WMware: vmmon in kernel not found
Hello,
I'm trying installing Windows 10 in vmware on Manjaro Plasma. But I'm getting this error:
Could not open /dev/vmmon: No such file or directory.
Please make sure that the kernel module `vmmon' is loaded.
So I google a bit and some say to run the /etc/init.d/vmware start command. But it comes out with "No such files or directiry" error.
Specs:
[storm@universe ~]$ inxi -Fxz
  Host: universe Kernel: 5.7.9-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 10.1.0 Desktop: KDE Plasma 5.19.3 Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME X370-A v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 5222 date: 10/15/2019
  Device-1: hidpp_battery_0 model: Logitech Wireless Solar Keyboard K750
  charge: 100% status: Full
  Device-2: hidpp_battery_1
  model: Logitech Marathon Mouse/Performance Plus M705
  charge: 55% (should be ignored) status: Discharging
  Topology: 8-Core model: AMD Ryzen 7 1700X bits: 64 type: MT MCP
  arch: Zen rev: 1 L2 cache: 4096 KiB
  bogomips: 108628
  Speed: 2947 MHz min/max: 2200/3400 MHz Core speeds (MHz): 1: 2913
  2: 2806 3: 2813 4: 2970 5: 2811 6: 2803 7: 3484 8: 2809 9: 2805 10: 2798
  11: 2797 12: 2806 13: 3409 14: 2805 15: 3004 16: 2954
  Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia
  v: 440.100 bus ID: 09:00.0
  Display: x11 server: X.Org 1.20.8 driver: nvidia
  resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
  direct render: Yes
  Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus ID: 09:00.1
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 0b:00.3
  Sound Server: ALSA v: k5.7.9-1-MANJARO
  Device-1: Qualcomm Atheros AR9227 Wireless Network Adapter driver: ath9k
  v: kernel bus ID: 06:01.0
  IF: wlp6s1 state: up mac: <filter>
  vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 07:00.0
  IF: enp7s0 state: down mac: <filter>
  Local Storage: total: 1.14 TiB used: 28.71 GiB (2.5%)
  ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
  ID-2: /dev/sdb vendor: Toshiba model: DT01ACA100 size: 931.51 GiB
  ID-1: / size: 227.77 GiB used: 11.57 GiB (5.1%) fs: ext4 dev: /dev/sda5
  ID-2: /home size: 915.89 GiB used: 17.14 GiB (1.9%) fs: ext4
  dev: /dev/sdb1
  System Temperatures: cpu: 48.8 C mobo: N/A gpu: nvidia temp: 50 C
  Processes: 339 Uptime: 4h 34m Memory: 31.30 GiB used: 4.47 GiB (14.3%)
  Init: systemd Compilers: gcc: 10.1.0 Shell: bash v: 5.0.18 inxi: 3.0.37
[storm@universe ~]$
Regards
Storm
Did you follow the wiki?
https://wiki.manjaro.org/index.php?title=VMware#Installing_VMWare_Workstation_on_Manjaro
This command won't work on a systemd based distro like arch/Manjaro.
Services are managed by systemctl.
I dropped the idea, when I saw the price-tag on vmware and went with oracle virtual box instead.
This topic was automatically closed after 180 days. New replies are no longer allowed.
