WIFI speed So Slow...[Broadcom BCM43142 802.11b/g/n]
I Have installed Manjaro kde plasma 20.0.3 on my Laptop I'm connected to the same wifi network with my Laptop & Desktop.
Download speed:
Desktop[Windows 10] :: 5mbps
Laptop[Manjaro 20.0.3] ::300-400Kbps
(Speed Tested on a ftp server)
inxi -Fxz[Laptop]
System:    Host: isifat-hp Kernel: 5.6.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
           Desktop: KDE Plasma 5.19.3 Distro: Manjaro Linux
Machine:   Type: Laptop System: Hewlett-Packard product: HP Notebook v: Type1ProductConfigId
           serial: <filter>
           Mobo: Hewlett-Packard model: 80C3 v: 96.51 serial: <filter> UEFI: Insyde v: F.27 date: 07/05/2018
Battery:   ID-1: BAT1 charge: 11.4 Wh condition: 27.0/41.4 Wh (65%) model: COMPAL PABAS0241231
           status: Charging
CPU:       Topology: Dual Core model: Intel Core i3-4005U bits: 64 type: MT MCP arch: Haswell rev: 1
           L2 cache: 3072 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 13574
           Speed: 799 MHz min/max: 800/1600 MHz Core speeds (MHz): 1: 798 2: 798 3: 800 4: 799
Graphics:  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard driver: i915 v: kernel
           bus ID: 00:02.0
           Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 20.1.3 direct render: Yes
Audio:     Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
           bus ID: 00:03.0
           Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0
           Sound Server: ALSA v: k5.6.19-2-MANJARO
Network:   Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169
           v: kernel port: 4000 bus ID: 07:00.0
           IF: enp7s0 state: down mac: <filter>
           Device-2: Broadcom and subsidiaries BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
           v: kernel port: 4000 bus ID: 0d:00.0
           IF: wlp13s0 state: up mac: <filter>
Drives:    Local Storage: total: 960.81 GiB used: 50.01 GiB (5.2%)
           ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541010A9E680 size: 931.51 GiB
           ID-2: /dev/sdb type: USB model: SMI USB DISK size: 29.30 GiB
Partition: ID-1: / size: 57.42 GiB used: 9.66 GiB (16.8%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 248.92 GiB used: 2.40 GiB (1.0%) fs: ext4 dev: /dev/sda3
           ID-3: swap-1 size: 7.81 GiB used: 181.2 MiB (2.3%) fs: swap dev: /dev/sda4
Sensors:   System Temperatures: cpu: 52.0 C mobo: N/A
Info:      Processes: 213 Uptime: 9h 20m Memory: 3.77 GiB used: 1.74 GiB (46.1%) Init: systemd Compilers:
           gcc: 10.1.0 Shell: bash v: 5.0.18 inxi: 3.0.37
I Searched on google & tried some tweak on network but it didn't worked.How to fix/Improve network speed??
I use same chip with broadcom-wl on my xps 13 works fine.
Following it for further updates on this topic
Try disabling IPv6. Be sure to reboot both your router and computer after disabling IPv6. There are numerous ways to accomplish this. Please search the forum for methods.
I would probably also try disabling MAC Address randomization.
