Sup guys,
A few minutes ago my laptop made some beep beep noises and a few seconds later the webcam active on it's own for about 1 second, my guess is that it took a photo but I didn't trigger it so my first though it that my laptop is compromise and someone is accessing my stuff, which of course it' s a big problem. So far the only new stuff I installed recently is the google-talkplugin and skypeforlinux-bin packages (both from AUR repositories) because I need it for my job.
I haven't install or configure any firewall nor any security stuff besides to what Manjaro has by default, so here are my questions:
- How can I improve my security?
- Is there any firewall by default on Manjaro? if so, how do I configure it?
- Have any of you guys experience anything like this before?
- Any port I should block to avoid any remote connection?
- How can I check if any package has been compromise on my install?
- Any other advice on what to do on these cases?
- Should I do a clean install? I would rather don't since that would take me quite sometime to make a backup of everything...
- And finally, I'm an active gamer, what rules should I add to keep steam and it's games connected?
Here is some info about my Manjaro install and laptop just in case it is a hardware related security issue since it is a Lenovo and that brand have a long history adding backdoors and stuff like that...:
System: Host: TATO Kernel: 4.7.10-1-MANJARO x86_64 (64 bit gcc: 6.2.1) Desktop: KDE Plasma 5.8.3 (Qt 5.7.0)
Distro: Manjaro Linux
Machine: Device: laptop System: LENOVO product: 20DM008UUS v: ThinkPad S3 Yoga 14
Mobo: LENOVO model: 20DM008UUS v: SDK0E50512 STD UEFI: LENOVO v: JFET39WW(1.16) date: 04/27/2015
Battery BAT0: charge: 3.5 Wh 7.1% condition: 49.5/56.0 Wh (88%) model: SMP 00HW001 status: Charging
CPU: Dual core Intel Core i5-5200U (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8782
clock speeds: max: 2700 MHz 1: 2499 MHz 2: 2499 MHz 3: 2635 MHz 4: 2546 MHz
Graphics: Card-1: Intel HD Graphics 5500 bus-ID: 00:02.0
Card-2: NVIDIA GM108M [GeForce 940M] bus-ID: 04:00.0
Display Server: X.Org 1.18.4 driver: intel Resolution: 1920x1080@59.98hz
GLX Renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2)
GLX Version: 3.0 Mesa 13.0.1 Direct Rendering: Yes
Audio: Card-1 Intel Wildcat Point-LP High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Card-2 Intel Broadwell-U Audio Controller driver: snd_hda_intel bus-ID: 00:03.0
Card-3 C-Media driver: USB Audio usb-ID: 002-009
Sound: Advanced Linux Sound Architecture v: k4.7.10-1-MANJARO
Network: Card: Intel Wireless 7265 driver: iwlwifi bus-ID: 02:00.0
IF: wlp2s0 state: up mac: 34:02:86:a0:ca:62
Drives: HDD Total Size: 1016.2GB (81.1% used)
ID-1: /dev/sda model: HGST_HTS541010A7 size: 1000.2GB
ID-2: /dev/sdb model: SanDisk_SSD_U110 size: 16.0GB
Partition: ID-1: / size: 69G used: 62G (95%) fs: ext4 dev: /dev/sda5
ID-2: swap-1 size: 16.01GB used: 0.00GB (0%) fs: swap dev: /dev/sdb1
Sensors: System Temperatures: cpu: 47.0C mobo: 35.0C
Fan Speeds (in rpm): cpu: 0
Info: Processes: 204 Uptime: 3:40 Memory: 6858.3/7903.1MB Init: systemd Gcc sys: 6.2.1
Client: Shell (bash 4.4.01) inxi: 2.3.4
Thanks in advance for everyone that can help me with this!
