Wireless issues Qualcomm Atheros
I have an old Dell Inspiron 1440 with a Qualcom Atheros wireless chip.
Intermittently, and without warning, the nic shuts off end disappears as if killed by the hardware switch.
Sometimes, toggling the hardware killswitch brings it back up. Most often it does not. Sometimes a reboot does it, but often two or three boots are required for the interface to come back up. It also shuts off after any hibernation and requres a reboot.
This is more than annoying. Here is the output of lshw:
       description: Wireless interface
       product: AR928X Wireless Network Adapter (PCI-Express)
       vendor: Qualcomm Atheros
       physical id: 0
       bus info: pci@0000:0c:00.0
       logical name: wlp12s0
       version: 01
       serial: 00:22:5f:f1:0a:4a
       width: 64 bits
       clock: 33MHz
       capabilities: bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=ath9k driverversion=5.4.55-1-MANJARO firmware=N/A ip=192.x.x.x latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:17 memory:f69f0000-f69fffff
Any suggestions?
Check tlp settings for it, maybe use tlpui
And maybe this will be also relevant
