WiFi adapter is missing - not recognized
hi, after installing Manjaro xfce, i was unable to see the wireless network list. when i searched for it, i saw a post saying it might be because network manager is not starting and used the command,
sudo systemctl enable networkmanager
and and i got this,
Failed to enable unit: Unit file networkmanager.service does not exist.
how to connect my laptop with a wifi network now?
(this is my very first Linux OS and i know nothing in it)
(i switched to KDE and i faced the issue on that too and its working)
In *nix land most everything is case sensitive.
NetworkManager
when i typed as NetworkManager, it didn't took that as a command
$ sudo systemctl status NetworkManager
got this,
��� NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; ven>
Drop-In: /usr/lib/systemd/system/NetworkManager.service.d
������NetworkManager-ovs.conf
Active: active (running) since Sun 2018-07-08 14:29:59 IST; 29min ago
Docs: man:NetworkManager(8)
Main PID: 470 (NetworkManager)
Tasks: 3 (limit: 4514)
Memory: 14.2M
CGroup: /system.slice/NetworkManager.service
������470 /usr/bin/NetworkManager --no-daemon
but it didn't enable wireless network.
No, you may have to . In xfce one goes to Menu > Settings > Network Connections.
but in there i see only eathernet.
See the "+" bottom left? That is a criptic way of saying add connection... :wink:
Also try searching the forum, maybe wireless network
I see that you are new here: Joined 37 mins ago Read 19m . So it takes a bit of time to learn some of the self help tools around, like the magnifying glass ( top right) for searching the forum.
I Well, i did setup wireless that way earlier. Maybe i did it wrong. I'll check the forums. Thanks for the help. :slightly_smiling_face:
There is a Manjaro Wiki too.
And of course Arch. https://wiki.archlinux.org/ If you search wireless network in the search box to the right, you will be offered language choices.
And of course come back here. :slightly_smiling_face:
This would help identify your issues:
inxi -Fxzc0
Post output please.
12 posts were split to a new topic: Wifi adapter not detected
Sorry for replying late and Thanks. I'll look in to it.
If your bios has the option, disable your NIC & WIFI, then power down. Remove your battery and power cord. Leave sit for a minute. Restart, boot to BIOS, enable NIC & WIFI, boot to Manjaro.
Then issue:
sudo rfkill unblock all
sudo ip link set enp3s0 up
I have the impression that this is ethernet, while OP looks for WiFi card missing (the Topic title is wrong)
Edit: ## Topic title changed to reflect the actual issue
No, my bios don't have that kind of options. I checked it twice.
No, maybe wifi driver is missing. Its a 6 months old laptop.
[kavin@kavin-pc ~]$ sudo rfkill unblock all
[sudo] password for kavin:
[kavin@kavin-pc ~]$ sudo ip link set enp3s0 up
Cannot find device "enp3s0"
[kavin@kavin-pc ~]$
Anyway anyhow you need to post your HW info
inxi -SMNxxxz
Use wgetpaste if you are on TTY
hi, ill check what's TTY is and post that as soon as i can.
-pc ~]$ inxi -SMNxxxz
Host: kavin-pc Kernel: 4.14.52-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 8.1.1 Desktop: Xfce 4.12.4 tk: Gtk 2.24.32 info: xfce4-panel
dm: lightdm 1.26.0 Distro: Manjaro Linux 17.1.11 Hakoila
Type: Laptop System: HP product: HP Laptop 15-bw0xx
v: Type1ProductConfigId serial: Chassis: type: 10
serial:
Mobo: HP model: 8331 v: 27.31 serial: UEFI: Insyde v: F.20
date: 11/01/2017
Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
driver: r8168 v: 8.045.08-NAPI port: 3000 bus ID: 02:00.0
chip ID: 10ec:8168
Card-2: Realtek driver: N/A port: 2000 bus ID: 03:00.0 chip ID: 10ec:d723
Try
modprobe rtl8723de
