Hi everyone,
Not content with my struggles with an iMac I also decided to try Manjaro on an old Macbook Air (model A1466) with the (in)famous broadcom wireless adapter.
Anyways I was going through various posts on the forums here and at times the wiki over at Arch and I managed to get the broadcom drivers installed (broadcom-wl-dkms) and I can see the wifi networks in the house. The only problem is that I can't connect to them, when I try I just seem to get stuck in an authentication loop, where it asks for the password, I enter it and then after a bit it tells me it failed and either pops the authentication window up again or just stays there disconnected.
Obvious things to rule out;
- The password is correct, I'm using it on other devices to connect and it works. Also made sure that I'm not typing it incorrectly.
- I'm not able to connect to either 2.4ghz or 5ghz. I can connect to my mobile phones wifi hotspot though.
- I've tried disabling IPV6 and it doesn't help
- I've also tried updating to Kernel 5.0.5 but that doesn't seem to have helped either.
andrew@Manjaro-MBA ~]$ hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" |grep -v "Config Status"
Model: "Broadcom BCM4360 802.11ac Wireless Network Adapter"
Driver: "wl"
Device File: wlp3s0
Link detected: yes
Driver Status: bcma is not active
Driver Activation Cmd: "modprobe bcma"
Driver Status: wl is active
Driver Activation Cmd: "modprobe wl"
Model: "Broadcom NetXtreme BCM57762 Gigabit Ethernet PCIe"
Driver: "tg3"
Device File: ens9
Link detected: yes
Driver Status: tg3 is active
Driver Activation Cmd: "modprobe tg3"
Here is the output from lsmod
[andrew@Manjaro-MBA ~]$ lsmod | sort
ac 16384 0
acpi_als 20480 0
aesni_intel 372736 2
aes_x86_64 20480 1 aesni_intel
agpgart 53248 2 intel_gtt,drm
ahci 40960 2
apple_bl 20480 0
applesmc 24576 0
bcm5974 24576 0
bdc_pci 16384 0
bluetooth 651264 31 btrtl,btintel,btbcm,bnep,btusb,rfcomm
bnep 28672 2
btbcm 16384 1 btusb
btintel 28672 1 btusb
btrtl 20480 1 btusb
btusb 57344 0
cfg80211 798720 1 wl
cmac 16384 1
cmdlinepart 16384 0
coretemp 20480 0
crc16 16384 2 bluetooth,ext4
crc32c_generic 16384 0
crc32c_intel 24576 2
crc32_pclmul 16384 0
crct10dif_pclmul 16384 1
cryptd 28672 3 crypto_simd,ghash_clmulni_intel,aesni_intel
crypto_simd 16384 1 aesni_intel
crypto_user 16384 0
drm 499712 8 drm_kms_helper,i915
drm_kms_helper 208896 1 i915
ecdh_generic 24576 2 bluetooth
evdev 28672 18
ext4 749568 1
fat 81920 1 vfat
fb_sys_fops 16384 1 drm_kms_helper
fscrypto 32768 1 ext4
fuse 131072 3
ghash_clmulni_intel 16384 0
glue_helper 16384 1 aesni_intel
hid 147456 3 usbhid,hid_apple,hid_generic
hid_apple 16384 0
hid_generic 16384 0
i2c_algo_bit 16384 1 i915
i2c_i801 36864 0
i915 2162688 19
industrialio 86016 2 acpi_als,kfifo_buf
input_leds 16384 0
input_polldev 20480 1 applesmc
intel_cstate 16384 0
intel_gtt 24576 1 i915
intel_powerclamp 20480 0
intel_rapl 28672 0
intel_rapl_perf 16384 0
intel_spi 24576 1 intel_spi_platform
intel_spi_platform 16384 0
intel_uncore 135168 0
ip_tables 32768 0
irqbypass 16384 1 kvm
iTCO_vendor_support 16384 1 iTCO_wdt
iTCO_wdt 16384 0
jbd2 131072 1 ext4
joydev 28672 0
kfifo_buf 16384 1 acpi_als
kvm 749568 2 kvmgt,kvm_intel
kvmgt 32768 0
kvm_intel 311296 0
ledtrig_audio 16384 1 snd_hda_codec_generic
libahci 40960 1 ahci
libata 282624 2 libahci,ahci
libphy 90112 1 tg3
lpc_ich 28672 0
mac_hid 16384 0
mbcache 16384 1 ext4
mdev 24576 2 kvmgt,vfio_mdev
mei 118784 1 mei_me
mei_me 45056 0
Module Size Used by
mousedev 24576 0
mtd 73728 5 cmdlinepart,intel_spi,ofpart
nls_cp437 20480 1
nls_iso8859_1 16384 1
ofpart 20480 0
pcc_cpufreq 20480 0
pcspkr 16384 0
rfcomm 86016 4
rfkill 28672 7 bluetooth,cfg80211
sbs 16384 0
sbshc 16384 1 sbs
scsi_mod 253952 4 sd_mod,usb_storage,uas,libata
sd_mod 57344 3
snd 102400 23 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,snd_pcm
snd_hda_codec 155648 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_cirrus
snd_hda_codec_cirrus 20480 1
snd_hda_codec_generic 90112 1 snd_hda_codec_cirrus
snd_hda_codec_hdmi 65536 1
snd_hda_core 98304 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_cirrus
snd_hda_intel 45056 8
snd_hwdep 16384 1 snd_hda_codec
snd_pcm 135168 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
snd_timer 40960 1 snd_pcm
soundcore 16384 1 snd
spi_nor 49152 1 intel_spi
spi_pxa2xx_platform 32768 0
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
tg3 180224 0
thunderbolt 155648 0
uas 28672 0
uinput 20480 0
usbhid 61440 0
usb_storage 73728 1 uas
vfat 20480 1
vfio 36864 3 kvmgt,vfio_mdev,vfio_iommu_type1
vfio_iommu_type1 32768 0
vfio_mdev 16384 0
wl 6463488 0
x86_pkg_temp_thermal 20480 0
xhci_hcd 262144 1 xhci_pci
xhci_pci 20480 0
x_tables 49152 1 ip_tables
dkms status
[andrew@Manjaro-MBA ~]$ dkms status
broadcom-wl, 6.30.223.271, 5.0.5-1-MANJARO, x86_64: installed
dmesg output
[andrew@Manjaro-MBA ~]$ dmesg | grep -i 'error\|seg\|fail\|broke\|warn\|dump\|denied\|broken\|wl'
[ 0.577715] ACPI Error: Needed type [Reference], found [Integer] 00000000d767dffa (20181213/exresop-69)
[ 0.577722] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Store] (20181213/dswexec-427)
[ 0.577729] ACPI Error: Method parse/execution failed \_PR.CPU0._PDC, AE_AML_OPERAND_TYPE (20181213/psparse-531)
[ 0.767265] pci 0000:06:05.0: BAR 14: failed to assign [mem size 0x00200000]
[ 0.767274] pci 0000:06:05.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 0.767279] pci 0000:06:06.0: BAR 14: failed to assign [mem size 0x00200000]
[ 0.767286] pci 0000:06:06.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 0.767292] pci 0000:06:05.0: BAR 13: failed to assign [io size 0x1000]
[ 0.767297] pci 0000:06:06.0: BAR 13: failed to assign [io size 0x1000]
[ 0.767303] pci 0000:06:06.0: BAR 14: failed to assign [mem size 0x00200000]
[ 0.767310] pci 0000:06:06.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 0.767316] pci 0000:06:06.0: BAR 13: failed to assign [io size 0x1000]
[ 0.767321] pci 0000:06:05.0: BAR 14: failed to assign [mem size 0x00200000]
[ 0.767328] pci 0000:06:05.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 0.767334] pci 0000:06:05.0: BAR 13: failed to assign [io size 0x1000]
[ 1.105170] dw_dmac_pci: probe of 0000:00:15.0 failed with error -16
[ 1.124149] Segment Routing with IPv6
[ 1.124461] RAS: Correctable Errors collector initialized.
[ 2.245890] systemd[1]: Listening on Process Core Dump Socket.
[ 3.122494] wl: loading out-of-tree module taints kernel.
[ 3.122501] wl: module license 'MIXED/Proprietary' taints kernel.
[ 3.132287] wl: module verification failed: signature and/or required key missing - tainting kernel
[ 3.538202] wlan0: Broadcom BCM43a0 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[ 3.671889] wl 0000:03:00.0 wlp3s0: renamed from wlan0
[ 4.092932] random: 5 urandom warning(s) missed due to ratelimiting
[ 320.193876] ERROR @wl_notify_scan_status :
[ 320.193879] wlp3s0 Scan_results error (-22)
kernal versions
[andrew@Manjaro-MBA ~]$ pacman -Qsq linux | grep linux | grep -v -E '(arch|util|sys|api|firmware)' | grep -v nvidia
linux419
linux50
linux50-headers
Final point, I have another Macbook Air - same type, model etc that my wife is using with Mac OS X and that can connect to the wifi without any problems.
Any ideas on what I'm missing and can do to fix it????
Thanks everyone!
