Which file do i need to edit to allway have max frequency at boot, with AMD ryzen 3950X CPU!
Hello Manjaro people
I wonder WERE is the file in Manjaro that i need to edit to always have gives max frequency (at all Cores 3.5GHz) at boot! i know i need to change governers to preformence mode, but i cant find the FILE to edit.
Moste of the guides are for intel CPU but i Have AMD Ryzen 9 3950X cpu.
Does anyone have idea how to solve this!
Have Manjare withe 5.7 Kernel.
Take a look in /etc/default/cpupower
RTFM https://linux.die.net/man/1/cpupower-frequency-set
Before 'adjusting' I'd just hastag lines, copy and then edit them.
I really don't know - I would peek into the tlp configuration located in /etc/tlp.conf.
And if that is overwhelming - there is gui package tlpui.
Big thanks to both of you Guys ( linux-aarhus and ben2talk)
in order to have the file /etc/default/cpupower on your system, you need to install the "cpupower" package first:
sudo pacman -S cpupower
(just in case you are missing this file and wondering why)
