lib/cloexec.h -> tests/cloexec.h
  lib/connect.c -> tests/connect.c
  lib/ctype.in.h -> tests/ctype.in.h
  lib/fdopen.c -> tests/fdopen.c
  lib/filename.h -> tests/filename.h
  lib/fpucw.h -> tests/fpucw.h
  lib/fstat.c -> tests/fstat.c
  lib/ftruncate.c -> tests/ftruncate.c
  lib/getcwd-lgpl.c -> tests/getcwd-lgpl.c
  lib/getpagesize.c -> tests/getpagesize.c
  lib/gettimeofday.c -> tests/gettimeofday.c
  lib/glthread/thread.c -> tests/glthread/thread.c
  lib/glthread/thread.h -> tests/glthread/thread.h
  lib/glthread/yield.h -> tests/glthread/yield.h
  lib/inet_pton.c -> tests/inet_pton.c
  lib/ioctl.c -> tests/ioctl.c
  lib/isblank.c -> tests/isblank.c
  lib/listen.c -> tests/listen.c
  lib/localtime-buffer.c -> tests/localtime-buffer.c
  lib/localtime-buffer.h -> tests/localtime-buffer.h
  lib/lstat.c -> tests/lstat.c
  lib/malloca.c -> tests/malloca.c
  lib/malloca.h -> tests/malloca.h
  lib/nanosleep.c -> tests/nanosleep.c
  lib/netinet_in.in.h -> tests/netinet_in.in.h
  lib/open.c -> tests/open.c
  lib/pathmax.h -> tests/pathmax.h
  lib/perror.c -> tests/perror.c
  lib/pipe.c -> tests/pipe.c
  lib/pthread_sigmask.c -> tests/pthread_sigmask.c
  lib/putenv.c -> tests/putenv.c
  lib/same-inode.h -> tests/same-inode.h
  lib/select.c -> tests/select.c
  lib/setenv.c -> tests/setenv.c
  lib/setsockopt.c -> tests/setsockopt.c
  lib/sig-handler.c -> tests/sig-handler.c
  lib/sig-handler.h -> tests/sig-handler.h
  lib/sigaction.c -> tests/sigaction.c
  lib/sigprocmask.c -> tests/sigprocmask.c
  lib/sleep.c -> tests/sleep.c
  lib/socket.c -> tests/socket.c
  lib/sockets.c -> tests/sockets.c
  lib/sockets.h -> tests/sockets.h
  lib/stat-time.c -> tests/stat-time.c
  lib/stat-time.h -> tests/stat-time.h
  lib/stat-w32.c -> tests/stat-w32.c
  lib/stat-w32.h -> tests/stat-w32.h
  lib/stat.c -> tests/stat.c
  lib/stdalign.in.h -> tests/stdalign.in.h
  lib/strerror_r.c -> tests/strerror_r.c
  lib/symlink.c -> tests/symlink.c
  lib/sys_ioctl.in.h -> tests/sys_ioctl.in.h
  lib/sys_select.in.h -> tests/sys_select.in.h
  lib/sys_socket.c -> tests/sys_socket.c
  lib/sys_socket.in.h -> tests/sys_socket.in.h
  lib/sys_stat.in.h -> tests/sys_stat.in.h
  lib/sys_time.in.h -> tests/sys_time.in.h
  lib/sys_uio.in.h -> tests/sys_uio.in.h
  lib/time.in.h -> tests/time.in.h
  lib/unsetenv.c -> tests/unsetenv.c
  lib/usleep.c -> tests/usleep.c
  lib/w32sock.h -> tests/w32sock.h
  lib/warn-on-use.h -> tests/warn-on-use.h
  lib/xalloc-oversized.h -> tests/xalloc-oversized.h
  top/GNUmakefile
  top/maint.mk
Creating directory ./gnulib/lib
Creating directory ./gnulib/tests
Creating directory ./gnulib/lib/glthread
Creating directory ./gnulib/tests/glthread
Copying file GNUmakefile
Replacing file build-aux/config.rpath (non-gnulib code backed up in build-aux/config.rpath~) !!
Copying file build-aux/gitlog-to-changelog
Copying file build-aux/useless-if-before-free
Copying file build-aux/vc-list-files
Copying file gnulib/lib/_Noreturn.h
Copying file gnulib/lib/alloca.in.h
Copying file gnulib/lib/arg-nonnull.h
Copying file gnulib/lib/asnprintf.c
Copying file gnulib/lib/asprintf.c
Copying file gnulib/lib/assure.h
Copying file gnulib/lib/basename-lgpl.c
Copying file gnulib/lib/byteswap.in.h
Copying file gnulib/lib/c++defs.h
Copying file gnulib/lib/c-ctype.c
Copying file gnulib/lib/c-ctype.h
Copying file gnulib/lib/close.c
Copying file gnulib/lib/dirname-lgpl.c
Copying file gnulib/lib/dirname.h
Copying file gnulib/lib/dosname.h
Copying file gnulib/lib/dup2.c
Copying file gnulib/lib/errno.in.h
Copying file gnulib/lib/error.c
Copying file gnulib/lib/error.h
Copying file gnulib/lib/exitfail.c
Copying file gnulib/lib/exitfail.h
Copying file gnulib/lib/fcntl.c
Copying file gnulib/lib/fcntl.in.h
Copying file gnulib/lib/fd-hook.c
Copying file gnulib/lib/fd-hook.h
Copying file gnulib/lib/float+.h
Copying file gnulib/lib/float.c
Copying file gnulib/lib/float.in.h
Copying file gnulib/lib/full-read.c
Copying file gnulib/lib/full-read.h
Copying file gnulib/lib/full-write.c
Copying file gnulib/lib/full-write.h
Copying file gnulib/lib/getdtablesize.c
Copying file gnulib/lib/getopt-cdefs.in.h
Copying file gnulib/lib/getopt-core.h
Copying file gnulib/lib/getopt-ext.h
Copying file gnulib/lib/getopt-pfx-core.h
Copying file gnulib/lib/getopt-pfx-ext.h
Copying file gnulib/lib/getopt.c
Copying file gnulib/lib/getopt.in.h
Copying file gnulib/lib/getopt1.c
Copying file gnulib/lib/getopt_int.h
Copying file gnulib/lib/getprogname.c
Copying file gnulib/lib/getprogname.h
Copying file gnulib/lib/gettext.h
Copying file gnulib/lib/glthread/lock.c
Copying file gnulib/lib/glthread/lock.h
Copying file gnulib/lib/glthread/threadlib.c
Copying file gnulib/lib/ignore-value.h
Copying file gnulib/lib/intprops.h
Copying file gnulib/lib/inttypes.in.h
Copying file gnulib/lib/itold.c
Copying file gnulib/lib/limits.in.h
Copying file gnulib/lib/malloc.c
Copying file gnulib/lib/memchr.c
Copying file gnulib/lib/memchr.valgrind
Copying file gnulib/lib/msvc-inval.c
Copying file gnulib/lib/msvc-inval.h
Copying file gnulib/lib/msvc-nothrow.c
Copying file gnulib/lib/msvc-nothrow.h
Copying file gnulib/lib/printf-args.c
Copying file gnulib/lib/printf-args.h
Copying file gnulib/lib/printf-parse.c
Copying file gnulib/lib/printf-parse.h
Copying file gnulib/lib/progname.c
Copying file gnulib/lib/progname.h
Copying file gnulib/lib/raise.c
Copying file gnulib/lib/read.c
Copying file gnulib/lib/safe-read.c
Copying file gnulib/lib/safe-read.h
Copying file gnulib/lib/safe-write.c
Copying file gnulib/lib/safe-write.h
Copying file gnulib/lib/signal.in.h
Copying file gnulib/lib/size_max.h
Copying file gnulib/lib/stdbool.in.h
Copying file gnulib/lib/stddef.in.h
Copying file gnulib/lib/stdint.in.h
Copying file gnulib/lib/stdio.in.h
Copying file gnulib/lib/stdlib.in.h
Copying file gnulib/lib/strerror-override.c
Copying file gnulib/lib/strerror-override.h
Copying file gnulib/lib/strerror.c
Copying file gnulib/lib/string.in.h
Copying file gnulib/lib/stripslash.c
Copying file gnulib/lib/strndup.c
Copying file gnulib/lib/strnlen.c
Copying file gnulib/lib/strtol.c
Copying file gnulib/lib/strtoll.c
Copying file gnulib/lib/strtoul.c
Copying file gnulib/lib/strtoull.c
Copying file gnulib/lib/sys-limits.h
Copying file gnulib/lib/sys_types.in.h
Copying file gnulib/lib/unistd.c
Copying file gnulib/lib/unistd.in.h
Copying file gnulib/lib/vasnprintf.c
Copying file gnulib/lib/vasnprintf.h
Copying file gnulib/lib/vasprintf.c
Copying file gnulib/lib/verify.h
Copying file gnulib/lib/warn-on-use.h
Copying file gnulib/lib/wchar.in.h
Copying file gnulib/lib/write.c
Copying file gnulib/lib/xsize.c
Copying file gnulib/lib/xsize.h
Copying file gnulib/lib/xstrtol-error.c
Copying file gnulib/lib/xstrtol.c
Copying file gnulib/lib/xstrtol.h
Copying file gnulib/lib/xstrtoll.c
Copying file gnulib/lib/xstrtoul.c
Copying file gnulib/lib/xstrtoull.c
Copying file gnulib/tests/_Noreturn.h
Copying file gnulib/tests/accept.c
Copying file gnulib/tests/alloca.c
Copying file gnulib/tests/arg-nonnull.h
Copying file gnulib/tests/arpa_inet.in.h
Copying file gnulib/tests/binary-io.c
Copying file gnulib/tests/binary-io.h
Copying file gnulib/tests/bind.c
Copying file gnulib/tests/c++defs.h
Copying file gnulib/tests/cloexec.c
Copying file gnulib/tests/cloexec.h
Copying file gnulib/tests/connect.c
Copying file gnulib/tests/ctype.in.h
Copying file gnulib/tests/fdopen.c
Copying file gnulib/tests/filename.h
Copying file gnulib/tests/fpucw.h
Copying file gnulib/tests/fstat.c
Copying file gnulib/tests/ftruncate.c
Copying file gnulib/tests/getcwd-lgpl.c
Copying file gnulib/tests/getpagesize.c
Copying file gnulib/tests/gettimeofday.c
Copying file gnulib/tests/glthread/thread.c
Copying file gnulib/tests/glthread/thread.h
Copying file gnulib/tests/glthread/yield.h
Copying file gnulib/tests/inet_pton.c
Copying file gnulib/tests/init.sh
Copying file gnulib/tests/ioctl.c
Copying file gnulib/tests/isblank.c
Copying file gnulib/tests/listen.c
Copying file gnulib/tests/localtime-buffer.c
Copying file gnulib/tests/localtime-buffer.h
Copying file gnulib/tests/lstat.c
Copying file gnulib/tests/macros.h
Copying file gnulib/tests/malloca.c
Copying file gnulib/tests/malloca.h
Copying file gnulib/tests/nanosleep.c
Copying file gnulib/tests/nap.h
Copying file gnulib/tests/netinet_in.in.h
Copying file gnulib/tests/open.c
Copying file gnulib/tests/pathmax.h
Copying file gnulib/tests/perror.c
Copying file gnulib/tests/pipe.c
Copying file gnulib/tests/pthread_sigmask.c
Copying file gnulib/tests/putenv.c
Copying file gnulib/tests/same-inode.h
Copying file gnulib/tests/select.c
Copying file gnulib/tests/setenv.c
Copying file gnulib/tests/setsockopt.c
Copying file gnulib/tests/sig-handler.c
Copying file gnulib/tests/sig-handler.h
Copying file gnulib/tests/sigaction.c
Copying file gnulib/tests/signature.h
Copying file gnulib/tests/sigprocmask.c
Copying file gnulib/tests/sleep.c
Copying file gnulib/tests/socket.c
Copying file gnulib/tests/sockets.c
Copying file gnulib/tests/sockets.h
Copying file gnulib/tests/stat-time.c
Copying file gnulib/tests/stat-time.h
Copying file gnulib/tests/stat-w32.c
Copying file gnulib/tests/stat-w32.h
Copying file gnulib/tests/stat.c
Copying file gnulib/tests/stdalign.in.h
Copying file gnulib/tests/strerror_r.c
Copying file gnulib/tests/symlink.c
Copying file gnulib/tests/sys_ioctl.in.h
Copying file gnulib/tests/sys_select.in.h
Copying file gnulib/tests/sys_socket.c
Copying file gnulib/tests/sys_socket.in.h
Copying file gnulib/tests/sys_stat.in.h
Copying file gnulib/tests/sys_time.in.h
Copying file gnulib/tests/sys_uio.in.h
Copying file gnulib/tests/test-accept.c
Copying file gnulib/tests/test-alloca-opt.c
Copying file gnulib/tests/test-arpa_inet.c
Copying file gnulib/tests/test-binary-io.c
Copying file gnulib/tests/test-binary-io.sh
Copying file gnulib/tests/test-bind.c
Copying file gnulib/tests/test-byteswap.c
Copying file gnulib/tests/test-c-ctype.c
Copying file gnulib/tests/test-cloexec.c
Copying file gnulib/tests/test-close.c
Copying file gnulib/tests/test-connect.c
Copying file gnulib/tests/test-ctype.c
Copying file gnulib/tests/test-dup2.c
Copying file gnulib/tests/test-environ.c
Copying file gnulib/tests/test-errno.c
Copying file gnulib/tests/test-fcntl-h.c
Copying file gnulib/tests/test-fcntl.c
Copying file gnulib/tests/test-fdopen.c
Copying file gnulib/tests/test-fgetc.c
Copying file gnulib/tests/test-float.c
Copying file gnulib/tests/test-fputc.c
Copying file gnulib/tests/test-fread.c
Copying file gnulib/tests/test-fstat.c
Copying file gnulib/tests/test-ftruncate.c
Copying file gnulib/tests/test-ftruncate.sh
Copying file gnulib/tests/test-fwrite.c
Copying file gnulib/tests/test-getcwd-lgpl.c
Copying file gnulib/tests/test-getdtablesize.c
Copying file gnulib/tests/test-getopt-gnu.c
Copying file gnulib/tests/test-getopt-main.h
Copying file gnulib/tests/test-getopt-posix.c
Copying file gnulib/tests/test-getopt.h
Copying file gnulib/tests/test-getopt_long.h
Copying file gnulib/tests/test-getprogname.c
Copying file gnulib/tests/test-gettimeofday.c
Copying file gnulib/tests/test-iconv.c
Copying file gnulib/tests/test-ignore-value.c
Copying file gnulib/tests/test-inet_pton.c
Copying file gnulib/tests/test-init.sh
Copying file gnulib/tests/test-intprops.c
Copying file gnulib/tests/test-inttypes.c
Copying file gnulib/tests/test-ioctl.c
Copying file gnulib/tests/test-isblank.c
Copying file gnulib/tests/test-limits-h.c
Copying file gnulib/tests/test-listen.c
Copying file gnulib/tests/test-lock.c
Copying file gnulib/tests/test-lstat.c
Copying file gnulib/tests/test-lstat.h
Copying file gnulib/tests/test-malloca.c
Copying file gnulib/tests/test-memchr.c
Copying file gnulib/tests/test-nanosleep.c
Copying file gnulib/tests/test-netinet_in.c
Copying file gnulib/tests/test-once.c
Copying file gnulib/tests/test-open.c
Copying file gnulib/tests/test-open.h
Copying file gnulib/tests/test-pathmax.c
Copying file gnulib/tests/test-perror.c
Copying file gnulib/tests/test-perror.sh
Copying file gnulib/tests/test-perror2.c
Copying file gnulib/tests/test-pipe.c
Copying file gnulib/tests/test-pthread_sigmask1.c
Copying file gnulib/tests/test-pthread_sigmask2.c
Copying file gnulib/tests/test-raise.c
Copying file gnulib/tests/test-read.c
Copying file gnulib/tests/test-rwlock1.c
Copying file gnulib/tests/test-select-fd.c
Copying file gnulib/tests/test-select-in.sh
Copying file gnulib/tests/test-select-out.sh
Copying file gnulib/tests/test-select-stdin.c
Copying file gnulib/tests/test-select.c
Copying file gnulib/tests/test-select.h
Copying file gnulib/tests/test-setenv.c
Copying file gnulib/tests/test-setsockopt.c
Copying file gnulib/tests/test-sigaction.c
Copying file gnulib/tests/test-signal-h.c
Copying file gnulib/tests/test-sigprocmask.c
Copying file gnulib/tests/test-sleep.c
Copying file gnulib/tests/test-sockets.c
Copying file gnulib/tests/test-stat-time.c
Copying file gnulib/tests/test-stat.c
Copying file gnulib/tests/test-stat.h
Copying file gnulib/tests/test-stdalign.c
Copying file gnulib/tests/test-stdbool.c
Copying file gnulib/tests/test-stddef.c
Copying file gnulib/tests/test-stdint.c
Copying file gnulib/tests/test-stdio.c
Copying file gnulib/tests/test-stdlib.c
Copying file gnulib/tests/test-strerror.c
Copying file gnulib/tests/test-strerror_r.c
Copying file gnulib/tests/test-string.c
Copying file gnulib/tests/test-strnlen.c
Copying file gnulib/tests/test-strtoll.c
Copying file gnulib/tests/test-strtoull.c
Copying file gnulib/tests/test-symlink.c
Copying file gnulib/tests/test-symlink.h
Copying file gnulib/tests/test-sys_ioctl.c
Copying file gnulib/tests/test-sys_select.c
Copying file gnulib/tests/test-sys_socket.c
Copying file gnulib/tests/test-sys_stat.c
Copying file gnulib/tests/test-sys_time.c
Copying file gnulib/tests/test-sys_types.c
Copying file gnulib/tests/test-sys_uio.c
Copying file gnulib/tests/test-sys_wait.h
Copying file gnulib/tests/test-thread_create.c
Copying file gnulib/tests/test-thread_self.c
Copying file gnulib/tests/test-time.c
Copying file gnulib/tests/test-unistd.c
Copying file gnulib/tests/test-unsetenv.c
Copying file gnulib/tests/test-usleep.c
Copying file gnulib/tests/test-vasnprintf.c
Copying file gnulib/tests/test-vasprintf.c
Copying file gnulib/tests/test-vc-list-files-cvs.sh
Copying file gnulib/tests/test-vc-list-files-git.sh
Copying file gnulib/tests/test-verify-try.c
Copying file gnulib/tests/test-verify.c
Copying file gnulib/tests/test-verify.sh
Copying file gnulib/tests/test-wchar.c
Copying file gnulib/tests/test-write.c
Copying file gnulib/tests/test-xstrtol.c
Copying file gnulib/tests/test-xstrtol.sh
Copying file gnulib/tests/test-xstrtoll.c
Copying file gnulib/tests/test-xstrtoll.sh
Copying file gnulib/tests/test-xstrtoul.c
Copying file gnulib/tests/test-xstrtoull.c
Copying file gnulib/tests/time.in.h
Copying file gnulib/tests/unsetenv.c
Copying file gnulib/tests/usleep.c
Copying file gnulib/tests/w32sock.h
Copying file gnulib/tests/warn-on-use.h
Copying file gnulib/tests/xalloc-oversized.h
Copying file gnulib/tests/zerosize-ptr.h
Copying file m4/00gnulib.m4
Copying file m4/absolute-header.m4
Copying file m4/alloca.m4
Copying file m4/arpa_inet_h.m4
Copying file m4/byteswap.m4
Copying file m4/close.m4
Copying file m4/ctype.m4
Copying file m4/dirname.m4
Copying file m4/double-slash-root.m4
Copying file m4/dup2.m4
Copying file m4/eealloc.m4
Copying file m4/environ.m4
Copying file m4/errno_h.m4
Copying file m4/error.m4
Copying file m4/exponentd.m4
Copying file m4/extensions.m4
Copying file m4/extern-inline.m4
Copying file m4/fcntl-o.m4
Copying file m4/fcntl.m4
Copying file m4/fcntl_h.m4
Copying file m4/fdopen.m4
Copying file m4/float_h.m4
Copying file m4/fpieee.m4
Copying file m4/fstat.m4
Copying file m4/ftruncate.m4
Copying file m4/getcwd.m4
Copying file m4/getdtablesize.m4
Copying file m4/getopt.m4
Copying file m4/getpagesize.m4
Copying file m4/getprogname.m4
Copying file m4/gettimeofday.m4
Copying file m4/gnu-make.m4
Copying file m4/gnulib-common.m4
Copying file m4/gnulib-tool.m4
Copying file m4/host-cpu-c-abi.m4
Replacing file m4/iconv.m4 (non-gnulib code backed up in m4/iconv.m4~) !!
Copying file m4/include_next.m4
Copying file m4/inet_pton.m4
Copying file m4/intmax_t.m4
Replacing file m4/inttypes-pri.m4 (non-gnulib code backed up in m4/inttypes-pri.m4~) !!
Copying file m4/inttypes.m4
Replacing file m4/inttypes_h.m4 (non-gnulib code backed up in m4/inttypes_h.m4~) !!
Copying file m4/ioctl.m4
Copying file m4/isblank.m4
Copying file m4/largefile.m4
Replacing file m4/lib-ld.m4 (non-gnulib code backed up in m4/lib-ld.m4~) !!
Replacing file m4/lib-link.m4 (non-gnulib code backed up in m4/lib-link.m4~) !!
Replacing file m4/lib-prefix.m4 (non-gnulib code backed up in m4/lib-prefix.m4~) !!
Copying file m4/limits-h.m4
Copying file m4/localtime-buffer.m4
Replacing file m4/lock.m4 (non-gnulib code backed up in m4/lock.m4~) !!
Replacing file m4/longlong.m4 (non-gnulib code backed up in m4/longlong.m4~) !!
Copying file m4/lstat.m4
Copying file m4/malloc.m4
Copying file m4/malloca.m4
Copying file m4/manywarnings-c++.m4
Copying file m4/manywarnings.m4
Copying file m4/math_h.m4
Copying file m4/memchr.m4
Copying file m4/mmap-anon.m4
Copying file m4/mode_t.m4
Copying file m4/msvc-inval.m4
Copying file m4/msvc-nothrow.m4
Copying file m4/multiarch.m4
Copying file m4/nanosleep.m4
Copying file m4/netinet_in_h.m4
Copying file m4/nocrash.m4
Copying file m4/off_t.m4
Copying file m4/open-cloexec.m4
Copying file m4/open.m4
Copying file m4/pathmax.m4
Copying file m4/perror.m4
Copying file m4/pipe.m4
Copying file m4/printf.m4
Copying file m4/pthread_rwlock_rdlock.m4
Copying file m4/pthread_sigmask.m4
Copying file m4/putenv.m4
Copying file m4/raise.m4
Copying file m4/read.m4
Copying file m4/safe-read.m4
Copying file m4/safe-write.m4
Copying file m4/select.m4
Copying file m4/setenv.m4
Copying file m4/sigaction.m4
Copying file m4/signal_h.m4
Copying file m4/signalblocking.m4
Replacing file m4/size_max.m4 (non-gnulib code backed up in m4/size_max.m4~) !!
Copying file m4/sleep.m4
Copying file m4/socketlib.m4
Copying file m4/sockets.m4
Copying file m4/socklen.m4
Copying file m4/sockpfaf.m4
Copying file m4/ssize_t.m4
Copying file m4/stat-time.m4
Copying file m4/stat.m4
Copying file m4/stdalign.m4
Copying file m4/stdbool.m4
Copying file m4/stddef_h.m4
Copying file m4/stdint.m4
Replacing file m4/stdint_h.m4 (non-gnulib code backed up in m4/stdint_h.m4~) !!
Copying file m4/stdio_h.m4
Copying file m4/stdlib_h.m4
Copying file m4/strerror.m4
Copying file m4/strerror_r.m4
Copying file m4/string_h.m4
Copying file m4/strndup.m4
Copying file m4/strnlen.m4
Copying file m4/strtoll.m4
Copying file m4/strtoull.m4
Copying file m4/symlink.m4
Copying file m4/sys_ioctl_h.m4
Copying file m4/sys_select_h.m4
Copying file m4/sys_socket_h.m4
Copying file m4/sys_stat_h.m4
Copying file m4/sys_time_h.m4
Copying file m4/sys_types_h.m4
Copying file m4/sys_uio_h.m4
Copying file m4/thread.m4
Copying file m4/threadlib.m4
Copying file m4/time_h.m4
Copying file m4/unistd_h.m4
Copying file m4/usleep.m4
Copying file m4/vasnprintf.m4
Copying file m4/vasprintf.m4
Copying file m4/warn-on-use.m4
Copying file m4/warnings.m4
Copying file m4/wchar_h.m4
Replacing file m4/wchar_t.m4 (non-gnulib code backed up in m4/wchar_t.m4~) !!
Replacing file m4/wint_t.m4 (non-gnulib code backed up in m4/wint_t.m4~) !!
Copying file m4/write.m4
Replacing file m4/xsize.m4 (non-gnulib code backed up in m4/xsize.m4~) !!
Copying file m4/xstrtol.m4
Copying file m4/yield.m4
Copying file maint.mk
Creating gnulib/lib/Makefile.am
Creating m4/gnulib-cache.m4
Creating m4/gnulib-comp.m4
Creating gnulib/tests/Makefile.am
Creating ./build-aux/.gitignore
Creating ./gnulib/lib/.gitignore
Creating ./gnulib/lib/glthread/.gitignore
Creating ./gnulib/tests/.gitignore
Creating ./gnulib/tests/glthread/.gitignore
Finished.
You may need to add #include directives for the following .h files.
  #include <byteswap.h>
  #include <fcntl.h>
  #include <inttypes.h>
  #include <stdio.h>
  #include <string.h>
  #include "c-ctype.h"
  #include "full-read.h"
  #include "full-write.h"
  #include "glthread/lock.h"
  #include "ignore-value.h"
  #include "progname.h"
  #include "xstrtol.h"
  #if HAVE_ICONV
  # include <iconv.h>
  #endif
You may need to use the following Makefile variables when linking.
Use them in <program>_LDADD when linking a program, or
in <library>_a_LDFLAGS or <library>_la_LDFLAGS when linking a library.
  $(LTLIBICONV) when linking with libtool, $(LIBICONV) otherwise
  $(LTLIBINTL) when linking with libtool, $(LIBINTL) otherwise
  $(LTLIBTHREAD) when linking with libtool, $(LIBTHREAD) otherwise
Don't forget to
  - add "gnulib/lib/Makefile" to AC_CONFIG_FILES in ./configure.ac,
  - add "gnulib/tests/Makefile" to AC_CONFIG_FILES in ./configure.ac,
  - mention "lib" in SUBDIRS in gnulib/Makefile.am,
  - mention "tests" in SUBDIRS in gnulib/Makefile.am,
  - mention "-I m4" in ACLOCAL_AMFLAGS in Makefile.am,
  - mention "m4/gnulib-cache.m4" in EXTRA_DIST in Makefile.am,
  - invoke gl_EARLY in ./configure.ac, right after AC_PROG_CC_STDC,
  - invoke gl_INIT in ./configure.ac.
autoreconf: Entering directory `.'
autoreconf: running: true
autoreconf: running: aclocal -I m4
autoreconf: configure.ac: tracing
autoreconf: running: true --copy
autoreconf: running: /usr/bin/autoconf
autoreconf: running: /usr/bin/autoheader
autoreconf: running: automake --add-missing --copy --no-force
configure.ac:182: warning: The 'AM_PROG_MKDIR_P' macro is deprecated, and its use is discouraged.
configure.ac:182: You should use the Autoconf-provided 'AC_PROG_MKDIR_P' macro instead,
configure.ac:182: and use '$(MKDIR_P)' instead of '$(mkdir_p)'in your Makefile.am files.
configure.ac:40: installing 'build-aux/compile'
configure.ac:27: installing 'build-aux/missing'
parallel-tests: installing 'build-aux/test-driver'
gnulib/lib/Makefile.am: installing 'build-aux/depcomp'
autoreconf: Leaving directory `.'
CONFIGUREDIR=.
# Run configure in BUILDDIR if it's set
if [ ! -z "$BUILDDIR" ]; then
    mkdir -p $BUILDDIR
    cd $BUILDDIR
    CONFIGUREDIR=..
fi
# Rerun the generator (requires OCaml interpreter).  This is *not* for
# anything that is required at configure-time when configure is run
# from a distribution tarball.  From those, nothing ocaml-related is
# required.
mkdir -p perl/lib/Win
./generator/generator.ml
File "./generator/generator.ml", line 686, characters 26-40:
686 |       if shortdesc.[0] <> Char.lowercase shortdesc.[0] then
Alert deprecated: Stdlib.Char.lowercase
Use Char.lowercase_ascii instead.
File "./generator/generator.ml", line 701, characters 15-32:
701 | let chan = ref Pervasives.stdout
Alert deprecated: module Stdlib.Pervasives
Use Stdlib instead.
If you need to stay compatible with OCaml < 4.07, you can use the
stdlib-shims library: https://github.com/ocaml/stdlib-shims
File "./generator/generator.ml", line 2190, characters 49-65:
2190 |       pr "\n                        [%s => 1,]" (String.lowercase flag)
Alert deprecated: Stdlib.String.lowercase
Use String.lowercase_ascii instead.
File "./generator/generator.ml", line 2220, characters 46-62:
2220 |       pr "  $flags += %d if $flags{%s};\n" n (String.lowercase flag)
File "./generator/generator.ml", line 3341, characters 43-59:
3341 |     fun (_, flag, _) -> pr ", %s = False" (String.lowercase flag)
File "./generator/generator.ml", line 3352, characters 41-57:
3352 |       pr "        if %s: flags += %d\n" (String.lowercase flag) n
File "./generator/generator.ml", line 3583, characters 17-33:
3583 |                 (String.lowercase flag);
File "./generator/generator.ml", line 3796, characters 10-27:
3796 |   chan := Pervasives.stdout;
Use Stdlib instead.
written lib/hivex.h
written lib/hivex.pod
written lib/hivex.syms
written ocaml/hivex.mli
written ocaml/hivex_c.c
written perl/lib/Win/Hivex.pm
written perl/Hivex.xs
written python/hivex/__init__.py
written python/hivex/hive_types.py
written python/hivex-py.c
written ruby/ext/hivex/_hivex.c
generated 6275 lines of code
# If no arguments were specified and configure has run before, use the previous
# arguments
if test $# = 0 && test -x ./config.status; then
    ./config.status --recheck
else
    $CONFIGUREDIR/configure "$@"
fi
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether make supports nested variables... (cached) yes
checking whether make supports the include directive... yes (GNU style)
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking whether _XOPEN_SOURCE should be defined... no
checking for Minix Amsterdam compiler... no
checking for ar... ar
checking for ranlib... ranlib
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for shared library run path origin... done
checking 32-bit host C ABI... no
checking for the common suffixes of directories in the library search path... lib,lib
checking whether imported symbols can be declared weak... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for multithread API to use... posix
checking for pthread_rwlock_t... yes
checking whether pthread_rwlock_rdlock prefers a writer to a reader... no
checking for size_t... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for _set_invalid_parameter_handler... no
checking for fcntl... yes
checking for symlink... yes
checking for getdtablesize... yes
checking for getprogname... no
checking for getexecname... no
checking for mprotect... yes
checking for strerror_r... yes
checking for __xpg_strerror_r... yes
checking for strndup... yes
checking for vasnprintf... no
checking for snprintf... yes
checking for ftruncate... yes
checking for gettimeofday... yes
checking for isblank... yes
checking for lstat... yes
checking for pipe... yes
checking for pthread_sigmask... no
checking for setenv... yes
checking for sigaction... yes
checking for sigaltstack... yes
checking for siginterrupt... yes
checking for sleep... yes
checking for catgets... yes
checking for shutdown... yes
checking for usleep... yes
checking for sys/socket.h... yes
checking for unistd.h... (cached) yes
checking for getopt.h... yes
checking for sys/cdefs.h... yes
checking for limits.h... yes
checking for wchar.h... yes
checking for stdint.h... (cached) yes
checking for inttypes.h... (cached) yes
checking for sys/mman.h... yes
checking for features.h... yes
checking for crtdefs.h... no
checking for arpa/inet.h... yes
checking for sys/stat.h... (cached) yes
checking for sys/time.h... yes
checking for netdb.h... yes
checking for netinet/in.h... yes
checking for semaphore.h... yes
checking for sys/select.h... yes
checking for sys/param.h... yes
checking for sys/wait.h... yes
checking for sys/ioctl.h... yes
checking for sys/uio.h... yes
checking whether // is distinct from /... no
checking whether the preprocessor supports include_next... yes
checking whether system header files limit the line length... no
checking for complete errno.h... yes
checking whether strerror_r is declared... yes
checking for strerror_r... (cached) yes
checking whether strerror_r returns char *... yes
checking for working fcntl.h... yes
checking for pid_t... yes
checking for mode_t... yes
checking whether getdtablesize is declared... yes
checking for getopt.h... (cached) yes
checking for getopt_long_only... yes
checking whether getopt is POSIX compatible... yes
checking for working GNU getopt function... yes
checking for working GNU getopt_long function... yes
checking for iconv... yes
checking for working iconv... yes
checking for iconv declaration...
         extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
checking whether limits.h has LLONG_MAX, WORD_BIT, ULLONG_WIDTH etc.... yes
checking for wint_t... yes
checking whether wint_t is too small... no
checking for unsigned long long int... yes
checking for long long int... yes
checking whether stdint.h conforms to C99... yes
checking whether stdint.h predates C++11... no
checking whether stdint.h has UINTMAX_WIDTH etc.... yes
checking whether the inttypes.h PRIxNN macros are broken... no
checking for a sed that does not truncate output... /usr/bin/sed
checking whether malloc, realloc, calloc are POSIX compliant... yes
checking for mmap... yes
checking for MAP_ANONYMOUS... yes
checking whether memchr works... yes
checking for sigset_t... yes
checking for ssize_t... yes
checking for uid_t in sys/types.h... yes
checking for stdbool.h that conforms to C99... yes
checking for _Bool... yes
checking for wchar_t... yes
checking whether strerror(0) succeeds... yes
checking for strerror_r with POSIX signature... no
checking whether __xpg_strerror_r works... yes
checking for C/C++ restrict keyword... __restrict
checking whether strndup is declared... yes
checking whether strnlen is declared... yes
checking for intmax_t... yes
checking where to find the exponent in a 'double'... word 1 bit 20
checking whether snprintf returns a byte count as in C99... yes
checking for snprintf... (cached) yes
checking for strnlen... yes
checking for wcslen... yes
checking for wcsnlen... yes
checking for mbrtowc... yes
checking for wcrtomb... yes
checking whether _snprintf is declared... no
checking whether <wchar.h> uses 'inline' correctly... yes
checking whether <sys/socket.h> is self-contained... yes
checking for shutdown... (cached) yes
checking whether <sys/socket.h> defines the SHUT_* macros... yes
checking for struct sockaddr_storage... yes
checking for sa_family_t... yes
checking for struct sockaddr_storage.ss_family... yes
checking if environ is properly declared... yes
checking whether stat file-mode macros are broken... no
checking for nlink_t... yes
checking whether getcwd (NULL, 0) allocates memory for result... yes
checking for getcwd with POSIX signature... yes
checking for struct timeval... yes
checking for wide-enough struct timeval.tv_sec member... yes
checking for IPv4 sockets... yes
checking for IPv6 sockets... yes
checking whether lstat correctly handles trailing slash... yes
checking for stdlib.h... (cached) yes
checking for GNU libc compatible malloc... yes
checking whether <sys/select.h> is self-contained... yes
checking for inline... inline
checking for library containing setsockopt... none needed
checking whether select supports a 0 argument... yes
checking whether select detects invalid fds... yes
checking whether alarm is declared... yes
checking for O_CLOEXEC... yes
checking for promoted mode_t type... mode_t
checking whether strerror_r is declared... (cached) yes
checking whether setenv is declared... yes
checking search.h usability... yes
checking search.h presence... yes
checking for search.h... yes
checking for tsearch... yes
checking for struct timespec in <time.h>... yes
checking whether unsetenv is declared... yes
checking for alloca as a compiler built-in... yes
checking byteswap.h usability... yes
checking byteswap.h presence... yes
checking for byteswap.h... yes
checking whether // is distinct from /... (cached) no
checking whether dup2 works... yes
checking for error_at_line... yes
checking whether fcntl handles F_DUPFD correctly... yes
checking whether fcntl understands F_DUPFD_CLOEXEC... needs runtime check
checking whether conversion from 'int' to 'long double' works... yes
checking whether getdtablesize works... yes
checking whether program_invocation_name is declared... yes
checking whether program_invocation_short_name is declared... yes
checking whether __argv is declared... no
checking whether INT32_MAX < INTMAX_MAX... yes
checking whether INT64_MAX == LONG_MAX... yes
checking whether UINT32_MAX < UINTMAX_MAX... yes
checking whether UINT64_MAX == ULONG_MAX... yes
checking for pthread_rwlock_t... (cached) yes
checking whether pthread_rwlock_rdlock prefers a writer to a reader... (cached) no
checking whether program_invocation_name is declared... (cached) yes
checking whether program_invocation_short_name is declared... (cached) yes
checking for raise... yes
checking for sigprocmask... yes
checking for volatile sig_atomic_t... yes
checking for sighandler_t... yes
checking for SIZE_MAX... yes
checking for ssize_t... (cached) yes
checking for good max_align_t... yes
checking whether NULL can be used in arbitrary expressions... yes
checking which flavor of printf attribute matches inttypes macros... system
checking for working strerror function... yes
checking for working strndup... yes
checking for working strnlen... yes
checking for strtoll... yes
checking for strtoull... yes
checking for ptrdiff_t... yes
checking for vasprintf... yes
checking for long long int... (cached) yes
checking whether fdopen sets errno... yes
checking for getpagesize... yes
checking whether getpagesize is declared... yes
checking whether gettimeofday clobbers localtime buffer... no
checking for gettimeofday with POSIX signature... almost
checking for library containing inet_pton... none required
checking whether inet_pton is declared... yes
checking whether byte ordering is bigendian... no
checking for ioctl... yes
checking for ioctl with POSIX signature... no
checking for mmap... (cached) yes
checking for library containing nanosleep... none required
checking for working nanosleep... no (mishandles large arguments)
checking whether <netinet/in.h> is self-contained... yes
checking whether open recognizes a trailing slash... yes
checking whether perror matches strerror... yes
checking for pthread_sigmask in -pthread... yes
checking whether pthread_sigmask is only a macro... no
checking whether pthread_sigmask returns error numbers... yes
checking whether pthread_sigmask unblocks signals correctly... guessing yes
checking for putenv compatible with GNU and SVID... yes
checking whether select supports a 0 argument... (cached) yes
checking whether select detects invalid fds... (cached) yes
checking whether setenv validates arguments... yes
checking for struct sigaction.sa_sigaction... yes
checking for sigprocmask... (cached) yes
checking whether sleep is declared... yes
checking for working sleep... yes
checking for socklen_t... yes
checking whether stat handles trailing slashes on files... yes
checking for struct stat.st_atim.tv_nsec... yes
checking whether struct stat.st_atim is of type struct timespec... yes
checking for struct stat.st_birthtimespec.tv_nsec... no
checking for struct stat.st_birthtimensec... no
checking for struct stat.st_birthtim.tv_nsec... no
checking for working stdalign.h... yes
checking whether symlink handles trailing slash correctly... yes
checking whether <sys/ioctl.h> declares ioctl... yes
checking for nlink_t... (cached) yes
checking for pthread_atfork... yes
checking for unsetenv... yes
checking for unsetenv() return type... int
checking whether unsetenv obeys POSIX... yes
checking for useconds_t... yes
checking whether usleep allows large arguments... yes
checking for sched_yield in -lrt... yes
checking how to print strings... printf
checking for a sed that does not truncate output... (cached) /usr/bin/sed
checking for fgrep... /usr/bin/grep -F
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... (cached) ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /usr/bin/dd
checking how to truncate binary pipes... /usr/bin/dd bs=4096 count=1
checking for mt... no
checking if : is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for gcc option to accept ISO C99... none needed
checking for gcc option to accept ISO Standard C... (cached) none needed
checking for function prototypes... yes
checking for special C compiler options needed for large files... (cached) no
checking for _FILE_OFFSET_BITS value needed for large files... (cached) no
checking size of long... 8
checking for byteswap.h... (cached) yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking libintl.h usability... yes
checking libintl.h presence... yes
checking for libintl.h... yes
checking for bindtextdomain... yes
checking for pod2man... pod2man
checking for pod2text... pod2text
checking for main in -lreadline... yes
checking whether NLS is requested... yes
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for LIBXML2... yes
checking for open_memstream... yes
checking for ocamlc... ocamlc
OCaml version is 4.09.0
OCaml library path is /usr/lib/ocaml
checking for ocamlopt... ocamlopt
checking for ocamlc.opt... ocamlc.opt
checking for ocamlopt.opt... ocamlopt.opt
checking for ocamldep... ocamldep
checking for ocamlmktop... ocamlmktop
checking for ocamlmklib... ocamlmklib
checking for ocamldoc... ocamldoc
checking for ocamlbuild... no
checking for ocamlfind... ocamlfind
checking for caml/unixsupport.h... yes
checking for function caml_raise_with_args... found
checking for perl... perl
checking for Test::More... yes
checking for ExtUtils::MakeMaker... yes
checking for IO::Stringy... yes
checking for python... python2
checking Python prefix... /usr
checking Python version... 2.7
checking for Python include path... -I/usr/include/python2.7
checking for Python site-packages path... /usr/lib/python2.7/site-packages
checking for Python extension suffix (PEP-3149)... .so
checking for PyCapsule_New in -lc... yes
checking for ruby... ruby
checking for rake... rake
checking for C library for Ruby extensions... -lruby
checking for ruby_init in -lruby... yes
checking for rb_hash_lookup... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating extra-tests/Makefile
config.status: creating generator/Makefile
config.status: creating gnulib/lib/Makefile
config.status: creating gnulib/tests/Makefile
config.status: creating hivex.pc
config.status: creating images/Makefile
config.status: creating lib/Makefile
config.status: creating lib/tools/Makefile
config.status: creating ocaml/Makefile
config.status: creating ocaml/META
config.status: creating perl/Makefile
config.status: creating perl/Makefile.PL
config.status: creating python/Makefile
config.status: creating po/Makefile.in
config.status: creating regedit/Makefile
config.status: creating ruby/Makefile
config.status: creating ruby/Rakefile
config.status: creating sh/Makefile
config.status: creating xml/Makefile
config.status: creating python/run-python-tests
config.status: creating ruby/run-ruby-tests
config.status: creating run
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing po-directories commands
config.status: creating po/POTFILES
Thank you for downloading hivex 1.3.18
This is how we have configured the optional components for you today:
OCaml bindings ...................... yes
Perl bindings ....................... yes
Python bindings ..................... yes
Ruby bindings ....................... yes
If any optional component is configured 'no' when you expected 'yes'
then you should check the preceeding messages.
Please report bugs back to the mailing list:
http://www.redhat.com/mailman/listinfo/libguestfs
Next you should type 'make' to build the package,
then 'make check' to run the tests.
make  all-recursive
make[1]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex'
Making all in gnulib/lib
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/gnulib/lib'
  GEN      alloca.h
  GEN      fcntl.h
  GEN      inttypes.h
  GEN      limits.h
  GEN      signal.h
  GEN      stdio.h
  GEN      stdlib.h
  GEN      string.h
  GEN      sys/types.h
  GEN      unistd.h
  GEN      wchar.h
make  all-recursive
make[3]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/gnulib/lib'
make[4]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/gnulib/lib'
  CC       c-ctype.lo
  CC       dirname-lgpl.lo
  CC       basename-lgpl.lo
  CC       stripslash.lo
  CC       exitfail.lo
  CC       fd-hook.lo
  CC       full-read.lo
  CC       full-write.lo
  CC       getprogname.lo
  CC       glthread/lock.lo
  CC       progname.lo
  CC       safe-read.lo
  CC       safe-write.lo
  CC       glthread/threadlib.lo
  CC       unistd.lo
  CC       xsize.lo
  CC       xstrtol.lo
  CC       xstrtoul.lo
  CC       xstrtol-error.lo
  CC       asnprintf.lo
  CC       fcntl.lo
  CC       printf-args.lo
  CC       printf-parse.lo
  CC       vasnprintf.lo
  CC       xstrtoll.lo
  CC       xstrtoull.lo
  CCLD     libgnu.la
make[4]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/gnulib/lib'
make[3]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/gnulib/lib'
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/gnulib/lib'
Making all in generator
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/generator'
make[2]: Nothing to be done for 'all'.
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/generator'
Making all in lib
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/lib'
Making all in tools
make[3]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/lib/tools'
make[3]: Nothing to be done for 'all'.
make[3]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/lib/tools'
make[3]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/lib'
  CC       libhivex_la-handle.lo
  CC       libhivex_la-node.lo
  CC       libhivex_la-offset-list.lo
  CC       libhivex_la-utf16.lo
  CC       libhivex_la-util.lo
  CC       libhivex_la-value.lo
  CC       libhivex_la-visit.lo
  CC       libhivex_la-write.lo
  CCLD     libhivex.la
pod2man \
  --section 3 \
  -c "Windows Registry" \
  --name "hivex" \
  --release "hivex-1.3.18" \
  hivex.pod > hivex.3-t && mv hivex.3-t hivex.3
mkdir -p ../html
pod2html \
  --css pod.css \
  --htmldir ../html \
  --outfile ../html/hivex.3.html \
  hivex.pod
make[3]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/lib'
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/lib'
Making all in images
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/images'
  CC       mklarge-mklarge.o
  CCLD     mklarge
cmp -s ./minimal ./minimal || \
    cp ./minimal ./minimal
./mklarge ./minimal ./large
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/images'
Making all in gnulib/tests
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/gnulib/tests'
  GEN      arpa/inet.h
  GEN      ctype.h
  GEN      sys/ioctl.h
  GEN      sys/select.h
  GEN      sys/socket.h
  GEN      sys/stat.h
  GEN      sys/time.h
  GEN      sys/uio.h
  GEN      time.h
make  all-recursive
make[3]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/gnulib/tests'
Making all in .
make[4]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/gnulib/tests'
make[4]: Nothing to be done for 'all-am'.
make[4]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/gnulib/tests'
make[3]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/gnulib/tests'
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/gnulib/tests'
Making all in xml
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/xml'
  CC       hivexml-hivexml.o
  CCLD     hivexml
pod2man \
  --section 1 \
  --name "hivexml" \
  hivexml.pod > hivexml.1-t && mv hivexml.1-t hivexml.1
mkdir -p ../html
cd .. && pod2html \
  --css 'pod.css' \
  --htmldir html \
  --outfile html/hivexml.1.html \
  /var/tmp/pamac-build-nigzi/hivex-git/src/hivex/xml/hivexml.pod
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/xml'
Making all in po
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/po'
test ! -f ./hivex.pot || \
  test -z "ca.gmo de.gmo es.gmo eu.gmo fr.gmo gu.gmo hi.gmo hu.gmo ja.gmo kn.gmo ml.gmo mr.gmo nl.gmo or.gmo pl.gmo pt_BR.gmo pt.gmo ru.gmo sr.gmo uk.gmo zh_CN.gmo" || make ca.gmo de.gmo es.gmo eu.gmo fr.gmo gu.gmo hi.gmo hu.gmo ja.gmo kn.gmo ml.gmo mr.gmo nl.gmo or.gmo pl.gmo pt_BR.gmo pt.gmo ru.gmo sr.gmo uk.gmo zh_CN.gmo
make[3]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/po'
rm -f ca.gmo && /usr/bin/msgfmt -c --statistics -o ca.gmo ca.po
21 translated messages, 1 fuzzy translation.
rm -f de.gmo && /usr/bin/msgfmt -c --statistics -o de.gmo de.po
7 translated messages, 15 untranslated messages.
rm -f es.gmo && /usr/bin/msgfmt -c --statistics -o es.gmo es.po
rm -f eu.gmo && /usr/bin/msgfmt -c --statistics -o eu.gmo eu.po
1 translated message, 21 untranslated messages.
rm -f fr.gmo && /usr/bin/msgfmt -c --statistics -o fr.gmo fr.po
rm -f gu.gmo && /usr/bin/msgfmt -c --statistics -o gu.gmo gu.po
18 translated messages, 1 fuzzy translation, 3 untranslated messages.
rm -f hi.gmo && /usr/bin/msgfmt -c --statistics -o hi.gmo hi.po
rm -f hu.gmo && /usr/bin/msgfmt -c --statistics -o hu.gmo hu.po
rm -f ja.gmo && /usr/bin/msgfmt -c --statistics -o ja.gmo ja.po
rm -f kn.gmo && /usr/bin/msgfmt -c --statistics -o kn.gmo kn.po
rm -f ml.gmo && /usr/bin/msgfmt -c --statistics -o ml.gmo ml.po
1 translated message, 1 fuzzy translation, 20 untranslated messages.
rm -f mr.gmo && /usr/bin/msgfmt -c --statistics -o mr.gmo mr.po
rm -f nl.gmo && /usr/bin/msgfmt -c --statistics -o nl.gmo nl.po
rm -f or.gmo && /usr/bin/msgfmt -c --statistics -o or.gmo or.po
rm -f pl.gmo && /usr/bin/msgfmt -c --statistics -o pl.gmo pl.po
rm -f pt_BR.gmo && /usr/bin/msgfmt -c --statistics -o pt_BR.gmo pt_BR.po
20 translated messages, 1 fuzzy translation, 1 untranslated message.
rm -f pt.gmo && /usr/bin/msgfmt -c --statistics -o pt.gmo pt.po
rm -f ru.gmo && /usr/bin/msgfmt -c --statistics -o ru.gmo ru.po
rm -f sr.gmo && /usr/bin/msgfmt -c --statistics -o sr.gmo sr.po
rm -f uk.gmo && /usr/bin/msgfmt -c --statistics -o uk.gmo uk.po
rm -f zh_CN.gmo && /usr/bin/msgfmt -c --statistics -o zh_CN.gmo zh_CN.po
make[3]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/po'
touch stamp-po
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/po'
Making all in sh
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/sh'
  CC       hivexsh-hivexsh.o
  CCLD     hivexsh
pod2man \
  --section 1 \
  --name "hivexget" \
  hivexget.pod > hivexget.1-t && mv hivexget.1-t hivexget.1
pod2man \
  --section 1 \
  --name "hivexsh" \
  hivexsh.pod > hivexsh.1-t && mv hivexsh.1-t hivexsh.1
mkdir -p ../html
cd .. && pod2html \
  --css 'pod.css' \
  --htmldir html \
  --outfile html/hivexget.1.html \
  /var/tmp/pamac-build-nigzi/hivex-git/src/hivex/sh/hivexget.pod
mkdir -p ../html
cd .. && pod2html \
  --css 'pod.css' \
  --htmldir html \
  --outfile html/hivexsh.1.html \
  /var/tmp/pamac-build-nigzi/hivex-git/src/hivex/sh/hivexsh.pod
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/sh'
Making all in ocaml
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/ocaml'
rm -f .depend .depend-t
ocamlfind ocamldep hivex.mli hivex.ml | \
  /usr/bin/sed 's/ *$//' | \
  /usr/bin/sed -e :a -e '/ *\\$/N; s/ *\\\n */ /; ta' | \
  /usr/bin/sed -e 's, :,:,g' | \
  /usr/bin/sed -e 's,/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/ocaml/,./,g' | \
  sort > .depend-t
mv .depend-t .depend
 cd .. && /bin/sh /var/tmp/pamac-build-nigzi/hivex-git/src/hivex/build-aux/missing automake-1.16 --foreign ocaml/Makefile
 cd .. && /bin/sh ./config.status ocaml/Makefile
gcc -I.. -I/usr/lib/ocaml -I../ocaml -I../lib   -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong -fno-plt -fPIC -Wall -c hivex_c.c
ocamlfind ocamlc -package unix -c hivex.mli -o hivex.cmi
mkdir -p `dirname hivex.cmo`
ocamlfind ocamlc -package unix -c hivex.ml -o hivex.cmo
ocamlmklib -o mlhivex hivex_c.o hivex.cmo \
    -ldopt '-Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now' \
    -L../lib/.libs -lhivex
ocamlfind ocamlopt -package unix -c hivex.ml -o hivex.cmx
ocamlmklib -o mlhivex hivex_c.o hivex.cmx \
mkdir -p `dirname t/hivex_005_load.cmo`
ocamlfind ocamlc -package unix -c t/hivex_005_load.ml -o t/hivex_005_load.cmo
/bin/sh ../libtool --mode=execute -dlopen ../lib/libhivex.la \
  ocamlfind ocamlc -dllpath /var/tmp/pamac-build-nigzi/hivex-git/src/hivex/ocaml -package unix \
  -linkpkg mlhivex.cma t/hivex_005_load.cmo -o t/hivex_005_load
mkdir -p `dirname t/hivex_010_open.cmo`
ocamlfind ocamlc -package unix -c t/hivex_010_open.ml -o t/hivex_010_open.cmo
  -linkpkg mlhivex.cma t/hivex_010_open.cmo -o t/hivex_010_open
mkdir -p `dirname t/hivex_020_root.cmo`
ocamlfind ocamlc -package unix -c t/hivex_020_root.ml -o t/hivex_020_root.cmo
  -linkpkg mlhivex.cma t/hivex_020_root.cmo -o t/hivex_020_root
mkdir -p `dirname t/hivex_100_errors.cmo`
ocamlfind ocamlc -package unix -c t/hivex_100_errors.ml -o t/hivex_100_errors.cmo
  -linkpkg mlhivex.cma t/hivex_100_errors.cmo -o t/hivex_100_errors
mkdir -p `dirname t/hivex_110_gc_handle.cmo`
ocamlfind ocamlc -package unix -c t/hivex_110_gc_handle.ml -o t/hivex_110_gc_handle.cmo
  -linkpkg mlhivex.cma t/hivex_110_gc_handle.cmo -o t/hivex_110_gc_handle
mkdir -p `dirname t/hivex_120_rlenvalue.cmo`
ocamlfind ocamlc -package unix -c t/hivex_120_rlenvalue.ml -o t/hivex_120_rlenvalue.cmo
  -linkpkg mlhivex.cma t/hivex_120_rlenvalue.cmo -o t/hivex_120_rlenvalue
mkdir -p `dirname t/hivex_200_write.cmo`
ocamlfind ocamlc -package unix -c t/hivex_200_write.ml -o t/hivex_200_write.cmo
File "t/hivex_200_write.ml", line 60, characters 6-27:
60 |       str'.[i*2] <- str.[i];
Alert deprecated: Stdlib.String.set
Use Bytes.set instead.
File "t/hivex_200_write.ml", line 61, characters 6-28:
61 |       str'.[i*2+1] <- '\000'
File "t/hivex_200_write.ml", line 63, characters 4-27:
63 |     str'.[len'-2] <- '\000';
File "t/hivex_200_write.ml", line 64, characters 4-27:
64 |     str'.[len'-1] <- '\000';
  -linkpkg mlhivex.cma t/hivex_200_write.cmo -o t/hivex_200_write
mkdir -p `dirname t/hivex_300_fold.cmo`
ocamlfind ocamlc -package unix -c t/hivex_300_fold.ml -o t/hivex_300_fold.cmo
  -linkpkg mlhivex.cma t/hivex_300_fold.cmo -o t/hivex_300_fold
rm t/hivex_100_errors.cmo t/hivex_300_fold.cmo t/hivex_020_root.cmo t/hivex_120_rlenvalue.cmo t/hivex_010_open.cmo t/hivex_005_load.cmo t/hivex_200_write.cmo t/hivex_110_gc_handle.cmo
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/ocaml'
Making all in perl
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/perl'
[ . != . ] && cp -rsu /var/tmp/pamac-build-nigzi/hivex-git/src/hivex/perl/. ./.
make[2]: [Makefile:1762: Makefile-pl] Error 1 (ignored)
perl Makefile.PL INSTALLDIRS=site PREFIX=/usr
Warning: -L../lib/.libs changed to -L/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/perl/../lib/.libs
Generating a Unix-style Makefile-pl
Writing Makefile-pl for Win::Hivex
Writing MYMETA.yml and MYMETA.json
make -f Makefile-pl
make[3]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/perl'
cp lib/Win/Hivex.pm blib/lib/Win/Hivex.pm
cp lib/Win/Hivex/Regedit.pm blib/lib/Win/Hivex/Regedit.pm
Running Mkbootstrap for Hivex ()
chmod 644 "Hivex.bs"
"/usr/bin/perl" -MExtUtils::Command::MM -e 'cp_nonempty' -- Hivex.bs blib/arch/auto/Win/Hivex/Hivex.bs 644
"/usr/bin/perl" "/usr/share/perl5/core_perl/ExtUtils/xsubpp"  -typemap '/usr/share/perl5/core_perl/ExtUtils/typemap' -typemap '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/perl/typemap' -typemap '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/perl/typemap'  Hivex.xs > Hivex.xsc
mv Hivex.xsc Hivex.c
cc -c  -I../lib -I../lib -D_REENTRANT -D_GNU_SOURCE -fwrapv -fno-strict-aliasing -pipe -fstack-protector-strong -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -D_FORTIFY_SOURCE=2 -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong -fno-plt -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong -fno-plt   -DVERSION=\"1.3.18\" -DXS_VERSION=\"1.3.18\" -fPIC "-I/usr/lib/perl5/5.30/core_perl/CORE"   Hivex.c
rm -f blib/arch/auto/Win/Hivex/Hivex.so
LD_RUN_PATH="/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/perl/../lib/.libs" cc  -shared -Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now -L/usr/local/lib -fstack-protector-strong  Hivex.o  -o blib/arch/auto/Win/Hivex/Hivex.so  \
   -L/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/perl/../lib/.libs -lhivex   \
chmod 755 blib/arch/auto/Win/Hivex/Hivex.so
Manifying 2 pod documents
make[3]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/perl'
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/perl'
Making all in regedit
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/regedit'
pod2man \
  --section 1 \
  --name "hivexregedit" \
  hivexregedit > hivexregedit.1-t && mv hivexregedit.1-t hivexregedit.1
mkdir -p ../html
cd .. && pod2html \
  --css 'pod.css' \
  --htmldir html \
  --outfile html/hivexregedit.1.html \
  /var/tmp/pamac-build-nigzi/hivex-git/src/hivex/regedit/hivexregedit
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/regedit'
Making all in python
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/python'
  CC       libhivexmod_la-hivex-py.lo
  CCLD     libhivexmod.la
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/python'
Making all in ruby
make[2]: Entering directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/ruby'
rake build
top_srcdir=$(pwd)/..; top_builddir=$(pwd)/..; export ARCHFLAGS="-arch $(uname -m)"; mkdir -p ./ext/hivex; cd ./ext/hivex; ruby /var/tmp/pamac-build-nigzi/hivex-git/src/hivex/ruby/ext/hivex/extconf.rb --with-_hivex-include=$top_srcdir/lib --with-_hivex-lib=$top_builddir/lib/.libs
checking for hivex.h... *** /var/tmp/pamac-build-nigzi/hivex-git/src/hivex/ruby/ext/hivex/extconf.rb failed ***
Could not create Makefile due to some reason, probably lack of necessary
libraries and/or headers.  Check the mkmf.log file for more details.  You may
need configuration options.
Provided configuration options:
	--with-opt-dir
	--without-opt-dir
	--with-opt-include
	--without-opt-include=${opt-dir}/include
	--with-opt-lib
	--without-opt-lib=${opt-dir}/lib
	--with-make-prog
	--without-make-prog
	--srcdir=/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/ruby/ext/hivex
	--curdir
	--ruby=/var/lib/snapd/snap/ruby/160/bin/$(RUBY_BASE_NAME)
	--with-_hivex-dir
	--without-_hivex-dir
	--with-_hivex-include=${_hivex-dir}/include
	--with-_hivex-lib=${_hivex-dir}/lib
/var/lib/snapd/snap/ruby/160/lib/ruby/2.6.0/mkmf.rb:467:in `try_do': The compiler failed to generate an executable file. (RuntimeError)
You have to install development tools first.
	from /var/lib/snapd/snap/ruby/160/lib/ruby/2.6.0/mkmf.rb:601:in `try_cpp'
	from /var/lib/snapd/snap/ruby/160/lib/ruby/2.6.0/mkmf.rb:1109:in `block in have_header'
	from /var/lib/snapd/snap/ruby/160/lib/ruby/2.6.0/mkmf.rb:959:in `block in checking_for'
	from /var/lib/snapd/snap/ruby/160/lib/ruby/2.6.0/mkmf.rb:361:in `block (2 levels) in postpone'
	from /var/lib/snapd/snap/ruby/160/lib/ruby/2.6.0/mkmf.rb:331:in `open'
	from /var/lib/snapd/snap/ruby/160/lib/ruby/2.6.0/mkmf.rb:361:in `block in postpone'
	from /var/lib/snapd/snap/ruby/160/lib/ruby/2.6.0/mkmf.rb:357:in `postpone'
	from /var/lib/snapd/snap/ruby/160/lib/ruby/2.6.0/mkmf.rb:958:in `checking_for'
	from /var/lib/snapd/snap/ruby/160/lib/ruby/2.6.0/mkmf.rb:1108:in `have_header'
	from /var/tmp/pamac-build-nigzi/hivex-git/src/hivex/ruby/ext/hivex/extconf.rb:25:in `<main>'
rake aborted!
Command failed with status (1): [top_srcdir=$(pwd)/..; top_builddir=$(pwd)/...]
/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/ruby/Rakefile:57:in `block in <top (required)>'
Tasks: TOP => build => ./ext/hivex/_hivex.so => ./ext/hivex/Makefile
(See full trace by running task with --trace)
make[2]: *** [Makefile:1761: all] Error 1
make[2]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex/ruby'
make[1]: *** [Makefile:1402: all-recursive] Error 1
make[1]: Leaving directory '/var/tmp/pamac-build-nigzi/hivex-git/src/hivex'
make: *** [Makefile:1309: all] Error 2
==> ERROR: A failure occurred in build().
    Aborting...
When i download it from the official cite everything is the same - general fail with ruby... I downloaded files needed files for the extra tests - still the same... I have latest ruby installed thru pamac-manager !
I'm just stuck with that hivex - reede thems in redhat forum in obuntu and even here - here was 1 theme, I think it was about error loop with ocaml - not sure how it ended and it was closed one without solution for hivex...
Even if i follow other VM road, I think it's important to solve that thing!
EDIT:
Currently im trying to find how to
Revert "out of tree build: ruby"
https://github.com/coriolis/hivex/blob/master/ChangeLog - said here in the changelog
Also once trying to install hivex with pamac-manager - pamac-manager told me some error
something with that -> git://git.sv.gnu.org/gnulib.git
which led to me to GNU and GNU-LIB
Yaourt is no longer maintained and as such unsupported. Try a different aur helper like yay.
the problem is not in yaourt - it's in hivex - even trying to install it thru diffrent locations - gives hell of a pain and not willing to successfully install...
When i decided to try instalin libguestfs ( which need hivex, hivex need ruby - i have ruby, but hivex doesn't care ) in pamac-manager - the whole pamac-manager freez ( stop running) and i have to kill it thru kSys ( windows user here :smiley: )
Not allowed here.
:smiley:
On the other hand, why don't you ask there?
That's just your opinion.
Okay - eX win user :smiley:
As a normal person with less knowledge and strange logic, can I ask you - why the fault to be in yaourt ? Like, I'm trying to execute this two days ( maybe more ) pamac-manager goes brown pants with the hive and libguestfs... I'll try again with different lib ( maybe yay), but still - I downloaded hivex execute the programs(commands) in a way that doesn't have anything to do with yaourt and still the same error - if you want I can show the code and the order that I follow... Don't get me wrong I know it's old and unsupported, but still it didn't interfere with the second method ( or at least i see it like this ) - I just wanna hear your opinion because I'm new and i wanna learn :slight_smile:
Thanks in advance !
do you have matching kernel headers and base-devel installed?
sudo pacman -S linux52-headers base-devel
Looks like i had headers, I just updated and re-installed them :confused:
[nigzi@nigzi500 ~]$ sudo pacman -S linux52-headers base-devel
[sudo] password for nigzi:
warning: linux52-headers-5.2.21-1 is up to date -- reinstalling
:: There are 26 members in group base-devel:
:: Repository core
   1) autoconf  2) automake  3) binutils  4) bison  5) fakeroot  6) file  7) findutils  8) flex  9) gawk  10) gcc  11) gettext  12) grep  13) groff  14) gzip
   15) libtool  16) m4  17) make  18) pacman  19) patch  20) pkgconf  21) sed  22) sudo  23) systemd  24) texinfo  25) util-linux  26) which
Enter a selection (default=all):
warning: autoconf-2.69-5 is up to date -- reinstalling
warning: automake-1.16.1-1 is up to date -- reinstalling
warning: binutils-2.32-3 is up to date -- reinstalling
warning: bison-3.4-1 is up to date -- reinstalling
warning: fakeroot-1.24-1 is up to date -- reinstalling
warning: file-5.37-3 is up to date -- reinstalling
warning: findutils-4.7.0-1 is up to date -- reinstalling
warning: flex-2.6.4-2 is up to date -- reinstalling
warning: gawk-5.0.1-1 is up to date -- reinstalling
warning: gcc-9.2.0-2 is up to date -- reinstalling
warning: gettext-0.20.1-2 is up to date -- reinstalling
warning: grep-3.3-2 is up to date -- reinstalling
warning: groff-1.22.4-1 is up to date -- reinstalling
warning: gzip-1.10-2 is up to date -- reinstalling
warning: libtool-2.4.6+42+gb88cebd5-6 is up to date -- reinstalling
warning: m4-1.4.18-2 is up to date -- reinstalling
warning: make-4.2.1-3 is up to date -- reinstalling
warning: pacman-5.1.3-1 is up to date -- reinstalling
warning: patch-2.7.6-7 is up to date -- reinstalling
warning: pkgconf-1.6.3-2 is up to date -- reinstalling
warning: sed-4.7-2 is up to date -- reinstalling
warning: sudo-1.8.28-0 is up to date -- reinstalling
warning: systemd-242.135-1 is up to date -- reinstalling
warning: texinfo-6.6-1 is up to date -- reinstalling
warning: util-linux-2.34-3 is up to date -- reinstalling
warning: which-2.21-4 is up to date -- reinstalling
resolving dependencies...
Packages (27) autoconf-2.69-5  automake-1.16.1-1  binutils-2.32-3  bison-3.4-1  fakeroot-1.24-1  file-5.37-3  findutils-4.7.0-1  flex-2.6.4-2  gawk-5.0.1-1
              gcc-9.2.0-2  gettext-0.20.1-2  grep-3.3-2  groff-1.22.4-1  gzip-1.10-2  libtool-2.4.6+42+gb88cebd5-6  linux52-headers-5.2.21-1  m4-1.4.18-2  make-4.2.1-3
              pacman-5.1.3-1  patch-2.7.6-7  pkgconf-1.6.3-2  sed-4.7-2  sudo-1.8.28-0  systemd-242.135-1  texinfo-6.6-1  util-linux-2.34-3  which-2.21-4
Total Download Size:    10,32 MiB
Total Installed Size:  326,67 MiB
Net Upgrade Size:        0,00 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
 gawk-5.0.1-1-x86_64                                                       1096,1 KiB   140K/s 00:08 [############################################################] 100%
 m4-1.4.18-2-x86_64                                                         169,7 KiB  0,00B/s 00:00 [############################################################] 100%
 autoconf-2.69-5-any                                                        586,7 KiB   624K/s 00:01 [############################################################] 100%
 automake-1.16.1-1-any                                                      598,6 KiB   155K/s 00:04 [############################################################] 100%
 bison-3.4-1-x86_64                                                         620,7 KiB   125K/s 00:05 [############################################################] 100%
 util-linux-2.34-3-x86_64                                                     2,1 MiB   555K/s 00:04 [############################################################] 100%
 findutils-4.7.0-1-x86_64                                                   454,7 KiB   116K/s 00:04 [############################################################] 100%
 flex-2.6.4-2-x86_64                                                        298,4 KiB  1338K/s 00:00 [############################################################] 100%
 groff-1.22.4-1-x86_64                                                     2043,9 KiB   189K/s 00:11 [############################################################] 100%
 texinfo-6.6-1-x86_64                                                      1299,0 KiB   281K/s 00:05 [############################################################] 100%
 make-4.2.1-3-x86_64                                                        412,7 KiB   260K/s 00:02 [############################################################] 100%
 pacman-5.1.3-1-x86_64                                                      780,9 KiB   158K/s 00:05 [############################################################] 100%
 patch-2.7.6-7-x86_64                                                        92,8 KiB   344K/s 00:00 [############################################################] 100%
(27/27) checking keys in keyring        [############################################################] 100%
(27/27) checking package integrity        [############################################################] 100%
(27/27) loading package files        [############################################################] 100%
(27/27) checking for file conflicts        [############################################################] 100%
(27/27) checking available disk space        [############################################################] 100%
(1/1) Remove DKMS modules
==> dkms remove acpi_call/1.1.0 -k 5.2.21-1-MANJARO
( 1/27) reinstalling linux52-headers        [############################################################] 100%
( 2/27) reinstalling gawk        [############################################################] 100%
( 3/27) reinstalling m4        [############################################################] 100%
( 4/27) reinstalling autoconf        [############################################################] 100%
( 5/27) reinstalling automake        [############################################################] 100%
( 6/27) reinstalling binutils        [############################################################] 100%
( 7/27) reinstalling bison        [############################################################] 100%
( 8/27) reinstalling sed        [############################################################] 100%
( 9/27) reinstalling util-linux        [############################################################] 100%
(10/27) reinstalling fakeroot        [############################################################] 100%
(11/27) reinstalling file        [############################################################] 100%
(12/27) reinstalling findutils        [############################################################] 100%
(13/27) reinstalling flex        [############################################################] 100%
(14/27) reinstalling gcc        [############################################################] 100%
(15/27) reinstalling gettext        [############################################################] 100%
(16/27) reinstalling grep        [############################################################] 100%
(17/27) reinstalling groff        [############################################################] 100%
(18/27) reinstalling gzip        [############################################################] 100%
(19/27) reinstalling libtool        [############################################################] 100%
(20/27) reinstalling texinfo        [############################################################] 100%
(21/27) reinstalling make        [############################################################] 100%
(22/27) reinstalling systemd        [############################################################] 100%
(23/27) reinstalling pacman        [############################################################] 100%
(24/27) reinstalling patch        [############################################################] 100%
(25/27) reinstalling pkgconf        [############################################################] 100%
(26/27) reinstalling sudo        [############################################################] 100%
(27/27) reinstalling which        [############################################################] 100%
( 1/13) Creating system user accounts...
( 2/13) Updating linux52 module dependencies...
( 3/13) Install DKMS modules
==> dkms install acpi_call/1.1.0 -k 5.2.21-1-MANJARO
( 4/13) Updating linux52 initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux52.preset: 'default'
  -> -k /boot/vmlinuz-5.2-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.2-x86_64.img
==> Starting build: 5.2.21-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.2-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux52.preset: 'fallback'
  -> -k /boot/vmlinuz-5.2-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.2-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.2-x86_64-fallback.img
( 5/13) Reloading system bus configuration...
( 6/13) Updating journal message catalog...
( 7/13) Reloading system manager configuration...
( 8/13) Updating udev hardware database...
( 9/13) Applying kernel sysctl settings...
(10/13) Creating temporary files...
(11/13) Reloading device manager configuration...
(12/13) Arming ConditionNeedsUpdate...
(13/13) Updating the info directory file...
[nigzi@nigzi500 ~]$ ^C
[nigzi@nigzi500 ~]$
Pamac-manager still split the same error for hivex-git...
rake aborted!
    Aborting...
Thanks for getting involved again with my adventure man ! I own you a few beers :smiley:
would you know why it's trying to grab ruby libs from a snap package?
do you have ruby installed as a snap? (i dont use snaps so i really have no idea)
After removing yaourt with
Sudo -Rsc yaourt
Install YAY with pamac and then trying to install hivex (and anything other) with YAY i get:
yay -S hivexyay: error while loading shared libraries: libalpm.so.12: cannot open shared object file: No such file or directory
I have - I also instaleted it afterwards trying to "make it run" :sweat_smile:
Even without it it still had that error i think... i will uninstall it right away and try again ( it's the first time I have installed it thru snap package )
is there a reason why you cant just use the hivex pakage in manjaro's repo?
You mean from pamac-manager ? If so - the first installation try is exactly from there !
no, to rule out possibility of the problem being pamac itself. i think you should
  • get rid of the snap ruby package and install the correct on from manjaro's repo
    sudo pacman -S ruby
  • install hivex
    sudo pacman -S hivex
if it fails, post the entire output
your title "hivex cant find ruby", was it such a great idea integrating snap/flatpak into pamac? (rhetorical question)
It's short movie and i tried it already :smiley:
[nigzi@nigzi500 ~]$ sudo pacman -S ruby
warning: dependency cycle detected:
warning: rubygems will be installed before its ruby dependency
Packages (2) rubygems-3.0.6-1  ruby-2.6.5-1
Total Download Size:    0,21 MiB
Total Installed Size:  13,84 MiB
 rubygems-3.0.6-1-any                                                       217,4 KiB  1162K/s 00:00 [############################################################] 100%
(2/2) checking keys in keyring        [############################################################] 100%
(2/2) checking package integrity        [############################################################] 100%
(2/2) loading package files        [############################################################] 100%
(2/2) checking for file conflicts        [############################################################] 100%
(2/2) checking available disk space        [############################################################] 100%
(1/2) installing rubygems        [############################################################] 100%
(2/2) installing ruby        [############################################################] 100%
Optional dependencies for ruby
    ruby-docs: Ruby documentation
    tk: for Ruby/TK
(1/1) Arming ConditionNeedsUpdate...
[nigzi@nigzi500 ~]$ sudo pacman -S hivex
error: target not found: hivex
Edit : extra test with syyu
[nigzi@nigzi500 ~]$ sudo pacman -Syyu
 core        149,2 KiB   995K/s 00:00 [############################################################] 100%
 extra        1770,7 KiB  2,66M/s 00:01 [############################################################] 100%
 community        5,3 MiB  2,76M/s 00:02 [############################################################] 100%
 multilib        184,4 KiB   357K/s 00:01 [############################################################] 100%
 archlinuxfr        10,5 KiB  0,00B/s 00:00 [############################################################] 100%
warning: package-query: local (1.9-3) is newer than extra (1.9-2)
 there is nothing to do
Edit 2: also tried :
sudo pacman-mirrors --country all --api --protocols all --set-branch stable && sudo pacman -Syyu
Then tried to instal hivex - the same error again ! I'll save if you want the result of the reset of the mirror list ( trying to keep the thread tidy )
stop trying to get hivex-git to build, cure the disease, not the symptom. hivex is in the manjaro community repo, yet you cant see it. manjaro's package-query is 1.9.2, but you have 1.9-3 from an outside repo
[quote="Niks, post:14, topic:108527"]
* archlinuxfr        10,5 KiB  0,00B/s 00:00 [############################################################] 100%
post full outputs: (2 u's for downgrade)
sudo pacman -Syyuu
sudo pacman-mirrors -c all
sudo pacman -Syyu hivex
cat /etc/pacman.conf
the commands look redundant, but i put them that way for a reason.
Actually, it's not (anymore). Maybe it got removed at some point?
freggeldoe@... $ pacman -Ss hivex
freggeldoe@... $ trizen -Ss hivex
aur/hivex-git 1.3.15.r1.891c426-1 [1+] [0.00%] [19 Mar 2018]
    System for extracting the contents of Windows Registry - git checkout
edit: It's available in testing and unstable but not (yet?) in stable: http://manjaro32.org/repo-compare/community.html
So maybe wait for next stable release to install hivex from repositories.
im in testing branch so that makes sense. i assumed with the other issues the user was having that the problem was related to either mirrors failing to sync properly which in a the past couple days considering the pacman version was updated and then rolled back due to issues. pacman-mirrors also got updates pushed a few times in just the past couple days.
@niks either wait until the recent wave of updates reaches stable, OR manually grab the package from testing, OR switch to testing branch.
i still think you should check your pacman.conf and make sure archlinuxfr is the last repo listed (furthest down, manjaro repos should come before (above) it . then also run an update with -Syyuu so your package-query package is the one in manjaro's repo and not from archlinuxfr
Jobs done boss ! / It was constatly annoying me that error btw - so thanks again /
From your talk I understand it why i don't have it and you have it, either way - i manage to run that VM :smiley: without it, I'm just almost 100% sure that becouse it's missing it gives my weak 3340M a really hard time
Full copy paste of your orders:
nigzi@nigzi500 ~]$ sudo pacman -Syyuu
 core        149,2 KiB   975K/s 00:00 [#######################################################################################] 100%
 extra        1770,8 KiB  2,47M/s 00:01 [#######################################################################################] 100%
 community        5,3 MiB  2,41M/s 00:02 [#######################################################################################] 100%
 multilib        184,4 KiB   323K/s 00:01 [#######################################################################################] 100%
 archlinuxfr        10,5 KiB  0,00B/s 00:00 [#######################################################################################] 100%
warning: package-query: downgrading from version 1.9-3 to version 1.9-2
Packages (1) package-query-1.9-2
Total Download Size:    0,03 MiB
Total Installed Size:   0,08 MiB
Net Upgrade Size:      -0,01 MiB
:: Proceed with installation? [Y/n] y
 package-query-1.9-2-x86_64        27,6 KiB  8,98M/s 00:00 [#######################################################################################] 100%
(1/1) checking keys in keyring        [#######################################################################################] 100%
(1/1) checking package integrity        [#######################################################################################] 100%
(1/1) loading package files        [#######################################################################################] 100%
(1/1) checking for file conflicts        [#######################################################################################] 100%
(1/1) checking available disk space        [#######################################################################################] 100%
(1/1) downgrading package-query        [#######################################################################################] 100%
[nigzi@nigzi500 ~]$ sudo pacman-mirrors -c all
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  ..... Australia      : http://manjaro.melbourneitmirror.net/
  0.320 Austria        : http://mirror.easyname.at/manjaro/
  0.777 Austria        : ftp://mirror.easyname.at/manjaro/
  ..... Bangladesh     : http://mirror.xeonbd.com/manjaro/
::ERROR TIMEOUT 'http://mirror.xeonbd.com/manjaro/'
  0.437 Belgium        : https://mirror.futureweb.be/manjaro/
  0.281 Belgium        : http://mirror.futureweb.be/manjaro/
  2.401 Brazil         : https://manjaro.c3sl.ufpr.br/
  ..... Brazil         : https://www.caco.ic.unicamp.br/manjaro/
  0.704 Bulgaria       : https://mirrors.netix.net/manjaro/
  0.541 Bulgaria       : https://manjaro.ipacct.com/manjaro/
  2.317 Chile          : https://mirror.ufro.cl/manjaro/
  0.503 Denmark        : https://mirrors.dotsrc.org/manjaro/
  0.903 Denmark        : https://www.uex.dk/public/manjaro/
  1.403 Ecuador        : http://mirror.espoch.edu.ec/manjaro/
  0.485 France         : https://manjaro.ynh.ovh/
  0.366 France         : http://kibo.remi.lu/
  0.789 Georgia        : https://manjaro.grena.ge/
  0.523 Georgia        : http://manjaro.grena.ge/
  0.344 Germany        : https://mirror.alpix.eu/manjaro/
  0.297 Germany        : http://mirror.ragenetwork.de/manjaro/
  ..... Germany        : https://ftp.halifax.rwth-aachen.de/manjaro/
::ERROR [Errno 101] Network is unreachable 'https://ftp.halifax.rwth-aachen.de/manjaro/'
  ..... Germany        : ftp://ftp.halifax.rwth-aachen.de/manjaro/
::ERROR ftp error: timeout('timed out') 'ftp://ftp.halifax.rwth-aachen.de/manjaro/'
  0.382 Germany        : https://mirror.netzspielplatz.de/manjaro/packages/
  0.439 Germany        : https://mirror.philpot.de/manjaro/
  0.373 Germany        : https://manjaro.moson.eu/
  0.271 Germany        : http://manjaro.moson.eu/
  0.243 Hungary        : https://quantum-mirror.hu/mirrors/pub/manjaro/
  0.167 Hungary        : http://quantum-mirror.hu/mirrors/pub/manjaro/
  0.250 Hungary        : https://nova.quantum-mirror.hu/mirrors/pub/manjaro/
  0.154 Hungary        : http://nova.quantum-mirror.hu/mirrors/pub/manjaro/
  ..... Japan          : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
  0.393 Netherlands    : https://mirror.neostrada.nl/manjaro/
  0.254 Netherlands    : http://mirror.neostrada.nl/manjaro/
  0.505 Netherlands    : ftp://mirror.neostrada.nl/manjaro/
  1.892 New_Zealand    : http://manjaro.mirrors.theom.nz/
  1.364 Poland         : https://mirror.tuchola-dc.pl/manjaro/
  0.441 Ukraine        : http://mirrors.colocall.net/manjaro/
  0.862 Ukraine        : ftp://mirrors.colocall.net/manjaro/
  0.423 United_Kingdom : http://mirror.catn.com/pub/manjaro/
  ..... United_Kingdom : http://repo.manjaro.org.uk/
  0.244 United_Kingdom : http://manjaro.mirrors.uk2.net/
  1.353 United_States  : https://repo.ialab.dsu.edu/manjaro/
  1.199 United_States  : http://repo.ialab.dsu.edu/manjaro/
  0.913 United_States  : https://mirror.math.princeton.edu/pub/manjaro/
::INFO Writing mirror list
::Hungary         : https://nova.quantum-mirror.hu/mirrors/pub/manjaro/stable
::Hungary         : https://quantum-mirror.hu/mirrors/pub/manjaro/stable
::United_Kingdom  : http://manjaro.mirrors.uk2.net/stable
::Germany         : https://manjaro.moson.eu/stable
::Belgium         : https://mirror.futureweb.be/manjaro/stable
::Germany         : http://mirror.ragenetwork.de/manjaro/stable
::Germany         : https://mirror.alpix.eu/manjaro/stable
::France          : http://kibo.remi.lu/stable
::Germany         : https://mirror.netzspielplatz.de/manjaro/packages/stable
::United_Kingdom  : http://mirror.catn.com/pub/manjaro/stable
::Germany         : https://mirror.philpot.de/manjaro/stable
::France          : https://manjaro.ynh.ovh/stable
::Denmark         : https://mirrors.dotsrc.org/manjaro/stable
::Netherlands     : https://mirror.neostrada.nl/manjaro/stable
::Georgia         : https://manjaro.grena.ge/stable
::Bulgaria        : https://manjaro.ipacct.com/manjaro/stable
::Bulgaria        : https://mirrors.netix.net/manjaro/stable
::Austria         : http://mirror.easyname.at/manjaro/stable
::Ukraine         : http://mirrors.colocall.net/manjaro/stable
::Denmark         : https://www.uex.dk/public/manjaro/stable
::United_States   : https://mirror.math.princeton.edu/pub/manjaro/stable
::United_States   : https://repo.ialab.dsu.edu/manjaro/stable
::Poland          : https://mirror.tuchola-dc.pl/manjaro/stable
::Ecuador         : http://mirror.espoch.edu.ec/manjaro/stable
::New_Zealand     : http://manjaro.mirrors.theom.nz/stable
::Chile           : https://mirror.ufro.cl/manjaro/stable
::Australia       : http://manjaro.melbourneitmirror.net/stable
::Brazil          : https://manjaro.c3sl.ufpr.br/stable
::United_Kingdom  : http://repo.manjaro.org.uk/stable
::Japan           : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::Brazil          : https://www.caco.ic.unicamp.br/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
[nigzi@nigzi500 ~]$ sudo pacman -Syyu hivex
 core        149,2 KiB  1492K/s 00:00 [#######################################################################################] 100%
 extra        1770,9 KiB  1133K/s 00:02 [#######################################################################################] 100%
 community        5,3 MiB  1377K/s 00:04 [#######################################################################################] 100%
 multilib        184,4 KiB  1901K/s 00:00 [#######################################################################################] 100%
 archlinuxfr        10,5 KiB  3,43M/s 00:00 [#######################################################################################] 100%
[nigzi@nigzi500 ~]$ cat /etc/pacman.conf
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
#HookDir     = /etc/pacman.d/hooks/
HoldPkg      = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst    = manjaro-system archlinux-keyring manjaro-keyring
#XferCommand = /usr/bin/curl -C - -f %u > %o
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta    = 0.7
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#TotalDownload
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
# Should have below lines
[archlinuxfr]
SigLevel = Never
Server = http://repo.archlinux.fr/$arch
[nigzi@nigzi500 ~]$
My dumb@ss even copied the line
@freggel.doe - Thanks for clearing the mist !
@dglt
How to do that ?
I'm currently in intel config with that being "said" in the fail you mantion
#!/bin/sh
#this script is run as a display setup script
#that replaces the one used by nvidia/prime.
#this powers-down/disables the nvidia dGPU and
#removes it from /sys/bus/pce/devices
#for the current boot. this is reset after reboot.
# PLEASE READ BELOW TO ENABLE THIS
xrandr --auto
echo 'auto' > '/sys/bus/pci/devices/0000:01:00.0/power/control'  #adjust busid if needed
##make sure the line below is the correct acpi_call to disable your nvidia gpu.
#to find out what call disables your nvidia gpu,
#run this (not while using nvidia gpu, this is why i left it commented out.
#` sudo /etc/switch/gpu_switch_check.sh `
#and see which acpi_call is returned as "works!" and then uncomment and edit this file to match.
#same goes for the the BusID of nvidia card,
#default is set to 0000:01:00.0 (syntax is important)
#if your nvidia gpu has a 1:0:0 busID, just uncomment the line, no change needed.
#echo '\_SB.PCI0.PEG0.PEGP._OFF' > /proc/acpi/call
#echo -n 1 > '/sys/bus/pci/devices/0000:01:00.0/remove'
i manage to run the VM and i saw I'm short on Vram - I'm using second monitor and I'm wondering - can I pass the video output to that second monitor :sweat_smile:
