weird kernel panic mode
I have 4 OS's install , windows, mint, mint xfce, and manjaro; when I install an OS, I always disconnect all of the other drives, so what ever OS is in it , is contain on that hard drive only, there for I can boot from any of them ; if I start manjaro first it boots correctly and I can boot any other OS from there also , but if I start any other first , manjaro goes into kernel panic . :exploding_head:
Manjaro (and Arch) use two arguments on the initrd line in grub.cfg. Most other distros expect only 1. The newest grub can support 2(+?) arguments, but most non-arch distros are still using an older grub. The panic is because the second argument is half of the kernel. Half of linux won't start. A few non-arch type distros do have the newer grub.
The recommendation is to make Manjaro's grub 1st in boot order. If that is not feasible, then add a custom.cfg to the other distros to add a manual menu entry for manjaro (suggest the grub command configfile.) A search of the forum for "custom.cfg" yielded these ideas to make a custom.cfg. Just add it to /boot/grub/ for each distro that panics on loading Manjaro.
Good Luck
thanks for making it clear, for me is ok that manjaro starts firs, is just as fast as linux or maybe a tad faster, I was a little concern that maybe it was showing some sort of instability ,thats all ; thanks again
This topic was automatically closed after 180 days. New replies are no longer allowed.
