WiFi adapter is missing - not recognized
-pc ~]$ modprobe rtl8723de
modprobe: FATAL: Module rtl8723de not found in directory /lib/modules/4.14.52-1-MANJARO
Provide some more info please:
rfkill list
cat /etc/modprobe.d/*.conf | grep rtl
lsmod | grep rtl
lsmod | grep wl
sure.
[kavin@kavin-pc ~]$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
[kavin@kavin-pc ~]$ cat /etc/modprobe.d/*.conf | grep rtl
[kavin@kavin-pc ~]$
[kavin@kavin-pc ~]$ lsmod | grep rtl
btrtl 16384 1 btusb
bluetooth 630784 12 btrtl,btintel,btbcm,bnep,btusb
[kavin@kavin-pc ~]$ lsmod | grep wl
[kavin@kavin-pc ~]$
these commands,
and
lsmod | grep wl
didn't work.
Post this
lspci -v | grep d723
[kavin@kavin-pc ~]$ lspci -v | grep d723
lspci: Unable to load libkmod resources: error -12
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device d723
[kavin@kavin-pc ~]$
And
lspci -knn | grep Realtek
[kavin@kavin-pc ~]$ lspci -knn | grep Realtek
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:d723]
[kavin@kavin-pc ~]$
The AUR packages:
aur/rtl8723de-dkms 1-1 (2, 0.207568)
    RTL8723 wireless + bluetooth modules (DKMS)
or
aur/rtlwifi_new-extended-dkms r257.fc08be6-1 (1, 0.427981)
    Newest Realtek rtlwifi codes, extended branch
aur/rtlwifi_new-dkms r221.01cbe67-2 (15, 0.004718)
may be worth trying.
It seems this adapter is not compatible with Linux or there are no Linux drivers in the kernel.
It is suggested (Archwiki) to try use ndiswrapper if you can get the relevant WinOS driver.
Though, there is a github repo that reports having a driver for this chip.
You may want to try installing it (instructions included)
i have no idea what you want you are asking. :worried:
can you explain a little please?
thank you!
I'll check those.:slightly_smiling_face:
It's the Github repo I pointed, you are lucky!!
You just need to install that AUR package and you should have your driver.
Search the AUR for "rtl8723de" and install the package that will pop out.
im getting this while using the commands from the github
bash: dkms: command not found
what is AUR?
sorry. im clueless :disappointed:
https://wiki.manjaro.org/index.php?title=Arch_User_Repository
https://wiki.archlinux.org/index.php/Arch_User_Repository
After your study (Disclaimer: important!)
  • Start Pamac (Add/Install Software)
  • In Preferences, go to AUR tab and enable AUR.
  • Exit Preferences
  • Refresh Databases
  • Search for "rtl8723de".
  • Install the package that is found.
  • Reboot
This is the driver package you want from the AUR.
https://aur.archlinux.org/packages/rtlwifi_new-extended-dkms/
You must also install the linux headers package that matches your kernel number.
If you are on 4.17 then install:
linux417-headers
i think the driver is not the right one.
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 60h-6fh) Processor Root Complex
	Subsystem: Hewlett-Packard Company Family 15h (Models 60h-6fh) Processor Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 60h-6fh) I/O Memory Management Unit
	Subsystem: Hewlett-Packard Company Family 15h (Models 60h-6fh) I/O Memory Management Unit
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Stoney [Radeon R2/R3/R4/R5 Graphics] (rev da)
	Subsystem: Hewlett-Packard Company Stoney [Radeon R2/R3/R4/R5 Graphics]
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
00:01.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device 15b3
	Subsystem: Hewlett-Packard Company Device 8331
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 60h-6fh) Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 60h-6fh) Processor Root Port
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 60h-6fh) Processor Root Port
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 60h-6fh) Processor Root Port
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 60h-6fh) Host Bridge
00:08.0 Encryption controller: Advanced Micro Devices, Inc. [AMD] Device 1578
00:09.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 157d
00:09.2 Audio device: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 60h-6fh) Audio Controller
	Subsystem: Hewlett-Packard Company Family 15h (Models 60h-6fh) Audio Controller
00:10.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 20)
	Subsystem: Hewlett-Packard Company FCH USB XHCI Controller
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 4b)
	Subsystem: Hewlett-Packard Company FCH SATA Controller [AHCI mode]
	Kernel driver in use: ahci
	Kernel modules: ahci
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 49)
	Subsystem: Hewlett-Packard Company FCH USB EHCI Controller
	Kernel driver in use: ehci-pci
	Kernel modules: ehci_pci
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 4b)
	Subsystem: Hewlett-Packard Company FCH SMBus Controller
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 11)
	Subsystem: Hewlett-Packard Company FCH LPC Bridge
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15b0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15b1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15b2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15b3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15b4
	Kernel driver in use: fam15h_power
	Kernel modules: fam15h_power
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15b5
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / R7 M520] (rev ff)
	Kernel driver in use: radeon
	Kernel modules: radeon, amdgpu
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
	Subsystem: Hewlett-Packard Company RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
	Kernel driver in use: r8168
	Kernel modules: r8169, r8168
	Subsystem: Hewlett-Packard Company Device 8319
[kavin@kavin-pc ~]$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
    link/ether 48:ba:4e:a9:b1:bd brd ff:ff:ff:ff:ff:ff
[kavin@kavin-pc ~]$ ip link set interface up
Cannot find device "interface"
[kavin@kavin-pc ~]$ dmesg | grep firmware
[   10.508694] [drm] Found UVD firmware Version: 1.43 Family ID: 15
[   10.539458] [drm] Found VCE firmware Version: 52.0 Binary ID: 3
[   10.819036] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[kavin@kavin-pc ~]$
i downloaded the driver RTL8111 and tried to install manually, but it failed to install.
[kavin@kavin-pc ~]$ sudo sh -c 'echo blacklist r8169 >> /etc/modprobe.d/blacklist.conf'
[sudo] password for kavin:
[kavin@kavin-pc ~]$ tar xfvj /home/kavin/Downloads/0010-r8168-8.045.08.tar.bz2
r8168-8.045.08/
r8168-8.045.08/autorun.sh
r8168-8.045.08/Makefile
r8168-8.045.08/README
r8168-8.045.08/src/
r8168-8.045.08/src/Makefile
r8168-8.045.08/src/Makefile_linux24x
r8168-8.045.08/src/r8168.h
r8168-8.045.08/src/r8168_asf.c
r8168-8.045.08/src/r8168_asf.h
r8168-8.045.08/src/r8168_dash.h
r8168-8.045.08/src/r8168_fiber.h
r8168-8.045.08/src/r8168_n.c
r8168-8.045.08/src/r8168_realwow.h
r8168-8.045.08/src/rtltool.c
r8168-8.045.08/src/rtltool.h
r8168-8.045.08/src/rtl_eeprom.c
r8168-8.045.08/src/rtl_eeprom.h
[kavin@kavin-pc ~]$ cd r8168-8.045.08
[kavin@kavin-pc r8168-8.045.08]$ sudo ./autorun.sh
Check old driver and unload it.
rmmod r8168
Build the module and install
make[2]: *** No rule to make target 'clean'.  Stop.
make[1]: *** [Makefile:108: clean] Error 2
make: *** [Makefile:47: clean] Error 2
[kavin@kavin-pc r8168-8.045.08]$ cd
please post
hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" | grep -v "Config Status"
[kavin@kavin-pc ~]$ hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" | grep -v "Config Status"
  Model: "Realtek Network controller"
  Model: "Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller"
  Driver: "r8168"
  Device File: enp2s0
  Link detected: yes
    Driver Status: r8169 is not active
    Driver Activation Cmd: "modprobe r8169"
    Driver Status: r8168 is active
    Driver Activation Cmd: "modprobe r8168"
  Model: "Realtek 802.11n WLAN Adapter"
  Driver: "btusb"
    Driver Status: btusb is active
    Driver Activation Cmd: "modprobe btusb"
[kavin@kavin-pc ~]$
