''' inxi -Fxxxza
Host: tom-virtualbox Kernel: 5.4.23-1-MANJARO x86_64 bits: 64
compiler: gcc v: 9.2.1
root=UUID=e10151c0-9fde-4ad8-8572-4212d3e6b37d rw quiet apparmor=1
Desktop: Xfce 4.14.2 tk: Gtk 3.24.13 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Virtualbox System: innotek product: VirtualBox v: 1.2
serial: Chassis: Oracle Corporation type: 1 serial:
Mobo: Oracle model: VirtualBox v: 1.2 serial: BIOS: innotek
v: VirtualBox date: 12/01/2006
Topology: Quad Core model: AMD Ryzen 5 2600X bits: 64 type: MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 6000626
L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
bogomips: 28759
Speed: 3593 MHz min/max: N/A Core speeds (MHz): 1: 3593 2: 3593 3: 3593
4: 3593
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.15.0.0
bus ID: 00:02.0 chip ID: 15ad:0405
Display: x11 server: X.Org 1.20.7 driver: vmware unloaded: modesetting
alternate: fbdev,vesa resolution: 1680x1050~60Hz
OpenGL: renderer: SVGA3D; build v: 2.1 Mesa 19.3.4 direct render: Yes
Device-1: Intel 82801AA AC97 Audio vendor: Dell driver: snd_intel8x0
v: kernel bus ID: 00:05.0 chip ID: 8086:2415
Sound Server: ALSA v: k5.4.23-1-MANJARO
Device-1: Intel 82540EM Gigabit Ethernet driver: e1000 v: 7.3.21-k8-NAPI
port: d020 bus ID: 00:03.0 chip ID: 8086:100e
IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge
driver: piix4_smbus v: N/A port: d200 bus ID: 00:07.0 chip ID: 8086:7113
Local Storage: total: 20.00 GiB used: 7.14 GiB (35.7%)
ID-1: /dev/sda vendor: VirtualBox model: VBOX HARDDISK size: 20.00 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: rev: 1.0 scheme: MBR
ID-1: / raw size: 19.99 GiB size: 19.55 GiB (97.80%)
used: 7.14 GiB (36.5%) fs: ext4 dev: /dev/sda1
Message: No sensors data was found. Is sensors configured?
Processes: 174 Uptime: 7m Memory: 3.85 GiB used: 1.05 GiB (27.4%)
Init: systemd v: 242 Compilers: gcc: 9.2.1 Shell: bash v: 5.0.16
running in: xfce4-terminal inxi: 3.0.37 '''
''' xrandr
Screen 0: minimum 1 x 1, current 1680 x 1050, maximum 8192 x 8192
Virtual1 connected primary 1680x1050+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
800x600 60.00 + 60.32
2560x1600 59.99
1920x1440 60.00
1856x1392 60.00
1792x1344 60.00
1920x1200 59.88
1600x1200 60.00
1680x1050 59.95*
1400x1050 59.98
1280x1024 60.02
1440x900 59.89
1280x960 60.00
1360x768 60.02
1280x800 59.81
1152x864 75.00
1280x768 59.87
1024x768 60.00
640x480 59.94
Virtual2 disconnected (normal left inverted right x axis y axis)
Virtual3 disconnected (normal left inverted right x axis y axis)
Virtual4 disconnected (normal left inverted right x axis y axis)
Virtual5 disconnected (normal left inverted right x axis y axis)
Virtual6 disconnected (normal left inverted right x axis y axis)
Virtual7 disconnected (normal left inverted right x axis y axis)
Virtual8 disconnected (normal left inverted right x axis y axis)'''
'''mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-virtualmachine 2020.01.18 true PCI
Warning: No installed USB configs! '''
''' mhwd -l
0000:00:02.0 (0300:15ad:0405) Display controller VMware, Inc.:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI '''
As you can see I am Emulating Manjaro as I am Testing the OS before Putting it on my main system, i appreiacte that it may be diffrent and have diffrent solutions depending on whether Manjaro is emulated or not, However at this time I am not Transitioning to Manjaro until I have used the os in my vm for an extended period.
Thank You a bunch for helping me out
p.s sorry for the late reply
