hello! I have a problem. I have my wireless network adapter connected to my laptop but it doesn't connect to any wifi network. My laptop has wifi working but the signal is so weak (I think the wifi antenna is broken) so I always have to use my phone's mobile hotspot to connect to the internet and I have to put my phone so close to my laptop. But this isn't my problem. This is the reason why I'm using a wirless network adapter. I used windows 10 in this laptop but it was so slow so I switched to Manjaro XFCE and it performs well. When I was in Windows, I didn't have this problem that my wireless network adapter doesn't connect to any wifi network. It shows the wifi networks. Please help! Thank you.
Hello,
Just passed by to mention that your description is not providing any wireless model, no detail about your hardware, kernel.
Most of us do not start with the premise there is an hardware issue. The mentions like "works in Windows" might have a negative recoil effect ... This is how we consider starting a good help request:
Welcome to Manjaro!
okay, sorry for that but here are the details:
Kernel: 4.14.182-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: X200MA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X200MA v: 1.0 serial: <filter>
UEFI [Legacy]: American Megatrends v: X200MA.601 date: 04/19/2019
ID-1: BAT0 charge: 12.4 Wh condition: 20.1/24.8 Wh (81%) volts: 11.2/11.2
model: ASUSTeK X200-30 type: Li-ion serial: <filter> status: Discharging
RAM: total: 1.84 GiB used: 984.5 MiB (52.2%)
RAM Report:
Topology: Dual Core model: Intel Celeron N2840 bits: 64 type: MCP
arch: Silvermont rev: 8 L2 cache: 1024 KiB bogomips: 8666
Speed: 613 MHz min/max: 500/2582 MHz Core speeds (MHz): 1: 1580 2: 1400
Flags: 3dnowprefetch acpi aperfmperf apic arat arch_perfmon bts clflush
cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept erms
est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs
pge pni popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2
tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi vpid xtopology
xtpr
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0f31
Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting
alternate: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 20.0.7
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:0f04
Sound Server: ALSA v: k4.14.182-1-MANJARO
Device-1: Broadcom and subsidiaries BCM43142 802.11b/g/n vendor: Lite-On
driver: wl v: kernel port: f000 bus ID: 02:00.0 chip ID: 14e4:4365
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK
driver: r8169 v: 2.3LK-NAPI port: e000 bus ID: 03:00.2 chip ID: 10ec:8136
IF: enp3s0f2 state: down mac: <filter>
Device-3: Realtek RTL8192EU 802.11b/g/n WLAN Adapter type: USB
driver: rtl8xxxu bus ID: 1-4.3:5 chip ID: 0bda:818b serial: <filter>
IF: wlp0s20u4u3 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 19.74 GiB (4.2%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050A7E680
size: 465.76 GiB speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: AF10 scheme: MBR
ID-1: / size: 457.45 GiB used: 19.74 GiB (4.3%) fs: ext4 dev: /dev/sda1
label: N/A uuid: 40aa730e-6d0b-4944-8a0d-79729d3222b5
ID-2: /var/lib/snapd/snap/core18/1754 raw size: 54.9 MiB
size: <root required> used: <root required> fs: squashfs dev: /dev/loop0
label: N/A uuid: N/A
ID-3: /var/lib/snapd/snap/snapd/7264 raw size: 27.1 MiB
size: <root required> used: <root required> fs: squashfs dev: /dev/loop1
Hub: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-3:2 info: Chicony USB2.0 VGA UVC WebCam type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b483
Hub: 1-4:3 info: Genesys Logic Hub ports: 3 rev: 2.0 speed: 480 Mb/s
chip ID: 05e3:0608
Device-2: 1-4.1:4 info: Lite-On Broadcom BCM43142A0 Bluetooth Device
type: <vendor specific> driver: btusb interfaces: 4 rev: 2.0
speed: 12 Mb/s chip ID: 04ca:2006 serial: <filter>
Device-3: 1-4.3:5 info: Realtek RTL8192EU 802.11b/g/n WLAN Adapter
type: Network driver: rtl8xxxu interfaces: 1 rev: 2.1 speed: 480 Mb/s
Hub: 2-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 6280.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 161 Uptime: 11m Init: systemd v: 245 Compilers: gcc: 10.1.0
Shell: bash v: 5.0.17 running in: xfce4-terminal inxi: 3.0.37
Also, sorry because I'm not really good in English and I didn't understand all the things said in that tutorials but I will try.
This is the info of my wireless network adapter:
Thank you!
You will have to follow this:
Still in english, but should be straight forward as is providing all the commands to run.
You may be able to get your internal Broadcom wifi adapter working simply by disabling MAC Address randomization. Looking at your outputs the internal adapter is working. Search the terms "disable MAC Address randomization" on the forum for directions.
thank you very much! this worked! thank you thank you!
